This resolves a merge issue with a iio driver, and the zram code.
As part of transition caused due to acquisition of Ozmo Devices by Atmel,
my email address is changed.
Signed-off-by: Rupesh Gujare <rgujare@ozmodevices.com>
Removed myself (ckelly@ozmodevices.com) as maintainer of ozwpan.
Removed my email address from the TODO file.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Timur Tabi no longer works for Freescale, so update the email address
and status for all of his maintained projects.
Also mark the QE library as orphaned, for lack of interest in
maintaining it.
The CS4270 driver is marked as "Odd Fixes" because appropriate hardware
is no longer available.
Pull networking fixes from David Miller:
1) Fix regression allowing IP_TTL setting of zero, fix from Cong Wang.
2) Fix leak regressions in tunap, from Jason Wang.
3) be2net driver always returns IRQ_HANDLED in INTx handler, fix from
Sathya Perla.
4) qlge doesn't really support NETIF_F_TSO6, don't set that flag. Fix
from Amerigo Wang.
5) Add 802.11ad Atheros wil6210 driver, from Vladimir Kondratiev.
6) Fix MTU calculations in mac80211 layer, from T Krishna Chaitanya.
7) Station info layer of mac80211 needs to use del_timer_sync(), from
Johannes Berg.
8) tcp_read_sock() can loop forever, because we don't immediately stop
when recv_actor() returns zero. Fix from Eric Dumazet.
9) Fix WARN_ON() in tcp_cleanup_rbuf(). We have to use sk_eat_skb() in
tcp_recv_skb() to handle the case where a large GRO packet is split
up while it is use by a splice() operation. Fix also from Eric
Dumazet.
10) addrconf_get_prefix_route() in ipv6 tests flags incorrectly, it
does:
if (X && (p->flags & Y) != 0)
when it really meant to go:
if (X && (p->flags & X) != 0)
fix from Romain Kuntz.
11) Fix lost Kconfig dependency for bfin_mac driver hardware
timestamping. From Lars-Peter Clausen.
12) Fix regression in handling of RST without ACK in TCP, from Eric
Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (37 commits)
be2net: fix unconditionally returning IRQ_HANDLED in INTx
tuntap: fix leaking reference count
tuntap: forbid calling TUNSETIFF when detached
tuntap: switch to use rtnl_dereference()
net, wireless: overwrite default_ethtool_ops
qlge: remove NETIF_F_TSO6 flag
tcp: accept RST without ACK flag
net: ethernet: xilinx: Do not use NO_IRQ in axienet
net: ethernet: xilinx: Do not use axienet on PPC
bnx2x: Allow management traffic after boot from SAN
bnx2x: Fix fastpath structures when memory allocation fails
bfin_mac: Restore hardware time-stamping dependency on BF518
tun: avoid owner checks on IFF_ATTACH_QUEUE
bnx2x: move debugging code before the return
tuntap: refuse to re-attach to different tun_struct
ipv6: use addrconf_get_prefix_route for prefix route lookup [v2]
ipv6: fix the noflags test in addrconf_get_prefix_route
tcp: fix splice() and tcp collapsing interaction
tcp: splice: fix an infinite loop in tcp_read_sock()
net: prevent setting ttl=0 via IP_TTL
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: Omar Ramirez Luna <omar.ramirez@ti.com>
Cc: Omar Ramirez Luna <omar.ramirez@copitl.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Change MAINTAINED to Maintained.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
This file was moved to arch/arm/mach-omap2/omap=5Fhwmod.h by commit
2a296c8f89bc ("ARM: OMAP: Make plat/omap=5Fhwmod.h local to
mach-omap2").
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
New job, new address.
Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
Due to I moved to use suse.com mail address, so, add patch to change the
mail address in MAINTAINERS file.
Cc: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
This directory was moved to drivers/staging/sm7xxfb/ by commit
925aa6600cee ("staging: sm7xxfb: sm7xx becomes sm7xxfb").
