path: root/MAINTAINERS
2016-06-14Merge branch 'linus' into locking/core, to pick up fixes before merging new ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-11Merge tag 'devicetree-fixes-for-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree fixes from Rob Herring: - fix unflatten_dt_nodes when dad parameter is set. - add vendor prefixes for TechNexion and UniWest - documentation fix for Marvell BT - OF IRQ kerneldoc fixes - restrict CMA alignment adjustments to non dma-coherent - a couple of warning fixes in reserved-memory code - DT maintainers updates * tag 'devicetree-fixes-for-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: drivers: of: add definition of early_init_dt_alloc_reserved_memory_arch drivers/of: Fix depth for sub-tree blob in unflatten_dt_nodes() drivers: of: Fix of_pci.h header guard dt-bindings: Add vendor prefix for TechNexion of: add vendor prefix for UniWest dt: bindings: fix documentation for MARVELL's bt-sd8xxx wireless device of: add missing const for of_parse_phandle_with_args() in !CONFIG_OF of: silence warnings due to max() usage drivers: of: of_reserved_mem: fixup the CMA alignment not to affect dma-coherent of: irq: fix of_irq_get[_byname]() kernel-doc MAINTAINERS: DeviceTree maintainer updates
2016-06-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) nfnetlink timestamp taken from wrong skb, fix from Florian Westphal. 2) Revert some msleep conversions in rtlwifi as these spots are in atomic context, from Larry Finger. 3) Validate that NFTA_SET_TABLE attribute is actually specified when we call nf_tables_getset(). From Phil Turnbull. 4) Don't do mdio_reset in stmmac driver with spinlock held as that can sleep, from Vincent Palatin. 5) sk_filter() does things other than run a BPF filter, so we should not elide it's call just because sk->sk_filter is NULL. Fix from Eric Dumazet. 6) Fix missing backlog updates in several packet schedulers, from Cong Wang. 7) bnx2x driver should allow VLAN add/remove while the interface is down, from Michal Schmidt. 8) Several RDS/TCP race fixes from Sowmini Varadhan. 9) fq_codel scheduler doesn't return correct queue length in dumps, from Eric Dumazet. 10) Fix TCP stats for tail loss probe and early retransmit in ipv6, from Yuchung Cheng. 11) Properly initialize udp_tunnel_socket_cfg in l2tp_tunnel_create(), from Guillaume Nault. 12) qfq scheduler leaks SKBs if a kzalloc fails, fix from Florian Westphal. 13) sock_fprog passed into PACKET_FANOUT_DATA needs compat handling, from Willem de Bruijn. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits) vmxnet3: segCnt can be 1 for LRO packets packet: compat support for sock_fprog stmmac: fix parameter to dwmac4_set_umac_addr() net/mlx5e: Fix blue flame quota logic net/mlx5e: Use ndo_stop explicitly at shutdown flow net/mlx5: E-Switch, always set mc_promisc for allmulti vports net/mlx5: E-Switch, Modify node guid on vf set MAC net/mlx5: E-Switch, Fix vport enable flow net/mlx5: E-Switch, Use the correct error check on returned pointers net/mlx5: E-Switch, Use the correct free() function net/mlx5: Fix E-Switch flow steering capabilities check net/mlx5: Fix flow steering NIC capabilities check net/mlx5: Fix root flow table update net/mlx5: Fix MLX5_CMD_OP_MAX to be defined correctly net/mlx5: Fix masking of reserved bits in XRCD number net/mlx5: Fix the size of modify QP mailbox mlxsw: spectrum: Don't sleep during ndo_get_phys_port_name() mlxsw: spectrum: Make split flow match firmware requirements wext: Fix 32 bit iwpriv compatibility issue with 64 bit Kernel cfg80211: remove get/set antenna and tx power warnings ...
2016-06-09MAINTAINERS: Update locking tree description and file patternsIngo Molnar
Update the file patterns, the Git tree URI and also widen the scope from 'LOCKDEP and LOCKSTAT' to 'LOCKING PRIMITIVES'. Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: linux-kernel@vger.kernel.org
2016-06-07Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clk fixes from Stephen Boyd: "This finally removes the CLK_IS_ROOT flag by picking up the last few stragglers that didn't get merged by anyone this time around. Better to do it now than wait for another one to pop up. There's also a minor maintainers update and a Kconfig fix" * tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: clk: nxp: Select MFD_SYSCON for creg driver MAINTAINERS: Add file patterns for clock device tree bindings clk: Remove CLK_IS_ROOT flag clk: microchip: Remove CLK_IS_ROOT powerpc/512x: clk: Remove CLK_IS_ROOT vexpress/spc: Remove CLK_IS_ROOT
2016-06-04Merge tag 'wireless-drivers-for-davem-2016-06-04' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers Kalle Valo says: ==================== wireless-drivers fixes for 4.7 brcmfmac * add fallback RSSI report for devices that do not report per-chain values * fix a null pointer derefence regression on PCIe full dongle devices rtlwifi * fix scheduling while atomic regression from commit 49f86ec21c01 MAINTAINERS * add file patterns for wireless device tree bindings ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-04MAINTAINERS: Add file patterns for wireless device tree bindingsGeert Uytterhoeven
Submitters of device tree binding documentation may forget to CC the subsystem maintainer if this is missing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: linux-wireless@vger.kernel.org Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2016-06-02MAINTAINERS: DeviceTree maintainer updatesRob Herring
Grant stepped down as kernel DT maintainer and his linaro.org email will be bouncing soon, so remove him now. Pawel, Ian and Kumar either said they don't want to remain maintainers or didn't reply, so removing them as binding maintainers. Update the DT git tree to mine. Grant's has not been active for a while now. I'm actively using patchwork for binding review tracking, so add its URL. Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Frank Rowand <frowand.list@gmail.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-01MAINTAINERS: Add file patterns for clock device tree bindingsGeert Uytterhoeven
