path: root/MAINTAINERS
2014-06-30staging: wlags49_h2(5): remove driverKristina Martšenko
Remove the driver as it hasn't been cleaned up and it doesn't look like anyone is going to work on it anymore. Signed-off-by: Kristina Martšenko <kristina.martsenko@gmail.com> Cc: Henk de Groot <pe1dnn@amsat.org> Cc: David Kilroy <kilroyd@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-28staging: winbond: remove driverKristina Martšenko
The driver hasn't been cleaned up and nobody is working to do so, so remove it. Signed-off-by: Kristina Martšenko <kristina.martsenko@gmail.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-22Merge 3.16-rc2 into staging-nextGreg Kroah-Hartman
We want the staging fixes here as well.
2014-06-21Merge tag 'for-linus' of git://github.com/gxt/linuxLinus Torvalds
Pull UniCore32 bug fixes from Guan Xuetao: "This includes bugfixes to make unicore32 successfully build under defconfig, and some changes for allmodconfig (though not finished)" * tag 'for-linus' of git://github.com/gxt/linux: unicore32: Remove ARCH_HAS_CPUFREQ config option UniCore32: Change git tree location information in MAINTAINERS arch: unicore32: ksyms: export '__cpuc_coherent_kern_range' to avoid compiling failure arch: unicore32: ksyms: export 'pm_power_off' to avoid compiling failure. arch: unicore32: ksyms: export additional find_first_*() to avoid compiling failure arch:unicore32:mm: add devmem_is_allowed() to support STRICT_DEVMEM unicore32: include: asm: add missing ')' for PAGE_* macros in pgtable.h arch/unicore32/kernel/setup.c: add generic 'screen_info' to avoid compiling failure drivers: scsi: mvsas: fix compiling issue by adding 'MVS_' for "enum pci_interrupt_cause" arch: unicore32: kernel: ksyms: remove 'bswapsi2' and 'muldi3' to avoid compiling failure arch/unicore32/kernel/ksyms.c: remove 2 export symbols to avoid compiling failure drivers/rtc/rtc-puv3.c: remove "&dev->" for typo issue MIME-Version: 1.0 drivers/rtc/rtc-puv3.c: use dev_dbg() instead of dev_debug() for typo issue arch/unicore32/include/asm/io.h: add readl_relaxed() generic definition arch/unicore32/include/asm/ptrace.h: add generic definition for profile_pc() arch/unicore32/mm/alignment.c: include "asm/pgtable.h" to avoid compiling error arch/unicore32/kernel/clock.c: add readl() and writel() for 'PM_' macros arch/unicore32/kernel/module.c: use __vmalloc_node_range() instead of __vmalloc_area() arch/unicore32/kernel/ksyms.c: remove several undefined exported symbols
2014-06-21Merge tag 'char-misc-3.16-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char / misc driver fixes from Greg KH: "Here are 3 patches, one a revert of the UIO patch you objected to in 3.16-rc1 and that no one wanted to defend, a w1 driver bugfix, and a MAINTAINERS update for the vmware balloon driver. All of these, except for the MAINTAINERS update which just got added, have been in linux-next just fine" * tag 'char-misc-3.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: MAINTAINERS: add entry for VMware Balloon driver w1: mxc_w1: Fix incorrect "presence" status Revert "uio: fix vma io range check in mmap"
2014-06-20MAINTAINERS: add entry for VMware Balloon driverDmitry Torokhov
Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-20staging: crystalhd: remove driverKristina Martšenko
The driver hasn't had significant work done on it for a long time. Broadcom has EOLed the hardware and is no longer selling it. There are probably very few people still using it. So remove the driver. Signed-off-by: Kristina Martšenko <kristina.martsenko@gmail.com> Cc: Naren Sankar <nsankar@broadcom.com> Cc: Jarod Wilson <jarod@wilsonet.com> Cc: Scott Davilla <davilla@4pi.com> Cc: Manu Abraham <abraham.manu@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-20UniCore32: Change git tree location information in MAINTAINERSGuan Xuetao
UniCore32 git repo has moved to github. Branch 'unicore32' is used for prepared patches, and automatically merged to linux-next. Branch 'unicore32-working' is used for development. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
2014-06-18security: add Serge Hallyn as a maintainerJames Morris
Add Serge E. Hallyn <serge@hallyn.com> as a co-maintainer of the security subsystem, to avoid having a single point of failure in the development process. Signed-off-by: James Morris <james.l.morris@oracle.com>
2014-06-13MAINTAINERS: update cxgb4 maintainerDimitris Michailidis
Hari's been doing the patch submissions for a while now and he'll be taking over as maintainer. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-12Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm merge window pull request, changes all over the place, mostly normal levels of churn. Highlights: Core drm: More cleanups, fix race on connector/encoder naming, docs updates, object locking rework in prep for atomic modeset i915: mipi DSI support, valleyview power fixes, cursor size fixes, execlist refactoring, vblank improvements, userptr support, OOM handling improvements radeon: GPUVM tuning and large page size support, gart fixes, deep color HDMI support, HDMI audio cleanups nouveau: - displayport rework should fix lots of issues - initial gk20a support - gk110b support - gk208 fixes exynos: probe order fixes, HDMI changes, IPP consolidation msm: debugfs updates, misc fixes ast: ast2400 support, sync with UMS driver tegra: cleanups, hdmi + hw cursor for Tegra 124. panel: fixes existing panels add some new ones. ipuv3: moved from staging to drivers/gpu" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits) drm/nouveau/disp/dp: fix tmds passthrough on dp connector drm/nouveau/dp: probe dpcd to determine connectedness drm/nv50-: trigger update after all connectors disabled drm/nv50-: prepare for attaching a SOR to multiple heads drm/gf119-/disp: fix debug output on update failure drm/nouveau/disp/dp: make use of postcursor when its available drm/g94-/disp/dp: take max pullup value across all lanes drm/nouveau/bios/dp: parse lane postcursor data drm/nouveau/dp: fix support for dpms drm/nouveau: register a drm_dp_aux channel for each dp connector drm/g94-/disp: add method to power-off dp lanes drm/nouveau/disp/dp: maintain link in response to hpd signal drm/g94-/disp: bash and wait for something after changing lane power regs drm/nouveau/disp/dp: split link config/power into two steps drm/nv50/disp: train PIOR-attached DP from second supervisor drm/nouveau/disp/dp: make use of existing output data for link training drm/gf119/disp: start removing direct vbios parsing from supervisor drm/nv50/disp: start removing direct vbios parsing from supervisor drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal drm/nouveau/disp/dp: create subclass for dp outputs ...
