* tag 'v5.4.70': (3051 commits)
Linux 5.4.70
netfilter: ctnetlink: add a range check for l3/l4 protonum
ep_create_wakeup_source(): dentry name can change under you...
arch/arm/mach-imx/pm-imx6.c
arch/arm64/boot/dts/freescale/imx8mm-evk.dts
arch/arm64/boot/dts/freescale/imx8mn-ddr4-evk.dts
drivers/crypto/caam/caamalg.c
drivers/gpu/drm/imx/dw_hdmi-imx.c
drivers/gpu/drm/imx/imx-ldb.c
drivers/gpu/drm/imx/ipuv3/ipuv3-crtc.c
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/ethernet/freescale/dpaa2/dpaa2-eth.c
drivers/net/ethernet/freescale/enetc/enetc.c
drivers/net/ethernet/freescale/enetc/enetc_pf.c
drivers/thermal/imx_thermal.c
drivers/usb/cdns3/ep0.c
drivers/xen/swiotlb-xen.c
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
commit fcf1b6a35c16ac500fa908a4022238e5d666eabf upstream.
added to kbuild documentation. Provides more official info on building
kernels with Clang and LLVM than our wiki.
Suggested-by: Kees Cook <keescook@chromium.org>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Sedat Dilek <sedat.dilek@gmail.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Merge Linux stable release v5.4.24 into imx_5.4.y
* tag 'v5.4.24': (3306 commits)
Linux 5.4.24
blktrace: Protect q->blk_trace with RCU
kvm: nVMX: VMWRITE checks unsupported field before read-only field
arch/arm/boot/dts/imx6sll-evk.dts
arch/arm/boot/dts/imx7ulp.dtsi
arch/arm64/boot/dts/freescale/fsl-ls1028a.dtsi
drivers/clk/imx/clk-composite-8m.c
drivers/gpio/gpio-mxc.c
drivers/irqchip/Kconfig
drivers/mmc/host/sdhci-of-esdhc.c
drivers/mtd/nand/raw/gpmi-nand/gpmi-nand.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/dpaa/dpaa_eth.c
drivers/net/ethernet/mscc/ocelot.c
drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
drivers/net/phy/realtek.c
drivers/pci/controller/mobiveil/pcie-mobiveil-host.c
drivers/perf/fsl_imx8_ddr_perf.c
drivers/tee/optee/shm_pool.c
drivers/usb/cdns3/gadget.c
kernel/sched/cpufreq.c
net/core/xdp.c
sound/soc/sof/core.c
sound/soc/sof/imx/Kconfig
sound/soc/sof/loader.c
commit 96228b7df33f8eb9006f8ae96949400aed9bd303 upstream.
We've moved from bugzilla to gitlab.
Cc: stable@vger.kernel.org
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200212160434.6437-1-jani.nikula@intel.com
(cherry picked from commit 3a6a4f0810c8ade6f1ff63c34aa9834176b9d88b)
[ Upstream commit dff6bc1bfd462b76dc13ec19dedc2c134a62ac59 ]
Commit 6d97985072dc ("isdn: move capi drivers to staging") cleaned up the
isdn drivers and split the MAINTAINERS section for ISDN, but missed to add
the terminal slash for the two directories mISDN and hardware. Hence, all
files in those directories were not part of the new ISDN/mISDN SUBSYSTEM,
but were considered to be part of "THE REST".
Rectify the situation, and while at it, also complete the section with two
further build files that belong to that subsystem.
This was identified with a small script that finds all files belonging to
"THE REST" according to the current MAINTAINERS file, and I investigated
upon its output.
Fixes: 6d97985072dc ("isdn: move capi drivers to staging")
Signed-off-by: Lukas Bulwahn <lukas.bulwahn@gmail.com>
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
commit 44fe5cb32c7599a4059931a98794e0418619aa96 upstream.
When gpiolib.h internal header had been split to few, the commit 77cb907abe6c
("gpiolib: acpi: Split ACPI stuff to gpiolib-acpi.h") in particular missed
the MAINTAINERS database update. Do it here.
