path: root/MAINTAINERS
2015-08-24nfsd: Add Jeff Layton as co-maintainerJ. Bruce Fields
Jeff has been doing a lot of development (including much of the state-locking rewrite just as one example) plus lots of review and other miscellaneous nfsd work, so let's acknowledge the status quo. I'll continue to be the one to send regular pull requests but Jeff will should be available to cover there occasionally too. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-14Update maintainers for DRM STI driverBenjamin Gaignard
Add Vincent Abriou and myself as maintainers. Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Cc: Vincent Abriou <vincent.abriou@st.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-30MAINTAINERS: Appoint Jiang and Marc as irqdomain maintainersThomas Gleixner
Ben was pretty surprised that he is still listed as the maintainer and he has no objections against transferring the duty to those who rumaged in and revamped that code in the recent past. Add kernel/irq/msi.c to the affected files as it's part of the shiny new hierarchical irqdomain machinery. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Grant Likely <grant.likely@linaro.org>
2015-07-30MAINTAINERS: Appoint Marc Zyngier as irqchips co-maintainerThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Cc: Marc Zyngier <marc.zyngier@arm.com>
2015-07-25Merge tag 'for-linus-20150724' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD fixes from Brian Norris: "Two trivial updates. I meant to send these much earlier, but I've been preoccupied. - Add MAINTAINERS entry for diskonchip g3 driver - Fix an overlooked conflict in bitfield value assignments The latter update is a bit overdue, but there's no reason to wait any longer" * tag 'for-linus-20150724' of git://git.infradead.org/linux-mtd: mtd: nand: Fix NAND_USE_BOUNCE_BUFFER flag conflict MAINTAINERS: mtd: docg3: add docg3 maintainer
2015-07-23Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio/vhost fixes from Michael Tsirkin: "Bugfixes and documentation fixes. Igor's patch that allows users to tweak memory table size is borderline, but it does fix known crashes, so I merged it" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: vhost: add max_mem_regions module parameter vhost: extend memory regions allocation to vmalloc 9p/trans_virtio: reset virtio device on remove virtio/s390: rename drivers/s390/kvm -> drivers/s390/virtio MAINTAINERS: separate section for s390 virtio drivers virtio: define virtio_pci_cfg_cap in header. virtio: Fix typecast of pointer in vring_init() virtio scsi: fix unused variable warning vhost: use binary search instead of linear in find_region() virtio_net: document VIRTIO_NET_CTRL_GUEST_OFFLOADS
2015-07-19Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "By far most of the fixes here are updates to DTS files to deal with some mostly minor bugs. There's also a fix to deal with non-PM kernel configs on i.MX, a regression fix for ethernet on PXA platforms and a dependency fix for OMAP" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: keystone: dts: rename pcie nodes to help override status ARM: keystone: dts: fix dt bindings for PCIe ARM: pxa: fix dm9000 platform data regression ARM: dts: Correct audio input route & set mic bias for am335x-pepper ARM: OMAP2+: Add HAVE_ARM_SCU for AM43XX MAINTAINERS: digicolor: add dts files ARM: ux500: fix MMC/SD card regression ARM: ux500: define serial port aliases ARM: dts: OMAP5: Add #iommu-cells property to IOMMUs ARM: dts: OMAP4: Add #iommu-cells property to IOMMUs ARM: dts: Fix frequency scaling on Gumstix Pepper ARM: dts: configure regulators for Gumstix Pepper ARM: dts: omap3: overo: Update LCD panel names ARM: dts: cros-ec-keyboard: Add support for some Japanese keys ARM: imx6: gpc: always enable PU domain if CONFIG_PM is not set ARM: dts: imx53-qsb: fix TVE entry ARM: dts: mx23: fix iio-hwmon support ARM: dts: imx27: Adjust the GPT compatible string ARM: socfpga: dts: Fix entries order ARM: socfpga: dts: Fix adxl34x formating and compatible string
2015-07-17MAINTAINERS: uclinux-h8-devel is moderated for non-subscribersGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17Update Viresh Kumar's email addressViresh Kumar
Switch to my kernel.org alias instead of a badly named gmail address, which I rarely use. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17MAINTAINERS: change mhocko's email address to kernel.orgMichal Hocko
