path: root/MAINTAINERS
2007-12-10MAINTAINERS: update stale entriesJoe Perches
Some bad email addresses are removed: linux-tr@linuxtr.net ehaase@inf.fu-berlin.de Some are updated: linux@maxim.org.za to andrew@sanpeople.com linux-kernel@linux-mips.org to linux-mips@linux-mips.org jdike@karaya.com to jdike@addtoit.com The PCMCIA entry is corrected to a web address The ZR36120 VIDEO FOR LINUX DRIVER entry is removed Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: [PARISC] lba_pci: pci_claim_resources disabled expansion roms [PARISC] print more than one character at a time for pdc console [PARISC] Update parisc-linux MAINTAINERS entries [PARISC] timer interrupt should not be IRQ_DISABLED Revert "[PARISC] import necessary bits of libgcc.a"
2007-12-06[PARISC] Update parisc-linux MAINTAINERS entriesKyle McMartin
List changed & reordered so I'm more likely to see patches... Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-12-04MAINTAINERS: remove the MTRR entryAdrian Bunk
I haven't seen Richard doing MTRR related work for quite some time, and the "X86 ARCHITECTURE" entry in MAINTAINERS already covers the people currently responsible for this code. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-03Update Kdump Maintainer's detailsVivek Goyal
Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4680/1: parentheses around NR_IRQS definition [ARM] 4679/1: AT91: Change maintainer email address [ARM] 4675/1: pxa: fix mfp address definition error for pxa320 [ARM] 4674/1: pxa: increase LCD PCLK drive strength to fast 2mA for PXA300/PXA310 [ARM] 4673/1: pxa: add missing IRQ_SSP4 definitions for PXA3xx [ARM] 4672/1: pxa: fix DRCMR(n) to support PXA27x and later processors [ARM] 4665/1: fix __und_usr wrt accessing the undefined insn in user space [ARM] 4659/1: remove possibilities for spurious false negative with __kuser_cmpxchg [ARM] 4661/1: fix do_undefinstr wrt the enabling of IRQs [ARM] uengine: fix memset size error [ARM] 4648/1: i.MX/MX1 ensure more complete AITC initialization [ARM] 4611/2: AT91: Fix GPIO buttons pins on SAM9261-EK. [ARM] 4650/1: AT91: New-style init of I2C, support for i2c-gpio [ARM] 4604/2: AT91: Master clock divistor on SAM9 [ARM] 4662/1: Fix PXA serial driver compilation if SERIAL_PXA_CONSOLE is disabled [ARM] PXA ssp: unlock when ssp tries to close an invalid port [ARM] 4654/1: pxa: update default MFP register value [ARM] 4653/1: pxa: fix a gpio typo in mfp-pxa320.h [ARM] 4652/1: pxa: fix a typo of pxa27x usb host clk definition [ARM] 4651/1: pxa: add PXA3xx specific IRQ definitions
2007-11-29[ARM] 4679/1: AT91: Change maintainer email addressAndrew Victor
Change email address of AT91 maintainer. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-29add Mike Christie to MAINTAINERSMike Christie
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-28USB: mailing lists have changedGreg Kroah-Hartman
The linux-usb-devel and linux-usb-users are now hosted in the same list at vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: remove USB HUB entry from MAINTAINERSDavid Brownell
Digging through old mail, I found a note about needing to remove the separate entry for the USB HUB driver. It's not been separable from usbcore (host side!) since quite early in the 2.4 kernel series. And Johanness certainly isn't involved with it any more. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/net-2.6: (41 commits) [XFRM]: Fix leak of expired xfrm_states [ATM]: [he] initialize lock and tasklet earlier [IPV4]: Remove bogus ifdef mess in arp_process [SKBUFF]: Free old skb properly in skb_morph [IPV4]: Fix memory leak in inet_hashtables.h when NUMA is on [IPSEC]: Temporarily remove locks around copying of non-atomic fields [TCP] MTUprobe: Cleanup send queue check (no need to loop) [TCP]: MTUprobe: receiver window & data available checks fixed [MAINTAINERS]: tlan list is subscribers-only [SUNRPC]: Remove SPIN_LOCK_UNLOCKED [SUNRPC]: Make xprtsock.c:xs_setup_{udp,tcp}() static [PFKEY]: Sending an SADB_GET responds with an SADB_GET [IRDA]: Compilation for CONFIG_INET=n case [IPVS]: Fix compiler warning about unused register_ip_vs_protocol [ARP]: Fix arp reply when sender ip 0 [IPV6] TCPMD5: Fix deleting key operation. [IPV6] TCPMD5: Check return value of tcp_alloc_md5sig_pool(). [IPV4] TCPMD5: Use memmove() instead of memcpy() because we have overlaps. [IPV4] TCPMD5: Omit redundant NULL check for kfree() argument. ieee80211: Stop net_ratelimit/IEEE80211_DEBUG_DROP log pollution ...