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
Cc: Teddy Wang <teddy.wang@siliconmotion.com.cn>
Acked-by: Javier Muñoz <jmunhoz@igalia.com>
Added by commit 200efedd8766 ("pwm: Take over maintainership of the PWM
subsystem"), but I could not find any trace of that file being ever
added to the repository.
Acked-by: Thierry Reding <thierry.reding@avionic-design.de>
This pattern only matched arch/frv/lib/perf_event.c, which was removed
by commit e360adbe2924 ("irq_work: Add generic hardirq context
callbacks").
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
This driver was removed by commit 6187fee46f4b ("mmc: remove imxmmc
driver").
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
The documentation was moved to Documentation/misc-devices/mei/ instead.
Acked-by: Tomas Winkler <tomas.winkler@intel.com>
These files were removed by commit 1a8359e411eb ("x86/mid: Remove Intel
Moorestown").
Cc: Alan Cox <alan@linux.intel.com>
Cc: Len Brown <len.brown@intel.com>
This directory was removed by commit 7d99b3abaf84 ("isci, firmware:
Remove isci fallback parameter blob and generator").
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: James Bottomley <JBottomley@Parallels.com>
Cc: Intel SCU Linux support <intel-linux-scu@intel.com>
Cc: Lukasz Dorau <lukasz.dorau@intel.com>
Cc: Maciej Patelczyk <maciej.patelczyk@intel.com>
Cc: Dave Jiang <dave.jiang@intel.com>
This directory was moved to drivers/net/ieee802154/ by commit
31d178bffcff ("drivers/ieee802154: move ieee802154 drivers to net
folder").
Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
This file was moved to include/linux/platform_data/video-imxfb.h by
commit 82906b13a6f4 ("ARM: imx: move platform_data definitions").
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
This driver was removed by commit 1c3a918f78b7 ("ARM: clps711x: Remove
board support for CEIVA").
Cc: Christopher Hoover <ch@murgatroid.com>
Cc: Christopher Hoover <ch@hpl.hp.com>
This driver was never at dvb-usb-v2, as far as I could see.
Cc: Michael Krufky <mkrufky@linuxtv.org>
Several headers were moved or split to uapi/.
This file was moved to drivers/media/platform/soc_camera/atmel-isi.c by
commit b47ff4a3ed42 ("[media] move soc_camera to its own directory").
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Josh Wu <josh.wu@atmel.com>
This file was moved to include/linux/platform_data/dma-atmel.h by commit
7cdc39eeadf1 ("ARM: at91: move platform_data definitions").
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Tony Prisk <linux@prisktech.co.nz>
These files were merged into plat-samsung.
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
This file was moved to arch/arm/mach-rpc/time.c by commit a1be5d649699
("ARM: riscpc: move time-acorn.c to mach-rpc"), and the pattern for
arch/arm/mach-rpc/ already exists.
This subdirectory entry was added by commit 8a5700cd6754 ("MAINTAINERS:
add drivers/platform/msm to MSM subsystem") back in 2011, but I could
not find any trace of that directory being ever added to the repository.
Cc: Kenneth Heitke <kheitke@codeaurora.org>
Acked-by: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
This adds support for the 60 GHz 802.11ad Wilocity card
through a new driver, wil6210. Wilocity implemented the
firmware, QCA maintains the device driver.
Currently supported:
- STA: with security
- AP: limited to 1 connected STA, security disabled
- Monitor: due to a hardware/firmware limitation
either control or non-control frames are monitored
Using a STA and AP with this drive, one can assemble
a fully functional BSS. Throughput of 1.2Gbps is achieved
with iperf.
The wil6210 cards have on-board flash memory for the
firmware, the cards comes pre-flashed and no firmware
download is required.
For more details see:
http://wireless.kernel.org/en/users/Drivers/wil6210
Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs bug fixes from Jaegeuk Kim:
"This patch-set includes two major bug fixes:
- incorrect IUsed provided by *df -i*, and
- lookup failure of parent inodes in corner cases.
