path: root/MAINTAINERS
2019-04-20platform/x86: Add Intel AtomISP2 dummy / power-management driverHans de Goede
[ Upstream commit 49ad712afa88c502831d37f7089d98eac441fb80 ] The Image Signal Processor found on Cherry Trail devices is brought up in D0 state on devices which have camera sensors attached to it. The ISP will not enter D3 state again without some massaging of its registers beforehand and the ISP not being in D3 state blocks the SoC from entering S0ix modes. There was a driver for the ISP in drivers/staging but that got removed again because it never worked. It does not seem likely that a real driver for the ISP will be added to the mainline kernel anytime soon. This commit adds a dummy driver which contains the necessary magic from the staging driver to powerdown the ISP, so that Cherry Trail devices where the ISP is used will properly use S0ix modes when suspended. Together with other recent S0ix related fixes this allows S0ix modes to be entered on e.g. a Chuwi Hi8 Pro and a HP x2 210. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=196915 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-01MAINTAINERS: Add Sasha as a stable branch maintainerGreg Kroah-Hartman
commit cb5d21946d2a2f4687c482ab4604af1d29dac35a upstream. Sasha has somehow been convinced into helping me with the stable kernel maintenance. Codify this slip in good judgement before he realizes what he really signed up for :) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-22MAINTAINERS: Add an entry for the code of conductGreg Kroah-Hartman
As I introduced these files, I'm willing to be the maintainer of them as well. Acked-by: Chris Mason <clm@fb.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Acked-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-21Merge branch 'i2c/for-current' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Wolfram writes: "i2c for 4.19 Another driver bugfix and MAINTAINERS addition from I2C." * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: rcar: cleanup DMA for all kinds of failure MAINTAINERS: Add entry for Broadcom STB I2C controller
2018-10-20MAINTAINERS: Add entry for Broadcom STB I2C controllerKamal Dasu
Add an entry for the Broadcom STB I2C controller in the MAINTAINERS file. Signed-off-by: Kamal Dasu <kdasu.kdev@gmail.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> [wsa: fixed sorting and a whitespace error] Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2018-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netGreg Kroah-Hartman
David writes: "Networking 1) Fix gro_cells leak in xfrm layer, from Li RongQing. 2) BPF selftests change RLIMIT_MEMLOCK blindly, don't do that. From Eric Dumazet. 3) AF_XDP calls synchronize_net() under RCU lock, fix from Björn Töpel. 4) Out of bounds packet access in _decode_session6(), from Alexei Starovoitov. 5) Several ethtool bugs, where we copy a struct into the kernel twice and our validations of the values in the first copy can be invalidated by the second copy due to asynchronous updates to the memory by the user. From Wenwen Wang. 6) Missing netlink attribute validation in cls_api, from Davide Caratti. 7) LLC SAP sockets neet to be SOCK_RCU FREE, from Cong Wang. 8) rxrpc operates on wrong kvec, from Yue Haibing. 9) A regression was introduced by the disassosciation of route neighbour references in rt6_probe(), causing probe for neighbourless routes to not be properly rate limited. Fix from Sabrina Dubroca. 10) Unsafe RCU locking in tipc, from Tung Nguyen. 11) Use after free in inet6_mc_check(), from Eric Dumazet. 12) PMTU from icmp packets should update the SCTP transport pathmtu, from Xin Long. 13) Missing peer put on error in rxrpc, from David Howells. 14) Fix pedit in nfp driver, from Pieter Jansen van Vuuren. 15) Fix overflowing shift statement in qla3xxx driver, from Nathan Chancellor. 16) Fix Spectre v1 in ptp code, from Gustavo A. R. Silva. 17) udp6_unicast_rcv_skb() interprets udpv6_queue_rcv_skb() return value in an inverted manner, fix from Paolo Abeni. 18) Fix missed unresolved entries in ipmr dumps, from Nikolay Aleksandrov. 19) Fix NAPI handling under high load, we can completely miss events when NAPI has to loop more than one time in a cycle. From Heiner Kallweit." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (49 commits) ip6_tunnel: Fix encapsulation layout tipc: fix info leak from kernel tipc_event net: socket: fix a missing-check bug net: sched: Fix for duplicate class dump r8169: fix NAPI handling under high load net: ipmr: fix unresolved entry dumps net: mscc: ocelot: Fix comment in ocelot_vlant_wait_for_completion() sctp: fix the data size calculation in sctp_data_size virtio_net: avoid using netif_tx_disable() for serializing tx routine udp6: fix encap return code for resubmitting mlxsw: core: Fix use-after-free when flashing firmware during init sctp: not free the new asoc when sctp_wait_for_connect returns err sctp: fix race on sctp_id2asoc r8169: re-enable MSI-X on RTL8168g net: bpfilter: use get_pid_task instead of pid_task ptp: fix Spectre v1 vulnerability net: qla3xxx: Remove overflowing shift statement geneve, vxlan: Don't set exceptions if skb->len < mtu geneve, vxlan: Don't check skb_dst() twice sctp: get pr_assoc and pr_stream all status with SCTP_PR_SCTP_ALL instead ...
