Acked-by: Riku Voipio <riku.voipio@iki.fi>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits)
ethoc: limit the number of buffers to 128
ethoc: use system memory as buffer
ethoc: align received packet to make IP header at word boundary
ethoc: fix buffer address mapping
ethoc: fix typo to compute number of tx descriptors
au1000_eth: Duplicate test of RX_OVERLEN bit in update_rx_stats()
netxen: Fix Unlikely(x) > y
pasemi_mac: ethtool get settings fix
add maintainer for network drop monitor kernel service
tg3: Fix phylib locking strategy
rndis_host: support ETHTOOL_GPERMADDR
ipv4: arp_notify address list bug
gigaset: add kerneldoc comments
gigaset: correct debugging output selection
gigaset: improve error recovery
gigaset: fix device ERROR response handling
gigaset: announce if built with debugging
gigaset: handle isoc frame errors more gracefully
gigaset: linearize skb
gigaset: fix reject/hangup handling
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
agp: parisc-agp.c - use correct page_mask function
parisc: Fix linker script breakage.
parisc: convert to asm-generic/hardirq.h
parisc: Make THREAD_SIZE available to assembly files and linker scripts.
parisc: correct use of SHF_ALLOC
parisc: rename parisc's vmalloc_start to parisc_vmalloc_start
parisc: add me to Maintainers
parisc: includecheck fix: signal.c
parisc: HAVE_ARCH_TRACEHOOK
parisc: add skeleton syscall.h
parisc: stop using task->ptrace for {single,block}step flags
parisc: split syscall_trace into two halves
parisc: add missing TI_TASK macro in syscall.S
parisc: tracehook_signal_handler
parisc: tracehook_report_syscall
Add the file pattern of drivers/ieee1394/init_ohci1394_dma.c's
documentation to the maintainers database. init_ohci1394_dma.c is not
really part of the IEEE 1394 subsystem, but this maintainers contact
seems to be better than none at all.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Update Contec Micro9 maintainer and add entry in MAINTAINERS
Cc: Ryan Mallon <ryan@bluewatersys.com>
Requires: 5744/1
Signed-off-by: Hubert Feurstein <hubert.feurstein@contec.at>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Manfred Gruber <m.gruber@tirol.com>
I was getting ribbed about this earlier, so I figured I'd make it
official. Add myself as the maintainer of the drop monitor bits, so
people don't just gripe at Dave when it breaks (I'm sure it will never
break, but just in case :) ).
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'acpi-pad' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
acpi_pad: build only on X86
ACPI: create Processor Aggregator Device driver
Fixup trivial conflicts in MAINTAINERS file.
* master.kernel.org:/home/rmk/linux-2.6-arm: (25 commits)
ARM: 5728/1: Proper prefetch abort handling on ARMv6 and ARMv7
ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()
ARM: 5740/1: fix valid_phys_addr_range() range check
ARM: 5739/1: ARM: allow empty ATAG_CORE
ARM: 5735/1: sa1111: CodingStyle cleanups
ARM: 5738/1: Correct TCM documentation
ARM: 5734/1: arm: fix compilation of entry-common.S for older CPUs
ARM: 5733/1: fix bcmring compile error
ARM: 5732/1: remove redundant include file
ARM: 5731/2: Fix U300 generic GPIO, remove ifdefs from MMCI v3
ARM: Ensure do_cache_op takes mmap_sem
ARM: Fix __cpuexit section mismatch warnings
ARM: Don't allow highmem on SMP platforms without h/w TLB ops broadcast
ARM: includecheck fix: mach-davinci, board-dm365-evm.c
ARM: Remove unused CONFIG SA1100_H3XXX
ARM: Fix warning: unused variable 'highmem'
ARM: Fix warning: #warning syscall migrate_pages not implemented
ARM: Fix SA11x0 clocksource warning
ARM: Fix SA1100 Neponset serial section mismatch
ARM: Fix SA1100 Assabet/Neponset PCMCIA section mismatch warnings
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/xscaleiop
MAINTAINERS
[v2: fixed up virt_to_bus() issue spotted by sfr]
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Add new driver for Brocade Hardware
Signed-off-by: Jing Huang <huangj@brocade.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Tomas Cech <sleep_walker@suse.cz>
It has been suggested that given my proficiency with less popular
architectures, I should be officially listed as willing to see to the
care and feeding of this one.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
MAINTAINERS
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits)
x86/PCI: make 32 bit NUMA node array int, not unsigned char
x86/PCI: default pcibus cpumask to all cpus if it lacks affinity
MAINTAINTERS: remove hotplug driver entries
PCI: pciehp: remove slot capabilities definitions
PCI: pciehp: remove error message definitions
PCI: pciehp: remove number field
PCI: pciehp: remove hpc_ops
PCI: pciehp: remove pci_dev field
PCI: pciehp: remove crit_sect mutex
PCI: pciehp: remove slot_bus field
PCI: pciehp: remove first_slot field
PCI: pciehp: remove slot_device_offset field
PCI: pciehp: remove hp_slot field
PCI: pciehp: remove device field
PCI: pciehp: remove bus field
PCI: pciehp: remove slot_num_inc field
PCI: pciehp: remove num_slots field
PCI: pciehp: remove slot_list field
PCI: fix VGA arbiter header file
PCI: Disable AER with pci=nomsi
Fixed up trivial conflicts in MAINTAINERS
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Matt Mackall <mpm@selenic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6
* 'ixp4xx' of git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6:
Add MAINTAINERS entry for ARM/INTEL IXP4xx arch support.