Fixes: 77cb907abe6c ("gpiolib: acpi: Split ACPI stuff to gpiolib-acpi.h")
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
* qe/next: (6 commits)
config/qe: add irq-qeic support.
QE: remove PPCisms for QE
irqchip/qeic: remove PPCisms for QEIC
irqchip/qeic: merge qeic_of_init into qe_ic_init
irqchip/qeic: merge qeic init code from platforms to a common function
* pcie/next: (40 commits)
LF-128 PCI: imx: turn off the clocks and regulators when link is down
PCI: imx: add the imx pcie ep verification solution
misc: pci_endpoint_test: Add the layerscape PCIe GEN4 EP device support
PCI: mobiveil: Add workaround for unsupported request error
PCI: mobiveil: Add PCIe Gen4 EP driver for NXP Layerscape SoCs
Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com>
[ Aisheng: fix minor conflict due to removed VBOXSF_FS ]
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
This supports an Ethernet switching core from Vitesse / Microsemi /
Microchip (VSC9959) which is part of the Ocelot family (a brand name),
and whose code name is Felix. The switch can be (and is) integrated on
different SoCs as a PCIe endpoint device.
The functionality is provided by the core of the Ocelot switch driver
(drivers/net/ethernet/mscc). In this regard, the current driver is an
instance of Microsemi's Ocelot core driver, with a DSA front-end. It
inherits its name from VSC9959's code name, to distinguish itself from
the switchdev ocelot driver.
The patch adds the logic for probing a PCI device and defines the
register map for the VSC9959 switch core, since it has some differences
in register addresses and bitfield mappings compared to the other Ocelot
switches (VSC7511, VSC7512, VSC7513, VSC7514).
The Felix driver declares the register map as part of the "instance
table". Currently the VSC9959 inside NXP LS1028A is the only instance,
but presumably it can support other switches in the Ocelot family, when
used in DSA mode (Linux running on the external CPU, and not on the
embedded MIPS).
In a few cases, some h/w operations have to be done differently on
VSC9959 due to missing bitfields. This is the case for the switch core
reset and init. Because for this operation Ocelot uses some bits that
are not present on Felix, the latter has to use a register from the
global registers block (GCB) instead.
Although it is a PCI driver, it relies on DT bindings for compatibility
with DSA (CPU port link, PHY library). It does not have any custom
device tree bindings, since we would like to minimize its dependency on
device tree though.
Signed-off-by: Claudiu Manoil <claudiu.manoil@nxp.com>
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
While it is entirely possible that this tagger format is in fact more
generic than just these 2 switch families, I don't have that knowledge.
The Seville switch in NXP T1040 has a similar frame format, but there
are enough differences (e.g. DEST field starts at bit 57 instead of 56)
that calling this file tag_vitesse.c is a bit of a stretch at the
moment. The frame format has been listed in a comment so that people who
add support for further Vitesse switches can rework this tagger while
keeping compatibility with Felix.
The "ocelot" name was chosen instead of "felix" because even the Ocelot
switch can act as a DSA device when it is used in NPI mode, and the Felix
tagger format is almost identical. Currently it is only used for the
Felix switch embedded in the NXP LS1028A chip.
The ABI for this tagger should be considered "not stable" at the moment.
The DSA tag is always placed before the Ethernet header and therefore,
we are using the long prefix for RX tags to avoid putting the DSA master
port in promiscuous mode. Once there will be an API in DSA for drivers
to request DSA masters to be in promiscuous mode unconditionally, we
will switch to the "no prefix" extraction frame header, which will save
16 padding bytes for each RX frame.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
The Felix DSA driver needs to write to SYS_RAM_INIT_RAM_INIT for its own
chip initialization process.
Also update the MAINTAINERS file such that the headers exported by the
ocelot driver are under the same maintainers' umbrella as the driver
itself.
Introduce the rescan attribute as a device attribute to
synchronize the fsl-mc bus objects and the MC firmware.
To rescan the root dprc only, e.g.
echo 1 > /sys/bus/fsl-mc/devices/dprc.1/rescan
Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Define "struct fsl_mc_command" as a structure that can cross the
user/kernel boundary.