I am moving from mhocko@suse.cz to mhocko@kernel.org for kernel related stuff. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17MAINTAINERS: switch to suse.com many-in-one (fwd)Jiri Slaby
Since suse.{de,cz} is deprecated to use (but will still work for some time), switch to suse.com which is now to be used instead. Signed-off-by: Jiri Slaby <jslaby@suse.com> Acked-by: Alexander Graf <agraf@suse.de> Acked-by: David Sterba <dsterba@suse.com> Acked-by: Hannes Reinecke <hare@suse.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Jean Delvare <jdelvare@suse.com> Acked-by: Jiri Kosina <jkosina@suse.com> Acked-by: Michal Marek <mmarek@suse.com> Acked-by: NeilBrown <neilb@suse.com> Acked-by: Oliver Neukum <oneukum@suse.de> Acked-by: Takashi Iwai <tiwai@suse.com> Acked-by: Thomas Renninger <trenn@suse.de> Acked-by: Tomas Cech <sleep_walker@suse.com> Acked-by: Vojtech Pavlik <vojtech@suse.com> Signed-off-by: Jiri Kosina <jkosina@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-15Merge tag 'omap-for-v4.2/fixes-rc2-v2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Fixes for omaps, all dts changes except for one: - Fix up LCD panel name for overo boards - Three fixes for pepper board for regulators, freqeuncy scaling and audio input. Note that there is still one issue being worked on for booting with multi_v7_defconfig - Add missing #iommu-cells for omap4 and 5 - Add missing HAVE_ARM_SCU for am43xx * tag 'omap-for-v4.2/fixes-rc2-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (210 commits) ARM: dts: Correct audio input route & set mic bias for am335x-pepper ARM: OMAP2+: Add HAVE_ARM_SCU for AM43XX ARM: dts: OMAP5: Add #iommu-cells property to IOMMUs ARM: dts: OMAP4: Add #iommu-cells property to IOMMUs ARM: dts: Fix frequency scaling on Gumstix Pepper ARM: dts: configure regulators for Gumstix Pepper ARM: dts: omap3: overo: Update LCD panel names + Linux 4.2-rc2 Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-14MAINTAINERS: digicolor: add dts filesBaruch Siach
The 'digicolor' regexp doesn't cover the dts files. Add a glob pattern for them. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Missing list head init in bluetooth hidp session creation, from Tedd Ho-Jeong An. 2) Don't leak SKB in bridge netfilter error paths, from Florian Westphal. 3) ipv6 netdevice private leak in netfilter bridging, fixed by Julien Grall. 4) Fix regression in IP over hamradio bpq encapsulation, from Ralf Baechle. 5) Fix race between rhashtable resize events and table walks, from Phil Sutter. 6) Missing validation of IFLA_VF_INFO netlink attributes, fix from Daniel Borkmann. 7) Missing security layer socket state initialization in tipc code, from Stephen Smalley. 8) Fix shared IRQ handling in boomerang 3c59x interrupt handler, from Denys Vlasenko. 9) Missing minor_idr destroy on module unload on macvtap driver, from Johannes Thumshirn. 10) Various pktgen kernel thread races, from Oleg Nesterov. 11) Fix races that can cause packets to be processed in the backlog even after a device attached to that SKB has been fully unregistered. From Julian Anastasov. 12) bcmgenet driver doesn't account packet drops vs. errors properly, fix from Petri Gynther. 13) Array index validation and off by one fix in DSA layer from Florian Fainelli * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (66 commits) can: replace timestamp as unique skb attribute ARM: dts: dra7x-evm: Prevent glitch on DCAN1 pinmux can: c_can: Fix default pinmux glitch at init can: rcar_can: unify error messages can: rcar_can: print request_irq() error code can: rcar_can: fix typo in error message can: rcar_can: print signed IRQ # can: rcar_can: fix IRQ check net: dsa: Fix off-by-one in switch address parsing net: dsa: Test array index before use net: switchdev: don't abort unsupported operations net: bcmgenet: fix accounting of packet drops vs errors cdc_ncm: update specs URL Doc: z8530book: Fix typo in API-z8530-sync-txdma-open.html net: inet_diag: always export IPV6_V6ONLY sockopt for listening sockets bridge: mdb: allow the user to delete mdb entry if there's a querier net: call rcu_read_lock early in process_backlog net: do not process device backlog during unregistration bridge: fix potential crash in __netdev_pick_tx() net: axienet: Fix devm_ioremap_resource return value check ...