2014-06-11net: filter: add test_bpf module under MAINTAINERS' networking sectionDaniel Borkmann
Add lib/test_bpf.c entry to maintainers file under networking. All changes were posted via netdev for review, so make sure other people Cc it as well when they call get_maintainer.pl. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-10Merge tag 'mmc-updates-for-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC update from Chris Ball: "MMC highlights for 3.16: Core: - support HS400 mode of eMMC 5.0, via DT bindings mmc-hs400-1_{2,8}v - if card init at 3.3v doesn't work, try 1.8v and 1.2v too Drivers: - moxart: New driver for MOXA ART SoCs - rtsx_usb_sdmmc: New driver for Realtek USB card readers - sdhci: Large rework around IRQ/regulator handling, remove card_tasklet - sdhci-pci-o2micro: Add SeaBird SeaEagle SD3 support - sunxi: New driver for Allwinner sunxi SoCs - usdhi6rol0: New driver for Renesas SD/SDIO controller" * tag 'mmc-updates-for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (95 commits) mmc: sdhci-s3c: use mmc_of_parse and remove the card_tasklet mmc: add a driver for the Renesas usdhi6rol0 SD/SDIO host controller mmc: sdhci-of-esdhc: Fixup compile error mmc: tegra: fix reporting of base clock frequency mmc: tegra: disable UHS modes mmc: sdhci-dove: use mmc_of_parse() and remove card_tasklet CD handler MAINTAINERS: mmc: Add path to git tree mmc: dove: fix missing MACH_DOVE dependency mmc: sdhci: SD tuning is broken for some controllers mmc: sdhci-esdhc-imx: fix mmc ddr mode regression issue mmc: sdhci-pci-o2micro: Add SeaBird SeaEagle SD3 support mmc: omap_hsmmc: split omap-dma header file mmc: omap_hsmmc: fix cmd23 multiblock read/write mmc: omap_hsmmc: use devm_ioremap_resource mmc: omap_hsmmc: use devm_request_threaded_irq mmc: omap_hsmmc: use devm_request_irq mmc: omap_hsmmc: use devm_clk_get mmc: sunxi: Add driver for SD/MMC hosts found on Allwinner sunxi SoCs mmc: wmt-sdmmc: Use GFP_KERNEL instead of hard-coded value mmc: omap: Use DIV_ROUND_UP instead of open coded ...
2014-06-09Merge tag 'for-f2fs-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "In this round, there is no special interesting feature, but we've investigated a couple of tuning points with respect to the I/O flow. Several major bug fixes and a bunch of clean-ups also have been made. This patch-set includes the following major enhancement patches: - enhance wait_on_page_writeback - support SEEK_DATA and SEEK_HOLE - enhance readahead flows - enhance IO flushes - support fiemap - add some tracepoints The other bug fixes are as follows: - fix to support a large volume > 2TB correctly - recovery bug fix wrt fallocated space - fix recursive lock on xattr operations - fix some cases on the remount flow And, there are a bunch of cleanups" * tag 'for-f2fs-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (52 commits) f2fs: support f2fs_fiemap f2fs: avoid not to call remove_dirty_inode f2fs: recover fallocated space f2fs: fix to recover data written by dio f2fs: large volume support f2fs: avoid crash when trace f2fs_submit_page_mbio event in ra_sum_pages f2fs: avoid overflow when large directory feathure is enabled f2fs: fix recursive lock by f2fs_setxattr MAINTAINERS: add a co-maintainer from samsung for F2FS MAINTAINERS: change the email address for f2fs f2fs: use inode_init_owner() to simplify codes f2fs: avoid to use slab memory in f2fs_issue_flush for efficiency f2fs: add a tracepoint for f2fs_read_data_page f2fs: add a tracepoint for f2fs_write_{meta,node,data}_pages f2fs: add a tracepoint for f2fs_write_{meta,node,data}_page f2fs: add a tracepoint for f2fs_write_end f2fs: add a tracepoint for f2fs_write_begin f2fs: fix checkpatch warning f2fs: deactivate inode page if the inode is evicted f2fs: decrease the lock granularity during write_begin ...
2014-06-09Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI updates from James Bottomley: "This patch consists of the usual driver updates (qla2xxx, qla4xxx, lpfc, be2iscsi, fnic, ufs, NCR5380) The NCR5380 is the addition to maintained status of a long neglected driver for older hardware. In addition there are a lot of minor fixes and cleanups and some more updates to make scsi mq ready" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (130 commits) include/scsi/osd_protocol.h: remove unnecessary __constant mvsas: Recognise device/subsystem 9485/9485 as 88SE9485 Revert "be2iscsi: Fix processing cqe for cxn whose endpoint is freed" mptfusion: fix msgContext in mptctl_hp_hostinfo acornscsi: remove linked command support scsi/NCR5380: dprintk macro fusion: Remove use of DEF_SCSI_QCMD fusion: Add free msg frames to the head, not tail of list mpt2sas: Add free smids to the head, not tail of list mpt2sas: Remove use of DEF_SCSI_QCMD mpt2sas: Remove uses of serial_number mpt3sas: Remove use of DEF_SCSI_QCMD mpt3sas: Remove uses of serial_number qla2xxx: Use kmemdup instead of kmalloc + memcpy qla4xxx: Use kmemdup instead of kmalloc + memcpy qla2xxx: fix incorrect debug printk be2iscsi: Bump the driver version be2iscsi: Fix processing cqe for cxn whose endpoint is freed be2iscsi: Fix destroy MCC-CQ before MCC-EQ is destroyed be2iscsi: Fix memory corruption in MBX path ...
2014-06-09Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: - three fixes for 3.15 that didn't make it in time - limited Octeon 3 support. - paravirtualization support - improvment to platform support for Netlogix SOCs. - add support for powering down the Malta eval board in software - add many instructions to the in-kernel microassembler. - add support for the BPF JIT. - minor cleanups of the BCM47xx code. - large cleanup of math emu code resulting in significant code size reduction, better readability of the code and more accurate emulation. - improvments to the MIPS CPS code. - support C3 power status for the R4k count/compare clock device. - improvments to the GIO support for older SGI workstations. - increase number of supported CPUs to 256; this can be reached on certain embedded multithreaded ccNUMA configurations. - various small cleanups, updates and fixes * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (173 commits) MIPS: IP22/IP28: Improve GIO support MIPS: Octeon: Add twsi interrupt initialization for OCTEON 3XXX, 5XXX, 63XX DEC: Document the R4k MB ASIC mini interrupt controller DEC: Add self as the maintainer MIPS: Add microMIPS MSA support. MIPS: Replace calls to obsolete strict_strto call with kstrto* equivalents. MIPS: Replace obsolete strict_strto call with kstrto MIPS: BFP: Simplify code slightly. MIPS: Call find_vma with the mmap_sem held MIPS: Fix 'write_msa_##' inline macro. MIPS: Fix MSA toolchain support detection. mips: Update the email address of Geert Uytterhoeven MIPS: Add minimal defconfig for mips_paravirt MIPS: Enable build for new system 'paravirt' MIPS: paravirt: Add pci controller for virtio MIPS: Add code for new system 'paravirt' MIPS: Add functions for hypervisor call MIPS: OCTEON: Add OCTEON3 to __get_cpu_type MIPS: Add function get_ebase_cpunum MIPS: Add minimal support for OCTEON3 to c-r4k.c ...