2018-10-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== pull request (net): ipsec 2018-10-18 1) Free the xfrm interface gro_cells when deleting the interface, otherwise we leak it. From Li RongQing. 2) net/core/flow.c does not exist anymore, so remove it from the MAINTAINERS file. 3) Fix a slab-out-of-bounds in _decode_session6. From Alexei Starovoitov. 4) Fix RCU protection when policies inserted into thei bydst lists. From Florian Westphal. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2018-10-16Merge tag 'selinux-pr-20181015' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux Paul writes: "SELinux fixes for v4.19 We've got one SELinux "fix" that I'd like to get into v4.19 if possible. I'm using double quotes on "fix" as this is just an update to the MAINTAINERS file and not a code change. From my perspective, MAINTAINERS updates generally don't warrant inclusion during the -rcX phase, but this is a change to the mailing list location so it seemed prudent to get this in before v4.19 is released" * tag 'selinux-pr-20181015' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux: MAINTAINERS: update the SELinux mailing list location
2018-10-12MAINTAINERS: use the correct location for dt-bindings includes for muxPeter Rosin
Just drop the "linux" part of the path, it was never correct. Reported-by: Joe Perches <joe@perches.com> Fixes: 256ac0375098 ("dt-bindings: document devicetree bindings for mux-controllers and gpio-mux") Signed-off-by: Peter Rosin <peda@axentia.se> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-10Merge tag 'mips_fixes_4.19_2' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux Paul writes: "A few MIPS fixes for 4.19: - Avoid suboptimal placement of our VDSO when using the legacy mmap layout, which can prevent statically linked programs that were able to allocate large amounts of memory using the brk syscall prior to the introduction of our VDSO from functioning correctly. - Fix up CONFIG_CMDLINE handling for platforms which ought to ignore DT arguments but have incorrectly used them & lost other arguments since v3.16. - Fix a path in MAINTAINERS to use valid wildcards. - Fixup a regression from v4.17 in memset() for systems using CPU_DADDI_WORKAROUNDS." * tag 'mips_fixes_4.19_2' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: MIPS: memset: Fix CPU_DADDI_WORKAROUNDS `small_fixup' regression MAINTAINERS: MIPS/LOONGSON2 ARCHITECTURE - Use the normal wildcard style MIPS: Fix CONFIG_CMDLINE handling MIPS: VDSO: Always map near top of user memory
2018-10-10MAINTAINERS: update the SELinux mailing list locationPaul Moore
Signed-off-by: Paul Moore <paul@paul-moore.com>
2018-10-05Merge tag 'pci-v4.19-fixes-3' of ↵Greg Kroah-Hartman
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Bjorn writes: "PCI fixes for v4.19: - Reprogram bridge prefetch registers to fix NVIDIA and Radeon issues after suspend/resume (Daniel Drake) - Fix mvebu I/O mapping creation sequence (Thomas Petazzoni) - Fix minor MAINTAINERS file match issue (Bjorn Helgaas)" * tag 'pci-v4.19-fixes-3' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: mvebu: Fix PCI I/O mapping creation sequence MAINTAINERS: Remove obsolete drivers/pci pattern from ACPI section PCI: Reprogram bridge prefetch registers on resume