* keys/next:
encrypted_keys: Adds support for secure key-type as master key.
security/keys/secure_key: Adds the secure key support based on CAAM.
This PCIe controller is based on the Mobiveil GPEX IP, it work in EP
mode if select this config opteration.
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
[Zhiqiang: Correct the Copyright]
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Add the EP driver support for Mobiveil base on endpoint framework.
Add PCIe Gen4 controller DT bindings of NXP Layerscape SoCs.
Reviewed-by: Rob Herring <robh@kernel.org>
Refactor the Mobiveil PCIe Host Bridge IP driver to make
it easier to add support for both RC and EP mode driver.
This patch moved the Mobiveil driver to an new directory
'drivers/pci/controller/mobiveil' and refactor it according
to the RC and EP abstraction.
Reviewed-by: Minghuan Lian <Minghuan.Lian@nxp.com>
Reviewed-by: Subrahmanya Lingappa <l.subrahmanya@mobiveil.co.in>
Jailhouse allows explicitly enabled cells to write character-wise
messages to the hypervisor debug console. Make use of this for a
platform-agnostic boot diagnosis channel, specifically for non-root
cells. This also comes with earlycon support.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
(cherry picked from commit 60685bd589aef4972d20724863079edf2039eaa2)
From http://git.kiszka.org/?p=linux.git;a=shortlog;h=refs/heads/queues/jailhouse
Encrypted keys can use secure key-type as master key along with
trusted/user keys.
Secure key as master key uses, secure key type payload derieved
using CAAM hardware.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
Reviewed-by: Sahil Malhotra <sahil.malhotra@nxp.com>
Secure keys are derieved using CAAM crypto block.
Secure keys derieved are the random number symmetric keys from CAAM.
Blobs corresponding to the key are formed using CAAM. User space
will only be able to view the blob of the key.
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Pull networking fixes from David Miller:
1) Validate tunnel options length in act_tunnel_key, from Xin Long.
2) Fix DMA sync bug in gve driver, from Adi Suresh.
3) TSO kills performance on some r8169 chips due to HW issues, disable
by default in that case, from Corinna Vinschen.
4) Fix clock disable mismatch in fec driver, from Chubong Yuan.
5) Fix interrupt status bits define in hns3 driver, from Huazhong Tan.
6) Fix workqueue deadlocks in qeth driver, from Julian Wiedmann.
7) Don't napi_disable() twice in r8152 driver, from Hayes Wang.
8) Fix SKB extension memory leak, from Florian Westphal.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (54 commits)
r8152: avoid to call napi_disable twice
MAINTAINERS: Add myself as maintainer of virtio-vsock
udp: drop skb extensions before marking skb stateless
net: rtnetlink: prevent underflows in do_setvfinfo()
can: m_can_platform: remove unnecessary m_can_class_resume() call
can: m_can_platform: set net_device structure as driver data
hv_netvsc: Fix send_table offset in case of a host bug
hv_netvsc: Fix offset usage in netvsc_send_table()
net-ipv6: IPV6_TRANSPARENT - check NET_RAW prior to NET_ADMIN
sfc: Only cancel the PPS workqueue if it exists
nfc: port100: handle command failure cleanly
net-sysfs: fix netdev_queue_add_kobject() breakage
r8152: Re-order napi_disable in rtl8152_close
net: qca_spi: Move reset_count to struct qcaspi
net: qca_spi: fix receive buffer size check
net/ibmvnic: Ignore H_FUNCTION return from H_EOI to tolerate XIVE mode
Revert "net/ibmvnic: Fix EOI when running in XIVE mode"
net/mlxfw: Verify FSM error code translation doesn't exceed array size
net/mlx5: Update the list of the PCI supported devices
net/mlx5: Fix auto group size calculation
Since I'm actively working on vsock and virtio/vhost transports,
Stefan suggested to help him to maintain it.
Signed-off-by: Stefano Garzarella <sgarzare@redhat.com>
I prefer to use my personal email address for kernel related work.