2014-06-09Merge tag 'trace-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "Lots of tweaks, small fixes, optimizations, and some helper functions to help out the rest of the kernel to ease their use of trace events. The big change for this release is the allowing of other tracers, such as the latency tracers, to be used in the trace instances and allow for function or function graph tracing to be in the top level simultaneously" * tag 'trace-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (44 commits) tracing: Fix memory leak on instance deletion tracing: Fix leak of ring buffer data when new instances creation fails tracing/kprobes: Avoid self tests if tracing is disabled on boot up tracing: Return error if ftrace_trace_arrays list is empty tracing: Only calculate stats of tracepoint benchmarks for 2^32 times tracing: Convert stddev into u64 in tracepoint benchmark tracing: Introduce saved_cmdlines_size file tracing: Add __get_dynamic_array_len() macro for trace events tracing: Remove unused variable in trace_benchmark tracing: Eliminate double free on failure of allocation on boot up ftrace/x86: Call text_ip_addr() instead of the duplicated code tracing: Print max callstack on stacktrace bug tracing: Move locking of trace_cmdline_lock into start/stop seq calls tracing: Try again for saved cmdline if failed due to locking tracing: Have saved_cmdlines use the seq_read infrastructure tracing: Add tracepoint benchmark tracepoint tracing: Print nasty banner when trace_printk() is in use tracing: Add funcgraph_tail option to print function name after closing braces tracing: Eliminate duplicate TRACE_GRAPH_PRINT_xx defines tracing: Add __bitmask() macro to trace events to cpumasks and other bitmasks ...
2014-06-09Merge branch 'for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot of activities on cgroup side. Heavy restructuring including locking simplification took place to improve the code base and enable implementation of the unified hierarchy, which currently exists behind a __DEVEL__ mount option. The core support is mostly complete but individual controllers need further work. To explain the design and rationales of the the unified hierarchy Documentation/cgroups/unified-hierarchy.txt is added. Another notable change is css (cgroup_subsys_state - what each controller uses to identify and interact with a cgroup) iteration update. This is part of continuing updates on css object lifetime and visibility. cgroup started with reference count draining on removal way back and is now reaching a point where csses behave and are iterated like normal refcnted objects albeit with some complexities to allow distinguishing the state where they're being deleted. The css iteration update isn't taken advantage of yet but is planned to be used to simplify memcg significantly" * 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (77 commits) cgroup: disallow disabled controllers on the default hierarchy cgroup: don't destroy the default root cgroup: disallow debug controller on the default hierarchy cgroup: clean up MAINTAINERS entries cgroup: implement css_tryget() device_cgroup: use css_has_online_children() instead of has_children() cgroup: convert cgroup_has_live_children() into css_has_online_children() cgroup: use CSS_ONLINE instead of CGRP_DEAD cgroup: iterate cgroup_subsys_states directly cgroup: introduce CSS_RELEASED and reduce css iteration fallback window cgroup: move cgroup->serial_nr into cgroup_subsys_state cgroup: link all cgroup_subsys_states in their sibling lists cgroup: move cgroup->sibling and ->children into cgroup_subsys_state cgroup: remove cgroup->parent device_cgroup: remove direct access to cgroup->children memcg: update memcg_has_children() to use css_next_child() memcg: remove tasks/children test from mem_cgroup_force_empty() cgroup: remove css_parent() cgroup: skip refcnting on normal root csses and cgrp_dfl_root self css cgroup: use cgroup->self.refcnt for cgroup refcnting ...
2014-06-08Merge branch 'next' (accumulated 3.16 merge window patches) into masterLinus Torvalds
Now that 3.15 is released, this merges the 'next' branch into 'master', bringing us to the normal situation where my 'master' branch is the merge window. * accumulated work in next: (6809 commits) ufs: sb mutex merge + mutex_destroy powerpc: update comments for generic idle conversion cris: update comments for generic idle conversion idle: remove cpu_idle() forward declarations nbd: zero from and len fields in NBD_CMD_DISCONNECT. mm: convert some level-less printks to pr_* MAINTAINERS: adi-buildroot-devel is moderated MAINTAINERS: add linux-api for review of API/ABI changes mm/kmemleak-test.c: use pr_fmt for logging fs/dlm/debug_fs.c: replace seq_printf by seq_puts fs/dlm/lockspace.c: convert simple_str to kstr fs/dlm/config.c: convert simple_str to kstr mm: mark remap_file_pages() syscall as deprecated mm: memcontrol: remove unnecessary memcg argument from soft limit functions mm: memcontrol: clean up memcg zoneinfo lookup mm/memblock.c: call kmemleak directly from memblock_(alloc|free) mm/mempool.c: update the kmemleak stack trace for mempool allocations lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations mm: introduce kmemleak_update_trace() mm/kmemleak.c: use %u to print ->checksum ...
2014-06-07Merge tag 'clk-for-linus-3.16' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux into next Pull clock framework updates from Mike Turquette: "The clock framework changes for 3.16 are pretty typical: mostly clock driver additions and fixes. There are additions to the clock core code for some of the basic types (e.g. the common divider type has some fixes and featured added to it). One minor annoyance is a last-minute dependency that wasn't handled quite right. Commit ba0fae3b06a6 ("clk: berlin: add core clock driver for BG2/BG2CD") in this pull request depends on include/dt-bindings/clock/berlin2.h, which is already in your tree via the arm-soc pull request. Building for the berlin platform will break when the clk tree is built on it's own, but merged into your master branch everything should be fine" * tag 'clk-for-linus-3.16' of git://git.linaro.org/people/mike.turquette/linux: (75 commits) mmc: sunxi: Add driver for SD/MMC hosts found on Allwinner sunxi SoCs clk: export __clk_round_rate for providers clk: versatile: free icst on error return clk: qcom: Return error pointers for unimplemented clocks clk: qcom: Support msm8974pro global clock control hardware clk: qcom: Properly support display clocks on msm8974 clk: qcom: Support display RCG clocks clk: qcom: Return highest rate when round_rate() exceeds plan clk: qcom: Fix mmcc-8974's PLL configurations clk: qcom: Fix clk_rcg2_is_enabled() check clk: berlin: add core clock driver for BG2Q clk: berlin: add core clock driver for BG2/BG2CD clk: berlin: add driver for BG2x complex divider cells clk: berlin: add driver for BG2x simple PLLs clk: berlin: add driver for BG2x audio/video PLL clk: st: Terminate of match table clk/exynos4: Fix compilation warning ARM: shmobile: r8a7779: Add clock index macros for DT sources clk: divider: Fix overflow in clk_divider_bestdiv clk: u300: Terminate of match table ...
2014-06-06MAINTAINERS: adi-buildroot-devel is moderatedRichard Weinberger
Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06MAINTAINERS: add linux-api for review of API/ABI changesJosh Triplett
This makes it more likely that patch submitters will CC API/ABI changes to the linux-api list, and tools like get_maintainer.pl will do so automatically. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Michael Kerrisk <mtk.man-pages@gmail.com> Cc: Joe Perches <joe@perches.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-05amd-xgbe: Maintainer informationLendacky, Thomas
This patch adds the maintainer information for the AMD 10GbE platform driver. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-05Merge commit '9e9a928eed8796a0a1aaed7e0b676db86ba84594' into drm-nextDave Airlie
Merge drm-fixes into drm-next. Both i915 and radeon need this done for later patches. Conflicts: drivers/gpu/drm/drm_crtc_helper.c drivers/gpu/drm/i915/i915_drv.h drivers/gpu/drm/i915/i915_gem.c drivers/gpu/drm/i915/i915_gem_execbuffer.c drivers/gpu/drm/i915/i915_gem_gtt.c
2014-06-04Merge branch 'akpm' (patchbomb from Andrew) into nextLinus Torvalds
Merge misc updates from Andrew Morton: - a few fixes for 3.16. Cc'ed to stable so they'll get there somehow. - various misc fixes and cleanups - most of the ocfs2 queue. Review is slow... - most of MM. The MM queue is pretty huge this time, but not much in the way of feature work. - some tweaks under kernel/ - printk maintenance work - updates to lib/ - checkpatch updates - tweaks to init/ * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (276 commits) fs/autofs4/dev-ioctl.c: add __init to autofs_dev_ioctl_init fs/ncpfs/getopt.c: replace simple_strtoul by kstrtoul init/main.c: remove an ifdef kthreads: kill CLONE_KERNEL, change kernel_thread(kernel_init) to avoid CLONE_SIGHAND init/main.c: add initcall_blacklist kernel parameter init/main.c: don't use pr_debug() fs/binfmt_flat.c: make old_reloc() static fs/binfmt_elf.c: fix bool assignements fs/efs: convert printk(KERN_DEBUG to pr_debug fs/efs: add pr_fmt / use __func__ fs/efs: convert printk to pr_foo() scripts/checkpatch.pl: device_initcall is not the only __initcall substitute checkpatch: check stable email address checkpatch: warn on unnecessary void function return statements checkpatch: prefer kstrto<foo> to sscanf(buf, "%<lhuidx>", &bar); checkpatch: add warning for kmalloc/kzalloc with multiply checkpatch: warn on #defines ending in semicolon checkpatch: make --strict a default for files in drivers/net and net/ checkpatch: always warn on missing blank line after variable declaration block checkpatch: fix wildcard DT compatible string checking ...