ixp4xx: arch_idle() documentation fixup
ixp4xx: timer and clocks cleanups
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6
* 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6:
SFI: remove unneeded includes
sfi: Remove unused code
SFI: Hook PCI MMCONFIG
x86: add arch-specific SFI support
SFI: add capability to parse ACPI tables
SFI: add platform-independent core support
SFI: create linux/sfi.h
SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits)
ACPI: don't pass handle for fixed hardware notifications
ACPI: remove null pointer checks in deferred execution path
ACPI: simplify deferred execution path
acerhdf: additional BIOS versions
acerhdf: convert to dev_pm_ops
acerhdf: fix fan control for AOA150 model
thermal: add missing Kconfig dependency
acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file
hp-wmi: fix rfkill memory leak on unload
ACPI: remove unnecessary #ifdef CONFIG_DMI
ACPI: linux/acpi.h should not include linux/dmi.h
hwmon driver for ACPI 4.0 power meters
topstar-laptop: add new driver for hotkeys support on Topstar N01
thinkpad_acpi: fix rfkill memory leak on unload
thinkpad-acpi: report brightness events when required
thinkpad-acpi: don't poll by default any of the reserved hotkeys
thinkpad-acpi: Fix procfs hotkey reset command
thinkpad-acpi: deprecate hotkey_bios_mask
thinkpad-acpi: hotkey poll fixes
thinkpad-acpi: be more strict when detecting a ThinkPad
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Clearly mark ACPI drivers as such
i2c: Add driver for SMBus Control Method Interface
i2c-pnx: Correct use of request_region/request_mem_region
MAINTAINERS: Add maintainer for AT24 and PCA9564/PCA9665
i2c-piix4: Add AMD SB900 SMBus device ID
i2c/chips: Remove deprecated pcf8574 driver
i2c/chips: Remove deprecated pca9539 driver
i2c/chips: Remove deprecated pcf8575 driver
gpio/pcf857x: Copy i2c_device_id from old pcf8574 driver
i2c/scx200_acb: Provide more information on bus errors
i2c: Provide compatibility links for i2c adapters
i2c: Convert i2c adapters to bus devices
i2c: Convert i2c clients to a device type
i2c/tsl2550: Use combined SMBus transactions
i2c-taos-evm: Switch echo off to improve performance
i2c: Drop unused i2c_driver.id field
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (142 commits)
USB: Fix sysfs paths in documentation
USB: skeleton: fix coding style issues.
USB: O_NONBLOCK in read path of skeleton
USB: make usb-skeleton honor O_NONBLOCK in write path
USB: skel_read really sucks royally
USB: Add hub descriptor update hook for xHCI
USB: xhci: Support USB hubs.
USB: xhci: Set multi-TT field for LS/FS devices under hubs.
USB: xhci: Set route string for all devices.
USB: xhci: Fix command wait list handling.
USB: xhci: Change how xHCI commands are handled.
USB: xhci: Refactor input device context setup.
USB: xhci: Endpoint representation refactoring.