Submitters of device tree binding documentation may forget to CC the subsystem maintainer if this is missing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Turquette <mturquette@baylibre.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: linux-clk@vger.kernel.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2016-06-01Merge tag 'pinctrl-v4.7-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control fixes from Linus Walleij: "Here are three pin control fixes for v4.7. Not much, and just driver fixes: - add device tree matches to MAINTAINERS - inversion bug in the Nomadik driver - dual edge handling bug in the mediatek driver" * tag 'pinctrl-v4.7-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: mediatek: fix dual-edge code defect MAINTAINERS: Add file patterns for pinctrl device tree bindings pinctrl: nomadik: fix inversion of gpio direction
2016-05-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix negative error code usage in ATM layer, from Stefan Hajnoczi. 2) If CONFIG_SYSCTL is disabled, the default TTL is not initialized properly. From Ezequiel Garcia. 3) Missing spinlock init in mvneta driver, from Gregory CLEMENT. 4) Missing unlocks in hwmb error paths, also from Gregory CLEMENT. 5) Fix deadlock on team->lock when propagating features, from Ivan Vecera. 6) Work around buffer offset hw bug in alx chips, from Feng Tang. 7) Fix double listing of SCTP entries in sctp_diag dumps, from Xin Long. 8) Various statistics bug fixes in mlx4 from Eric Dumazet. 9) Fix some randconfig build errors wrt fou ipv6 from Arnd Bergmann. 10) All of l2tp was namespace aware, but the ipv6 support code was not doing so. From Shmulik Ladkani. 11) Handle on-stack hrtimers properly in pktgen, from Guenter Roeck. 12) Propagate MAC changes properly through VLAN devices, from Mike Manning. 13) Fix memory leak in bnx2x_init_one(), from Vitaly Kuznetsov. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits) sfc: Track RPS flow IDs per channel instead of per function usbnet: smsc95xx: fix link detection for disabled autonegotiation virtio_net: fix virtnet_open and virtnet_probe competing for try_fill_recv bnx2x: avoid leaking memory on bnx2x_init_one() failures fou: fix IPv6 Kconfig options openvswitch: update checksum in {push,pop}_mpls sctp: sctp_diag should dump sctp socket type net: fec: update dirty_tx even if no skb vlan: Propagate MAC address to VLANs atm: iphase: off by one in rx_pkt() atm: firestream: add more reserved strings vxlan: Accept user specified MTU value when create new vxlan link net: pktgen: Call destroy_hrtimer_on_stack() timer: Export destroy_hrtimer_on_stack() net: l2tp: Make l2tp_ip6 namespace aware Documentation: ip-sysctl.txt: clarify secure_redirects sfc: use flow dissector helpers for aRFS ieee802154: fix logic error in ieee802154_llsec_parse_dev_addr net: nps_enet: Disable interrupts before napi reschedule net/lapb: tuse %*ph to dump buffers ...
2016-05-30MAINTAINERS: Add file patterns for pinctrl device tree bindingsGeert Uytterhoeven
Submitters of device tree binding documentation may forget to CC the subsystem maintainer if this is missing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: linux-gpio@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-28Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull more MIPS updates from Ralf Baechle: "This is the secondnd batch of MIPS patches for 4.7. Summary: CPS: - Copy EVA configuration when starting secondary VPs. EIC: - Clear Status IPL. Lasat: - Fix a few off by one bugs. lib: - Mark intrinsics notrace. Not only are the intrinsics uninteresting, it would cause infinite recursion. MAINTAINERS: - Add file patterns for MIPS BRCM device tree bindings. - Add file patterns for mips device tree bindings. MT7628: - Fix MT7628 pinmux typos. - wled_an pinmux gpio. - EPHY LEDs pinmux support. Pistachio: - Enable KASLR VDSO: - Build microMIPS VDSO for microMIPS kernels. - Fix aliasing warning by building with `-fno-strict-aliasing' for debugging but also tracing them might result in recursion. Misc: - Add missing FROZEN hotplug notifier transitions. - Fix clk binding example for varioius PIC32 devices. - Fix cpu interrupt controller node-names in the DT files. - Fix XPA CPU feature separation. - Fix write_gc0_* macros when writing zero. - Add inline asm encoding helpers. - Add missing VZ accessor microMIPS encodings. - Fix little endian microMIPS MSA encodings. - Add 64-bit HTW fields and fix its configuration. - Fix sigreturn via VDSO on microMIPS kernel. - Lots of typo fixes. - Add definitions of SegCtl registers and use them" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (49 commits) MIPS: Add missing FROZEN hotplug notifier transitions MIPS: Build microMIPS VDSO for microMIPS kernels MIPS: Fix sigreturn via VDSO on microMIPS kernel MIPS: devicetree: fix cpu interrupt controller node-names MIPS: VDSO: Build with `-fno-strict-aliasing' MIPS: Pistachio: Enable KASLR MIPS: lib: Mark intrinsics notrace MIPS: Fix 64-bit HTW configuration MIPS: Add 64-bit HTW fields MAINTAINERS: Add file patterns for mips device tree bindings MAINTAINERS: Add file patterns for mips brcm device tree bindings MIPS: Simplify DSP instruction encoding macros MIPS: Add missing tlbinvf/XPA microMIPS encodings MIPS: Fix little endian microMIPS MSA encodings MIPS: Add missing VZ accessor microMIPS encodings MIPS: Add inline asm encoding helpers MIPS: Spelling fix lets -> let's MIPS: VR41xx: Fix typo MIPS: oprofile: Fix typo MIPS: math-emu: Fix typo ...