Signed-off-by: Zhu Yanjun <yanjun.zhu@oracle.com>
Acked-by: Rain River <rain.1986.08.12@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu fixes from Joerg Roedel:
- Fix for Intel IOMMU to correct invalidation commands when in SVA
mode.
- Update MAINTAINERS entry for Intel IOMMU
* tag 'iommu-fixes-v5.4-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/vt-d: Fix QI_DEV_IOTLB_PFSID and QI_DEV_EIOTLB_PFSID macros
MAINTAINERS: Update for INTEL IOMMU (VT-d) entry
git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux
Pull MIPS fixes from Paul Burton:
"A fix and simplification for SGI IP27 exception handlers, and a small
MAINTAINERS update for Broadcom MIPS systems"
* tag 'mips_fixes_5.4_4' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux:
MAINTAINERS: Remove Kevin as maintainer of BMIPS generic platforms
MIPS: SGI-IP27: fix exception handler replication
This went into staging in rc7. It turns out that was a mistake, and
apparently it wasn't even supposed to go there at all, but be introduced
as a regular filesystem.
We don't try to sneak in whole new filesystems this late in the rc, just
delete the whole thing, and it can be re-introduced as a proper patch
with proper acks from actual filesystem people instead of some odd
late-rc staging back-door.
Cc: Hans de Goede <hdegoede@redhat.com>
Update the INTEL IOMMU (VT-d) entry and add myself as the
co-maintainer. I have several years of VT-d development
experience and have actively contributed to Intel VT-d
driver during recent two years. I volunteer to take this
rule. With this role, I can better help review and test
patches.
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Ashok Raj <ashok.raj@intel.com>
Cc: Jacob Pan <jacob.jun.pan@linux.intel.com>
Cc: Kevin Tian <kevin.tian@intel.com>
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc
Pull ARM SoC fixes from Olof Johansson:
"A set of fixes that have trickled in over the last couple of weeks:
- MAINTAINER update for Cavium/Marvell ThunderX2
- stm32 tweaks to pinmux for Joystick/Camera, and RAM allocation for
CAN interfaces
- i.MX fixes for voltage regulator GPIO mappings, fixes voltage
scaling issues
- More i.MX fixes for various issues on i.MX eval boards: interrupt
storm due to u-boot leaving pins in new states, fixing power button
config, a couple of compatible-string corrections.
- Powerdown and Suspend/Resume fixes for Allwinner A83-based tablets
- A few documentation tweaks and a fix of a memory leak in the reset
subsystem"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc:
MAINTAINERS: update Cavium ThunderX2 maintainers
ARM: dts: stm32: change joystick pinctrl definition on stm32mp157c-ev1
ARM: dts: stm32: remove OV5640 pinctrl definition on stm32mp157c-ev1
ARM: dts: stm32: Fix CAN RAM mapping on stm32mp157c
ARM: dts: stm32: relax qspi pins slew-rate for stm32mp157
arm64: dts: zii-ultra: fix ARM regulator GPIO handle
ARM: sunxi: Fix CPU powerdown on A83T
ARM: dts: sun8i-a83t-tbs-a711: Fix WiFi resume from suspend
arm64: dts: imx8mn: fix compatible string for sdma
arm64: dts: imx8mm: fix compatible string for sdma
reset: fix reset_control_ops kerneldoc comment
ARM: dts: imx6-logicpd: Re-enable SNVS power key
soc: imx: gpc: fix initialiser format
ARM: dts: imx6qdl-sabreauto: Fix storm of accelerometer interrupts
arm64: dts: ls1028a: fix a compatible issue
reset: fix reset_control_get_exclusive kerneldoc comment
reset: fix reset_control_lookup kerneldoc comment
reset: fix of_reset_control_get_count kerneldoc comment
reset: fix of_reset_simple_xlate kerneldoc comment
reset: Fix memory leak in reset_control_array_put()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull IIO fixes and staging driver from Greg KH:
"Here is a mix of a number of IIO driver fixes for 5.4-rc7, and a whole
new staging driver.
The IIO fixes resolve some reported issues, all are tiny.