[Other Bug Fixes]
- Fix error handling routines
- Trigger recovery process correctly
- Resolve build failures due to missing header files
[Etc]
- Add a MAINTAINERS entry for f2fs
- Fix and clean up variables, functions, and equations
- Avoid warnings during compilation"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs:
f2fs: unify string length declarations and usage
f2fs: clean up unused variables and return values
f2fs: clean up the start_bidx_of_node function
f2fs: remove unneeded variable from f2fs_sync_fs
f2fs: fix fsync_inode list addition logic and avoid invalid access to memory
f2fs: remove unneeded initialization of nr_dirty in dirty_seglist_info
f2fs: handle error from f2fs_iget_nowait
f2fs: fix equation of has_not_enough_free_secs()
f2fs: add MAINTAINERS entry
f2fs: return a default value for non-void function
f2fs: invalidate the node page if allocation is failed
f2fs: add missing #include <linux/prefetch.h>
f2fs: do f2fs_balance_fs in front of dir operations
f2fs: should recover orphan and fsync data
f2fs: fix handling errors got by f2fs_write_inode
f2fs: fix up f2fs_get_parent issue to retrieve correct parent inode number
f2fs: fix wrong calculation on f_files in statfs
f2fs: remove set_page_dirty for atomic f2fs_end_io_write
Pull late ARM cleanups for omap from Olof Johansson:
"From Tony Lindgren:
Here are few more patches to finish the omap changes for multiplatform
conversion that are not strictly fixes, but were too complex to do
with the dependencies during the merge window. Those are to move of
serial-omap.h to platform_data, and the removal of remaining
cpu_is_omap macro usage outside mach-omap2.
Then there are several trivial fixes for typos and few minimal
omap2plus_defconfig updates."
* tag 'omap-late-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arch/arm/mach-omap2/dpll3xxx.c: drop if around WARN_ON
OMAP2: Fix a typo - replace regist with register.
ARM/omap: use module_platform_driver macro
ARM: OMAP2+: PMU: Remove unused header
ARM: OMAP4: remove duplicated include from omap_hwmod_44xx_data.c
ARM: OMAP2+: omap2plus_defconfig: enable twl4030 SoC audio
ARM: OMAP2+: omap2plus_defconfig: Add tps65217 support
ARM: OMAP2+: enable devtmpfs and devtmpfs automount
ARM: OMAP2+: omap_twl: Change TWL4030_MODULE_PM_RECEIVER to TWL_MODULE_PM_RECEIVER
ARM: OMAP2+: Drop plat/cpu.h for omap2plus
ARM: OMAP: Split fb.c to remove last remaining cpu_is_omap usage
MAINTAINERS: Add an entry for omap related .dts files
This patch adds myself to MAINTAINERS entry for the f2fs file system.
Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Signed-off-by: Corentin Chary <corentin.chary@gmail.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Moved to fs/ext3/ext3.h by commit 4613ad180d19 ("ext3: move headers to
fs/ext3/").
Cc: Jan Kara <jack@suse.cz>
Mark it so.
Cc: Harry Wei <harryxiyou@gmail.com>
All your omap .dts files are belong to us.
Benoît has been doing a good job picking up most of the
omap .dts files so far. Let's make sure we both get
cc:ed for the related patches.
The .dts patches need to be queued by us as separate
patches from drivers and other code changes to avoid
pointless merge conflists like we saw with v3.8
networking changes.
Cc: Benoît Cousson <b-cousson@ti.com>
Pull DRM updates from Dave Airlie:
"This is the one and only next pull for 3.8, we had a regression we
found last week, so I was waiting for that to resolve itself, and I
ended up with some Intel fixes on top as well.