2016-05-28Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull more rdma updates from Doug Ledford: "This is the second group of code for the 4.7 merge window. It looks large, but only in one sense. I'll get to that in a minute. The list of changes here breaks down as follows: - Dynamic counter infrastructure in the IB drivers This is a sysfs based code to allow free form access to the hardware counters RDMA devices might support so drivers don't need to code this up repeatedly themselves - SendOnlyFullMember multicast support - IB router support - A couple misc fixes - The big item on the list: hfi1 driver updates, plus moving the hfi1 driver out of staging There was a group of 15 patches in the hfi1 list that I thought I had in the first pull request but they weren't. So that added to the length of the hfi1 section here. As far as these go, everything but the hfi1 is pretty straight forward. The hfi1 is, if you recall, the driver that Al had complaints about how it used the write/writev interfaces in an overloaded fashion. The write portion of their interface behaved like the write handler in the IB stack proper and did bi-directional communications. The writev interface, on the other hand, only accepts SDMA request structures. The completions for those structures are sent back via an entirely different event mechanism. With the security patch, we put security checks on the write interface, however, we also knew they would be going away soon. Now, we've converted the write handler in the hfi1 driver to use ioctls from the IB reserved magic area for its bidirectional communications. With that change, Intel has addressed all of the items originally on their TODO when they went into staging (as well as many items added to the list later). As such, I moved them out, and since they were the last item in the staging/rdma directory, and I don't have immediate plans to use the staging area again, I removed the staging/rdma area. Because of the move out of staging, as well as a series of 5 patches in the hfi1 driver that removed code people thought should be done in a different way and was optional to begin with (a snoop debug interface, an eeprom driver for an eeprom connected directory to their hfi1 chip and not via an i2c bus, and a few other things like that), the line count, especially the removal count, is high" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (56 commits) staging/rdma: Remove the entire rdma subdirectory of staging IB/core: Make device counter infrastructure dynamic IB/hfi1: Fix pio map initialization IB/hfi1: Correct 8051 link parameter settings IB/hfi1: Update pkey table properly after link down or FM start IB/rdamvt: Fix rdmavt s_ack_queue sizing IB/rdmavt: Max atomic value should be a u8 IB/hfi1: Fix hard lockup due to not using save/restore spin lock IB/hfi1: Add tracing support for send with invalidate opcode IB/hfi1, qib: Add ieth to the packet header definitions IB/hfi1: Move driver out of staging IB/hfi1: Do not free hfi1 cdev parent structure early IB/hfi1: Add trace message in user IOCTL handling IB/hfi1: Remove write(), use ioctl() for user cmds IB/hfi1: Add ioctl() interface for user commands IB/hfi1: Remove unused user command IB/hfi1: Remove snoop/diag interface IB/hfi1: Remove EPROM functionality from data device IB/hfi1: Remove UI char device IB/hfi1: Remove multiple device cdev ...
2016-05-28MAINTAINERS: Add file patterns for mips device tree bindingsGeert Uytterhoeven
Submitters of device tree binding documentation may forget to CC the subsystem maintainer if this is missing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-mips@linux-mips.org Cc: devicetree@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/13340/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-05-28MAINTAINERS: Add file patterns for mips brcm device tree bindingsGeert Uytterhoeven
Submitters of device tree binding documentation may forget to CC the subsystem maintainer if this is missing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Hauke Mehrtens <hauke@hauke-m.de> Cc: Rafał Miłecki <zajec5@gmail.com> Cc: linux-mips@linux-mips.org Cc: devicetree@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/13339/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2016-05-27Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc updates and fixes from Andrew Morton: - late-breaking ocfs2 updates - random bunch of fixes * emailed patches from Andrew Morton <akpm@linux-foundation.org>: mm: disable DEFERRED_STRUCT_PAGE_INIT on !NO_BOOTMEM mm/memcontrol.c: move comments for get_mctgt_type() to proper position mm/memcontrol.c: fix the margin computation in mem_cgroup_margin() mm/cma: silence warnings due to max() usage mm: thp: avoid false positive VM_BUG_ON_PAGE in page_move_anon_rmap() oom_reaper: close race with exiting task mm: use early_pfn_to_nid in register_page_bootmem_info_node mm: use early_pfn_to_nid in page_ext_init MAINTAINERS: Kdump maintainers update MAINTAINERS: add kexec_core.c and kexec_file.c mm: oom: do not reap task if there are live threads in threadgroup direct-io: fix direct write stale data exposure from concurrent buffered read ocfs2: bump up o2cb network protocol version ocfs2: o2hb: fix hb hung time ocfs2: o2hb: don't negotiate if last hb fail ocfs2: o2hb: add some user/debug log ocfs2: o2hb: add NEGOTIATE_APPROVE message ocfs2: o2hb: add NEGO_TIMEOUT message ocfs2: o2hb: add negotiate timer
2016-05-27MAINTAINERS: Kdump maintainers updateVivek Goyal
I am proposing following updates to kdump maintainership. I have got busy in other things and not getting time to spend on kdump. Remove Haren Myneni as he has not participated in kdump development for a long time now. Add the names of Dave and Baoquan as kdump maintainers as they have been contributing to kdump for a long time now and they are in a much better position to spend time on this than me. Mark myself as a reviewer. Link: http://lkml.kernel.org/r/20160525131616.GB27291@redhat.com Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Simon Horman <horms@verge.net.au> Cc: Haren Myneni <hbabu@us.ibm.com> Cc: Dave Young <dyoung@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-27MAINTAINERS: add kexec_core.c and kexec_file.cMinfei Huang
In the below commits kexec.c was split to kexec.c, kexec_file.c and kexec_core.c. commit a43cac0d9dc2 ("kexec: split kexec_file syscall code to kexec_file.c") commit 2965faa5e03d ("kexec: split kexec_load syscall from kexec core code") Both kexec_file.c and kexec_core.c still belong to the kexec component. In order to get correct mail lists by using the script get_maintainer.pl, add these files to MAINTAINERS. Link: http://lkml.kernel.org/r/1464189735-59113-1-git-send-email-mnghuan@gmail.com Signed-off-by: Minfei Huang <mnghuan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-27Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A set of fixes that wasn't included in the first merge window pull request. This pull request contains: - A set of NVMe fixes from Keith, and one from Nic for the integrity side of it. - Fix from Ming, clearing ->mq_ops if we don't successfully setup a queue for multiqueue. - A set of stability fixes for bcache from Jiri, and also marking bcache as orphaned as it's no longer actively maintained (in mainline, at least)" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: clear q->mq_ops if init fail MAINTAINERS: mark bcache as orphan bcache: bch_gc_thread() is not freezable bcache: bch_allocator_thread() is not freezable bcache: bch_writeback_thread() is not freezable nvme/host: Add missing blk_integrity tag_size + flags assignments NVMe: Add device ID's with stripe quirk NVMe: Short-cut removal on surprise hot-unplug NVMe: Allow user initiated rescan NVMe: Reduce driver log spamming NVMe: Unbind driver on failure NVMe: Delete only created queues NVMe: Allocate queues only for online cpus