The staging driver addition is the vboxsf filesystem, which is the
VirtualBox guest shared folder code. Hans has been trying to get
filesystem reviewers to review the code for many months now, and
Christoph finally said to just merge it in staging now as it is
stand-alone and the filesystem people can review it easier over time
that way.
I know it's late for this big of an addition, but it is stand-alone.
The code has been in linux-next for a while, long enough to pick up a
few tiny fixes for it already so people are looking at it.
All of these have been in linux-next with no reported issues"
* tag 'staging-5.4-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: Fix error return code in vboxsf_fill_super()
staging: vboxsf: fix dereference of pointer dentry before it is null checked
staging: vboxsf: Remove unused including <linux/version.h>
staging: Add VirtualBox guest shared folder (vboxsf) support
iio: adc: stm32-adc: fix stopping dma
iio: imu: inv_mpu6050: fix no data on MPU6050
iio: srf04: fix wrong limitation in distance measuring
iio: imu: adis16480: make sure provided frequency is positive
1) BPF sample build fixes from Björn Töpel
2) Fix powerpc bpf tail call implementation, from Eric Dumazet.
3) DCCP leaks jiffies on the wire, fix also from Eric Dumazet.
4) Fix crash in ebtables when using dnat target, from Florian Westphal.
5) Fix port disable handling whne removing bcm_sf2 driver, from Florian
Fainelli.
6) Fix kTLS sk_msg trim on fallback to copy mode, from Jakub Kicinski.
7) Various KCSAN fixes all over the networking, from Eric Dumazet.
8) Memory leaks in mlx5 driver, from Alex Vesker.
9) SMC interface refcounting fix, from Ursula Braun.
10) TSO descriptor handling fixes in stmmac driver, from Jose Abreu.
11) Add a TX lock to synchonize the kTLS TX path properly with crypto
operations. From Jakub Kicinski.
12) Sock refcount during shutdown fix in vsock/virtio code, from Stefano
Garzarella.
13) Infinite loop in Intel ice driver, from Colin Ian King.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (108 commits)
ixgbe: need_wakeup flag might not be set for Tx
i40e: need_wakeup flag might not be set for Tx
igb/igc: use ktime accessors for skb->tstamp
i40e: Fix for ethtool -m issue on X722 NIC
iavf: initialize ITRN registers with correct values
ice: fix potential infinite loop because loop counter being too small
qede: fix NULL pointer deref in __qede_remove()
net: fix data-race in neigh_event_send()
vsock/virtio: fix sock refcnt holding during the shutdown
net: ethernet: octeon_mgmt: Account for second possible VLAN header
mac80211: fix station inactive_time shortly after boot
net/fq_impl: Switch to kvmalloc() for memory allocation
mac80211: fix ieee80211_txq_setup_flows() failure path
ipv4: Fix table id reference in fib_sync_down_addr
ipv6: fixes rt6_probe() and fib6_nh->last_probe init
net: hns: Fix the stray netpoll locks causing deadlock in NAPI path
net: usb: qmi_wwan: add support for DW5821e with eSIM support
CDC-NCM: handle incomplete transfer of MTU
nfc: netlink: fix double device reference drop
NFC: st21nfca: fix double free
I was trying to find the mm tree in MAINTAINERS by searching "Morton".
Unfortunately, I didn't find one. And I didn't even locate the MEMORY
MANAGEMENT section quickly, because Andrew's name was not listed there.
Thanks to Johannes who helped me find the mm tree.
Let save other's time searching around by adding:
M: Andrew Morton <akpm@linux-foundation.org>
T: git git://github.com/hnaz/linux-mm.git
[akpm@linux-foundation.org: add ozlabs.org quilt trees]
Link: http://lkml.kernel.org/r/20191030202217.3498133-1-songliubraving@fb.com
Signed-off-by: Song Liu <songliubraving@fb.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Per conversation with Dan, add myself to the zswap MAINTAINERS list.
Link: http://lkml.kernel.org/r/20191028143154.31304-1-vitaly.wool@konsulko.com
Signed-off-by: Vitaly Wool <vitaly.wool@konsulko.com>
Acked-by: Dan Streetman <ddstreet@ieee.org>
jnair is no longer at caviumnetworks.com (or at marvell.com). This also
means that Cavium ThunderX2 will now be maintained by Robert.