2018-10-05Merge branch 'locking-urgent-for-linus' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Ingo writes: "locking fixes: A fix in the ww_mutex self-test that produces a scary splat, plus an updates to the maintained-filed patters in MAINTAINER." * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/ww_mutex: Fix runtime warning in the WW mutex selftest MAINTAINERS: Remove dead path from LOCKING PRIMITIVES entry
2018-10-04MAINTAINERS: Remove net/core/flow.cSteffen Klassert
net/core/flow.c does not exist anymore, so remove it from the IPSEC NETWORKING section of the MAINTAINERS file. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2018-10-03Merge gitolite.kernel.org:/pub/scm/linux/kernel/git/davem/netGreg Kroah-Hartman
David writes: "Networking fixes: 1) Prefix length validation in xfrm layer, from Steffen Klassert. 2) TX status reporting fix in mac80211, from Andrei Otcheretianski. 3) Fix hangs due to TX_DROP in mac80211, from Bob Copeland. 4) Fix DMA error regression in b43, from Larry Finger. 5) Add input validation to xenvif_set_hash_mapping(), from Jan Beulich. 6) SMMU unmapping fix in hns driver, from Yunsheng Lin. 7) Bluetooh crash in unpairing on SMP, from Matias Karhumaa. 8) WoL handling fixes in the phy layer, from Heiner Kallweit. 9) Fix deadlock in bonding, from Mahesh Bandewar. 10) Fill ttl inherit infor in vxlan driver, from Hangbin Liu. 11) Fix TX timeouts during netpoll, from Michael Chan. 12) RXRPC layer fixes from David Howells. 13) Another batch of ndo_poll_controller() removals to deal with excessive resource consumption during load. From Eric Dumazet. 14) Fix a specific TIPC failure secnario, from LUU Duc Canh. 15) Really disable clocks in r8169 during suspend so that low power states can actually be reached. 16) Fix SYN backlog lockdep issue in tcp and dccp, from Eric Dumazet. 17) Fix RCU locking in netpoll SKB send, which shows up in bonding, from Dave Jones. 18) Fix TX stalls in r8169, from Heiner Kallweit. 19) Fix locksup in nfp due to control message storms, from Jakub Kicinski. 20) Various rmnet bug fixes from Subash Abhinov Kasiviswanathan and Sean Tranchetti. 21) Fix use after free in ip_cmsg_recv_dstaddr(), from Eric Dumazet." * gitolite.kernel.org:/pub/scm/linux/kernel/git/davem/net: (122 commits) ixgbe: check return value of napi_complete_done() sctp: fix fall-through annotation r8169: always autoneg on resume ipv4: fix use-after-free in ip_cmsg_recv_dstaddr() net: qualcomm: rmnet: Fix incorrect allocation flag in receive path net: qualcomm: rmnet: Fix incorrect allocation flag in transmit net: qualcomm: rmnet: Skip processing loopback packets net: systemport: Fix wake-up interrupt race during resume rtnl: limit IFLA_NUM_TX_QUEUES and IFLA_NUM_RX_QUEUES to 4096 bonding: fix warning message inet: make sure to grab rcu_read_lock before using ireq->ireq_opt nfp: avoid soft lockups under control message storm declance: Fix continuation with the adapter identification message net: fec: fix rare tx timeout r8169: fix network stalls due to missing bit TXCFG_AUTO_FIFO tun: napi flags belong to tfile tun: initialize napi_mutex unconditionally tun: remove unused parameters bond: take rcu lock in netpoll_send_skb_on_dev rtnetlink: Fail dump if target netnsid is invalid ...