2015-07-11Merge branch 'libnvdimm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm Pull libnvdimm fixes from Dan Williams: "1) Fixes for a handful of smatch reports (Thanks Dan C.!) and minor bug fixes (patches 1-6) 2) Correctness fixes to the BLK-mode nvdimm driver (patches 7-10). Granted these are slightly large for a -rc update. They have been out for review in one form or another since the end of May and were deferred from the merge window while we settled on the "PMEM API" for the PMEM-mode nvdimm driver (ie memremap_pmem, memcpy_to_pmem, and wmb_pmem). Now that those apis are merged we implement them in the BLK driver to guarantee that mmio aperture moves stay ordered with respect to incoming read/write requests, and that writes are flushed through those mmio-windows and platform-buffers to be persistent on media. These pass the sub-system unit tests with the updates to tools/testing/nvdimm, and have received a successful build-report from the kbuild robot (468 configs). With acks from Rafael for the touches to drivers/acpi/" * 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm: nfit: add support for NVDIMM "latch" flag nfit: update block I/O path to use PMEM API tools/testing/nvdimm: add mock acpi_nfit_flush_address entries to nfit_test tools/testing/nvdimm: fix return code for unimplemented commands tools/testing/nvdimm: mock ioremap_wt pmem: add maintainer for include/linux/pmem.h nfit: fix smatch "use after null check" report nvdimm: Fix return value of nvdimm_bus_init() if class_create() fails libnvdimm: smatch cleanups in __nd_ioctl sparse: fix misplaced __pmem definition
2015-07-11Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Kevin Hilman: "A fairly random colletion of fixes based on -rc1 for OMAP, sunxi and prima2 as well as a few arm64-specific DT fixes. This series also includes a late to support a new Allwinner (sunxi) SoC, but since it's rather simple and isolated to the platform-specific code, it's included it for this -rc" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arm64: dts: add device tree for ARM SMM-A53x2 on LogicTile Express 20MG arm: dts: vexpress: add missing CCI PMU device node to TC2 arm: dts: vexpress: describe all PMUs in TC2 dts GICv3: Add ITS entry to THUNDER dts arm64: dts: Add poweroff button device node for APM X-Gene platform ARM: dts: am4372.dtsi: disable rfbi ARM: dts: am57xx-beagle-x15: Provide supply for usb2_phy2 ARM: dts: am4372: Add emif node Revert "ARM: dts: am335x-boneblack: disable RTC-only sleep" ARM: sunxi: Enable simplefb in the defconfig ARM: Remove deprecated symbol from defconfig files ARM: sunxi: Add Machine support for A33 ARM: sunxi: Introduce Allwinner H3 support Documentation: sunxi: Update Allwinner SoC documentation ARM: prima2: move to use REGMAP APIs for rtciobrg ARM: dts: atlas7: add pinctrl and gpio descriptions ARM: OMAP2+: Remove unnessary return statement from the void function, omap2_show_dma_caps memory: omap-gpmc: Fix parsing of devices
2015-07-10Merge tag 'powerpc-4.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: - opal-prd mmap fix from Vaidy - set kernel taint for MCEs from Daniel - alignment exception description from Anton - ppc4xx_hsta_msi build fix from Daniel - opal-elog interrupt fix from Alistair - core_idle_state race fix from Shreyas - hv-24x7 lockdep fix from Sukadev - multiple cxl fixes from Daniel, Ian, Mikey & Maninder - update MAINTAINERS to point at shared tree * tag 'powerpc-4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: cxl: Check if afu is not null in cxl_slbia powerpc: Update MAINTAINERS to point at shared tree powerpc/perf/24x7: Fix lockdep warning cxl: Fix off by one error allowing subsequent mmap page to be accessed cxl: Fail mmap if requested mapping is larger than assigned problem state area cxl: Fix refcounting in kernel API powerpc/powernv: Fix race in updating core_idle_state powerpc/powernv: Fix opal-elog interrupt handler powerpc/ppc4xx_hsta_msi: Include ppc-pci.h to fix reference to hose_list powerpc: Add plain English description for alignment exception oopses cxl: Test the correct mmio space before unmapping powerpc: Set the correct kernel taint on machine check errors cxl/vphb.c: Use phb pointer after NULL check powerpc/powernv: Fix vma page prot flags in opal-prd driver
2015-07-10pmem: add maintainer for include/linux/pmem.hRoss Zwisler
The file include/linux/pmem.h was recently created to hold the PMEM API, and is logically part of the PMEM driver. Add an entry for this file to MAINTAINERS. Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-07-09MAINTAINERS: add secondary tree for ceph modulesSage Weil
The Ceph kernel code is primarily developed in the github tree, and only pushed to the korg tree before going to Linus. If Sage is unavailable and another maintainer needs to push something upstream, pull requests may originate from the github tree instead of Sage's korg tree. Signed-off-by: Sage Weil <sage@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2015-07-09MAINTAINERS: update ceph entriesSage Weil
