path: root/MAINTAINERS
2009-10-11Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (s3c-hwmon) Disable build for S3C64xx MAINTAINERS: Fix Riku Voipio's address hwmon: (asus_atk0110) Enable the EC hwmon: (asus_atk0110) Refactor the code hwmon: (sht15) Fix spurious section mismatch warning
2009-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (34 commits) [SCSI] qla2xxx: Fix NULL ptr deref bug in fail path during queue create [SCSI] st: fix possible memory use after free after MTSETBLK ioctl [SCSI] be2iscsi: Moving to pci_pools v3 [SCSI] libiscsi: iscsi_session_setup to allow for private space [SCSI] be2iscsi: add 10Gbps iSCSI - BladeEngine 2 driver [SCSI] zfcp: Fix hang when offlining device with offline chpid [SCSI] zfcp: Fix lockdep warning when offlining device with offline chpid [SCSI] zfcp: Fix oops during shutdown of offline device [SCSI] zfcp: Fix initial device and cfdc for delayed adapter allocation [SCSI] zfcp: correctly initialize unchained requests [SCSI] mpt2sas: Bump version 02.100.03.00 [SCSI] mpt2sas: Support dev remove when phy status is MPI2_EVENT_SAS_TOPO_PHYSTATUS_VACANT [SCSI] mpt2sas: Timeout occurred within the HANDSHAKE logic while waiting on firmware to ACK. [SCSI] mpt2sas: Call init_completion on a per request basis. [SCSI] mpt2sas: Target Reset will be issued from Interrupt context. [SCSI] mpt2sas: Added SCSIIO, Internal and high priority memory pools to support multiple TM [SCSI] mpt2sas: Copyright change to 2009. [SCSI] mpt2sas: Added mpi2_history.txt for MPI2 headers. [SCSI] mpt2sas: Update driver to MPI2 REV K headers. [SCSI] bfa: Brocade BFA FC SCSI driver ...
2009-10-09MAINTAINERS: Fix Riku Voipio's addressJean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Riku Voipio <riku.voipio@iki.fi>
2009-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) ethoc: limit the number of buffers to 128 ethoc: use system memory as buffer ethoc: align received packet to make IP header at word boundary ethoc: fix buffer address mapping ethoc: fix typo to compute number of tx descriptors au1000_eth: Duplicate test of RX_OVERLEN bit in update_rx_stats() netxen: Fix Unlikely(x) > y pasemi_mac: ethtool get settings fix add maintainer for network drop monitor kernel service tg3: Fix phylib locking strategy rndis_host: support ETHTOOL_GPERMADDR ipv4: arp_notify address list bug gigaset: add kerneldoc comments gigaset: correct debugging output selection gigaset: improve error recovery gigaset: fix device ERROR response handling gigaset: announce if built with debugging gigaset: handle isoc frame errors more gracefully gigaset: linearize skb gigaset: fix reject/hangup handling ...
2009-10-08Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: agp: parisc-agp.c - use correct page_mask function parisc: Fix linker script breakage. parisc: convert to asm-generic/hardirq.h parisc: Make THREAD_SIZE available to assembly files and linker scripts. parisc: correct use of SHF_ALLOC parisc: rename parisc's vmalloc_start to parisc_vmalloc_start parisc: add me to Maintainers parisc: includecheck fix: signal.c parisc: HAVE_ARCH_TRACEHOOK parisc: add skeleton syscall.h parisc: stop using task->ptrace for {single,block}step flags parisc: split syscall_trace into two halves parisc: add missing TI_TASK macro in syscall.S parisc: tracehook_signal_handler parisc: tracehook_report_syscall
2009-10-07add maintainer for network drop monitor kernel serviceNeil Horman
I was getting ribbed about this earlier, so I figured I'd make it official. Add myself as the maintainer of the drop monitor bits, so people don't just gripe at Dave when it breaks (I'm sure it will never break, but just in case :) ). Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-04Merge branch 'acpi-pad' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpi-pad' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: acpi_pad: build only on X86 ACPI: create Processor Aggregator Device driver Fixup trivial conflicts in MAINTAINERS file.