2014-06-04MAINTAINERS: pass on hwpoison maintainership to Naoya HoriguchiAndi Kleen
Horiguchi-san has done most of the work on hwpoison in the last years and he also does most of the reviewing. So I'm passing on the hwpoison maintainership to him. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04MAINTAINERS: add Joe as the get_maintainer.pl maintainerJoe Perches
Might as well be the get_maintainer maintainer... Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media into next Pull media updates from Mauro Carvalho Chehab: "This contains: - a new frontend/tuner driver set for si2168 and sa2157 - Videobuf 2 core now supports DVB too - A new gspca sub-driver (dtcs033) - saa7134 is now converted to use videobuf2 - add support for 4K timings - several other driver fixes and improvements PS. This pull request is shorter than usual, partly because I have some other patches on topic branches that I'll be sending you later this week" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (286 commits) [media] au0828-dvb: restore its permission to 644 [media] xc5000: delay tuner sleep to 5 seconds [media] xc5000: Don't use whitespace before tabs [media] xc5000: fix CamelCase [media] xc5000: Don't wrap msleep() [media] xc5000: get rid of positive error codes [media] au0828: reset streaming when a new frequency is set [media] au0828: Improve debug messages for urb_completion [media] au0828: Cancel stream-restart operation if frontend is disconnected [media] dib0700: fix RC support on Hauppauge Nova-TD [media] USB: as102_usb_drv.c: Remove useless return variables [media] v4l: Fix documentation of V4L2_PIX_FMT_H264_MVC and VP8 pixel formats [media] m5mols: Replace missing header [media] staging: lirc: Fix sparse warnings [media] fix mceusb endpoint type identification/handling [media] az6027: Added the PID for a new revision of the Elgato EyeTV Sat DVB-S Tuner [media] DocBook media: fix typo [media] adv7604: Add missing include to linux/types.h [media] v4l: Validate fields in the core code for subdev EDID ioctls [media] v4l: Add support for DV timings ioctls on subdev nodes ...
2014-06-04Merge branch '3.15-fixes' into mips-for-linux-nextRalf Baechle
2014-06-04DEC: Add self as the maintainerMaciej W. Rozycki
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6707/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-04Merge tag 'sound-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound into next Pull sound updates from Takashi Iwai: "At this time, majority of changes come from ASoC world while we got a few new drivers in other places for FireWire and USB. There have been lots of ASoC core cleanups / refactoring, but very little visible to external users. ASoC: - Support for specifying aux CODECs in DT - Removal of the deprecated mux and enum macros - More moves towards full componentisation - Removal of some unused I/O code - Lots of cleanups, fixes and enhancements to the davinci, Freescale, Haswell and Realtek drivers - Several drivers exposed directly in Kconfig for use with simple-card - GPIO descriptor support for jacks - More updates and fixes to the Freescale SSI, Intel and rsnd drivers - New drivers for Cirrus CS42L56, Realtek RT5639, RT5642 and RT5651 and ST STA350, Analog Devices ADAU1361, ADAU1381, ADAU1761 and ADAU1781, and Realtek RT5677 HD-audio: - Clean up Dell headset quirks - Noise fixes for Dell and Sony laptops - Thinkpad T440 dock fix - Realtek codec updates (ALC293,ALC233,ALC3235) - Tegra HD-audio HDMI support FireWire-audio: - FireWire audio stack enhancement (AMDTP, MIDI), support for incoming isochronous stream and duplex streams with timestamp synchronization - BeBoB-based devices support - Fireworks-based device support USB-audio: - Behringer BCD2000 USB device support Misc: - Clean up of a few old drivers, atmel, fm801, etc" * tag 'sound-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (480 commits) ASoC: Fix wrong argument for card remove callbacks ASoC: free jack GPIOs before the sound card is freed ALSA: firewire-lib: Remove a comment about restriction of asynchronous operation ASoC: cache: Fix error code when not using ASoC level cache ALSA: hda/realtek - Fix COEF widget NID for ALC260 replacer fixup ALSA: hda/realtek - Correction of fixup codes for PB V7900 laptop ALSA: firewire-lib: Use IEC 61883-6 compliant labels for Raw Audio data ASoC: add RT5677 CODEC driver ASoC: intel: The Baytrail/MAX98090 driver depends on I2C ASoC: rt5640: Add the function "get_clk_info" to RL6231 shared support ASoC: rt5640: Add the function of the PLL clock calculation to RL6231 shared support ASoC: rt5640: Add RL6231 class device shared support for RT5640, RT5645 and RT5651 ASoC: cache: Fix possible ZERO_SIZE_PTR pointer dereferencing error. ASoC: Add helper functions to cast from DAPM context to CODEC/platform ALSA: bebob: sizeof() vs ARRAY_SIZE() typo ASoC: wm9713: correct mono out PGA sources ALSA: synth: emux: soundfont.c: Cleaning up memory leak ASoC: fsl: Remove dependencies of boards for SND_SOC_EUKREA_TLV320 ASoC: fsl-ssi: Use regmap ASoC: fsl-ssi: reorder and document fsl_ssi_private ...