2016-05-27Merge tag 'platform-drivers-x86-v4.7-1' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver updates from Darren Hart: "Mostly minor updates and cleanups. One new power management controller driver for Intel Core SoCs. platform/x86: - Add PMC Driver for Intel Core SoC dell-rbtn: - Ignore ACPI notifications if device is suspended thinkpad_acpi: - save kbdlight state on suspend and restore it on resume intel_menlow: - reduce code duplication asus-wmi: - provide access to ALS control ideapad-laptop: - add a new WMI string for ESC key surfacepro3_button: - Add a warning when switching to tablet mode sony-laptop: - Avoid oops on module unload for older laptops intel_telemetry: - Constify telemetry_core_ops structures fujitsu-laptop: - Use IS_ENABLED() instead of checking for built-in or module asus-laptop: - correct error handling in sysfs_acpi_set - remove redundant initializers - correct error handling in asus_read_brightness() fujitsu-laptop: - Support radio LED" * tag 'platform-drivers-x86-v4.7-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: platform/x86: Add PMC Driver for Intel Core SoC dell-rbtn: Ignore ACPI notifications if device is suspended thinkpad_acpi: save kbdlight state on suspend and restore it on resume intel_menlow: reduce code duplication asus-wmi: provide access to ALS control ideapad-laptop: add a new WMI string for ESC key surfacepro3_button: Add a warning when switching to tablet mode sony-laptop: Avoid oops on module unload for older laptops intel_telemetry: Constify telemetry_core_ops structures fujitsu-laptop: Use IS_ENABLED() instead of checking for built-in or module asus-laptop: correct error handling in sysfs_acpi_set asus-laptop: remove redundant initializers asus-laptop: correct error handling in asus_read_brightness() fujitsu-laptop: Support radio LED
2016-05-27Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull second batch of KVM updates from Radim Krčmář: "General: - move kvm_stat tool from QEMU repo into tools/kvm/kvm_stat (kvm_stat had nothing to do with QEMU in the first place -- the tool only interprets debugfs) - expose per-vm statistics in debugfs and support them in kvm_stat (KVM always collected per-vm statistics, but they were summarised into global statistics) x86: - fix dynamic APICv (VMX was improperly configured and a guest could access host's APIC MSRs, CVE-2016-4440) - minor fixes ARM changes from Christoffer Dall: - new vgic reimplementation of our horribly broken legacy vgic implementation. The two implementations will live side-by-side (with the new being the configured default) for one kernel release and then we'll remove the legacy one. - fix for a non-critical issue with virtual abort injection to guests" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (70 commits) tools: kvm_stat: Add comments tools: kvm_stat: Introduce pid monitoring KVM: Create debugfs dir and stat files for each VM MAINTAINERS: Add kvm tools tools: kvm_stat: Powerpc related fixes tools: Add kvm_stat man page tools: Add kvm_stat vm monitor script kvm:vmx: more complete state update on APICv on/off KVM: SVM: Add more SVM_EXIT_REASONS KVM: Unify traced vector format svm: bitwise vs logical op typo KVM: arm/arm64: vgic-new: Synchronize changes to active state KVM: arm/arm64: vgic-new: enable build KVM: arm/arm64: vgic-new: implement mapped IRQ handling KVM: arm/arm64: vgic-new: Wire up irqfd injection KVM: arm/arm64: vgic-new: Add vgic_v2/v3_enable KVM: arm/arm64: vgic-new: vgic_init: implement map_resources KVM: arm/arm64: vgic-new: vgic_init: implement vgic_init KVM: arm/arm64: vgic-new: vgic_init: implement vgic_create KVM: arm/arm64: vgic-new: vgic_init: implement kvm_vgic_hyp_init ...
2016-05-27platform/x86: Add PMC Driver for Intel Core SoCRajneesh Bhardwaj
This patch adds the Power Management Controller driver as a PCI driver for Intel Core SoC architecture. This driver can utilize debugging capabilities and supported features as exposed by the Power Management Controller. Please refer to the below specification for more details on PMC features. http://www.intel.in/content/www/in/en/chipsets/100-series-chipset-datasheet-vol-2.html The current version of this driver exposes SLP_S0_RESIDENCY counter. This counter can be used for detecting fragile SLP_S0 signal related failures and take corrective actions when PCH SLP_S0 signal is not asserted after kernel freeze as part of suspend to idle flow (echo freeze > /sys/power/state). Intel Platform Controller Hub (PCH) asserts SLP_S0 signal when it detects favorable conditions to enter its low power mode. As a pre-requisite the SoC should be in deepest possible Package C-State and devices should be in low power mode. For example, on Skylake SoC the deepest Package C-State is Package C10 or PC10. Suspend to idle flow generally leads to PC10 state but PC10 state may not be sufficient for realizing the platform wide power potential which SLP_S0 signal assertion can provide. SLP_S0 signal is often connected to the Embedded Controller (EC) and the Power Management IC (PMIC) for other platform power management related optimizations. In general, SLP_S0 assertion == PC10 + PCH low power mode + ModPhy Lanes power gated + PLL Idle. As part of this driver, a mechanism to read the SLP_S0_RESIDENCY is exposed as an API and also debugfs features are added to indicate SLP_S0 signal assertion residency in microseconds. echo freeze > /sys/power/state wake the system cat /sys/kernel/debug/pmc_core/slp_s0_residency_usec Signed-off-by: Rajneesh Bhardwaj <rajneesh.bhardwaj@intel.com> Signed-off-by: Vishwanath Somayaji <vishwanath.somayaji@intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2016-05-26staging/rdma: Remove the entire rdma subdirectory of stagingDoug Ledford
This is no longer in use. Remove it. Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-26Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: - Introduce generic ADC thermal driver, based on OF thermal (Laxman Dewangan) - Introduce new thermal driver for Tango chips (Marc Gonzalez) - Rockchip driver support for RK3399, RK3366, and some fixes (Caesar Wang, Elaine Zhang and Shawn Lin) - Add CPU power cooling model to Mediatek thermal driver (Dawei Chien) - Wider usage of dev_thermal_zone_of_sensor_register (Eduardo Valentin) - TI thermal driver gained a new maintainer (Keerthy). - Enabled powerclamp driver by checking CPU feature and package cstate counter instead of CPU whitelist (Jacob Pan) - Various fixes on thermal governor, OF thermal, Tegra, and RCAR * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (50 commits) thermal: tango: initialize TEMPSI_CFG thermal: rockchip: use the usleep_range instead of udelay thermal: rockchip: add the notes for better reading thermal: rockchip: Support RK3366 SoCs in the thermal driver thermal: rockchip: handle the power sequence for tsadc controller thermal: rockchip: update the tsadc table for rk3399 thermal: rockchip: fixes the code_to_temp for tsadc driver thermal: rockchip: disable thermal->clk in err case thermal: tegra: add Tegra132 specific SOC_THERM driver thermal: fix ptr_ret.cocci warnings thermal: mediatek: Add cpu dynamic power cooling model. thermal: generic-adc: Add ADC based thermal sensor driver thermal: generic-adc: Add DT binding for ADC based thermal sensor thermal: tegra: fix static checker warning thermal: tegra: mark PM functions __maybe_unused thermal: add temperature sensor support for tango SoC thermal: hisilicon: fix IRQ imbalance enabling thermal: hisilicon: support to use any sensor thermal: rcar: Remove binding docs for r8a7794 thermal: tegra: add PM support ...