USB: gadget: ether needs to select CRC32
USB: fix USBTMC get_capabilities success handling
USB: fix missing error check in probing
USB: usbfs: add USBDEVFS_URB_BULK_CONTINUATION flag
USB: support for autosuspend in sierra while online
USB: ehci-dbgp,ehci: Allow dbpg to work with suspend/resume
USB: ehci-dbgp,documentation: Documentation updates for ehci-dbgp
* 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-score:
score: update email address in MAINTAINERS.
score: Cleanup linker script using new macros.
score: Make THREAD_SIZE available to assembly files.
score: Make PAGE_SIZE available to assembly.
Update maintainers entry for TI OMAP HS MMC support.
Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
Cc: <linux-mmc@vger.kernel.org>
On Saturday 01 August 2009 00:30:39 Mail Delivery Subsystem wrote:
> Delivery to the following recipient failed permanently:
> linware@sh.cvut.cz
> Technical details of permanent failure:
> Google tried to deliver your message, but it was rejected by the recipient
> domain. We recommend contacting the other email provider for further
> information about the cause of this error. The error that the other server
> returned was: 450 450 <linware@sh.cvut.cz>: Recipient address rejected:
> undeliverable address: unknown user: "linware" (state 14).
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Change the F entry for file rename, and make it also cover fsl_qe_udc
driver. Update the name accordingly.
Signed-off-by: Li Yang <leoli@freescale.com>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Joe Perches <joe@perches.com>
Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
trivial: fix typo in aic7xxx comment
trivial: fix comment typo in drivers/ata/pata_hpt37x.c
trivial: typo in kernel-parameters.txt
trivial: fix typo in tracing documentation
trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c
trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c
trivial: remove unnecessary semicolons
trivial: Fix duplicated word "options" in comment
trivial: kbuild: remove extraneous blank line after declaration of usage()
trivial: improve help text for mm debug config options
trivial: doc: hpfall: accept disk device to unload as argument
trivial: doc: hpfall: reduce risk that hpfall can do harm
trivial: SubmittingPatches: Fix reference to renumbered step
trivial: fix typos "man[ae]g?ment" -> "management"
trivial: media/video/cx88: add __init/__exit macros to cx88 drivers
trivial: fix typo in CONFIG_DEBUG_FS in gcov doc
trivial: fix missing printk space in amd_k7_smp_check
trivial: fix typo s/ketymap/keymap/ in comment
trivial: fix typo "to to" in multiple files
trivial: fix typos in comments s/DGBU/DBGU/
Add a driver for the the Consumer IR (CIR) functionality of the Winbond
WPCD376I chipset (found on e.g. Intel DG45FC motherboards).
Signed-off-by: David Härdeman <david@hardeman.nu>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
A couple of new uses of separate "P: name" "M: address" lines are
converted to single line "M: name <address>"
Cc: Anil Ravindranath <anil_ravindranath@pmc-sierra.com>
Cc: Kalle Valo <kalle.valo@nokia.com>
Otherwise 'arch/arm/*omap*/foo.c' wouldn't match
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
Signed-off-by: Hannes Eder <heder@google.com>
Remove myself as maintainer from the sdhci driver and steer people
towards the new MMC list for discussing it.
Signed-off-by: Pierre Ossman <pierre@ossman.eu>
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
The former address cannot be resolved.
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
- provide compatibility Kconfig entry for existing PERF_COUNTERS .config's
- provide courtesy copy of old perf_counter.h, for user-space projects
- small indentation fixups
- fix up MAINTAINERS
- fix small x86 printout fallout
- fix up small PowerPC comment fallout (use 'counter' as in register)
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <new-submission>
This adds Topstar Laptop Extras ACPI driver. It enables hotkeys
functionality with Topstar N01 netbook. Besides hotkeys there are
other functions exposed by its ACPI firmware, but for now only
hotkeys reporting on Topstar N01 is supported. Topstar is a chinese
manufacturer, its website can be currently reached at
http://www.topstardigital.cn/
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Reviewed-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Len Brown <len.brown@intel.com>
arch/x86/kernel/setup.c
drivers/acpi/power.c
init/main.c
Add me as the maintainer for the i2c drivers I feel responsible for as I
found patches going mainline I missed due to no Cc.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: David Brownell <dbrownell@users.sourceforge.net>
The old list has now been closed off; update the now invalid addresses.