2014-06-04Merge tag 'pm+acpi-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm into next Pull ACPI and power management updates from Rafael Wysocki: "ACPICA is the leader this time (63 commits), followed by cpufreq (28 commits), devfreq (15 commits), system suspend/hibernation (12 commits), ACPI video and ACPI device enumeration (10 commits each). We have no major new features this time, but there are a few significant changes of how things work. The most visible one will probably be that we are now going to create platform devices rather than PNP devices by default for ACPI device objects with _HID. That was long overdue and will be really necessary to be able to use the same drivers for the same hardware blocks on ACPI and DT-based systems going forward. We're not expecting fallout from this one (as usual), but it's something to watch nevertheless. The second change having a chance to be visible is that ACPI video will now default to using native backlight rather than the ACPI backlight interface which should generally help systems with broken Win8 BIOSes. We're hoping that all problems with the native backlight handling that we had previously have been addressed and we are in a good enough shape to flip the default, but this change should be easy enough to revert if need be. In addition to that, the system suspend core has a new mechanism to allow runtime-suspended devices to stay suspended throughout system suspend/resume transitions if some extra conditions are met (generally, they are related to coordination within device hierarchy). However, enabling this feature requires cooperation from the bus type layer and for now it has only been implemented for the ACPI PM domain (used by ACPI-enumerated platform devices mostly today). Also, the acpidump utility that was previously shipped as a separate tool will now be provided by the upstream ACPICA along with the rest of ACPICA code, which will allow it to be more up to date and better supported, and we have one new cpuidle driver (ARM clps711x). The rest is improvements related to certain specific use cases, cleanups and fixes all over the place. Specifics: - ACPICA update to upstream version 20140424. That includes a number of fixes and improvements related to things like GPE handling, table loading, headers, memory mapping and unmapping, DSDT/SSDT overriding, and the Unload() operator. The acpidump utility from upstream ACPICA is included too. From Bob Moore, Lv Zheng, David Box, David Binderman, and Colin Ian King. - Fixes and cleanups related to ACPI video and backlight interfaces from Hans de Goede. That includes blacklist entries for some new machines and using native backlight by default. - ACPI device enumeration changes to create platform devices rather than PNP devices for ACPI device objects with _HID by default. PNP devices will still be created for the ACPI device object with device IDs corresponding to real PNP devices, so that change should not break things left and right, and we're expecting to see more and more ACPI-enumerated platform devices in the future. From Zhang Rui and Rafael J Wysocki. - Updates for the ACPI LPSS (Low-Power Subsystem) driver allowing it to handle system suspend/resume on Asus T100 correctly. From Heikki Krogerus and Rafael J Wysocki. - PM core update introducing a mechanism to allow runtime-suspended devices to stay suspended over system suspend/resume transitions if certain additional conditions related to coordination within device hierarchy are met. Related PM documentation update and ACPI PM domain support for the new feature. From Rafael J Wysocki. - Fixes and improvements related to the "freeze" sleep state. They affect several places including cpuidle, PM core, ACPI core, and the ACPI battery driver. From Rafael J Wysocki and Zhang Rui. - Miscellaneous fixes and updates of the ACPI core from Aaron Lu, Bjørn Mork, Hanjun Guo, Lan Tianyu, and Rafael J Wysocki. - Fixes and cleanups for the ACPI processor and ACPI PAD (Processor Aggregator Device) drivers from Baoquan He, Manuel Schölling, Tony Camuso, and Toshi Kani. - System suspend/resume optimization in the ACPI battery driver from Lan Tianyu. - OPP (Operating Performance Points) subsystem updates from Chander Kashyap, Mark Brown, and Nishanth Menon. - cpufreq core fixes, updates and cleanups from Srivatsa S Bhat, Stratos Karafotis, and Viresh Kumar. - Updates, fixes and cleanups for the Tegra, powernow-k8, imx6q, s5pv210, nforce2, and powernv cpufreq drivers from Brian Norris, Jingoo Han, Paul Bolle, Philipp Zabel, Stratos Karafotis, and Viresh Kumar. - intel_pstate driver fixes and cleanups from Dirk Brandewie, Doug Smythies, and Stratos Karafotis. - Enabling the big.LITTLE cpufreq driver on arm64 from Mark Brown. - Fix for the cpuidle menu governor from Chander Kashyap. - New ARM clps711x cpuidle driver from Alexander Shiyan. - Hibernate core fixes and cleanups from Chen Gang, Dan Carpenter, Fabian Frederick, Pali Rohár, and Sebastian Capella. - Intel RAPL (Running Average Power Limit) driver updates from Jacob Pan. - PNP subsystem updates from Bjorn Helgaas and Fabian Frederick. - devfreq core updates from Chanwoo Choi and Paul Bolle. - devfreq updates for exynos4 and exynos5 from Chanwoo Choi and Bartlomiej Zolnierkiewicz. - turbostat tool fix from Jean Delvare. - cpupower tool updates from Prarit Bhargava, Ramkumar Ramachandra and Thomas Renninger. - New ACPI ec_access.c tool for poking at the EC in a safe way from Thomas Renninger" * tag 'pm+acpi-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (187 commits) ACPICA: Namespace: Remove _PRP method support. intel_pstate: Improve initial busy calculation intel_pstate: add sample time scaling intel_pstate: Correct rounding in busy calculation intel_pstate: Remove C0 tracking PM / hibernate: fixed typo in comment ACPI: Fix x86 regression related to early mapping size limitation ACPICA: Tables: Add mechanism to control early table checksum verification. ACPI / scan: use platform bus type by default for _HID enumeration ACPI / scan: always register ACPI LPSS scan handler ACPI / scan: always register memory hotplug scan handler ACPI / scan: always register container scan handler ACPI / scan: Change the meaning of missing .attach() in scan handlers ACPI / scan: introduce platform_id device PNP type flag ACPI / scan: drop unsupported serial IDs from PNP ACPI scan handler ID list ACPI / scan: drop IDs that do not comply with the ACPI PNP ID rule ACPI / PNP: use device ID list for PNPACPI device enumeration ACPI / scan: .match() callback for ACPI scan handlers ACPI / battery: wakeup the system only when necessary power_supply: allow power supply devices registered w/o wakeup source ...
2014-06-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: include/net/inetpeer.h net/ipv6/output_core.c Changes in net were fixing bugs in code removed in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-03Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: (28 commits) cpufreq: handle calls to ->target_index() in separate routine cpufreq: s5pv210: drop check for CONFIG_PM_VERBOSE cpufreq: intel_pstate: Remove unused member name of cpudata cpufreq: Break out early when frequency equals target_freq cpufreq: Tegra: drop wrapper around tegra_update_cpu_speed() cpufreq: imx6q: Remove unused include cpufreq: imx6q: Drop devm_clk/regulator_get usage cpufreq: powernow-k8: Suppress checkpatch warnings cpufreq: powernv: make local function static cpufreq: Enable big.LITTLE cpufreq driver on arm64 cpufreq: nforce2: remove DEFINE_PCI_DEVICE_TABLE macro intel_pstate: Add CPU IDs for Broadwell processors cpufreq: Fix build error on some platforms that use cpufreq_for_each_* PM / OPP: Move cpufreq specific OPP functions out of generic OPP library PM / OPP: Remove cpufreq wrapper dependency on internal data organization cpufreq: Catch double invocations of cpufreq_freq_transition_begin/end intel_pstate: Remove sample parameter in intel_pstate_calc_busy cpufreq: Kconfig: Fix spelling errors cpufreq: Make linux-pm@vger.kernel.org official mailing list cpufreq: exynos: Use dev_err/info function instead of pr_err/info ...