- The Ceph common code is used by both fs/ceph and drivers/block/rbd. Add a separate maintainers entry. - Add Ilya as libceph maintainer and cephfs submaintainer. - Attribute Documentation/ABI/testing/sysfs-bus-rbd to rbd. - ceph-devel@vger.kernel.org should be L, not M in rbd entry. Signed-off-by: Sage Weil <sage@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2015-07-08arm64: dts: add device tree for ARM SMM-A53x2 on LogicTile Express 20MGKristina Martsenko
Add a DTS file for the MP2 Cortex-A53 Soft Macrocell Model implemented on a LogicTile Express 20MG (V2F-1XV7) daughterboard. This is based on the version that's currently available from the ARM DTS repository [1]. [1] git://linux-arm.org/arm-dts.git Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-07-08MAINTAINER: add bridge netfilterPablo Neira Ayuso
So scripts/get_maintainer.pl shows the Netfilter mailing lists. Reported-by: Julien Grall <julien.grall@citrix.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-07-08powerpc: Update MAINTAINERS to point at shared treeMichael Ellerman
Now that we have a shared powerpc tree on kernel.org, point folks at that as the primary place to look for powerpc stuff. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-07-07virtio/s390: rename drivers/s390/kvm -> drivers/s390/virtioCornelia Huck
This more accurately reflects what these drivers actually do. Suggested-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2015-07-07MAINTAINERS: separate section for s390 virtio driversCornelia Huck
The s390-specific virtio drivers have probably more to do with virtio than with kvm today; let's move them out into a separate section to reflect this and to be able to add relevant mailing lists. CC: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2015-07-06MAINTAINERS: mtd: docg3: add docg3 maintainerRobert Jarzmik
Add myself as maintainer of the NAND based MSystems DiskOnChip G3 driver. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-07-05Merge tag 'platform-drivers-x86-v4.2-2' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull late x86 platform driver updates from Darren Hart: "The following came in a bit later and I wanted them to bake in next a few more days before submitting, thus the second pull. A new intel_pmc_ipc driver, a symmetrical allocation and free fix in dell-laptop, a couple minor fixes, and some updated documentation in the dell-laptop comments. intel_pmc_ipc: - Add Intel Apollo Lake PMC IPC driver tc1100-wmi: - Delete an unnecessary check before the function call "kfree" dell-laptop: - Fix allocating & freeing SMI buffer page - Show info about WiGig and UWB in debugfs - Update information about wireless control" * tag 'platform-drivers-x86-v4.2-2' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: intel_pmc_ipc: Add Intel Apollo Lake PMC IPC driver tc1100-wmi: Delete an unnecessary check before the function call "kfree" dell-laptop: Fix allocating & freeing SMI buffer page dell-laptop: Show info about WiGig and UWB in debugfs dell-laptop: Update information about wireless control
2015-07-04Merge tag 'ntb-4.2' of git://github.com/jonmason/ntbLinus Torvalds
Pull NTB updates from Jon Mason: "This includes a pretty significant reworking of the NTB core code, but has already produced some significant performance improvements. An abstraction layer was added to allow the hardware and clients to be easily added. This required rewriting the NTB transport layer for this abstraction layer. This modification will allow future "high performance" NTB clients. In addition to this change, a number of performance modifications were added. These changes include NUMA enablement, using CPU memcpy instead of asyncdma, and modification of NTB layer MTU size" * tag 'ntb-4.2' of git://github.com/jonmason/ntb: (22 commits) NTB: Add split BAR output for debugfs stats NTB: Change WARN_ON_ONCE to pr_warn_once on unsafe NTB: Print driver name and version in module init NTB: Increase transport MTU to 64k from 16k NTB: Rename Intel code names to platform names NTB: Default to CPU memcpy for performance NTB: Improve performance with write combining NTB: Use NUMA memory in Intel driver NTB: Use NUMA memory and DMA chan in transport NTB: Rate limit ntb_qp_link_work NTB: Add tool test client NTB: Add ping pong test client NTB: Add parameters for Intel SNB B2B addresses NTB: Reset transport QP link stats on down NTB: Do not advance transport RX on link down NTB: Differentiate transport link down messages NTB: Check the device ID to set errata flags NTB: Enable link for Intel root port mode in probe NTB: Read peer info from local SPAD in transport NTB: Split ntb_hw_intel and ntb_transport drivers ...