2016-05-26IB/hfi1: Move driver out of stagingDennis Dalessandro
The TODO list for the hfi1 driver was completed during 4.6. In addition other objections raised (which are far beyond what was in the TODO list) have been addressed as well. It is now time to remove the driver from staging and into the drivers/infiniband sub-tree. Reviewed-by: Jubin John <jubin.john@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-05-25Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Mostly tooling and PMU driver fixes, but also a number of late updates such as the reworking of the call-chain size limiting logic to make call-graph recording more robust, plus tooling side changes for the new 'backwards ring-buffer' extension to the perf ring-buffer" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits) perf record: Read from backward ring buffer perf record: Rename variable to make code clear perf record: Prevent reading invalid data in record__mmap_read perf evlist: Add API to pause/resume perf trace: Use the ptr->name beautifier as default for "filename" args perf trace: Use the fd->name beautifier as default for "fd" args perf report: Add srcline_from/to branch sort keys perf evsel: Record fd into perf_mmap perf evsel: Add overwrite attribute and check write_backward perf tools: Set buildid dir under symfs when --symfs is provided perf trace: Only auto set call-graph to "dwarf" when syscalls are being traced perf annotate: Sort list of recognised instructions perf annotate: Fix identification of ARM blt and bls instructions perf tools: Fix usage of max_stack sysctl perf callchain: Stop validating callchains by the max_stack sysctl perf trace: Fix exit_group() formatting perf top: Use machine->kptr_restrict_warned perf trace: Warn when trying to resolve kernel addresses with kptr_restrict=1 perf machine: Do not bail out if not managing to read ref reloc symbol perf/x86/intel/p4: Trival indentation fix, remove space ...
2016-05-25Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - add support for Fintek F81865 Super-IO chip - add support for watchdogs (RWDT and SWDT) found on RCar Gen3 based SoCs from Renesas - octeon: Handle the FROZEN hot plug notifier actions - f71808e_wdt fixes and cleanups - some small improvements in code and documentation * git://www.linux-watchdog.org/linux-watchdog: MAINTAINERS: Add file patterns for watchdog device tree bindings Documentation: Add ebc-c384_wdt watchdog-parameters.txt entry watchdog: shwdt: Use setup_timer() watchdog: cpwd: Use setup_timer() arm64: defconfig: enable Renesas Watchdog Timer watchdog: renesas-wdt: add driver watchdog: remove error message when unable to allocate watchdog device watchdog: f71808e_wdt: Fix WDTMOUT_STS register read watchdog: f71808e_wdt: Fix typo watchdog: f71808e_wdt: Add F81865 support watchdog: sp5100_tco: properly check for new register layouts watchdog: core: Fix circular locking dependency watchdog: core: fix trivial typo in a comment watchdog: hpwdt: Adjust documentation to match latest kernel module parameters. watchdog: imx2_wdt: add external reset support via dt prop watchdog: octeon: Handle the FROZEN hot plug notifier actions. watchdog: qcom: Report reboot reason
2016-05-25MAINTAINERS: Add kvm toolsJanosch Frank
The new kvm subdirectory in tools contains kvm related scripts. Signed-off-by: Janosch Frank <frankja@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2016-05-24MAINTAINERS: mark bcache as orphanJiri Kosina
The submitted patches are not being reacted upon, and Jens is only picking up stable fixes on an rather ad-hoc basis. Link: lkml.kernel.org/r/574462C5.40307@kernel.dk Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-23Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge yet more updates from Andrew Morton: - Oleg's "wait/ptrace: assume __WALL if the child is traced". It's a kernel-based workaround for existing userspace issues. - A few hotfixes - befs cleanups - nilfs2 updates - sys_wait() changes - kexec updates - kdump - scripts/gdb updates - the last of the MM queue - a few other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (84 commits) kgdb: depends on VT drm/amdgpu: make amdgpu_mn_get wait for mmap_sem killable drm/radeon: make radeon_mn_get wait for mmap_sem killable drm/i915: make i915_gem_mmap_ioctl wait for mmap_sem killable uprobes: wait for mmap_sem for write killable prctl: make PR_SET_THP_DISABLE wait for mmap_sem killable exec: make exec path waiting for mmap_sem killable aio: make aio_setup_ring killable coredump: make coredump_wait wait for mmap_sem for write killable vdso: make arch_setup_additional_pages wait for mmap_sem for write killable ipc, shm: make shmem attach/detach wait for mmap_sem killable mm, fork: make dup_mmap wait for mmap_sem for write killable mm, proc: make clear_refs killable mm: make vm_brk killable mm, elf: handle vm_brk error mm, aout: handle vm_brk failures mm: make vm_munmap killable mm: make vm_mmap killable mm: make mmap_sem for write waits killable for mm syscalls MAINTAINERS: add co-maintainer for scripts/gdb ...