This is probably a good time to map various email addresses used for
my patches to my personal email ID, update .mailmap to do this.
Link: https://lore.kernel.org/r/20191106035203.5389-1-c.jayachandran@gmail.com
Signed-off-by: Jayachandran C <c.jayachandran@gmail.com>
Acked-by: Robert Richter <rrichter@marvell.com>
Daniel Borkmann says:
pull-request: bpf 2019-11-02
The following pull-request contains BPF updates for your *net* tree.
We've added 6 non-merge commits during the last 6 day(s) which contain
a total of 8 files changed, 35 insertions(+), 9 deletions(-).
The main changes are:
1) Fix ppc BPF JIT's tail call implementation by performing a second pass
to gather a stable JIT context before opcode emission, from Eric Dumazet.
2) Fix build of BPF samples sys_perf_event_open() usage to compiled out
unavailable test_attr__{enabled,open} checks. Also fix potential overflows
in bpf_map_{area_alloc,charge_init} on 32 bit archs, from Björn Töpel.
3) Fix narrow loads of bpf_sysctl context fields with offset > 0 on big endian
archs like s390x and also improve the test coverage, from Ilya Leoshkevich.
The last time Kevin did a review was sometime around 2014,
since then, he has not been active for the BMIPS generic platform
changes.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[paulburton@kernel.org:
Drop the non-technical commit message content; Kevin's absence from
the role is ample reasoning for this change.]
Signed-off-by: Paul Burton <paulburton@kernel.org>
1) Fix free/alloc races in batmanadv, from Sven Eckelmann.
2) Several leaks and other fixes in kTLS support of mlx5 driver, from
Tariq Toukan.
3) BPF devmap_hash cost calculation can overflow on 32-bit, from Toke
Høiland-Jørgensen.
4) Add an r8152 device ID, from Kazutoshi Noguchi.
5) Missing include in ipv6's addrconf.c, from Ben Dooks.
6) Use siphash in flow dissector, from Eric Dumazet. Attackers can
easily infer the 32-bit secret otherwise etc.
7) Several netdevice nesting depth fixes from Taehee Yoo.
8) Fix several KCSAN reported errors, from Eric Dumazet. For example,
when doing lockless skb_queue_empty() checks, and accessing
sk_napi_id/sk_incoming_cpu lockless as well.
9) Fix jumbo packet handling in RXRPC, from David Howells.
10) Bump SOMAXCONN and tcp_max_syn_backlog values, from Eric Dumazet.
11) Fix DMA synchronization in gve driver, from Yangchun Fu.
12) Several bpf offload fixes, from Jakub Kicinski.
13) Fix sk_page_frag() recursion during memory reclaim, from Tejun Heo.
14) Fix ping latency during high traffic rates in hisilicon driver, from
Jiangfent Xiao.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (146 commits)
net: fix installing orphaned programs
net: cls_bpf: fix NULL deref on offload filter removal
selftests: bpf: Skip write only files in debugfs
selftests: net: reuseport_dualstack: fix uninitalized parameter
r8169: fix wrong PHY ID issue with RTL8168dp
net: dsa: bcm_sf2: Fix IMP setup for port different than 8
net: phylink: Fix phylink_dbg() macro
gve: Fixes DMA synchronization.
inet: stop leaking jiffies on the wire
ixgbe: Remove duplicate clear_bit() call
Documentation: networking: device drivers: Remove stray asterisks
e1000: fix memory leaks
i40e: Fix receive buffer starvation for AF_XDP
igb: Fix constant media auto sense switching when no cable is connected
net: ethernet: arc: add the missed clk_disable_unprepare
igb: Enable media autosense for the i350.
igb/igc: Don't warn on fatal read failures when the device is removed
tcp: increase tcp_max_syn_backlog max value
net: increase SOMAXCONN to 4096
netdevsim: Fix use-after-free during device dismantle
VirtualBox hosts can share folders with guests, this commit adds a
VFS driver implementing the Linux-guest side of this, allowing folders
exported by the host to be mounted under Linux.