2015-07-04NTB: Split ntb_hw_intel and ntb_transport driversAllen Hubbe
Change ntb_hw_intel to use the new NTB hardware abstraction layer. Split ntb_transport into its own driver. Change it to use the new NTB hardware abstraction layer. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add NTB hardware abstraction layerAllen Hubbe
Abstract the NTB device behind a programming interface, so that it can support different hardware and client drivers. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-03Merge tag 'hwspinlock-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock Pull hwspinlock updates from Ohad Ben-Cohen: - hwspinlock core DT support from Suman Anna - OMAP hwspinlock DT support from Suman Anna - QCOM hwspinlock DT support from Bjorn Andersson - a new CSR atlas7 hwspinlock driver from Wei Chen - CSR atlas7 hwspinlock DT binding document from Wei Chen - a tiny QCOM hwspinlock driver fix from Bjorn Andersson * tag 'hwspinlock-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock: hwspinlock: qcom: Correct msb in regmap_field DT: hwspinlock: add the CSR atlas7 hwspinlock bindings document hwspinlock: add a CSR atlas7 driver hwspinlock: qcom: Add support for Qualcomm HW Mutex block DT: hwspinlock: Add binding documentation for Qualcomm hwmutex hwspinlock/omap: add support for dt nodes Documentation: dt: add the omap hwspinlock bindings document hwspinlock/core: add device tree support Documentation: dt: add common bindings for hwspinlock
2015-07-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse updates from Miklos Szeredi: "This is the start of improving fuse scalability. An input queue and a processing queue is split out from the monolithic fuse connection, each of those having their own spinlock. The end of the patchset adds the ability to clone a fuse connection. This means, that instead of having to read/write requests/answers on a single fuse device fd, the fuse daemon can have multiple distinct file descriptors open. Each of those can be used to receive requests and send answers, currently the only constraint is that a request must be answered on the same fd as it was read from. This can be extended further to allow binding a device clone to a specific CPU or NUMA node. Based on a patchset by Srinivas Eeda and Ashish Samant. Thanks to Ashish for the review of this series" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: (40 commits) fuse: update MAINTAINERS entry fuse: separate pqueue for clones fuse: introduce per-instance fuse_dev structure fuse: device fd clone fuse: abort: no fc->lock needed for request ending fuse: no fc->lock for pqueue parts fuse: no fc->lock in request_end() fuse: cleanup request_end() fuse: request_end(): do once fuse: add req flag for private list fuse: pqueue locking fuse: abort: group pqueue accesses fuse: cleanup fuse_dev_do_read() fuse: move list_del_init() from request_end() into callers fuse: duplicate ->connected in pqueue fuse: separate out processing queue fuse: simplify request_wait() fuse: no fc->lock for iqueue parts fuse: allow interrupt queuing without fc->lock fuse: iqueue locking ...
2015-07-01Merge tag 'clk-for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clock framework updates from Michael Turquette: "The changes to the common clock framework for 4.2 are dominated by new drivers and updates to existing ones, as usual. There are some fixes to the framework itself and several cleanups for sparse warnings, etc" * tag 'clk-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (135 commits) clk: stm32: Add clock driver for STM32F4[23]xxx devices dt-bindings: Document the STM32F4 clock bindings cpufreq: exynos: remove Exynos4210 specific cpufreq driver support ARM: Exynos: switch to using generic cpufreq driver for Exynos4210 clk: samsung: exynos4: add cpu clock configuration data and instantiate cpu clock clk: samsung: add infrastructure to register cpu clocks clk: add CLK_RECALC_NEW_RATES clock flag for Exynos cpu clock support doc: dt: add documentation for lpc1850-ccu clk driver clk: add lpc18xx ccu clk driver doc: dt: add documentation for lpc1850-cgu clk driver clk: add lpc18xx cgu clk driver clk: keystone: add support for post divider register for main pll clk: mvebu: flag the crypto clk as CLK_IGNORE_UNUSED clk: cygnus: remove Cygnus dummy clock binding clk: cygnus: add clock support for Broadcom Cygnus clk: Change bcm clocks build dependency clk: iproc: add initial common clock support clk: iproc: define Broadcom iProc clock binding MAINTAINERS: update email for Michael Turquette clk: meson: add some error handling in meson_clk_register_cpu() ...