2014-06-03Merge branches 'pnp', 'powercap', 'pm-runtime' and 'pm-opp'Rafael J. Wysocki
* pnp: MAINTAINERS: Remove Bjorn Helgaas as PNP maintainer PNP / resources: remove positive test on unsigned values * powercap: powercap / RAPL: add new CPU IDs powercap / RAPL: further relax energy counter checks * pm-runtime: PM / runtime: Update documentation to reflect the current code flow * pm-opp: PM / OPP: discard duplicate OPPs PM / OPP: Make OPP invisible to users in Kconfig PM / OPP: fix incorrect OPP count handling in of_init_opp_table
2014-06-03Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging into next Pull hwmon updates from Guenter Roeck: "New driver for NCT6683D New chip support to existing drivers: - add support for STTS2004 and AT30TSE004 to jc42 driver - add support for EMC1402/EMC1412/EMC1422 to emc1403 driver Other notable changes: - document hwmon kernel API - convert jc42, lm70, lm75, lm77, lm83, lm92, max1619, tmp421, and tmp102 drivers to use new hwmon API functions - replace function macros in lm80, lm92, and jc42 drivers with real code - convert emc1403 driver to use regmap, add support for additional attributes, and add device IDs for EMC1412, EMC1413, and EMC1414 - various additional cleanup and minor bug fixes in several drivers" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (60 commits) hwmon: (nct6775) Fix probe unwind paths to properly unregister platform devices hwmon: (nct6683) Fix probe unwind paths to properly unregister platform devices hwmon: (ultra45_env) Introduce managed version of kzalloc hwmon: Driver for NCT6683D hwmon: (lm80) Rearrange code to avoid forward declarations hwmon: (lm80) Convert fan display function macros into functions hwmon: (lm80) Convert voltage display function macros into functions hwmon: (lm80) Convert temperature display function macros into functions hwmon: (lm80) Normalize all temperature values to 16 bit hwmon: (lm80) Simplify TEMP_FROM_REG hwmon: (lm83) Convert to use devm_hwmon_device_register_with_groups hwmon: (lm83) Rearange code to avoid forward declarations hwmon: (lm83) Drop FSF address hwmon: (max1619) Convert to use devm_hwmon_device_register_with_groups hwmon: (max1619) Drop function macros hwmon: (max1619) Rearrange code to avoid forward declarations hwmon: (max1619) Drop FSF address hwmon: (max1619) Fix critical alarm display hwmon: (jc42) Add support for STTS2004 and AT30TSE004 hwmon: (jc42) Convert function macros into functions ...
2014-06-03Merge tag 'staging-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging into next Pull staging driver updates from Greg KH: "Here is the big staging driver pull request for 3.16-rc1. Lots of stuff here, tons of cleanup patches, a few new drivers, and some removed as well, but I think we are still adding a few thousand more lines than we remove, due to the new drivers being bigger than the ones deleted. One notible bit of work did stand out, Jes Sorensen has gone on a tear, fixing up a wireless driver to be "more sane" than it originally was from the vendor, with over 500 patches merged here. Good stuff, and a number of users laptops are better off for it. All of this has been in linux-next for a while" * tag 'staging-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1703 commits) staging: skein: fix sparse warning for static declarations staging/mt29f_spinand: coding style fixes staging: silicom: fix sparse warning for static variable staging: lustre: Fix coding style staging: android: binder.c: Use more appropriate functions for euid retrieval staging: lustre: fix integer as NULL pointer warnings Revert "staging: dgap: remove unneeded kfree() in dgap_tty_register_ports()" Staging: rtl8192u: r8192U_wx.c Fixed a misplaced brace staging: ion: shrink highmem pages on kswapd staging: ion: use compound pages on high order pages for system heap staging: ion: remove struct ion_page_pool_item staging: ion: simplify ion_page_pool_total() staging: ion: tidy up a bit staging: rtl8723au: Remove redundant casting in usb_ops_linux.c staging: rtl8723au: Remove redundant casting in rtl8723a_hal_init.c staging: rtl8723au: Remove redundant casting in rtw_xmit.c staging: rtl8723au: Remove redundant casting in rtw_wlan_util.c staging: rtl8723au: Remove redundant casting in rtw_sta_mgt.c staging: rtl8723au: Remove redundant casting in rtw_recv.c staging: rtl8723au: Remove redundant casting in rtw_mlme.c ...
2014-06-03Merge tag 'char-misc-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc into next Pull char/misc driver patches from Greg KH: "Here is the big char / misc driver update for 3.16-rc1. Lots of different driver updates for a variety of different drivers and minor driver subsystems. All have been in linux-next with no reported issues" * tag 'char-misc-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (79 commits) hv: use correct order when freeing monitor_pages spmi: of: fixup generic SPMI devicetree binding example applicom: dereferencing NULL on error path misc: genwqe: fix uninitialized return value in genwqe_free_sync_sgl() miscdevice.h: Simple syntax fix to make pointers consistent. MAINTAINERS: Add miscdevice.h to file list for char/misc drivers. mcb: Add support for shared PCI IRQs drivers: Remove duplicate conditionally included subdirs misc: atmel_pwm: only build for supported platforms mei: me: move probe quirk to cfg structure mei: add per device configuration mei: me: read H_CSR after asserting reset mei: me: drop harmful wait optimization mei: me: fix hw ready reset flow mei: fix memory leak of mei_clients array uio: fix vma io range check in mmap drivers: uio_dmem_genirq: Fix memory leak in uio_dmem_genirq_probe() w1: do not unlock unheld list_mutex in __w1_remove_master_device() w1: optional bundling of netlink kernel replies connector: allow multiple messages to be sent in one packet ...
2014-06-03Merge back earlier cpufreq material.Rafael J. Wysocki
Conflicts: arch/mips/loongson/lemote-2f/clock.c drivers/cpufreq/intel_pstate.c
2014-06-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Unbreak zebra and other netlink apps, from Eric W Biederman. 2) Some new qmi_wwan device IDs, from Aleksander Morgado. 3) Fix info leak in DCB netlink handler of qlcnic driver, from Dan Carpenter. 4) inet_getid() and ipv6_select_ident() do not generate monotonically increasing ID numbers, fix from Eric Dumazet. 5) Fix memory leak in __sk_prepare_filter(), from Leon Yu. 6) Netlink leftover bytes warning message is user triggerable, rate limit it. From Michal Schmidt. 7) Fix non-linear SKB panic in ipvs, from Peter Christensen. 8) Congestion window undo needs to be performed even if only never retransmitted data is SACK'd, fix from Yuching Cheng. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (24 commits) net: filter: fix possible memory leak in __sk_prepare_filter() net: ec_bhf: Add runtime dependencies tcp: fix cwnd undo on DSACK in F-RTO netlink: Only check file credentials for implicit destinations ipheth: Add support for iPad 2 and iPad 3 team: fix mtu setting net: fix inet_getid() and ipv6_select_ident() bugs net: qmi_wwan: interface #11 in Sierra Wireless MC73xx is not QMI net: qmi_wwan: add additional Sierra Wireless QMI devices bridge: Prevent insertion of FDB entry with disallowed vlan netlink: rate-limit leftover bytes warning and print process name bridge: notify user space after fdb update net: qmi_wwan: add Netgear AirCard 341U net: fix wrong mac_len calculation for vlans batman-adv: fix NULL pointer dereferences net/mlx4_core: Reset RoCE VF gids when guest driver goes down emac: aggregation of v1-2 PLB errors for IER register emac: add missing support of 10mbit in emac/rgmii can: only rename enabled led triggers when changing the netdev name ipvs: Fix panic due to non-linear skb ...