This driver depends on the guest <-> host IPC functions exported by
the vboxguest driver.
Link: https://lore.kernel.org/r/20191028111744.143863-2-hdegoede@redhat.com
I'm leaving SiFive in a bit less than two weeks, which means I'll be
losing my @sifive email address. I don't have my new email address yet,
so I'm switching over to my personal address instead.
Signed-off-by: Palmer Dabbelt <palmer@sifive.com>
Signed-off-by: Palmer Dabbelt <palmer@dabbelt.com>
Signed-off-by: Paul Walmsley <paul.walmsley@sifive.com>
Dave's Facebook email address is not working, and my attempts
to contact him are failing. Let's remove it to trim down the
list of TLS maintainers.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Reviewed-by: Simon Horman <simon.horman@netronome.com>
Andrii Nakryiko has been part of our weekly BPF patch review rotation
for quite some time now and provided excellent and timely feedback on
BPF patches, therefore give credit where credit is due and add him
officially to the BPF core reviewer team to the MAINTAINERS file.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Andrii Nakryiko <andriin@fb.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Link: https://lore.kernel.org/bpf/af565dbef3b0b35040f26bfd16ed59cc0bae8066.1572360528.git.daniel@iogearbox.net
"A few MIPS fixes:
- Fix VDSO time-related function behavior for systems where we need
to fall back to syscalls, but were instead returning bogus results.
- A fix to TLB exception handlers for Cavium Octeon systems where
they would inadvertently clobber the $1/$at register.
- A build fix for bcm63xx configurations.
- Switch to using my @kernel.org email address"
* tag 'mips_fixes_5.4_3' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux:
MIPS: tlbex: Fix build_restore_pagemask KScratch restore
MIPS: bmips: mark exception vectors as char arrays
mips: vdso: Fix __arch_get_hw_counter()
MAINTAINERS: Use @kernel.org address for Paul Burton
"A slightly larger set of fixes have accrued in the last two weeks.
Mostly a collection of the usual smaller fixes:
- Marvell Armada: USB phy setup issues on Turris Mox
- Broadcom: GPIO/pinmux DT mapping corrections for Stingray, MMC bus
width fix for RPi Zero W, GPIO LED removal for RPI CM3. Also some
maintainer updates.
- OMAP: Fixlets for display config, interrupt settings for wifi, some
clock/PM pieces. Also IOMMU regression fix and a ti-sysc
no-watchdog regression fix.
- i.MX: A few fixes around PM/settings, some devicetree fixlets and
catching up with config option changes in DRM
- Rockchip: RockRro64 misc DT fixups, Hugsun X99 USB-C, Kevin display
panel settings
... and some smaller fixes for Davinci (backlight, McBSP DMA),
Allwinner (phy regulators, PMU removal on A64, etc)"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (42 commits)
MAINTAINERS: Update the Spreadtrum SoC maintainer
MAINTAINERS: Remove Gregory and Brian for ARCH_BRCMSTB
ARM: dts: bcm2837-rpi-cm3: Avoid leds-gpio probing issue
bus: ti-sysc: Fix watchdog quirk handling
ARM: OMAP2+: Add pdata for OMAP3 ISP IOMMU
ARM: OMAP2+: Plug in device_enable/idle ops for IOMMUs
ARM: davinci_all_defconfig: enable GPIO backlight
ARM: davinci: dm365: Fix McBSP dma_slave_map entry
ARM: dts: bcm2835-rpi-zero-w: Fix bus-width of sdhci
ARM: imx_v6_v7_defconfig: Enable CONFIG_DRM_MSM
arm64: dts: imx8mn: Use correct clock for usdhc's ipg clk
arm64: dts: imx8mm: Use correct clock for usdhc's ipg clk
arm64: dts: imx8mq: Use correct clock for usdhc's ipg clk
ARM: dts: imx7s: Correct GPT's ipg clock source
ARM: dts: vf610-zii-scu4-aib: Specify 'i2c-mux-idle-disconnect'
ARM: dts: imx6q-logicpd: Re-Enable SNVS power key
arm64: dts: lx2160a: Correct CPU core idle state name
mailmap: Add Simon Arlott (replacement for expired email address)
arm64: dts: rockchip: Fix override mode for rk3399-kevin panel
https://github.com/Broadcom/stblinux into arm/fixes
This pull request contains MAINTAINERS file updates for Broadcom SoCs
for the 5.5 kernel, please pull the following:
- Simon adds a .mailmap alias for his old email
- Stefan updates the existing BCM2835 with BCM2711 which is the chip
name for the Raspberry Pi 4
- Florian removes Gregory and Brian from the MAINTAINERS file for
BRCMSTB SoCs
* tag 'arm-soc/for-5.5/maintainers' of https://github.com/Broadcom/stblinux:
MAINTAINERS: Add BCM2711 to BCM2835 ARCH
Link: https://lore.kernel.org/r/20191023212814.30622-3-f.fainelli@gmail.com
Change my email address, and add more Spreadtrum SC27xx series PMIC
drivers to maintain.