2015-07-01Merge tag 'platform-drivers-x86-v4.2-1' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver updates from Darren Hart: "Fairly routine update for platform-drivers-x86. Mostly fixes and cleanups, with a significant refactoring of toshiba* drivers. Includes the addition of the dell-rbtn driver. Details: asus-wmi: - fan control dell*: - add Dell airplane mode switch driver ideapad-laptop: - platform rfkill fixes, and regression fix pvpanic: - handle missing _STA correctly toshiba*: - rafactor bluetooth support - haps documentation - driver cleanup other: - Use acpi_video_unregister_backlight instead of acpi_video_unregister in serveral drivers. - Orphan msi-wmi. * tag 'platform-drivers-x86-v4.2-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (24 commits) MAINTAINERS: Orphan x86 driver msi-wmi ideapad: fix software rfkill setting dell-laptop: Use dell-rbtn instead i8042 filter when possible dell-rbtn: Export notifier for other kernel modules dell-rbtn: Dell Airplane Mode Switch driver samsung-laptop: Use acpi_video_unregister_backlight instead of acpi_video_unregister asus-wmi: Use acpi_video_unregister_backlight instead of acpi_video_unregister apple_gmux: Use acpi_video_unregister_backlight instead of acpi_video_unregister pvpanic: handle missing _STA correctly ideapad_laptop: Lenovo G50-30 fix rfkill reports wireless blocked asus-wmi: add fan control Documentation/ABI: Add file describing the sysfs entries for toshiba_haps toshiba_haps: Make use of DEVICE_ATTR_{RW, WO} macros toshiba_haps: Replace sscanf with kstrtoint toshiba_acpi: Bump driver version to 0.22 toshiba_acpi: Remove TOS_FAILURE check from some functions toshiba_acpi: Comments cleanup toshiba_acpi: Rename hci_{read, write}1 functions toshiba_acpi: Remove no longer needed hci_{read, write}2 functions toshiba_bluetooth: Change BT status message to debug ...
2015-07-01Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - the rest of MM - scripts/gdb updates - ipc/ updates - lib/ updates - MAINTAINERS updates - various other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits) genalloc: rename of_get_named_gen_pool() to of_gen_pool_get() genalloc: rename dev_get_gen_pool() to gen_pool_get() x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit MAINTAINERS: add zpool MAINTAINERS: BCACHE: Kent Overstreet has changed email address MAINTAINERS: move Jens Osterkamp to CREDITS MAINTAINERS: remove unused nbd.h pattern MAINTAINERS: update brcm gpio filename pattern MAINTAINERS: update brcm dts pattern MAINTAINERS: update sound soc intel patterns MAINTAINERS: remove website for paride MAINTAINERS: update Emulex ocrdma email addresses bcache: use kvfree() in various places libcxgbi: use kvfree() in cxgbi_free_big_mem() target: use kvfree() in session alloc and free IB/ehca: use kvfree() in ipz_queue_{cd}tor() drm/nouveau/gem: use kvfree() in u_free() drm: use kvfree() in drm_free_large() cxgb4: use kvfree() in t4_free_mem() cxgb3: use kvfree() in cxgb_free_mem() ...
2015-07-01Merge tag 'arc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC architecture updates from Vineet Gupta: - support for HS38 cores based on ARCv2 ISA ARCv2 is the next generation ISA from Synopsys and basis for the HS3{4,6,8} families of processors which retain the traditional ARC mantra of low power and configurability and are now more performant and feature rich. HS38x is a 10 stage pipeline core which supports MMU (with huge pages) and SMP (upto 4 cores) among other features. + www.synopsys.com/dw/ipdir.php?ds=arc-hs38-processor + http://news.synopsys.com/2014-10-14-New-DesignWare-ARC-HS38-Processor-Doubles-Performance-for-Embedded-Linux-Applications + http://www.embedded.com/electronics-news/4435975/Synopsys-ARC-HS38-core-gives-2X-boost-to-Linux-based-apps - support for ARC SDP (Software Development platform): Main Board + CPU Cards = AXS101: CPU Card with ARC700 in silicon @ 700 MHz = AXS103: CPU Card with HS38x in FPGA - refactoring of ARCompact port to accomodate new ARCv2 ISA - misc updates/cleanups * tag 'arc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (72 commits) ARC: Fix build failures for ARCompact in linux-next after ARCv2 support ARCv2: Allow older gcc to cope with new regime of ARCv2/ARCompact support ARCv2: [vdk] dts files and defconfig for HS38 VDK ARCv2: [axs103] Support ARC SDP FPGA platform for HS38x cores ARC: [axs101] Prepare for AXS103 ARCv2: [nsim*hs*] Support simulation platforms for HS38x cores ARCv2: All bits in place, allow ARCv2 builds ARCv2: SLC: Handle explcit flush for DMA ops (w/o IO-coherency) ARCv2: STAR 9000837815 workaround hardware exclusive transactions livelock ARC: Reduce bitops lines of code using macros ARCv2: barriers arch: conditionally define smp_{mb,rmb,wmb} ARC: add smp barriers around atomics per Documentation/atomic_ops.txt ARC: add compiler barrier to LLSC based cmpxchg ARCv2: SMP: intc: IDU 2nd level intc for dynamic IRQ distribution ARCv2: SMP: clocksource: Enable Global Real Time counter ARCv2: SMP: ARConnect debug/robustness ARCv2: SMP: Support ARConnect (MCIP) for Inter-Core-Interrupts et al ARC: make plat_smp_ops weak to allow over-rides ARCv2: clocksource: Introduce 64bit local RTC counter ...