2014-06-02Merge tag 'soc-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull part one of ARM SoC updates from Olof Johansson: "A quite large set of SoC updates this cycle. In no particular order: - Multi-cluster power management for Samsung Exynos, adding support for big.LITTLE CPU switching on EXYNOS5 - SMP support for Marvell Armada 375 and 38x - SMP rework on Allwinner A31 - Xilinx Zynq support for SOC_BUS, big endian - Marvell orion5x platform cleanup, modernizing the implementation and moving to DT. - _Finally_ moving Samsung Exynos over to support MULTIPLATFORM, so that their platform can be enabled in the same kernel binary as most of the other v7 platforms in the tree. \o/ The work isn't quite complete, there's some driver fixes still needed, but the basics now work. New SoC support added: - Freescale i.MX6SX - LSI Axxia AXM55xx SoCs - Samsung EXYNOS 3250, 5260, 5410, 5420 and 5800 - STi STIH407 plus a large set of various smaller updates for different platforms. I'm probably missing some important one here" * tag 'soc-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (281 commits) ARM: exynos: don't run exynos4 l2x0 setup on other platforms ARM: exynos: Fix "allmodconfig" build errors in mcpm and hotplug ARM: EXYNOS: mcpm rename the power_down_finish ARM: EXYNOS: Enable mcpm for dual-cluster exynos5800 SoC ARM: EXYNOS: Enable multi-platform build support ARM: EXYNOS: Consolidate Kconfig entries ARM: EXYNOS: Add support for EXYNOS5410 SoC ARM: EXYNOS: Support secondary CPU boot of Exynos3250 ARM: EXYNOS: Add Exynos3250 SoC ID ARM: EXYNOS: Add 5800 SoC support ARM: EXYNOS: initial board support for exynos5260 SoC clk: exynos5410: register clocks using common clock framework ARM: debug: qcom: add UART addresses to Kconfig help for APQ8084 ARM: sunxi: allow building without reset controller Documentation: devicetree: arm: sort enable-method entries ARM: rockchip: convert smp bringup to CPU_METHOD_OF_DECLARE clk: exynos5250: Add missing sysmmu clocks for DISP and ISP blocks ARM: dts: axxia: Add reset controller power: reset: Add Axxia system reset driver ARM: axxia: Adding defconfig for AXM55xx ...
2014-06-02Merge tag 'pci-v3.16-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into next Pull PCI changes from Bjorn Helgaas: "Enumeration - Notify driver before and after device reset (Keith Busch) - Use reset notification in NVMe (Keith Busch) NUMA - Warn if we have to guess host bridge node information (Myron Stowe) - Work around AMD Fam15h BIOSes that fail to provide _PXM (Suravee Suthikulpanit) - Clean up and mark early_root_info_init() as deprecated (Suravee Suthikulpanit) Driver binding - Add "driver_override" for force specific binding (Alex Williamson) - Fail "new_id" addition for devices we already know about (Bandan Das) Resource management - Support BAR sizes up to 8GB (Nikhil Rao, Alan Cox) - Don't move IORESOURCE_PCI_FIXED resources (Bjorn Helgaas) - Mark SBx00 HPET BAR as IORESOURCE_PCI_FIXED (Bjorn Helgaas) - Fail safely if we can't handle BARs larger than 4GB (Bjorn Helgaas) - Reject BAR above 4GB if dma_addr_t is too small (Bjorn Helgaas) - Don't convert BAR address to resource if dma_addr_t is too small (Bjorn Helgaas) - Don't set BAR to zero if dma_addr_t is too small (Bjorn Helgaas) - Don't print anything while decoding is disabled (Bjorn Helgaas) - Don't add disabled subtractive decode bus resources (Bjorn Helgaas) - Add resource allocation comments (Bjorn Helgaas) - Restrict 64-bit prefetchable bridge windows to 64-bit resources (Yinghai Lu) - Assign i82875p_edac PCI resources before adding device (Yinghai Lu) PCI device hotplug - Remove unnecessary "dev->bus" test (Bjorn Helgaas) - Use PCI_EXP_SLTCAP_PSN define (Bjorn Helgaas) - Fix rphahp endianess issues (Laurent Dufour) - Acknowledge spurious "cmd completed" event (Rajat Jain) - Allow hotplug service drivers to operate in polling mode (Rajat Jain) - Fix cpqphp possible NULL dereference (Rickard Strandqvist) MSI - Replace pci_enable_msi_block() by pci_enable_msi_exact() (Alexander Gordeev) - Replace pci_enable_msix() by pci_enable_msix_exact() (Alexander Gordeev) - Simplify populate_msi_sysfs() (Jan Beulich) Virtualization - Add Intel Patsburg (X79) root port ACS quirk (Alex Williamson) - Mark RTL8110SC INTx masking as broken (Alex Williamson) Generic host bridge driver - Add generic PCI host controller driver (Will Deacon) Freescale i.MX6 - Use new clock names (Lucas Stach) - Drop old IRQ mapping (Lucas Stach) - Remove optional (and unused) IRQs (Lucas Stach) - Add support for MSI (Lucas Stach) - Fix imx6_add_pcie_port() section mismatch warning (Sachin Kamat) Renesas R-Car - Add gen2 device tree support (Ben Dooks) - Use new OF interrupt mapping when possible (Lucas Stach) - Add PCIe driver (Phil Edworthy) - Add PCIe MSI support (Phil Edworthy) - Add PCIe device tree bindings (Phil Edworthy) Samsung Exynos - Remove unnecessary OOM messages (Jingoo Han) - Fix add_pcie_port() section mismatch warning (Sachin Kamat) Synopsys DesignWare - Make MSI ISR shared IRQ aware (Lucas Stach) Miscellaneous - Check for broken config space aliasing (Alex Williamson) - Update email address (Ben Hutchings) - Fix Broadcom CNB20LE unintended sign extension (Bjorn Helgaas) - Fix incorrect vgaarb conditional in WARN_ON() (Bjorn Helgaas) - Remove unnecessary __ref annotations (Bjorn Helgaas) - Add arch/x86/kernel/quirks.c to MAINTAINERS PCI file patterns (Bjorn Helgaas) - Fix use of uninitialized MPS value (Bjorn Helgaas) - Tidy x86/gart messages (Bjorn Helgaas) - Fix return value from pci_user_{read,write}_config_*() (Gavin Shan) - Turn pcibios_penalize_isa_irq() into a weak function (Hanjun Guo) - Remove unused serial device IDs (Jean Delvare) - Use designated initialization in PCI_VDEVICE (Mark Rustad) - Fix powerpc NULL dereference in pci_root_buses traversal (Mike Qiu) - Configure MPS on ARM (Murali Karicheri) - Remove unnecessary includes of <linux/init.h> (Paul Gortmaker) - Move Open Firmware devspec attribute to PCI common code (Sebastian Ott) - Use pdev->dev.groups for attribute creation on s390 (Sebastian Ott) - Remove pcibios_add_platform_entries() (Sebastian Ott) - Add new ID for Intel GPU "spurious interrupt" quirk (Thomas Jarosch) - Rename pci_is_bridge() to pci_has_subordinate() (Yijing Wang) - Add and use new pci_is_bridge() interface (Yijing Wang) - Make pci_bus_add_device() void (Yijing Wang) DMA API - Clarify physical/bus address distinction in docs (Bjorn Helgaas) - Fix typos in docs (Emilio López) - Update dma_pool_create ()and dma_pool_alloc() descriptions (Gioh Kim) - Change dma_declare_coherent_memory() CPU address to phys_addr_t (Bjorn Helgaas) - Pass GAPSPCI_DMA_BASE CPU & bus address to dma_declare_coherent_memory() (Bjorn Helgaas)" * tag 'pci-v3.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (92 commits) MAINTAINERS: Add generic PCI host controller driver PCI: generic: Add generic PCI host controller driver PCI: imx6: Add support for MSI PCI: designware: Make MSI ISR shared IRQ aware PCI: imx6: Remove optional (and unused) IRQs PCI: imx6: Drop old IRQ mapping PCI: imx6: Use new clock names i82875p_edac: Assign PCI resources before adding device ARM/PCI: Call pcie_bus_configure_settings() to set MPS PCI: imx6: Fix imx6_add_pcie_port() section mismatch warning PCI: Make pci_bus_add_device() void PCI: exynos: Fix add_pcie_port() section mismatch warning PCI: Introduce new device binding path using pci_dev.driver_override PCI: rcar: Add gen2 device tree support PCI: cpqphp: Fix possible null pointer dereference PCI: rcar: Add R-Car PCIe device tree bindings PCI: rcar: Add MSI support for PCIe PCI: rcar: Add Renesas R-Car PCIe driver PCI: Fix return value from pci_user_{read,write}_config_*() PCI: exynos: Remove unnecessary OOM messages ...