2016-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull more security subsystem updates from James Morris: "Minor updates for the keys code" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: MAINTAINERS: Update keyrings record and add asymmetric keys record lib: asn1_decoder - add MODULE_LICENSE("GPL") KEYS: The PKCS#7 test key type should use the secondary keyring
2016-05-23MAINTAINERS: add co-maintainer for scripts/gdbKieran Bingham
Add myself as a co-maintainer for scripts/gdb supporting Jan Kizka Link: http://lkml.kernel.org/r/fb5d34ce563f33d2f324f26f592b24ded30032ee.1462865983.git.jan.kiszka@siemens.com Signed-off-by: Kieran Bingham <kieran@bingham.xyz> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23MAINTAINERS: add web link for nilfs projectRyusuke Konishi
Add nilfs.osdn.jp as the second web site of nilfs project. Link: http://lkml.kernel.org/r/1461935747-10380-6-git-send-email-konishi.ryusuke@lab.ntt.co.jp Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23MAINTAINERS: Add file patterns for net device tree bindingsGeert Uytterhoeven
Submitters of device tree binding documentation may forget to CC the subsystem maintainer if this is missing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-23Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Here's the main drm pull request for 4.7, it's been a busy one, and I've been a bit more distracted in real life this merge window. Lots more ARM drivers, not sure if it'll ever end. I think I've at least one more coming the next merge window. But changes are all over the place, support for AMD Polaris GPUs is in here, some missing GM108 support for nouveau (found in some Lenovos), a bunch of MST and skylake fixes. I've also noticed a few fixes from Arnd in my inbox, that I'll try and get in asap, but I didn't think they should hold this up. New drivers: - Hisilicon kirin display driver - Mediatek MT8173 display driver - ARC PGU - bitstreamer on Synopsys ARC SDP boards - Allwinner A13 initial RGB output driver - Analogix driver for DisplayPort IP found in exynos and rockchip DRM Core: - UAPI headers fixes and C++ safety - DRM connector reference counting - DisplayID mode parsing for Dell 5K monitors - Removal of struct_mutex from drivers - Connector registration cleanups - MST robustness fixes - MAINTAINERS updates - Lockless GEM object freeing - Generic fbdev deferred IO support panel: - Support for a bunch of new panels i915: - VBT refactoring - PLL computation cleanups - DSI support for BXT - Color manager support - More atomic patches - GEM improvements - GuC fw loading fixes - DP detection fixes - SKL GPU hang fixes - Lots of BXT fixes radeon/amdgpu: - Initial Polaris support - GPUVM/Scheduler/Clock/Power improvements - ASYNC pageflip support - New mesa feature support nouveau: - GM108 support - Power sensor support improvements - GR init + ucode fixes. - Use GPU provided topology information vmwgfx: - Add host messaging support gma500: - Some cleanups and fixes atmel: - Bridge support - Async atomic commit support fsl-dcu: - Timing controller for LCD support - Pixel clock polarity support rcar-du: - Misc fixes exynos: - Pipeline clock support - Exynoss4533 SoC support - HW trigger mode support - export HDMI_PHY clock - DECON5433 fixes - Use generic prime functions - use DMA mapping APIs rockchip: - Lots of little fixes vc4: - Render node support - Gamma ramp support - DPI output support msm: - Mostly cleanups and fixes - Conversion to generic struct fence etnaviv: - Fix for prime buffer handling - Allow hangcheck to be coalesced with other wakeups tegra: - Gamme table size fix" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (1050 commits) drm/edid: add displayid detailed 1 timings to the modelist. (v1.1) drm/edid: move displayid validation to it's own function. drm/displayid: Iterate over all DisplayID blocks drm/edid: move displayid tiled block parsing into separate function. drm: Nuke ->vblank_disable_allowed drm/vmwgfx: Report vmwgfx version to vmware.log drm/vmwgfx: Add VMWare host messaging capability drm/vmwgfx: Kill some lockdep warnings drm/nouveau/gr/gf100-: fix race condition in fecs/gpccs ucode drm/nouveau/core: recognise GM108 chipsets drm/nouveau/gr/gm107-: fix touching non-existent ppcs in attrib cb setup drm/nouveau/gr/gk104-: share implementation of ppc exception init drm/nouveau/gr/gk104-: move rop_active_fbps init to nonctx drm/nouveau/bios/pll: check BIT table version before trying to parse it drm/nouveau/bios/pll: prevent oops when limits table can't be parsed drm/nouveau/volt/gk104: round up in gk104_volt_set drm/nouveau/fb/gm200: setup mmu debug buffer registers at init() drm/nouveau/fb/gk20a,gm20b: setup mmu debug buffer registers at init() drm/nouveau/fb/gf100-: allocate mmu debug buffers drm/nouveau/fb: allow chipset-specific actions for oneinit() ...
2016-05-23Merge tag 'keys-next-20160511' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into for-linus
2016-05-23MAINTAINERS: Add file patterns for watchdog device tree bindingsGeert Uytterhoeven
Submitters of device tree binding documentation may forget to CC the subsystem maintainer if this is missing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: linux-watchdog@vger.kernel.org
2016-05-22Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu Pull m68knommu update from Greg Ungerer: "Only a single change to update my email address in the MAINTAINERS file" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68k: change m68knommu maintainer email address
2016-05-21Merge tag 'for-f2fs-4.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "In this round, as Ted pointed out, fscrypto allows one more key prefix given by filesystem to resolve backward compatibility issues. Other than that, we've fixed several error handling cases by introducing a fault injection facility. We've also achieved performance improvement in some workloads as well as a bunch of bug fixes. Summary: Enhancements: - fs-specific prefix for fscrypto - fault injection facility - expose validity bitmaps for user to be aware of fragmentation - fallocate/rm/preallocation speed up - use percpu counters Bug fixes: - some inline_dentry/inline_data bugs - error handling for atomic/volatile/orphan inodes - recover broken superblock" * tag 'for-f2fs-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (73 commits) f2fs: fix to update dirty page count correctly f2fs: flush pending bios right away when error occurs f2fs: avoid ENOSPC fault in the recovery process f2fs: make exit_f2fs_fs more clear f2fs: use percpu_counter for total_valid_inode_count f2fs: use percpu_counter for alloc_valid_block_count f2fs: use percpu_counter for # of dirty pages in inode f2fs: use percpu_counter for page counters f2fs: use bio count instead of F2FS_WRITEBACK page count f2fs: manipulate dirty file inodes when DATA_FLUSH is set f2fs: add fault injection to sysfs f2fs: no need inc dirty pages under inode lock f2fs: fix incorrect error path handling in f2fs_move_rehashed_dirents f2fs: fix i_current_depth during inline dentry conversion f2fs: correct return value type of f2fs_fill_super f2fs: fix deadlock when flush inline data f2fs: avoid f2fs_bug_on during recovery f2fs: show # of orphan inodes f2fs: support in batch fzero in dnode page f2fs: support in batch multi blocks preallocation ...