2015-07-01fuse: update MAINTAINERS entryMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2015-06-30MAINTAINERS: add zpoolDan Streetman
Add entry for zpool to MAINTAINERS file. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: BCACHE: Kent Overstreet has changed email addressJoe Perches
Kent's email address in MAINTAINERS seems to be invalid. This was his last sign-off address, so use that if appropriate. Fix the S: status entry while there. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kent Overstreet <kent.overstreet@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: move Jens Osterkamp to CREDITSJoe Perches
Jens' email address bounces, so move his name and entry to CREDITS. Signed-off-by: Joe Perches <joe@perches.com> Cc: Ishizaki Kou <kou.ishizaki@toshiba.co.jp> Cc: Jens Osterkamp <jens@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: remove unused nbd.h patternJoe Perches
Commit 13e71d69cc74 ("nbd: Remove kernel internal header") deleted the file, remove the pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update brcm gpio filename patternJoe Perches
Commit 23a71fd616bf ("dt-bindings: brcm: rationalize Broadcom documentation naming") renamed the file, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update brcm dts patternJoe Perches
Commit 8c0b9ee8665c ("MIPS: Move device-trees into vendor sub-directories") moved the files, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andrew Bresticker <abrestic@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update sound soc intel patternsJoe Perches
Commit 2106241a6803 ("ASoC: Intel: create common folder and move common files in") moved the files around. Update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Jie Yang <yang.jie@intel.com> Acked-by: Jie Yang <yang.jie@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: remove website for parideSudip Mukherjee
The webpage mentioned is not working, Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30MAINTAINERS: update Emulex ocrdma email addressesLaurent Navet
@emulex.com addresses respond to use @avagotech.com. Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Acked-By: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-29intel_pmc_ipc: Add Intel Apollo Lake PMC IPC driverqipeng.zha
This driver provides support for PMC control on Apollo Lake platforms. The PMC is an ARC processor which defines some IPC commands for communication with other entities in the CPU. Signed-off-by: qipeng.zha <qipeng.zha@intel.com> [fengguang.wu@intel.com: Fix Sparse and Cocinelle warnings] Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com>
2015-06-29Merge tag 'libnvdimm-for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm Pull libnvdimm subsystem from Dan Williams: "The libnvdimm sub-system introduces, in addition to the libnvdimm-core, 4 drivers / enabling modules: NFIT: Instantiates an "nvdimm bus" with the core and registers memory devices (NVDIMMs) enumerated by the ACPI 6.0 NFIT (NVDIMM Firmware Interface table). After registering NVDIMMs the NFIT driver then registers "region" devices. A libnvdimm-region defines an access mode and the boundaries of persistent memory media. A region may span multiple NVDIMMs that are interleaved by the hardware memory controller. In turn, a libnvdimm-region can be carved into a "namespace" device and bound to the PMEM or BLK driver which will attach a Linux block device (disk) interface to the memory. PMEM: Initially merged in v4.1 this driver for contiguous spans of persistent memory address ranges is re-worked to drive PMEM-namespaces emitted by the libnvdimm-core. In this update the PMEM driver, on x86, gains the ability to assert that writes to persistent memory have been flushed all the way through the caches and buffers in the platform to persistent media. See memcpy_to_pmem() and wmb_pmem(). BLK: This new driver enables access to persistent memory media through "Block Data Windows" as defined by the NFIT. The primary difference of this driver to PMEM is that only a small window of persistent memory is mapped into system address space at any given point in time. Per-NVDIMM windows are reprogrammed at run time, per-I/O, to access different portions of the media. BLK-mode, by definition, does not support DAX. BTT: This is a library, optionally consumed by either PMEM or BLK, that converts a byte-accessible namespace into a disk with atomic sector update semantics (prevents sector tearing on crash or power loss). The sinister aspect of sector tearing is that most applications do not know they have a atomic sector dependency. At least today's disk's rarely ever tear sectors and if they do one almost certainly gets a