2018-10-02Merge tag 'fbdev-v4.19-rc7' of https://github.com/bzolnier/linuxGreg Kroah-Hartman
Bartlomiej writes: "fbdev fixes for v4.19-rc7: - fix OMAPFB_MEMORY_READ ioctl to not leak kernel memory in omapfb driver (Tomi Valkeinen) - add missing prepare/unprepare clock operations in pxa168fb driver (Lubomir Rintel) - add nobgrt option in efifb driver to disable ACPI BGRT logo restore (Hans de Goede) - fix spelling mistake in fall-through annotation in stifb driver (Gustavo A. R. Silva) - fix URL for uvesafb repository in the documentation (Adam Jackson)" * tag 'fbdev-v4.19-rc7' of https://github.com/bzolnier/linux: video/fbdev/stifb: Fix spelling mistake in fall-through annotation uvesafb: Fix URLs in the documentation efifb: BGRT: Add nobgrt option fbdev/omapfb: fix omapfb_memory_read infoleak pxa168fb: prepare the clock
2018-10-02MAINTAINERS: Remove dead path from LOCKING PRIMITIVES entryWill Deacon
Since 890658b7ab48 ("locking/mutex: Kill arch specific code"), there are no mutex header files under arch/, so we can remove the redundant entry from MAINTAINERS. Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Jason Low <jason.low2@hpe.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20181001142856.GC9716@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-10-01Merge tag 'armsoc-fixes' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Olof writes: "ARM: SoC fixes A handful of fixes that have been coming in the last couple of weeks: - Freescale fixes for on-chip accellerators - A DT fix for stm32 to avoid fallback to non-DMA SPI mode - Fixes for badly specified interrupts on BCM63xx SoCs - Allwinner A64 HDMI was incorrectly specified as fully compatble with R40 - Drive strength fix for SAMA5D2 NAND pins on one board" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: stm32: update SPI6 dmas property on stm32mp157c soc: fsl: qe: Fix copy/paste bug in ucc_get_tdm_sync_shift() soc: fsl: qbman: qman: avoid allocating from non existing gen_pool ARM: dts: BCM63xx: Fix incorrect interrupt specifiers MAINTAINERS: update the Annapurna Labs maintainer email ARM: dts: sun8i: drop A64 HDMI PHY fallback compatible from R40 DT ARM: dts: at91: sama5d2_ptc_ek: fix nand pinctrl
2018-10-01MAINTAINERS: MIPS/LOONGSON2 ARCHITECTURE - Use the normal wildcard styleJoe Perches
Neither git nor get_maintainer understands the curly brace style. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Paul Burton <paul.burton@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/20821/ Cc: Huacai Chen <chenhc@lemote.com> Cc: linux-mips <linux-mips@linux-mips.org> Cc: LKML <linux-kernel@vger.kernel.org>
2018-09-30Merge tag 'auxdisplay-for-greg-v4.19-rc6' of https://github.com/ojeda/linuxGreg Kroah-Hartman
Miguel writes: "A trivial fix for auxdisplay - MAINTAINERS reference fix for moved file Reported by Joe Perches" * tag 'auxdisplay-for-greg-v4.19-rc6' of https://github.com/ojeda/linux: MAINTAINERS: fix reference to moved drivers/{misc => auxdisplay}/panel.c
2018-09-30MAINTAINERS: fix reference to moved drivers/{misc => auxdisplay}/panel.cMiguel Ojeda
Commit 51c1e9b554c9 ("auxdisplay: Move panel.c to drivers/auxdisplay folder") moved the file, but the MAINTAINERS reference was not updated. Link: https://lore.kernel.org/lkml/20180928220131.31075-1-joe@perches.com/ Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
2018-09-28MAINTAINERS: Remove obsolete drivers/pci pattern from ACPI sectionBjorn Helgaas
Prior to 256a45937093 ("PCI/AER: Squash aerdrv_acpi.c into aerdrv.c"), drivers/pci/pcie/aer/aerdrv_acpi.c contained code to parse the ACPI HEST table. That code now lives in drivers/pci/pcie/aer.c. Remove the "F: drivers/pci/*/*/*acpi*" pattern because it matches nothing. We could add a "F: drivers/pci/pcie/aer.c" pattern to the ACPI APEI section, but that file sees a lot of changes, almost none of which are of interest to the ACPI folks. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2018-09-28Update maintainers for bnx2/bnx2x/qlge/qlcnic drivers.Sudarsana Reddy Kalluru