2009-10-02Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (25 commits) ARM: 5728/1: Proper prefetch abort handling on ARMv6 and ARMv7 ARM: 5727/1: Pass IFSR register to do_PrefetchAbort() ARM: 5740/1: fix valid_phys_addr_range() range check ARM: 5739/1: ARM: allow empty ATAG_CORE ARM: 5735/1: sa1111: CodingStyle cleanups ARM: 5738/1: Correct TCM documentation ARM: 5734/1: arm: fix compilation of entry-common.S for older CPUs ARM: 5733/1: fix bcmring compile error ARM: 5732/1: remove redundant include file ARM: 5731/2: Fix U300 generic GPIO, remove ifdefs from MMCI v3 ARM: Ensure do_cache_op takes mmap_sem ARM: Fix __cpuexit section mismatch warnings ARM: Don't allow highmem on SMP platforms without h/w TLB ops broadcast ARM: includecheck fix: mach-davinci, board-dm365-evm.c ARM: Remove unused CONFIG SA1100_H3XXX ARM: Fix warning: unused variable 'highmem' ARM: Fix warning: #warning syscall migrate_pages not implemented ARM: Fix SA11x0 clocksource warning ARM: Fix SA1100 Neponset serial section mismatch ARM: Fix SA1100 Assabet/Neponset PCMCIA section mismatch warnings ...
2009-10-02Merge branch 'fixes' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/xscaleiop Conflicts: MAINTAINERS
2009-10-02[SCSI] be2iscsi: add 10Gbps iSCSI - BladeEngine 2 driverJayamohan Kallickal
[v2: fixed up virt_to_bus() issue spotted by sfr] Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-02[SCSI] bfa: Brocade BFA FC SCSI driverJing Huang
Add new driver for Brocade Hardware Signed-off-by: Jing Huang <huangj@brocade.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-01MAINTAINERS: ARM/Palm file patternsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Tomas Cech <sleep_walker@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-27parisc: add me to MaintainersJames Bottomley
It has been suggested that given my proficiency with less popular architectures, I should be officially listed as willing to see to the care and feeding of this one. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-09-24Merge branch 'origin' into for-linusRussell King
2009-09-24Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) x86/PCI: make 32 bit NUMA node array int, not unsigned char x86/PCI: default pcibus cpumask to all cpus if it lacks affinity MAINTAINTERS: remove hotplug driver entries PCI: pciehp: remove slot capabilities definitions PCI: pciehp: remove error message definitions PCI: pciehp: remove number field PCI: pciehp: remove hpc_ops PCI: pciehp: remove pci_dev field PCI: pciehp: remove crit_sect mutex PCI: pciehp: remove slot_bus field PCI: pciehp: remove first_slot field PCI: pciehp: remove slot_device_offset field PCI: pciehp: remove hp_slot field PCI: pciehp: remove device field PCI: pciehp: remove bus field PCI: pciehp: remove slot_num_inc field PCI: pciehp: remove num_slots field PCI: pciehp: remove slot_list field PCI: fix VGA arbiter header file PCI: Disable AER with pci=nomsi ... Fixed up trivial conflicts in MAINTAINERS
2009-09-24MAINTAINERS: add Matt Mackall and Herbert Xu to HARDWARE RANDOM NUMBER GENERATORJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: David Daney <ddaney@caviumnetworks.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge branch 'ixp4xx' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6 * 'ixp4xx' of git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6: Add MAINTAINERS entry for ARM/INTEL IXP4xx arch support. ixp4xx: arch_idle() documentation fixup ixp4xx: timer and clocks cleanups
2009-09-23Merge branch 'sfi-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6 * 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6: SFI: remove unneeded includes sfi: Remove unused code SFI: Hook PCI MMCONFIG x86: add arch-specific SFI support SFI: add capability to parse ACPI tables SFI: add platform-independent core support SFI: create linux/sfi.h SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-23Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Clearly mark ACPI drivers as such i2c: Add driver for SMBus Control Method Interface i2c-pnx: Correct use of request_region/request_mem_region MAINTAINERS: Add maintainer for AT24 and PCA9564/PCA9665 i2c-piix4: Add AMD SB900 SMBus device ID i2c/chips: Remove deprecated pcf8574 driver i2c/chips: Remove deprecated pca9539 driver i2c/chips: Remove deprecated pcf8575 driver gpio/pcf857x: Copy i2c_device_id from old pcf8574 driver i2c/scx200_acb: Provide more information on bus errors i2c: Provide compatibility links for i2c adapters i2c: Convert i2c adapters to bus devices i2c: Convert i2c clients to a device type i2c/tsl2550: Use combined SMBus transactions i2c-taos-evm: Switch echo off to improve performance i2c: Drop unused i2c_driver.id field
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (142 commits) USB: Fix sysfs paths in documentation USB: skeleton: fix coding style issues. USB: O_NONBLOCK in read path of skeleton USB: make usb-skeleton honor O_NONBLOCK in write path USB: skel_read really sucks royally USB: Add hub descriptor update hook for xHCI USB: xhci: Support USB hubs. USB: xhci: Set multi-TT field for LS/FS devices under hubs. USB: xhci: Set route string for all devices. USB: xhci: Fix command wait list handling. USB: xhci: Change how xHCI commands are handled. USB: xhci: Refactor input device context setup. USB: xhci: Endpoint representation refactoring. USB: gadget: ether needs to select CRC32 USB: fix USBTMC get_capabilities success handling USB: fix missing error check in probing USB: usbfs: add USBDEVFS_URB_BULK_CONTINUATION flag USB: support for autosuspend in sierra while online USB: ehci-dbgp,ehci: Allow dbpg to work with suspend/resume USB: ehci-dbgp,documentation: Documentation updates for ehci-dbgp ...