2016-05-20Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge more updates from Andrew Morton: - the rest of MM - KASAN updates - procfs updates - exit, fork updates - printk updates - lib/ updates - radix-tree testsuite updates - checkpatch updates - kprobes updates - a few other misc bits * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (162 commits) samples/kprobes: print out the symbol name for the hooks samples/kprobes: add a new module parameter kprobes: add the "tls" argument for j_do_fork init/main.c: simplify initcall_blacklisted() fs/efs/super.c: fix return value checkpatch: improve --git <commit-count> shortcut checkpatch: reduce number of `git log` calls with --git checkpatch: add support to check already applied git commits checkpatch: add --list-types to show message types to show or ignore checkpatch: advertise the --fix and --fix-inplace options more checkpatch: whine about ACCESS_ONCE checkpatch: add test for keywords not starting on tabstops checkpatch: improve CONSTANT_COMPARISON test for structure members checkpatch: add PREFER_IS_ENABLED test lib/GCD.c: use binary GCD algorithm instead of Euclidean radix-tree: free up the bottom bit of exceptional entries for reuse dax: move RADIX_DAX_ definitions to dax.c radix-tree: make radix_tree_descend() more useful radix-tree: introduce radix_tree_replace_clear_tags() radix-tree: tidy up __radix_tree_create() ...
2016-05-20Merge tag 'staging-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging and IIO driver updates from Greg KH: "Here's the big staging and iio driver update for 4.7-rc1. I think we almost broke even with this release, only adding a few more lines than we removed, which isn't bad overall given that there's a bunch of new iio drivers added. The Lustre developers seem to have woken up from their sleep and have been doing a great job in cleaning up the code and pruning unused or old cruft, the filesystem is almost readable :) Other than that, just a lot of basic coding style cleanups in the churn. All have been in linux-next for a while with no reported issues" * tag 'staging-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (938 commits) Staging: emxx_udc: emxx_udc: fixed coding style issue staging/gdm724x: fix "alignment should match open parenthesis" issues staging/gdm724x: Fix avoid CamelCase staging: unisys: rename misleading var ii with frag staging: unisys: visorhba: switch success handling to error handling staging: unisys: visorhba: main path needs to flow down the left margin staging: unisys: visorinput: handle_locking_key() simplifications staging: unisys: visorhba: fail gracefully for thread creation failures staging: unisys: visornic: comment restructuring and removing bad diction staging: unisys: fix format string %Lx to %llx for u64 staging: unisys: remove unused struct members staging: unisys: visorchannel: correct variable misspelling staging: unisys: visorhba: replace functionlike macro with function staging: dgnc: Need to check for NULL of ch staging: dgnc: remove redundant condition check staging: dgnc: fix 'line over 80 characters' staging: dgnc: clean up the dgnc_get_modem_info() staging: lustre: lnet: enable configuration per NI interface staging: lustre: o2iblnd: properly set ibr_why staging: lustre: o2iblnd: remove last of kiblnd_tunables_fini ...
2016-05-20Merge tag 'driver-core-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the "big" driver core update for 4.7-rc1. Mostly just debugfs changes, the long-known and messy races with removing debugfs files should be fixed thanks to the great work of Nicolai Stange. We also have some isa updates in here (the x86 maintainers told me to take it through this tree), a new warning when we run out of dynamic char major numbers, and a few other assorted changes, details in the shortlog. All have been in linux-next for some time with no reported issues" * tag 'driver-core-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (32 commits) Revert "base: dd: don't remove driver_data in -EPROBE_DEFER case" gpio: ws16c48: Utilize the ISA bus driver gpio: 104-idio-16: Utilize the ISA bus driver gpio: 104-idi-48: Utilize the ISA bus driver gpio: 104-dio-48e: Utilize the ISA bus driver watchdog: ebc-c384_wdt: Utilize the ISA bus driver iio: stx104: Utilize the module_isa_driver and max_num_isa_dev macros iio: stx104: Add X86 dependency to STX104 Kconfig option Documentation: Add ISA bus driver documentation isa: Implement the max_num_isa_dev macro isa: Implement the module_isa_driver macro pnp: pnpbios: Add explicit X86_32 dependency to PNPBIOS isa: Decouple X86_32 dependency from the ISA Kconfig option driver-core: use 'dev' argument in dev_dbg_ratelimited stub base: dd: don't remove driver_data in -EPROBE_DEFER case kernfs: Move faulting copy_user operations outside of the mutex devcoredump: add scatterlist support debugfs: unproxify files created through debugfs_create_u32_array() debugfs: unproxify files created through debugfs_create_blob() debugfs: unproxify files created through debugfs_create_bool() ...
2016-05-20Merge tag 'char-misc-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char / misc driver updates from Greg KH: "Here's the big char and misc driver update for 4.7-rc1. Lots of different tiny driver subsystems have updates here with new drivers and functionality. Details in the shortlog. All have been in linux-next with no reported issues for a while" * tag 'char-misc-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (125 commits) mcb: Delete num_cells variable which is not required mcb: Fixed bar number assignment for the gdd mcb: Replace ioremap and request_region with the devm version mcb: Implement bus->dev.release callback mcb: export bus information via sysfs mcb: Correctly initialize the bus's device mei: bus: call mei_cl_read_start under device lock coresight: etb10: adjust read pointer only when needed coresight: configuring ETF in FIFO mode when acting as link coresight: tmc: implementing TMC-ETF AUX space API coresight: moving struct cs_buffers to header file coresight: tmc: keep track of memory width coresight: tmc: make sysFS and Perf mode mutually exclusive coresight: tmc: dump system memory content only when needed coresight: tmc: adding mode of operation for link/sinks coresight: tmc: getting rid of multiple read access coresight: tmc: allocating memory when needed coresight: tmc: making prepare/unprepare functions generic coresight: tmc: splitting driver in ETB/ETF and ETR components coresight: tmc: cleaning up header file ...
2016-05-20Merge tag 'tty-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty and serial driver updates from Greg KH: "Here's the large TTY and Serial driver update for 4.7-rc1. A few new serial drivers are added here, and Peter has fixed a bunch of long-standing bugs in the tty layer and serial drivers as normal. Full details in the shortlog. All of these have been in linux-next for a while with no reported issues" * tag 'tty-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (88 commits) MAINTAINERS: 8250: remove website reference serial: core: Fix port mutex assert if lockdep disabled serial: 8250_dw: fix wrong logic in dw8250_check_lcr() tty: vt, finish looping on duplicate tty: vt, return error when con_startup fails QE-UART: add "fsl,t1040-ucc-uart" to of_device_id serial: mctrl_gpio: Drop support for out1-gpios and out2-gpios serial: 8250dw: Add device HID for future AMD UART controller Fix OpenSSH pty regression on close serial: mctrl_gpio: add IRQ locking serial: 8250: Integrate Fintek into 8250_base serial: mps2-uart: add support for early console serial: mps2-uart: add MPS2 UART driver dt-bindings: document the MPS2 UART bindings serial: sirf: Use generic uart-has-rtscts DT property serial: sirf: Introduce helper variable struct device_node *np serial: mxs-auart: Use generic uart-has-rtscts DT property serial: imx: Use generic uart-has-rtscts DT property doc: DT: Add Generic Serial Device Tree Bindings serial: 8250: of: Make tegra_serial_handle_break() static ...