Signed-off-by: Sudarsana Reddy Kalluru <Sudarsana.Kalluru@cavium.com> Signed-off-by: Ameen Rahman <Ameen.Rahman@cavium.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-09-28MAINTAINERS: change bridge maintainersStephen Hemminger
I haven't been doing reviews only but not active development on bridge code for several years. Roopa and Nikolay have been doing most of the new features and have agreed to take over as new co-maintainers. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com> Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
2018-09-28Merge tag 'pci-v4.19-fixes-2' of ↵Greg Kroah-Hartman
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Bjorn writes: "PCI fixes: - Fix ACPI hotplug issue that causes black screen crash at boot (Mika Westerberg) - Fix DesignWare "scheduling while atomic" issues (Jisheng Zhang) - Add PPC contacts to MAINTAINERS for PCI core error handling (Bjorn Helgaas) - Sort Mobiveil MAINTAINERS entry (Lorenzo Pieralisi)" * tag 'pci-v4.19-fixes-2' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: ACPI / hotplug / PCI: Don't scan for non-hotplug bridges if slot is not bridge PCI: dwc: Fix scheduling while atomic issues MAINTAINERS: Move mobiveil PCI driver entry where it belongs MAINTAINERS: Update PPC contacts for PCI core error handling
2018-09-26uvesafb: Fix URLs in the documentationAdam Jackson
Signed-off-by: Adam Jackson <ajax@redhat.com> Reviewed-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
2018-09-23MAINTAINERS: update the Annapurna Labs maintainer emailAntoine Tenart
Free Electrons became Bootlin. Update my email accordingly. Signed-off-by: Antoine Tenart <antoine.tenart@bootlin.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2018-09-23Merge branch 'x86-urgent-for-linus' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Thomas writes: "A set of fixes for x86: - Resolve the kvmclock regression on AMD systems with memory encryption enabled. The rework of the kvmclock memory allocation during early boot results in encrypted storage, which is not shareable with the hypervisor. Create a new section for this data which is mapped unencrypted and take care that the later allocations for shared kvmclock memory is unencrypted as well. - Fix the build regression in the paravirt code introduced by the recent spectre v2 updates. - Ensure that the initial static page tables cover the fixmap space correctly so early console always works. This worked so far by chance, but recent modifications to the fixmap layout can - depending on kernel configuration - move the relevant entries to a different place which is not covered by the initial static page tables. - Address the regressions and issues which got introduced with the recent extensions to the Intel Recource Director Technology code. - Update maintainer entries to document reality" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Expand static page table for fixmap space MAINTAINERS: Add X86 MM entry x86/intel_rdt: Add Reinette as co-maintainer for RDT MAINTAINERS: Add Borislav to the x86 maintainers x86/paravirt: Fix some warning messages x86/intel_rdt: Fix incorrect loop end condition x86/intel_rdt: Fix exclusive mode handling of MBA resource x86/intel_rdt: Fix incorrect loop end condition x86/intel_rdt: Do not allow pseudo-locking of MBA resource x86/intel_rdt: Fix unchecked MSR access x86/intel_rdt: Fix invalid mode warning when multiple resources are managed x86/intel_rdt: Global closid helper to support future fixes x86/intel_rdt: Fix size reporting of MBA resource x86/intel_rdt: Fix data type in parsing callbacks x86/kvm: Use __bss_decrypted attribute in shared variables x86/mm: Add .bss..decrypted section to hold shared variables
2018-09-20MAINTAINERS: Move mobiveil PCI driver entry where it belongsLorenzo Pieralisi
Commit 92f9ccca4c08 ("PCI: mobiveil: Add Mobiveil PCIe Host Bridge IP driver DT bindings") managed to add a MAINTAINERS entry where it does not really belong (ie in the middle of a totally unrelated series of entries and in the wrong alphabetical order). Fix it. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Subrahmanya Lingappa <l.subrahmanya@mobiveil.co.in>