2014-06-02Merge tag 'hsi-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-hsi into next Pull HSI (High Speed Syncronous Interface) changes from Sebastian Reichel: "Please pull the following changes for the HSI subsystem, which I have taken over from Carlos Chinea <carlos.chinea@nokia.com>. The below patches have been worked on in the linux-omap mailinglist for 10 months and are well tested in linux-next (have been in there for more than two weeks) without any problems arising. Apart from that potential regressions are very limited, because the subsystem is not yet used by any platform in the mainline kernel. - Add some documentation for the HSI subsystem - Add Device Tree support for the HSI subsystem - Add OMAP3 SSI driver (SSI is a legacy variant of HSI) - Add Nokia N900 Modem driver (without speech support for now)" * tag 'hsi-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-hsi: HSI: Introduce Nokia N900 modem driver HSI: Introduce driver for SSI Protocol Documentation: DT: omap-ssi binding documentation HSI: Introduce OMAP SSI driver HSI: Add common DT binding for HSI client devices HSI: export method to (un)register clients HSI: Add channel resource support to HSI clients HSI: method to unregister clients from an hsi port HSI: hsi-char: fix driver for multiport scenarios MAINTAINERS: update HSI entry Documentation: HSI: Add some general description for the HSI subsystem
2014-06-02Merge tag 'gpio-v3.16-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio into next Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v3.16 series. There is a lot of action in the GPIO subsystem doing refactorings and cleanups, almost as many deletions as insertions and minor feature growth and no new drivers this time. Which is actually pretty nice. Some GPIO-related stuff will come in through the pin control tree as well. Details: - We are finalizing and fixing up the gpiochip irqchip helpers bringing a helpful irqchip implementation into the gpiolib core and avoiding duplicate code and, more importantly, duplicate bug fixes: * Support for using the helpers with threaded interrupt handlers as used on sleeping GPIO-irqchips * Do not set up hardware triggers for edges or levels if the default IRQ type is IRQ_TYPE_NONE - some drivers would exploit the fact that you could get default initialization of the IRQ type from the core at probe() but if no default type is set up from the helper, we should not call the driver to configure anything. Wait until a consumer requests the interrupt instead. * Make the irqchip helpers put the GPIO irqs into their own lock class. The GPIO irqchips can often emit (harmless, but annoying) lockdep warnings about recursions when they are in fact just cascaded IRQs. By putting them into their own lock class we help the lockdep core to keep track of things. * Switch the tc3589x GPIO expanders to use the irqchip helpers * Switch the OMAP GPIO driver to use the irqchip helpers * Add some documentation for the irqchip helpers * select IRQ_DOMAIN when using the helpers since some platforms may not be using this by default and it's a strict dependency. - Continued GPIO descriptor refactoring: * Remove the one instance of gpio_to_desc() from the device tree code, making the OF GPIO code use GPIO descriptors only. * Introduce gpiod_get_optional() and gpiod_get_optional_index() akin to the similar regulator functions for cases where the use of GPIO is optional and not strictly required. * Make of_get_named_gpiod_flags() private - we do not want to unnecessarily expose APIs to drivers that make the gpiolib harder than necessary to maintain and refactor. Privatize this function. - Support "-gpio" suffix for the OF GPIO retrieveal path. We used to look for "foo-gpios" or just "gpios" in device tree nodes, but it turns out that some drivers with a single GPIO line will just state "foo-gpio" (singularis). Sigh. Support this with a fallback looking for it, as this simplifies driver code and handles it in core code. - Switch the ACPI GPIO core to fetch GPIOs with the *_cansleep function variants as the GPIO operation region handler can sleep, and shall be able to handle gpiochips that sleep. - Tons of cleanups and janitorial work from Jingoo Han, Axel Lin, Javier Martinez Canillas and Abdoulaye Berthe. Notably Jingoo cut off a ton of pointless OOM messages. - Incremental development and fixes for various drivers, nothing really special here" * tag 'gpio-v3.16-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits) gpio: select IRQ_DOMAIN for gpiolib irqchip helpers gpio: pca953x: use gpiolib irqchip helpers gpio: pcf857x: Add IRQF_SHARED when request irq gpio: pcf857x: Avoid calling irq_domain_cleanup twice gpio: mcp23s08: switch chip count to int gpio: dwapb: use a second irq chip gpio: ep93xx: Use devm_ioremap_resource() gpio: mcp23s08: fixed count variable for devicetree probing gpio: Add run-time dependencies to R-Car driver gpio: pch: add slab include Documentation / ACPI: Fix location of GPIO documentation gpio / ACPI: use *_cansleep version of gpiod_get/set APIs gpio: generic: add request function pointer gpio-pch: Fix Kconfig dependencies gpio: make of_get_named_gpiod_flags() private gpio: gpioep93xx: use devm functions gpio: janzttl: use devm function gpio: timberdale: use devm functions gpio: bt8xx: use devm function for memory allocation gpio: include linux/bug.h in interface header ...
2014-05-30bnx2x: update MAINTAINERS for bnx2x and e-mail addressesAriel Elior
The bnx2x development team has transferred from Broadcom to Qlogic. This patch updates some obsolete email addresses to usable ones. The bnx2x files contain headers with legal information from Broadcom. Qlogic Legal depratment is taking their time coming up with their own legal info. So this patch only updates contact information. I will follow up with a patch for the headers once I have the required info. Signed-off-by: Ariel Elior <ariel.elior@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-30Merge branch 'pci/host-generic' into nextBjorn Helgaas
* pci/host-generic: MAINTAINERS: Add generic PCI host controller driver PCI: generic: Add generic PCI host controller driver Conflicts: drivers/pci/host/Kconfig drivers/pci/host/Makefile
2014-05-30MAINTAINERS: Add generic PCI host controller driverWill Deacon
Add myself as the maintainer for the generic PCI host controller driver. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Arnd Bergmann <arnd@arndb.de>
2014-05-31MAINTAINERS: add a co-maintainer from samsung for F2FSJaegeuk Kim
This patch adds a samsung guy for an F2FS maintainer. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2014-05-30MAINTAINERS: change the email address for f2fsJaegeuk Kim
This patch changes the valid email address to maintain the f2fs file system. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