* 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-score: (22 commits)
score: add TIF_NOTIFY_RESUME define in asm/thread_info.h
score: make init_thread_union align to THREAD_SIZE
score: update files according to review comments.
score: add old syscall support
score: add MEMORY_START and MEMORY_SIZE define, to make the code clear
score: update inconsistent declare after .c was changed
score: remove unused code, add include files in .c
score: clean up mm/init.c
score: make irq.h definitions local
score: cleanups: dead code, 0 as pointer, shadowed variables
score: fix function prototypes
score: add address space annotations
score: add missing #includes
score: move save arg5 and arg6 instruction in front of enable_irq
score: add prototypes for wrapped syscalls
score: remove init_mm
score: add generic sys_call_table
score: remove __{put,get}_user_unknown
score: unset __ARCH_WANT_IPC_PARSE_VERSION
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (55 commits)
regulator: Voltage count for AB3100
mfd: Convert WM8350 to use request_threaded_irq()
mfd: Update MAINTAINERS patterns for WM831x
mfd: Fix twl4030-power warnings
regulator: AB3100 support
rtc: AB3100 RTC support
mfd: Fix ab3100-otp build failure
mfd: OMAP: Board-specifc twl4030 DPS scripts for RX51 board
mfd: Print warning for twl4030 out-of-order script loading
mfd: Add support for TWL4030/5030 dynamic power switching
mfd: AB3100 OTP readout
regulator: Add Freescale MC13783 driver
mfd: Add Freescale MC13783 driver
mfd: AB3100 disable irq nosync
mfd: AB3100 alter default setting
mfd: AB3100 propagate error
mfd: AB3100 accessor function cleanups
rtc: Add support for RTCs on Wolfson WM831x devices
regulator: get pcap data from the parent device
input: PCAP2 misc input driver
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (62 commits)
DaVinci: DM646x - platform changes for vpif capture and display drivers
davinci: DM355 - platform changes for vpfe capture
davinci: DM644x platform changes for vpfe capture
davinci: audio: move tlv320aic33 i2c setup into board files
DaVinci: EDMA: Adding 2 new APIs for allocating/freeing PARAMs
DaVinci: DM365: Adding entries for DM365 IRQ's
DaVinci: DM355: Adding PINMUX entries for DM355 Display
davinci: Handle pinmux conflict between mmc/sd and nor flash
davinci: Add NOR flash support for da850/omap-l138
davinci: Add NAND flash support for DA850/OMAP-L138
davinci: Add MMC/SD support for da850/omap-l138
davinci: Add platform support for da850/omap-l138 GLCD
davinci: Macro to convert GPIO signal to GPIO pin number
davinci: Audio support for DA850/OMAP-L138 EVM
davinci: Audio support for DA830 EVM
davinci: Correct the number of GPIO pins for da850/omap-l138
davinci: Configure MDIO pins for EMAC
DaVinci: DM365: Add Support for new Revision of silicon
DaVinci: DM365: Fix Compilation issue due to PINMUX entry
DaVinci: EDMA: Updating default queue handling
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
ext3: Flush disk caches on fsync when needed
ext3: Add locking to ext3_do_update_inode
ext3: Fix possible deadlock between ext3_truncate() and ext3_get_blocks()
jbd: Annotate transaction start also for journal_restart()
jbd: Journal block numbers can ever be only 32-bit use unsigned int for them
ext3: Update MAINTAINERS for ext3 and JBD
JBD: round commit timer up to avoid uncommitted transaction
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits)
vsnprintf: remove duplicate comment of vsnprintf
softirq: add BLOCK_IOPOLL to softirq_to_name
oprofile: fix oprofile regression: select RING_BUFFER_ALLOW_SWAP
tracing: switch function prints from %pf to %ps
vsprintf: add %ps that is the same as %pS but is like %pf
tracing: Fix minor bugs for __unregister_ftrace_function_probe
tracing: remove notrace from __kprobes annotation
tracing: optimize global_trace_clock cachelines
MAINTAINERS: Update tracing tree details
ftrace: document function and function graph implementation
tracing: make testing syscall events a separate configuration
tracing: remove some unused macros
ftrace: add compile-time check on F_printk()
tracing: fix F_printk() typos
tracing: have TRACE_EVENT macro use __flags to not shadow parameter
tracing: add static to generated TRACE_EVENT functions
ring-buffer: typecast cmpxchg to fix PowerPC warning
tracing: add filter event logic to special, mmiotrace and boot tracers
tracing: remove trace_event_types.h
tracing: use the new trace_entries.h to create format files