2018-09-20MAINTAINERS: Add X86 MM entryThomas Gleixner
Dave, Andy and Peter are de facto overseing the mm parts of X86. Add an explicit maintainers entry. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Andy Lutomirski <luto@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@kernel.org>
2018-09-20x86/intel_rdt: Add Reinette as co-maintainer for RDTFenghua Yu
Reinette Chatre is doing great job on enabling pseudo-locking and other features in RDT. Add her as co-maintainer for RDT. Suggested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Reinette Chatre <reinette.chatre@intel.com> Cc: "H Peter Anvin" <hpa@zytor.com> Cc: "Tony Luck" <tony.luck@intel.com> Link: https://lkml.kernel.org/r/1537472228-221799-1-git-send-email-fenghua.yu@intel.com
2018-09-20Merge tag 'sound-4.19-rc5' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Takashi writes: "sound fixes for 4.19-rc5 here comes a collection of various fixes, mostly for stable-tree or regression fixes. Two relatively high LOCs are about the (rather simple) conversion of uapi integer types in topology API, and a regression fix about HDMI hotplug notification on AMD HD-audio. The rest are all small individual fixes like ASoC Intel Skylake race condition, minor uninitialized page leak in emu10k1 ioctl, Firewire audio error paths, and so on." * tag 'sound-4.19-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (33 commits) ALSA: fireworks: fix memory leak of response buffer at error path ALSA: oxfw: fix memory leak of discovered stream formats at error path ALSA: oxfw: fix memory leak for model-dependent data at error path ALSA: bebob: fix memory leak for M-Audio FW1814 and ProjectMix I/O at error path ALSA: hda - Enable runtime PM only for discrete GPU ALSA: oxfw: fix memory leak of private data ALSA: firewire-tascam: fix memory leak of private data ALSA: firewire-digi00x: fix memory leak of private data sound: don't call skl_init_chip() to reset intel skl soc sound: enable interrupt after dma buffer initialization Revert "ASoC: Intel: Skylake: Acquire irq after RIRB allocation" ALSA: emu10k1: fix possible info leak to userspace on SNDRV_EMU10K1_IOCTL_INFO ASoC: cs4265: fix MMTLR Data switch control ASoC: AMD: Ensure reset bit is cleared before configuring ALSA: fireface: fix memory leak in ff400_switch_fetching_mode() ALSA: bebob: use address returned by kmalloc() instead of kernel stack for streaming DMA mapping ASoC: rsnd: don't fallback to PIO mode when -EPROBE_DEFER ASoC: rsnd: adg: care clock-frequency size ASoC: uniphier: change status to orphan ASoC: rsnd: fixup not to call clk_get/set under non-atomic ...
2018-09-19MAINTAINERS: Add Borislav to the x86 maintainersThomas Gleixner
Borislav is effectivly maintaining parts of X86 already, make it official. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Borislav Petkov <bp@alien8.de>
2018-09-18MAINTAINERS: Update PPC contacts for PCI core error handlingBjorn Helgaas
The original PCI error recovery functionality was for the powerpc-specific IBM EEH feature. PCIe subsequently added some similar features, including AER and DPC, that can be used on any architecture. We want the generic PCI core error handling support to work with all of these features. Driver error recovery callbacks should be independent of which feature the platform provides. Add the generic PCI core error recovery files to the powerpc EEH MAINTAINERS entry so the powerpc folks will be copied on changes to the generic PCI error handling strategy. Add Sam and Oliver as maintainers for this area. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Russell Currey <ruscur@russell.cc> Acked-by: Sam Bobroff <sbobroff@linux.ibm.com>
2018-09-17Merge tag 'asoc-v4.19-rc4' of ↵Takashi Iwai
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v4.19 This is the usual set of small fixes scatterd around various drivers, plus one fix for DAPM and a UAPI build fix. There's not a huge amount that stands out here relative to anything else.