CRC error on access. NVDIMMs will always tear and always silently. Until an application is audited to be robust in the presence of sector-tearing the usage of BTT is recommended. Thanks to: Ross Zwisler, Jeff Moyer, Vishal Verma, Christoph Hellwig, Ingo Molnar, Neil Brown, Boaz Harrosh, Robert Elliott, Matthew Wilcox, Andy Rudoff, Linda Knippers, Toshi Kani, Nicholas Moulin, Rafael Wysocki, and Bob Moore" * tag 'libnvdimm-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm: (33 commits) arch, x86: pmem api for ensuring durability of persistent memory updates libnvdimm: Add sysfs numa_node to NVDIMM devices libnvdimm: Set numa_node to NVDIMM devices acpi: Add acpi_map_pxm_to_online_node() libnvdimm, nfit: handle unarmed dimms, mark namespaces read-only pmem: flag pmem block devices as non-rotational libnvdimm: enable iostat pmem: make_request cleanups libnvdimm, pmem: fix up max_hw_sectors libnvdimm, blk: add support for blk integrity libnvdimm, btt: add support for blk integrity fs/block_dev.c: skip rw_page if bdev has integrity libnvdimm: Non-Volatile Devices tools/testing/nvdimm: libnvdimm unit test infrastructure libnvdimm, nfit, nd_blk: driver for BLK-mode access persistent memory nd_btt: atomic sector updates libnvdimm: infrastructure for btt devices libnvdimm: write blk label set libnvdimm: write pmem label set libnvdimm: blk labels and namespace instantiation ...
2015-06-29Merge tag 'dmaengine-4.2-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have support for few new devices, few new features and odd fixes spread thru the subsystem. New devices added: - support for CSRatlas7 dma controller - Allwinner H3(sun8i) controller - TI DMA crossbar driver on DRA7x - new pxa driver New features added: - memset support is bought back now that we have a user in xdmac controller - interleaved transfers support different source and destination strides - supporting DMA routers and configuration thru DT - support for reusing descriptors - xdmac memset and interleaved transfer support - hdmac support for interleaved transfers - omap-dma support for memcpy Others: - Constify platform_device_id - mv_xor fixes and improvements" * tag 'dmaengine-4.2-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: xgene: fix file permission dmaengine: fsl-edma: clear pending interrupts on initialization dmaengine: xdmac: Add memset support Documentation: dmaengine: document DMA_CTRL_ACK dmaengine: virt-dma: don't always free descriptor upon completion dmaengine: Revert "drivers/dma: remove unused support for MEMSET operations" dmaengine: hdmac: Implement interleaved transfers dmaengine: Move icg helpers to global header dmaengine: mv_xor: improve descriptors list handling and reduce locking dmaengine: mv_xor: Enlarge descriptor pool size dmaengine: mv_xor: add support for a38x command in descriptor mode dmaengine: mv_xor: Rename function for consistent naming dmaengine: mv_xor: bug fix for racing condition in descriptors cleanup dmaengine: pl330: fix wording in mcbufsz message dmaengine: sirf: add CSRatlas7 SoC support dmaengine: xgene-dma: Fix "incorrect type in assignement" warnings dmaengine: fix kernel-doc documentation dmaengine: pxa_dma: add support for legacy transition dmaengine: pxa_dma: add debug information dmaengine: pxa: add pxa dmaengine driver ...
2015-06-29Merge tag 'linux-kselftest-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest update from Shuah Khan: "This update adds two new test suites: futex and seccomp. In addition, it includes fixes for bugs in timers, other tests, and compile framework. It introduces new quicktest feature to enable users to choose to run tests that complete in a short time" * tag 'linux-kselftest-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests: add quicktest support selftests: add seccomp suite selftest, x86: fix incorrect comment tools selftests: Fix 'clean' target with make 3.81 selftests/futex: Add .gitignore kselftest: Add exit code defines selftests: Add futex tests to the top-level Makefile selftests/futex: Increment ksft pass and fail counters selftests/futex: Update Makefile to use lib.mk selftests: Add futex functional tests kselftests: timers: Check _ALARM clockids are supported before suspending kselftests: timers: Ease alarmtimer-suspend unreasonable latency value kselftests: timers: Increase delay between suspends in alarmtimer-suspend selftests/exec: do not install subdir as it is already created selftests/ftrace: install test.d selftests: copy TEST_DIRS to INSTALL_PATH Test compaction of mlocked memory selftests/mount: output WARN messages when mount test skipped selftests/timers: Make git ignore all binaries in timers test suite