Link: https://lore.kernel.org/r/a48483d13243450ecf3b777d49e741b6367f2c6b.1571881956.git.baolin.wang@linaro.org
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
The last time Gregory and Brian did a review was sometime around 2015,
since then, they have not been active for ARCH_BRCMSTB changes.
Following the position of other maintainers and Harald Welte's position
here:
[1] http://laforge.gnumonks.org/blog/20180307-mchardy-gpl/
remove both of them.
Acked-by: Brian Norris <computersforpeace@gmail.com>
"I was battling a cold after some recent trips, so quite a bit piled up
meanwhile, sorry about that.
Highlights:
1) Fix fd leak in various bpf selftests, from Brian Vazquez.
2) Fix crash in xsk when device doesn't support some methods, from
Magnus Karlsson.
3) Fix various leaks and use-after-free in rxrpc, from David Howells.
4) Fix several SKB leaks due to confusion of who owns an SKB and who
should release it in the llc code. From Eric Biggers.
5) Kill a bunc of KCSAN warnings in TCP, from Eric Dumazet.
6) Jumbo packets don't work after resume on r8169, as the BIOS resets
the chip into non-jumbo mode during suspend. From Heiner Kallweit.
7) Corrupt L2 header during MPLS push, from Davide Caratti.
8) Prevent possible infinite loop in tc_ctl_action, from Eric
Dumazet.
9) Get register bits right in bcmgenet driver, based upon chip
version. From Florian Fainelli.
10) Fix mutex problems in microchip DSA driver, from Marek Vasut.
11) Cure race between route lookup and invalidation in ipv4, from Wei
Wang.
12) Fix performance regression due to false sharing in 'net'
structure, from Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (145 commits)
net: reorder 'struct net' fields to avoid false sharing
net: dsa: fix switch tree list
net: ethernet: dwmac-sun8i: show message only when switching to promisc
net: aquantia: add an error handling in aq_nic_set_multicast_list
net: netem: correct the parent's backlog when corrupted packet was dropped
net: netem: fix error path for corrupted GSO frames
macb: propagate errors when getting optional clocks
xen/netback: fix error path of xenvif_connect_data()
net: hns3: fix mis-counting IRQ vector numbers issue
net: usb: lan78xx: Connect PHY before registering MAC
vsock/virtio: discard packets if credit is not respected
vsock/virtio: send a credit update when buffer size is changed
mlxsw: spectrum_trap: Push Ethernet header before reporting trap
net: ensure correct skb->tstamp in various fragmenters
net: bcmgenet: reset 40nm EPHY on energy detect
net: bcmgenet: soft reset 40nm EPHYs before MAC init
net: phy: bcm7xxx: define soft_reset for 40nm EPHY
net: bcmgenet: don't set phydev->link from MAC
net: Update address for MediaTek ethernet driver in MAINTAINERS
ipv4: fix race condition between route lookup and invalidation
Switch to using my paulburton@kernel.org email address in order to avoid
subject mangling that's being imposed on my previous address.
Signed-off-by: Paul Burton <paul.burton@mips.com>