2018-09-15Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Misc fixes: liblockdep fixes and ww_mutex fixes" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/ww_mutex: Fix spelling mistake "cylic" -> "cyclic" locking/lockdep: Delete unnecessary #include tools/lib/lockdep: Add dummy task_struct state member tools/lib/lockdep: Add empty nmi.h tools/lib/lockdep: Update Sasha Levin email to MSFT jump_label: Fix typo in warning message locking/mutex: Fix mutex debug call and ww_mutex documentation
2018-09-14Merge tag 'staging-4.19-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging/IIO driver fixes from Greg KH: "Here are a few small staging and iio driver fixes for -rc4. Nothing major, just a few small bugfixes for some reported issues, and a MAINTAINERS file update for the fbtft drivers. We also re-enable the building of the erofs filesystem as the XArray patches that were causing it to break never got merged in the -rc1 cycle, so there's no reason it can't be turned back on for now. The problem that was previously there is now being handled in the Xarray tree at the moment, so it will not hit us again in the future. All of these patches have been in linux-next with no reported issues" * tag 'staging-4.19-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: vboxvideo: Change address of scanout buffer on page-flip staging: vboxvideo: Fix IRQs no longer working staging: gasket: TODO: re-implement using UIO staging/fbtft: Update TODO and mailing lists staging: erofs: rename superblock flags (MS_xyz -> SB_xyz) iio: imu: st_lsm6dsx: take into account ts samples in wm configuration Revert "iio: temperature: maxim_thermocouple: add MAX31856 part" Revert "staging: erofs: disable compiling temporarile" MAINTAINERS: Switch a maintainer for drivers/staging/gasket staging: wilc1000: revert "fix TODO to compile spi and sdio components in single module"
2018-09-13MAINTAINERS: Make Dennis the percpu tree maintainerTejun Heo
Dennis rewrote a significant portion of the percpu allocator and has shown that he can respond in a timely and helpful manner when issues are reported against percpu allocator. Let's make Dennis the percpu tree maintainer. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Dennis Zhou <dennis@kernel.org> Cc: Christoph Lameter <cl@linux.com>
2018-09-12Merge tag 'pci-v4.19-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: - Add Tyrel Datwyler as maintainer for PPC64 RPA hotplug (Tyrel Datwyler) - Add Gustavo Pimentel as DesignWare PCI maintainer (Joao Pinto) - Fix a Switchtec Spectre v1 vulnerability (Gustavo A. R. Silva) - Revert an unnecessary Intel 300 ACS quirk (Mika Westerberg) - Fix pciehp hot-add/powerfault detection that left indicators in wrong state (Keith Busch) - Fix pci_reset_bus() logic error (Dennis Dalessandro) - Revert IB/hfi1 PCI reset change that caused a deadlock (Dennis Dalessandro) - Allow enabling PASID on Root Complex Integrated Endpoints (Felix Kuehling) * tag 'pci-v4.19-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Fix enabling of PASID on RC integrated endpoints IB/hfi1,PCI: Allow bus reset while probing PCI: Fix faulty logic in pci_reset_bus() PCI: pciehp: Fix hot-add vs powerfault detection order switchtec: Fix Spectre v1 vulnerability Revert "PCI: Add ACS quirk for Intel 300 series" MAINTAINERS: Add Gustavo Pimentel as DesignWare PCI maintainer MAINTAINERS: Add entries for PPC64 RPA PCI hotplug drivers
2018-09-11MAINTAINERS: Add Gustavo Pimentel as DesignWare PCI maintainerJoao Pinto
Currently I am managing the Synopsys drivers & tools team (full-time) and so I am passing the pcie-designware maintenance to Gustavo. Signed-off-by: Joao Pinto <jpinto@synopsys.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Gustavo Pimentel <gustavo.pimentel@synopsys.com> CC: Jingoo Han <jingoohan1@gmail.com>
2018-09-11MAINTAINERS: Add entries for PPC64 RPA PCI hotplug driversTyrel Datwyler
Add myself as maintainer of the IBM RPA hotplug modules in the drivers/pci/hotplug directory. These modules provide kernel interfaces for support of Dynamic Logical Partitioning (DLPAR) of Logical and Physical IO slots, and hotplug of physical PCI slots of a PHB on RPA-compliant ppc64 platforms (pseries). Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2018-09-10tools/lib/lockdep: Update Sasha Levin email to MSFTSasha Levin
Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <Alexander.Levin@microsoft.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20180813190527.16853-2-alexander.levin@microsoft.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-09-10staging/fbtft: Update TODO and mailing listsDaniel Vetter