2007-11-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6.24Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6.24: sh: include ax88796 in the defconfig for r7785rp sh: include ax88796 in the defconfig for r7780mp sh: fix R2D-1 CF support fb: Orphan imsttfb. sh: Update mailing list info. sh: lockless UTLB miss fast-path. sh: Kill off UTLB flush in fast-path. sh: Fix copy_{to,from}_user_page() with cache disabled.
2007-11-26mac68k: mailing list addresssFinn Thain
The mail service for the mac.linux-m68k.org domain is defunct. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-22[MAINTAINERS]: tlan list is subscribers-onlyGabriel Craciunescu
Your mail to 'Tlan-devel' with the subject drivers/net/tlan question Is being held until the list moderator can review it for approval. The reason it is being held: Post by non-member to a members-only list Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-19fb: Orphan imsttfb.Paul Mundt
I haven't had this hardware in years, so kill off my MAINTAINERS entry for this and flag it as orphaned. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-19sh: Update mailing list info.Paul Mundt
DaveM has provided a vger list, update MAINTAINERS to reflect this. Also, rip out the sh64 entry (as this can just be rolled in to the general sh case), and add the git path. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-10softmac: MAINTAINERS updateJohannes Berg
This patch marks softmac as obsolete in MAINTAINERS and removes Joe and myself as maintainers, we're no longer using it nor interested in the code in any way. Also remove the website reference because I took it offline. Hopefully the code will go away in 2.6.25. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Joseph Jezak <josejx@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-10b43legacy: add me as maintainer and fix URLsStefano Brivio
As b43legacy is going to be orphaned, add me as a maintainer. Fix URLs for the related website and fix my e-mail address in MAINTAINERS file. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Cc: Larry Finger <larry.finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] ibmvscsi: Prevent IO during partner login [SCSI] lpfc : Correct queue tag handling [SCSI] Update MAINTAINER email address and trees [SCSI] osst: fix if (...) \n #if... cases missing semicolons when false
2007-11-03[SCSI] Update MAINTAINER email address and treesJames Bottomley
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-11-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: linux-input mailing list moved to vger.kernel.org Input: inport, logibm - use KERN_INFO when reporting missing mouse Input: appletouch - idle reset logic broke older Fountains Input: hp_sdc.c - fix section mismatch Input: appletouch - add Johannes Berg as maintainer Input: Add Euro and Dollar key codes Input: xpad - add more USB IDs
2007-11-02Input: linux-input mailing list moved to vger.kernel.orgDmitry Torokhov
Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Johannes Berg <johannes@sipsolutions.net>
2007-10-29Pull documentation into release branchLen Brown
2007-10-27Input: appletouch - add Johannes Berg as maintainerJohannes Berg
After the last patch that broke appletouch for powerbooks again I'd like to take over maintainership of this driver to make sure it doesn't break again in the future. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-27[JFFS2] Update MAINTAINERS entry -- the jffs-dev list is deadDavid Woodhouse
2007-10-25Merge branch 'fixes-davem' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2007-10-25[PATCH] add myself as mac80211 maintainerJohannes Berg
This adds myself as mac80211 maintainer and updates the git URL to point to the wireless-2.6 tree. Also move Jiri down so he isn't first in list. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-25Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: [IPV4]: Explicitly call fib_get_table() in fib_frontend.c [NET]: Use BUILD_BUG_ON in net/core/flowi.c [NET]: Remove in-code externs for some functions from net/core/dev.c [NET]: Don't declare extern variables in net/core/sysctl_net_core.c [TCP]: Remove unneeded implicit type cast when calling tcp_minshall_update() [NET]: Treat the sign of the result of skb_headroom() consistently [9P]: Fix missing unlock before return in p9_mux_poll_start [PKT_SCHED]: Fix sch_prio.c build with CONFIG_NETDEVICES_MULTIQUEUE [IPV4] ip_gre: sendto/recvfrom NBMA address [SCTP]: Consolidate sctp_ulpq_renege_xxx functions [NETLINK]: Fix ACK processing after netlink_dump_start [VLAN]: MAINTAINERS update [DCCP]: Implement SIOCINQ/FIONREAD [NET]: Validate device addr prior to interface-up