Highlights:
- new driver: nvidia tegra 20/30/hdmi support
- radeon: add support for previously unused DMA engines, more HDMI
regs, eviction speeds ups and fixes
- i915: HSW support enable, agp removal on GEN6, seqno wrapping
- exynos: IPP subsystem support (image post proc), HDMI
- nouveau: display class reworking, nv20->40 z compression
- ttm: start of locking fixes, rcu usage for lookups,
- core: documentation updates, docbook integration, monotonic clock
usage, move from connector to object properties"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (590 commits)
drm/exynos: add gsc ipp driver
drm/exynos: add rotator ipp driver
drm/exynos: add fimc ipp driver
drm/exynos: add iommu support for ipp
drm/exynos: add ipp subsystem
drm/exynos: support device tree for fimd
radeon: fix regression with eviction since evict caching changes
drm/radeon: add more pedantic checks in the CP DMA checker
drm/radeon: bump version for CS ioctl support for async DMA
drm/radeon: enable the async DMA rings in the CS ioctl
drm/radeon: add VM CS parser support for async DMA on cayman/TN/SI
drm/radeon/kms: add evergreen/cayman CS parser for async DMA (v2)
drm/radeon/kms: add 6xx/7xx CS parser for async DMA (v2)
drm/radeon: fix htile buffer size computation for command stream checker
drm/radeon: fix fence locking in the pageflip callback
drm/radeon: make indirect register access concurrency-safe
drm/radeon: add W|RREG32_IDX for MM_INDEX|DATA based mmio accesss
drm/exynos: support extended screen coordinate of fimd
drm/exynos: fix x, y coordinates for right bottom pixel
drm/exynos: fix fb offset calculation for plane
This file was moved to drivers/i2c/i2c-stub.c by commit 31d178b
(i2c-stub: Move to drivers/i2c).
Cc: "Mark M. Hoffman" <mhoffman@lightlink.com>
Pull fbdev changes from Tomi Valkeinen:
"OMAPDSS changes, including:
- use dynanic debug prints
- OMAP platform dependency removals
- Creation of compat-layer, helping us to improve omapdrm
- Misc cleanups, aiming to make omadss more in line with the upcoming
common display framework
Exynos DP changes for the 3.8 merge window:
- Device Tree support for Samsung Exynos DP
- SW Link training is cleaned up.
- HPD interrupt is supported.
Samsung Framebuffer changes for the 3.8 merge window:
- The bit definitions of header file are updated.
- Some minor typos are fixed.
- Some minor bugs of s3c_fb_check_var() are fixed.
FB related changes for SH Mobile, Freescale DIU
Add support for the Solomon SSD1307 OLED Controller"
* tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linux: (191 commits)
OMAPDSS: fix TV-out issue with DSI PLL
Revert "OMAPFB: simplify locking"
OMAPFB: remove silly loop in fb2display()
OMAPFB: fix error handling in omapfb_find_best_mode()
OMAPFB: use devm_kzalloc to allocate omapfb2_device
OMAPDSS: DISPC: remove dispc fck uses
OMAPDSS: DISPC: get dss clock rate from dss driver
drivers/video/console/softcursor.c: remove redundant NULL check before kfree()
drivers/video: add support for the Solomon SSD1307 OLED Controller
OMAPDSS: use omapdss_compat_init() in other drivers
OMAPDSS: export dispc functions
OMAPDSS: export dss_feat functions
OMAPDSS: export dss_mgr_ops functions
OMAPDSS: separate compat files in the Makefile
OMAPDSS: move display sysfs init to compat layer
OMAPDSS: DPI: use dispc's check_timings
OMAPDSS: DISPC: add dispc_ovl_check()
OMAPDSS: move irq handling to dispc-compat
OMAPDSS: move omap_dispc_wait_for_irq_interruptible_timeout to dispc-compat.c
OMAPDSS: move blocking mgr enable/disable to compat layer
arch/arm/mach-davinci/devices-da8xx.c
arch/arm/plat-omap/common.c
drivers/media/platform/omap/omap_vout.c
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson:
"This is a branch with updates for Marvell's mvebu/kirkwood platforms.
They came in late-ish, and were heavily interdependent such that it
didn't make sense to split them up across the cross-platform topic
branches. So here they are (for the second release in a row) in a
branch on their own."
* tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits)
arm: l2x0: add aurora related properties to OF binding
arm: mvebu: add Aurora L2 Cache Controller to the DT
arm: mvebu: add L2 cache support
dma: mv_xor: fix error handling path
dma: mv_xor: fix error checking of irq_of_parse_and_map()
dma: mv_xor: use request_irq() instead of devm_request_irq()
dma: mv_xor: clear the window override control registers
arm: mvebu: fix address decoding armada_cfg_base() function
ARM: mvebu: update defconfig with I2C and RTC support
ARM: mvebu: Add SATA support for OpenBlocks AX3-4
ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4
ARM: mvebu: Add support for I2C on OpenBlocks AX3-4
ARM: mvebu: Add support for I2C controllers in Armada 370/XP
arm: mvebu: Add hardware I/O Coherency support
arm: plat-orion: Add coherency attribute when setup mbus target
arm: dma mapping: Export a dma ops function arm_dma_set_mask
arm: mvebu: Add SMP support for Armada XP
arm: mm: Add support for PJ4B cpu and init routines
arm: mvebu: Add IPI support via doorbells
arm: mvebu: Add initial support for power managmement service unit
Pull MIPS updates from Ralf Baechle:
"The MIPS bits for 3.8. This also includes a bunch fixes that were
sitting in the linux-mips.org git tree for a long time. This pull
request contains updates to several OCTEON drivers and the board
support code for BCM47XX, BCM63XX, XLP, XLR, XLS, lantiq, Loongson1B,
updates to the SSB bus support, MIPS kexec code and adds support for
kdump.
When pulling this, there are two expected merge conflicts in
include/linux/bcma/bcma_driver_chipcommon.h which are trivial to
resolve, just remove the conflict markers and keep both alternatives."
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (90 commits)
MIPS: PMC-Sierra Yosemite: Remove support.
VIDEO: Newport Fix console crashes
MIPS: wrppmc: Fix build of PCI code.
MIPS: IP22/IP28: Fix build of EISA code.
MIPS: RB532: Fix build of prom code.
MIPS: PowerTV: Fix build.
MIPS: IP27: Correct fucked grammar in ops-bridge.c
MIPS: Highmem: Fix build error if CONFIG_DEBUG_HIGHMEM is disabled
MIPS: Fix potencial corruption
MIPS: Fix for warning from FPU emulation code
MIPS: Handle COP3 Unusable exception as COP1X for FP emulation
MIPS: Fix poweroff failure when HOTPLUG_CPU configured.
MIPS: MT: Fix build with CONFIG_UIDGID_STRICT_TYPE_CHECKS=y
MIPS: Remove unused smvp.h
MIPS/EDAC: Improve OCTEON EDAC support.
MIPS: OCTEON: Add definitions for OCTEON memory contoller registers.
MIPS: OCTEON: Add OCTEON family definitions to octeon-model.h
ata: pata_octeon_cf: Use correct byte order for DMA in when built little-endian.
MIPS/OCTEON/ata: Convert pata_octeon_cf.c to use device tree.
MIPS: Remove usage of CEVT_R4K_LIB config option.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Missing MAINTAINERS entries were added for several drivers
- Adds V4L2 support for DMABUF handling, allowing zero-copy buffer
sharing between V4L2 devices and GPU
- Got rid of all warnings when compiling with W=1 on x86
- Add a new driver for Exynos hardware (s3c-camif)
- Several bug fixes, cleanups and driver improvements
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (243 commits)
[media] omap3isp: Replace cpu_is_omap3630() with ISP revision check
[media] omap3isp: Prepare/unprepare clocks before/after enable/disable
[media] omap3isp: preview: Add support for 8-bit formats at the sink pad
[media] omap3isp: Replace printk with dev_*
[media] omap3isp: Find source pad from external entity
[media] omap3isp: Configure CSI-2 phy based on platform data
[media] omap3isp: Add PHY routing configuration
[media] omap3isp: Add CSI configuration registers from control block to ISP resources
[media] omap3isp: Remove unneeded module memory address definitions
[media] omap3isp: Use monotonic timestamps for statistics buffers
[media] uvcvideo: Fix control value clamping for unsigned integer controls
[media] uvcvideo: Mark first output terminal as default video node
[media] uvcvideo: Add VIDIOC_[GS]_PRIORITY support
[media] uvcvideo: Return -ENOTTY for unsupported ioctls
[media] uvcvideo: Set device_caps in VIDIOC_QUERYCAP
[media] uvcvideo: Don't fail when an unsupported format is requested
[media] uvcvideo: Return -EACCES when trying to access a read/write-only control
[media] uvcvideo: Set error_idx properly for extended controls API failures
[media] rtl28xxu: add NOXON DAB/DAB+ USB dongle rev 2
[media] fc2580: write some registers conditionally
Pull first round of SCSI updates from James Bottomley:
"This patch set includes two large new drivers: mpt3sas (for the next
gen fusion SAS hardware) and csiostor a FCoE offload driver for the
Chelsio converged network cards (this includes some net changes which
I've OK'd with DaveM).