2009-09-23Merge branch 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-scoreLinus Torvalds
* 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-score: score: update email address in MAINTAINERS. score: Cleanup linker script using new macros. score: Make THREAD_SIZE available to assembly files. score: Make PAGE_SIZE available to assembly.
2009-09-23MAINTAINERS: update for TI OMAP hsmmc driverMadhusudhan Chikkature
Update maintainers entry for TI OMAP HS MMC support. Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23MAINTAINERS: remove dead ncpfs listBartlomiej Zolnierkiewicz
On Saturday 01 August 2009 00:30:39 Mail Delivery Subsystem wrote: > Delivery to the following recipient failed permanently: > > linware@sh.cvut.cz > > Technical details of permanent failure: > Google tried to deliver your message, but it was rejected by the recipient > domain. We recommend contacting the other email provider for further > information about the cause of this error. The error that the other server > returned was: 450 450 <linware@sh.cvut.cz>: Recipient address rejected: > undeliverable address: unknown user: "linware" (state 14). Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23USB: gadget: Update Freescale UDC entry in MAINTAINERSLi Yang
Change the F entry for file rename, and make it also cover fsl_qe_udc driver. Update the name accordingly. Signed-off-by: Li Yang <leoli@freescale.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23score: update email address in MAINTAINERS.Chen Liqin
Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com>
2009-09-22Merge branch 'master' into for-linusRussell King
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22input: add a driver for the Winbond WPCD376I Consumer IR hardwareDavid Härdeman
Add a driver for the the Consumer IR (CIR) functionality of the Winbond WPCD376I chipset (found on e.g. Intel DG45FC motherboards). Signed-off-by: David Härdeman <david@hardeman.nu> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: move ARM lists to infradeadJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: integrate P:/M: linesJoe Perches
A couple of new uses of separate "P: name" "M: address" lines are converted to single line "M: name <address>" Signed-off-by: Joe Perches <joe@perches.com> Cc: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Cc: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: omap: fix regexFelipe Contreras
Otherwise 'arch/arm/*omap*/foo.c' wouldn't match Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: acpi: add 'include/acpi'Felipe Contreras
2009-09-22MAINTAINERS: add IPVS include filesHannes Eder
Signed-off-by: Hannes Eder <heder@google.com> Cc: Joe Perches <joe@perches.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22sdhci: orphan driver and listPierre Ossman
Remove myself as maintainer from the sdhci driver and steer people towards the new MMC list for discussing it. Signed-off-by: Pierre Ossman <pierre@ossman.eu> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Add MAINTAINERS entry for ARM/INTEL IXP4xx arch support.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-09-21Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
2009-09-21trivial: update the Kernel Janitors' web-page URLMarkus Heidelberg
The former address cannot be resolved. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21perf: Tidy up after the big renameIngo Molnar
- provide compatibility Kconfig entry for existing PERF_COUNTERS .config's - provide courtesy copy of old perf_counter.h, for user-space projects - small indentation fixups - fix up MAINTAINERS - fix small x86 printout fallout - fix up small PowerPC comment fallout (use 'counter' as in register) Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19Merge branch 'for-rmk' of git://linux-arm.org/linux-2.6Russell King
2009-09-19Merge branch 'topstar-laptop' into releaseLen Brown
2009-09-19topstar-laptop: add new driver for hotkeys support on Topstar N01Herton Ronaldo Krzesinski
This adds Topstar Laptop Extras ACPI driver. It enables hotkeys functionality with Topstar N01 netbook. Besides hotkeys there are other functions exposed by its ACPI firmware, but for now only hotkeys reporting on Topstar N01 is supported. Topstar is a chinese manufacturer, its website can be currently reached at http://www.topstardigital.cn/ Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Reviewed-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'linus' into sfi-releaseLen Brown
Conflicts: arch/x86/kernel/setup.c drivers/acpi/power.c init/main.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-18MAINTAINERS: Add maintainer for AT24 and PCA9564/PCA9665Wolfram Sang
Add me as the maintainer for the i2c drivers I feel responsible for as I found patches going mainline I missed due to no Cc. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-18ARM: Update mailing list addressesRussell King
The old list has now been closed off; update the now invalid addresses. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-18Merge branch 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-scoreLinus Torvalds
* 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-score: (22 commits) score: add TIF_NOTIFY_RESUME define in asm/thread_info.h score: make init_thread_union align to THREAD_SIZE score: update files according to review comments. score: add old syscall support score: add MEMORY_START and MEMORY_SIZE define, to make the code clear score: update inconsistent declare after .c was changed score: remove unused code, add include files in .c score: clean up mm/init.c score: make irq.h definitions local score: cleanups: dead code, 0 as pointer, shadowed variables score: fix function prototypes score: add address space annotations score: add missing #includes score: move save arg5 and arg6 instruction in front of enable_irq score: add prototypes for wrapped syscalls score: remove init_mm score: add generic sys_call_table score: remove __{put,get}_user_unknown score: unset __ARCH_WANT_IPC_PARSE_VERSION score: update files according to review comments ...