2007-10-25suspend: MAINTAINERS updateLen Brown
> I guess it is time to clarify that suspend and hibernation are separate > things, and add Rafael as a maintainer. Plus, people blame us for suspend > problems, anyway, I guess it is fair to mark us as suspend maintainers, too. If blame is the qualification, I guess I'm already part of this merry band:-) Change to Supported from Maintained, as the folks that sign my paycheck agree it is a good idea for me to help out on suspend. Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-25ACPI: update MAINTAINERSLen Brown
Newly minted project home page -- http://www.lesswatts.org/projects/acpi/ Konstantin moved on, so default back to Len for Thermal/Fan. Rui replaces Luming on video. Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-25lguest: Add to maintainers file.Rusty Russell
2007-10-23[VLAN]: MAINTAINERS updatePatrick McHardy
Ben stepped down from VLAN maintainership due to a lack of time, add myself as new maintainer. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-23Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (39 commits) Remove Andrew Morton from list of net driver maintainers. bonding: Acquire correct locks in alb for promisc change bonding: Convert more locks to _bh, acquire rtnl, for new locking bonding: Convert locks to _bh, rework alb locking for new locking bonding: Convert miimon to new locking bonding: Convert balance-rr transmit to new locking Convert bonding timers to workqueues Update MAINTAINERS to reflect my (jgarzik's) current efforts. pasemi_mac: fix typo defxx.c: dfx_bus_init() is __devexit not __devinit s390 MAINTAINERS remove header_ops bug in qeth driver sky2: crash on remove MIPSnet: Delete all the useless debugging printks. AR7 ethernet: small post-merge cleanups and fixes mv643xx_eth: Hook up mv643xx_get_sset_count mv643xx_eth: Remove obsolete checksum offload comment mv643xx_eth: Merge drivers/net/mv643xx_eth.h into mv643xx_eth.c mv643xx_eth: Remove unused register defines mv643xx_eth: Clean up mv643xx_eth.h ...
2007-10-23Remove Andrew Morton from list of net driver maintainers.Jeff Garzik
He now rules the world, not just this tiny tract of land. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Andrew Morton
2007-10-23Update MAINTAINERS to reflect my (jgarzik's) current efforts.Jeff Garzik
Remove net driver entries (they fall under the more general 'net driver maintainer') umbrella. Remove entries for older drivers that either no longer exist, are about to be removed, or I no longer care about. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-23s390 MAINTAINERSUrsula Braun
adding Frank Blaschka to s390 networking maintainers Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-23Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (39 commits) [SCSI] qla2xxx: Update version number to 8.02.00-k5. [SCSI] qla2xxx: Correct display of ISP serial-number. [SCSI] qla2xxx: Correct residual-count handling discrepancies during UNDERRUN handling. [SCSI] qla2xxx: Make driver (mostly) legacy I/O port free. [SCSI] qla2xxx: Fix issue where final flash-segment updates were falling into the slow-path write handler. [SCSI] qla2xxx: Handle unaligned sector writes during NVRAM/VPD updates. [SCSI] qla2xxx: Defer explicit interrupt-polling processing to init-time scenarios. [SCSI] qla2xxx: Resync with latest HBA SSID specification -- 2.2u. [SCSI] sym53c8xx: Remove sym_xpt_async_sent_bdr [SCSI] sym53c8xx: Remove pci_dev pointer from sym_shcb [SCSI] sym53c8xx: Make interrupt handler capable of returning IRQ_NONE [SCSI] sym53c8xx: Get rid of IRQ_FMT and IRQ_PRM [SCSI] sym53c8xx: Use scmd_printk where appropriate [SCSI] sym53c8xx: Simplify DAC DMA handling [SCSI] sym53c8xx: Remove tag_ctrl module parameter [SCSI] sym53c8xx: Remove io_ws, mmio_ws and ram_ws elements [SCSI] sym53c8xx: Remove ->device_id [SCSI] sym53c8xx: Use pdev->revision [SCSI] sym53c8xx: PCI Error Recovery support [SCSI] sym53c8xx: Stop overriding scsi_done ...