2016-05-20Merge tag 'clk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clk updates from Stephen Boyd: "It's the usual big pile of driver updates and additions, but we do have a couple core changes in here as well. Core: - CLK_IS_CRITICAL support has been added. This should allow drivers to properly express that a certain clk should stay on even if their prepare/enable count drops to 0 (and in turn the parents of these clks should stay enabled). - A clk registration API has been added, clk_hw_register(), and an OF clk provider API has been added, of_clk_add_hw_provider(). These APIs have been put in place to further split clk providers from clk consumers, with the goal being to have clk providers never deal with struct clk pointers at all. Conversion of provider drivers is on going. clkdev has also gained support for registering clk_hw pointers directly so we can convert drivers that don't use devicetree. New Drivers: - Marvell ap806 and cp110 system controllers (with clks inside!) - Hisilicon Hi3519 clock and reset controller - Axis ARTPEC-6 clock controllers - Oxford Semiconductor OXNAS clock controllers - AXS10X I2S PLL - Rockchip RK3399 clock and reset controller Updates: - MMC2 and UART2 clks on Samsung Exynos 3250, ACLK on Samsung Exynos 542x SoCs, and some more clk ID exporting for bus frequency scaling - Proper BCM2835 PCM clk support and various other clks - i.MX clk updates for i.MX6SX, i.MX7, and VF610 - Renesas updates for R-Car H3 - Tegra210 got updates for DisplayPort and HDMI 2.0 - Rockchip driver refactorings and fixes due to adding RK3399 support" * tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (139 commits) clk: fix critical clock locking clk: qcom: mmcc-8996: Remove clocks that should be controlled by RPM clk: ingenic: Allow divider value to be divided clk: sunxi: Add display and TCON0 clocks driver clk: rockchip: drop old_rate calculation on pll rate changes clk: rockchip: simplify GRF handling in pll clocks clk: rockchip: lookup General Register Files in rockchip_clk_init clk: rockchip: fix the rk3399 sdmmc sample / drv name clk: mvebu: new driver for Armada CP110 system controller dt-bindings: arm: add DT binding for Marvell CP110 system controller clk: mvebu: new driver for Armada AP806 system controller clk: hisilicon: add CRG driver for hi3519 soc clk: hisilicon: export some hisilicon APIs to modules reset: hisilicon: add reset controller driver for hisilicon SOCs clk: bcm/kona: Do not use sizeof on pointer type clk: qcom: msm8916: Fix crypto clock flags clk: nxp: lpc18xx: Initialize clk_init_data::flags to 0 clk/axs10x: Add I2S PLL clock driver clk: imx7d: fix ahb clock mux 1 clk: fix comment of devm_clk_hw_register() ...
2016-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes and more updates from David Miller: 1) Tunneling fixes from Tom Herbert and Alexander Duyck. 2) AF_UNIX updates some struct sock bit fields with the socket lock, whereas setsockopt() sets overlapping ones with locking. Seperate out the synchronized vs. the AF_UNIX unsynchronized ones to avoid corruption. From Andrey Ryabinin. 3) Mount BPF filesystem with mount_nodev rather than mount_ns, from Eric Biederman. 4) A couple kmemdup conversions, from Muhammad Falak R Wani. 5) BPF verifier fixes from Alexei Starovoitov. 6) Don't let tunneled UDP packets get stuck in socket queues, if something goes wrong during the encapsulation just drop the packet rather than signalling an error up the call stack. From Hannes Frederic Sowa. 7) SKB ref after free in batman-adv, from Florian Westphal. 8) TCP iSCSI, ocfs2, rds, and tipc have to disable BH in it's TCP callbacks since the TCP stack runs pre-emptibly now. From Eric Dumazet. 9) Fix crash in fixed_phy_add, from Rabin Vincent. 10) Fix length checks in xen-netback, from Paul Durrant. 11) Fix mixup in KEY vs KEYID macsec attributes, from Sabrina Dubroca. 12) RDS connection spamming bug fixes from Sowmini Varadhan * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (152 commits) net: suppress warnings on dev_alloc_skb uapi glibc compat: fix compilation when !__USE_MISC in glibc udp: prevent skbs lingering in tunnel socket queues bpf: teach verifier to recognize imm += ptr pattern bpf: support decreasing order in direct packet access net: usb: ch9200: use kmemdup ps3_gelic: use kmemdup net:liquidio: use kmemdup bpf: Use mount_nodev not mount_ns to mount the bpf filesystem net: cdc_ncm: update datagram size after changing mtu tuntap: correctly wake up process during uninit intel: Add support for IPv6 IP-in-IP offload ip6_gre: Do not allow segmentation offloads GRE_CSUM is enabled with FOU/GUE RDS: TCP: Avoid rds connection churn from rogue SYNs RDS: TCP: rds_tcp_accept_worker() must exit gracefully when terminating rds-tcp net: sock: move ->sk_shutdown out of bitfields. ipv6: Don't reset inner headers in ip6_tnl_xmit ip4ip6: Support for GSO/GRO ip6ip6: Support for GSO/GRO ipv6: Set features for IPv6 tunnels ...
2016-05-20MAINTAINERS: remove Koichi YasutakeJiri Slaby
The MTA says: <yasutake.koichi@jp.panasonic.com>: unknown user: "yasutake.koichi@jp.panasonic.com" Link: http://lkml.kernel.org/r/1462776755-9607-1-git-send-email-jslaby@suse.cz Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20MAINTAINERS: remove defunct spear mailing listEric Engestrom
It looks like the email address for this mailing list doesn't exist anymore: <spear-devel@list.st.com>: host mxb-00178001.gslb.pphosted.com[91.207.212.93] said: 550 5.1.1 User Unknown (in reply to RCPT TO command) Signed-off-by: Eric Engestrom <eric.engestrom@imgtec.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Jiri Slaby <jslaby@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20MAINTAINERS: remove linux@lists.openrisc.netJiri Slaby
$ host -t mx lists.openrisc.net Host lists.openrisc.net not found: 3(NXDOMAIN) Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