The rest of the patch is driver updates (qla2xxx, lpfc, hptiop,
be2iscsi) plus a few assorted updates and bug fixes.
We also have a Power Management rework in the Upper Layer Drivers
preparatory to doing ACPI zero power optical devices, but the actual
enabler is still being worked on.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (72 commits)
[SCSI] mpt3sas: add new driver supporting 12GB SAS
[SCSI] scsi_transport_sas: add 12GB definitions for mpt3sas
[SCSI] miscdevice: Adding support for MPT3SAS_MINOR(222)
[SCSI] csiostor: remove unneeded memset()
[SCSI] csiostor: Fix sparse warnings.
[SCSI] qla2xxx: Display that driver is operating in legacy interrupt mode.
[SCSI] qla2xxx: Dont clear drv active on iospace config failure.
[SCSI] qla2xxx: Fix typo in qla2xxx driver.
[SCSI] qla2xxx: Update ql2xextended_error_logging parameter description with new option.
[SCSI] qla2xxx: Parameterize the link speed of hba rather than fcport.
[SCSI] qla2xxx: Add 16Gb/s case to get port speed capability.
[SCSI] qla2xxx: Move marking fcport online ahead of setting iiDMA speed.
[SCSI] qla2xxx: Add acquiring of risc semaphore before doing ISP reset.
[SCSI] qla2xxx: Ignore driver ack bit if corresponding presence bit is not set.
[SCSI] qla2xxx: Fix typo in qla83xx_fw_dump function.
[SCSI] qla2xxx: Add Gen3 PCIe speed 8GT/s to the log message.
[SCSI] qla2xxx: Use correct Request-Q-Out register during bidirectional request processing
[SCSI] qla2xxx: Move noisy Start scsi failed messages to verbose logging level.
[SCSI] qla2xxx: Fix coccinelle warnings in qla2x00_relogin.
[SCSI] qla2xxx: No fcport FC-4 type assignment in GA_NXT response.
Pull KVM updates from Marcelo Tosatti:
"Considerable KVM/PPC work, x86 kvmclock vsyscall support,
IA32_TSC_ADJUST MSR emulation, amongst others."
Fix up trivial conflict in kernel/sched/core.c due to cross-cpu
migration notifier added next to rq migration call-back.
* tag 'kvm-3.8-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (156 commits)
KVM: emulator: fix real mode segment checks in address linearization
VMX: remove unneeded enable_unrestricted_guest check
KVM: VMX: fix DPL during entry to protected mode
x86/kexec: crash_vmclear_local_vmcss needs __rcu
kvm: Fix irqfd resampler list walk
KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump
x86/kexec: VMCLEAR VMCSs loaded on all cpus if necessary
KVM: MMU: optimize for set_spte
KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface
KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation
KVM: PPC: bookehv: Add guest computation mode for irq delivery
KVM: PPC: Make EPCR a valid field for booke64 and bookehv
KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit
KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation
KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation
KVM: PPC: e500: Add emulation helper for getting instruction ea
KVM: PPC: bookehv64: Add support for interrupt handling
KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler
KVM: PPC: booke: Fix get_tb() compile error on 64-bit
KVM: PPC: e500: Silence bogus GCC warning in tlb code
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