2007-10-23[POWERPC] Add Vitaly Bordug as PPC8xx maintainerMarcelo Tosatti
Vitaly has been doing most of the 8xx maintenance work. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-21[SCSI] aic7xxx: Update Maintainer informationHannes Reinecke
Might as well take the blame officially. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-20New maintainers for the x86 (32-bit and 64-bit) architectureIngo Molnar
Add new maintainers for the x86 (32-bit and 64-bit) architecture. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: fix first module build kconfig: update kconfig-language text kbuild: introduce cc-cross-prefix kbuild: disable depmod in cross-compile kernel build kbuild: make deb-pkg - add 'Provides:' line kconfig: comment typo in scripts/kconfig/Makefile. kbuild: stop docproc segfaulting when SRCTREE isn't set. kbuild: modpost problem when symbols move from one module to another kbuild: cscope - filter out .tmp_* in find_sources kbuild: mailing list has moved kbuild: check asm symlink when building a kernel
2007-10-18The next round of scheduled OSS code removalAdrian Bunk
This patch contains the next round of scheduled OSS code removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Kexec: Update URL in MAINTAINERS fileSigned-off-by@vergenet.net":Simon
I'm not sure that the new URL satifies the requirement of status/info, but it does at least as good a job as the old URL, and contains current releases of kexec-tools, rather than somewhat ancient versions. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18kbuild: mailing list has movedSam Ravnborg
The old list at sourceforge had a few issues: - it was subscriber-only - it were relying on moderation And I could see several mails did not get to the list lately so I decided this was a good time for a new list. I already requested marc.info to archieve the new list - and I dunno where else the old list was archieved but we ought to update. I have no access to the list of subscribers on the old list so people will have to subscribe manually. How to subscribe: send a mail to: majordomo@vger.kernel.org containing following text: subscribe linux-kbuild See also http://vger.kernel.org/vger-lists.html Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-17Change man-pages maintainer addressMichael Kerrisk
The email address that I use for man-pages maintenance has changed as of now. This patch changes the address in Documentation/HOWTO and MAINTAINERS. Signed-off-by: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ide-cd is unmaintainedAlan Cox
I simply don't have any old IDE systems any more or time to really look after this. Nobody responded to the previous linux-ide mail about maintainers so... Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17maintainers: linux-omap list is subscribers onlyRandy Dunlap
You are not allowed to post to this mailing list, and your message has been automatically rejected. If you think that your messages are being rejected in error, contact the mailing list owner at linux-omap-open-source-owner@linux.omap.com. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-15Merge branch 'v2.6.24-lockdep' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep * 'v2.6.24-lockdep' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep: lockdep: annotate dir vs file i_mutex lockdep: per filesystem inode lock class lockdep: annotate kprobes irq fiddling lockdep: annotate rcu_read_{,un}lock{,_bh} lockdep: annotate journal_start() lockdep: s390: connect the sysexit hook lockdep: x86_64: connect the sysexit hook lockdep: i386: connect the sysexit hook lockdep: syscall exit check lockdep: fixup mutex annotations lockdep: fix mismatched lockdep_depth/curr_chain_hash lockdep: Avoid /proc/lockdep & lock_stat infinite output lockdep: maintainers