Motivated by the ksummit-discuss discussion. Cc: Shuah Khan <shuahkhan@gmail.com> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Cc: linux-fbdev@vger.kernel.org Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-07i2c: xiic: Record xilinx i2c with Zynq fragmentMichal Simek
Include xilinx soft i2c controller to Zynq fragment to make clear who is responsible for it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2018-09-05ASoC: uniphier: change status to orphanKatsuhiro Suzuki
Since I'm leaving from Socionext, I'll unable to access specification documents of this hardware (these are not public). So change the state to orphan until someone will maintain this driver. Signed-off-by: Katsuhiro Suzuki <suzuki.katsuhiro@socionext.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-27MAINTAINERS: Switch a maintainer for drivers/staging/gasketTodd Poynor
Todd Poynor takes over for John Joseph. Signed-off-by: John Joseph <jnjoseph@google.com> Signed-off-by: Todd Poynor <toddpoynor@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-27Fix up libata MAINTAINERS entryJens Axboe
The email was botched in one entry, and I also forgot to update the location of the git tree. It'll be under the linux-block umbrella, just with different branches. Reported-by: Baruch Siach <baruch@tkos.co.il> Fixes: 7634ccd2da97 ("libata: maintainership update") Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-25Merge tag 'libnvdimm-for-4.19_misc' of ↵Linus Torvalds
gitolite.kernel.org:pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dave Jiang: "Collection of misc libnvdimm patches for 4.19 submission: - Adding support to read locked nvdimm capacity. - Change test code to make DSM failure code injection an override. - Add support for calculate maximum contiguous area for namespace. - Add support for queueing a short ARS when there is on going ARS for nvdimm. - Allow NULL to be passed in to ->direct_access() for kaddr and pfn params. - Improve smart injection support for nvdimm emulation testing. - Fix test code that supports for emulating controller temperature. - Fix hang on error before devm_memremap_pages() - Fix a bug that causes user memory corruption when data returned to user for ars_status. - Maintainer updates for Ross Zwisler emails and adding Jan Kara to fsdax" * tag 'libnvdimm-for-4.19_misc' of gitolite.kernel.org:pub/scm/linux/kernel/git/nvdimm/nvdimm: libnvdimm: fix ars_status output length calculation device-dax: avoid hang on error before devm_memremap_pages() tools/testing/nvdimm: improve emulation of smart injection filesystem-dax: Do not request kaddr and pfn when not required md/dm-writecache: Don't request pointer dummy_addr when not required dax/super: Do not request a pointer kaddr when not required tools/testing/nvdimm: kaddr and pfn can be NULL to ->direct_access() s390, dcssblk: kaddr and pfn can be NULL to ->direct_access() libnvdimm, pmem: kaddr and pfn can be NULL to ->direct_access() acpi/nfit: queue issuing of ars when an uc error notification comes in libnvdimm: Export max available extent libnvdimm: Use max contiguous area for namespace size MAINTAINERS: Add Jan Kara for filesystem DAX MAINTAINERS: update Ross Zwisler's email address tools/testing/nvdimm: Fix support for emulating controller temperature tools/testing/nvdimm: Make DSM failure code injection an override acpi, nfit: Prefer _DSM over _LSR for namespace label reads libnvdimm: Introduce locked DIMM capacity support
2018-08-25libata: maintainership updateJens Axboe
Tejun Heo wrote: > > I asked Jens whether he could take care of the libata tree and he > thankfully agreed, so, from now on, Jens will be the libata > maintainer. > > Thanks a lot! Thanks for your work in this area. I still remember the first linux storage summit we did in Vancouver 2001, Tejun was invited to talk about his libata error handling work. Before that, it was basically a crap shoot if we recovered properly or not... A lot of water has flown under the bridge since then! Here's an "official" patch. Linus, can you apply it? Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: - Add Daniel Lezcano as the reviewer of thermal framework and SoC driver changes (Daniel Lezcano). - Fix a bug in intel_dts_soc_thermal driver, which does not translate IO-APIC GSI (Global System Interrupt) into Linux irq number (Hans de Goede). - For device tree bindings, allow cooling devices sharing same trip point with same contribution value to share cooling map (Viresh Kumar). * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: dt-bindings: thermal: Allow multiple devices to share cooling map MAINTAINERS: Add Daniel Lezcano as designated reviewer for thermal Thermal: Intel SoC DTS: Translate IO-APIC GSI number to linux irq number
