path: root/MAINTAINERS
2005-06-13[NET]: Move the netdev list to vger.kernel.org.Ralf Baechle
From: Ralf Baechle <ralf@linux-mips.org> There are archives of the old list at http://oss.sgi.com/archives/netdev Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-31[PATCH] I2C: ALI1563 SMBus driver fixR.Marek@sh.cvut.cz
This patch fixes "grave" bugs in i2c-ali1563 driver. It seems on recent chipset revisions the HSTS_DONE is set only for block transfers, so we must detect the end of ordinary transaction other way. Also due to missing and mask, setting other transfer modes was not possible. Moreover the continous byte mode transfer uses DAT0 for command rather than CMD command. All those changes were tested with help of Chunhao Huang from Winbond. I'm willing to maintain the driver. Second patch adds me as maintainer if this is neccessary. Signed-Off-By: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-17[PATCH] update sn2 maintainerJesse Barnes
Now that I'm no longer at SGI and don't have access to Altix equipment, it's time to pass on the job of patch monkey to someone else. Greg Edwards has foolishly^Wkindly volunteered for the job, so here's a patch to update the MAINTAINERS file with the appropriate information. Signed-off-by: Jesse Barnes <jesse.barnes@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-05-05[PATCH] orinoco MAINTAINERS updatePavel Roskin
Add mailing list addresses for Orinoco and update its homepage. Signed-off-by: Pavel Roskin <proski@gnu.org> Cc: David Gibson <hermes@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Fix Tpm driver -- Maintainers entryKylene Hall
This patch adds the maintainers entry. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fbdev MAINTAINERS updateBenjamin Herrenschmidt
This patch does the long overdue updates to MAINTAINERS file for aty128fb and radeonfb. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Maintainers list update: linux-net -> netdevHorms
Use netdev as the mailing list contact instead of the mostly dead linux-net list. Signed-off-by: Horms <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] MAINTAINERS: remove obsolete ACP/MWAVE MODEM entryAdrian Bunk
Both maintainer email addresses are bouncing and the web address is no longer valid. Seems to be a good time to remove the entry. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] update maintainer for /dev/randomMatt Mackall
Ted has agreed to let me take over as maintainer of /dev/random and friends. I've gone ahead and added a line to his entry in CREDITS. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
