path: root/MAINTAINERS
2005-07-12[PATCH] MAINTAINERS: irda-users@lists.sourceforge.net is subscribers onlyOlaf Hering
Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] Add MAINTAINERS entry for audit subsystemChris Wright
I've been asked about this a couple times, and there's no info in MAINTAINERS file. Add MAINTAINERS entry for audit subsystem. Signed-off-by: Chris Wright <chrisw@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] pcmcia: update MAINTAINERS entryDominik Brodowski
PCMCIA/CardBus is handled by a team of developers at the specified mailing list. Additional developers wanting to help are most welcome. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-06[SPARC]: Fix "Eddie C. Dost" e-mail addressEddie C. Dost
2005-06-28[PATCH] V4L maintainer patchMauro Carvalho Chehab
This patch updates maintainer info for BTTV and V4L. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Acked-by: Gerd Knorr <kraxel@bytesex.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] MAINTAINERS: Update Roland Dreier's emailRoland Dreier
Cisco bought Topspin, so I'm now a shiny happy Cisco employee. Update my entry in MAINTAINERS. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] MAINTAINERS: document that uclinux-dev@uclinux.org is subscribers-onlyAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] update Computone MAINTAINERS entryAdrian Bunk
This patch states that Michael still maintains this driver and removes a no longer mailing list. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: add kexec syscallsEric W. Biederman
This patch introduces the architecture independent implementation the sys_kexec_load, the compat_sys_kexec_load system calls. Kexec on panic support has been integrated into the core patch and is relatively clean. In addition the hopefully architecture independent option crashkernel=size@location has been docuemented. It's purpose is to reserve space for the panic kernel to live, and where no DMA transfer will ever be setup to access. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] swsusp: documentation updatesPavel Machek
This updates documentation and fixes pointers in MAINTAINERS file. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xtensa: Tensilica Xtensa CPU arch maintainer recordChris Zankel
Start of a patch series which adds support for the xtensa architecture to Linux. The Xtensa architecture is highly configurable and usually buried inside an SOC device. So, if you buy a new printer, digital camera, or cell phone, there is a chance that there is an Xtensa inside even though you don't know it (sometimes as a small audio-engine or as a control CPU). Linux hasn't been adopted widely with Xtensa yet, but with Linux growing in the embedded space, I am sure it will become much more important. The attached patch supplies the maintainer record for an architecture implementation for the Tensilica Xtensa CPU series. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/paulus/ppc64-2.6Linus Torvalds
2005-06-23[PATCH] Document the fact that linux-arm-kernel is subscribers-only.Alexey Dobriyan
"Non-members are not allowed to post messages to this list. Blame the original poster for cross-posting to subscriber-only mailing lists. " Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] ppc64: add BPA platform typeArnd Bergmann
This adds the basic support for running on BPA machines. So far, this is only the IBM workstation, and it will not run on others without a little more generalization. It should be possible to configure a kernel for any combination of CONFIG_PPC_BPA with any of the other multiplatform targets. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-21[PATCH] I2C: Sensors mailing list has movedJean Delvare
The following patch updates all references to the sensors mailing list, so as to reflect the fact that the list recently moved to a new home and changed addresses. I'll work out a similar patch for Linux 2.4 soon. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] Framebuffer driver for Arc LCD boardJaya Kumar
Add support for the Arc monochrome LCD board. The board uses KS108 controllers to drive individual 64x64 LCD matrices. The board can be paneled in a variety of setups such as 2x1=128x64, 4x4=256x256 and so on. The board/host interface is through GPIO. Signed-off-by: Jaya Kumar <jayalk@intworks.biz> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <linux-fbdev-devel@lists.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-18[PATCH] DocBook: MAINTAINER entryMartin Waitz
Martin can maintain the DocBook system for us. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-13[NET]: Move the netdev list to vger.kernel.org.Ralf Baechle
From: Ralf Baechle <ralf@linux-mips.org> There are archives of the old list at http://oss.sgi.com/archives/netdev Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-31[PATCH] I2C: ALI1563 SMBus driver fixR.Marek@sh.cvut.cz
This patch fixes "grave" bugs in i2c-ali1563 driver. It seems on recent chipset revisions the HSTS_DONE is set only for block transfers, so we must detect the end of ordinary transaction other way. Also due to missing and mask, setting other transfer modes was not possible. Moreover the continous byte mode transfer uses DAT0 for command rather than CMD command. All those changes were tested with help of Chunhao Huang from Winbond. I'm willing to maintain the driver. Second patch adds me as maintainer if this is neccessary. Signed-Off-By: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-17[PATCH] update sn2 maintainerJesse Barnes
Now that I'm no longer at SGI and don't have access to Altix equipment, it's time to pass on the job of patch monkey to someone else. Greg Edwards has foolishly^Wkindly volunteered for the job, so here's a patch to update the MAINTAINERS file with the appropriate information. Signed-off-by: Jesse Barnes <jesse.barnes@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-05-05[PATCH] orinoco MAINTAINERS updatePavel Roskin
Add mailing list addresses for Orinoco and update its homepage. Signed-off-by: Pavel Roskin <proski@gnu.org> Cc: David Gibson <hermes@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Fix Tpm driver -- Maintainers entryKylene Hall
This patch adds the maintainers entry. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fbdev MAINTAINERS updateBenjamin Herrenschmidt
This patch does the long overdue updates to MAINTAINERS file for aty128fb and radeonfb. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Maintainers list update: linux-net -> netdevHorms
Use netdev as the mailing list contact instead of the mostly dead linux-net list. Signed-off-by: Horms <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] MAINTAINERS: remove obsolete ACP/MWAVE MODEM entryAdrian Bunk
Both maintainer email addresses are bouncing and the web address is no longer valid. Seems to be a good time to remove the entry. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] update maintainer for /dev/randomMatt Mackall
Ted has agreed to let me take over as maintainer of /dev/random and friends. I've gone ahead and added a line to his entry in CREDITS. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