2009-09-18Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (55 commits) regulator: Voltage count for AB3100 mfd: Convert WM8350 to use request_threaded_irq() mfd: Update MAINTAINERS patterns for WM831x mfd: Fix twl4030-power warnings regulator: AB3100 support rtc: AB3100 RTC support mfd: Fix ab3100-otp build failure mfd: OMAP: Board-specifc twl4030 DPS scripts for RX51 board mfd: Print warning for twl4030 out-of-order script loading mfd: Add support for TWL4030/5030 dynamic power switching mfd: AB3100 OTP readout regulator: Add Freescale MC13783 driver mfd: Add Freescale MC13783 driver mfd: AB3100 disable irq nosync mfd: AB3100 alter default setting mfd: AB3100 propagate error mfd: AB3100 accessor function cleanups rtc: Add support for RTCs on Wolfson WM831x devices regulator: get pcap data from the parent device input: PCAP2 misc input driver ...
2009-09-18Merge branch 'davinci-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci * 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (62 commits) DaVinci: DM646x - platform changes for vpif capture and display drivers davinci: DM355 - platform changes for vpfe capture davinci: DM644x platform changes for vpfe capture davinci: audio: move tlv320aic33 i2c setup into board files DaVinci: EDMA: Adding 2 new APIs for allocating/freeing PARAMs DaVinci: DM365: Adding entries for DM365 IRQ's DaVinci: DM355: Adding PINMUX entries for DM355 Display davinci: Handle pinmux conflict between mmc/sd and nor flash davinci: Add NOR flash support for da850/omap-l138 davinci: Add NAND flash support for DA850/OMAP-L138 davinci: Add MMC/SD support for da850/omap-l138 davinci: Add platform support for da850/omap-l138 GLCD davinci: Macro to convert GPIO signal to GPIO pin number davinci: Audio support for DA850/OMAP-L138 EVM davinci: Audio support for DA830 EVM davinci: Correct the number of GPIO pins for da850/omap-l138 davinci: Configure MDIO pins for EMAC DaVinci: DM365: Add Support for new Revision of silicon DaVinci: DM365: Fix Compilation issue due to PINMUX entry DaVinci: EDMA: Updating default queue handling ...
2009-09-18Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext3: Flush disk caches on fsync when needed ext3: Add locking to ext3_do_update_inode ext3: Fix possible deadlock between ext3_truncate() and ext3_get_blocks() jbd: Annotate transaction start also for journal_restart() jbd: Journal block numbers can ever be only 32-bit use unsigned int for them ext3: Update MAINTAINERS for ext3 and JBD JBD: round commit timer up to avoid uncommitted transaction
2009-09-17Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits) vsnprintf: remove duplicate comment of vsnprintf softirq: add BLOCK_IOPOLL to softirq_to_name oprofile: fix oprofile regression: select RING_BUFFER_ALLOW_SWAP tracing: switch function prints from %pf to %ps vsprintf: add %ps that is the same as %pS but is like %pf tracing: Fix minor bugs for __unregister_ftrace_function_probe tracing: remove notrace from __kprobes annotation tracing: optimize global_trace_clock cachelines MAINTAINERS: Update tracing tree details ftrace: document function and function graph implementation tracing: make testing syscall events a separate configuration tracing: remove some unused macros ftrace: add compile-time check on F_printk() tracing: fix F_printk() typos tracing: have TRACE_EVENT macro use __flags to not shadow parameter tracing: add static to generated TRACE_EVENT functions ring-buffer: typecast cmpxchg to fix PowerPC warning tracing: add filter event logic to special, mmiotrace and boot tracers tracing: remove trace_event_types.h tracing: use the new trace_entries.h to create format files ...
