Add the x86 platform driver git tree to MAINTAINERS.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Progress on KVM for Embedded PowerPC has stalled, but for Book3S there's quite
a lot of work to do and going on.
So in agreement with Hollis and Avi, we should switch maintainers for PowerPC.
Acked-by: Hollis Blanchard <hollis@penguinppc.org>
Signed-off-by: Avi Kivity <avi@redhat.com>
drivers/firmware/iscsi_ibft.c
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits)
rcu: Fix accelerated GPs for last non-dynticked CPU
rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand boot
rcu: Fix accelerated grace periods for last non-dynticked CPU
rcu: Export rcu_scheduler_active
rcu: Make rcu_read_lock_sched_held() take boot time into account
rcu: Make lockdep_rcu_dereference() message less alarmist
sched, cgroups: Fix module export
rcu: Add RCU_CPU_STALL_VERBOSE to dump detailed per-task information
rcu: Fix rcutorture mod_timer argument to delay one jiffy
rcu: Fix deadlock in TREE_PREEMPT_RCU CPU stall detection
rcu: Convert to raw_spinlocks
rcu: Stop overflowing signed integers
rcu: Use canonical URL for Mathieu's dissertation
rcu: Accelerate grace period if last non-dynticked CPU
rcu: Fix citation of Mathieu's dissertation
rcu: Documentation update for CONFIG_PROVE_RCU
security: Apply lockdep-based checking to rcu_dereference() uses
idr: Apply lockdep-based diagnostics to rcu_dereference() uses
radix-tree: Disable RCU lockdep checking in radix tree
vfs: Abstract rcu_dereference_check for files-fdtable use
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86:
toshiba_acpi: Add full hotkey support
hp-wmi: Add support for tablet rotation key
dell-laptop: Add another Dell laptop to the DMI whitelist
classmate-laptop: use a single MODULE_DEVICE_TABLE to get correct aliases
dell-laptop: Pay attention to which devices the hardware switch controls
dell-laptop: Use buffer with 32-bit physical address
dell-laptop: Blacklist machines not supporting dell-laptop
dell-laptop: Block software state changes when rfkill hard blocked
dell-laptop: Fix small memory leak
dell-laptop: Fix platform device unregistration
dell-laptop: Update rfkill state on kill switch
compal-laptop: Replace sysfs support with rfkill support
compal-laptop: Add support for known Compal made Dell laptops
MAINTAINERS: update drivers/platform/x86 information
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6
* 'ibft-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft-2.6:
ibft: Update MAINTAINERS file.
drivers/firmware/iscsi_ibft.c: remove NIPQUAD_FMT, use %pI4
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (362 commits)
V4L-DVB: cx88-dvb: remove extra attribution for core
V4L/DVB: v4l: soc_camera: fix bound checking of mbus_fmt[] index
V4L/DVB: Add support for SMT7020 to cx88
V4L/DVB: radio-si470x: Use UTF-8 encoding on a comment
V4L/DVB: MAINTAINERS: Telegent tlg2300 section fix
V4L/DVB: gspca_stv06xx: Add support for camera button
V4L/DVB: gspca_ov519: add support for the button on ov511 based cams
V4L/DVB: gspca_ov519: Add support for the button on ov518 based cams
V4L/DVB: gspca_ov519: add support for the button on ov519 based cams
V4L/DVB: gspca_main: Fix a compile error when CONFIG_INPUT is not set
V4L/DVB: gspca_main: some input error handling fixes
V4L/DVB: gspca_main: Allow use of input device creation code for non int. inputs
V4L/DVB: gspca_pac7302: much improved exposure control
V4L/DVB: gspca_sonixb: Make sonixb driver handle pas106 and pas202 cameras
V4L/DVB: gspca_sonixb: pas106: fixup bright ctrl and add gain and exposure ctrls
V4L/DVB: Documentation: gspca.txt: update known mr97310a cams
V4L/DVB: gspca_mr97310a: add support for the Sakar 1638x CyberPix
V4L/DVB: gscpa_sonixb: limit ov7630 max framerate at 640x480
V4L/DVB: gspca_sonixb: pas202: fixup brightness ctrl and add gain and exposure ctrls
V4L/DVB: gscpa_sonixb: Differentiate between sensors with a coarse and fine expo ctrl
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (158 commits)
[SCSI] Fix printing of failed 32-byte commands
[SCSI] Fix printing of variable length commands
[SCSI] libsrp: fix bug in ADDITIONAL CDB LENGTH interpretation
[SCSI] scsi_dh_alua: Add IBM Power Virtual SCSI ALUA device to dev list
[SCSI] scsi_dh_alua: add netapp to dev list
[SCSI] qla2xxx: Update version number to 8.03.02-k1.
[SCSI] qla2xxx: EEH: Restore PCI saved state during pci slot reset.
[SCSI] qla2xxx: Add firmware ETS burst support.
[SCSI] qla2xxx: Correct loop-resync issues during SNS scans.
[SCSI] qla2xxx: Correct use-after-free issue in terminate_rport_io callback.
[SCSI] qla2xxx: Correct EH bus-reset handling.
[SCSI] qla2xxx: Proper clean-up of BSG requests when request times out.
[SCSI] qla2xxx: Initialize payload receive length in failure path of vendor commands
[SCSI] fix duplicate removal on error path in scsi_sysfs_add_sdev
[SCSI] fix refcounting bug in scsi_get_host_dev
[SCSI] fix memory leak in scsi_report_lun_scan
[SCSI] lpfc: correct PPC build failure
[SCSI] raid_class: add raid1e
[SCSI] mpt2sas: Do not call sas_is_tlr_enabled for RAID volumes.
[SCSI] zfcp: Introduce header file for qdio structs and inline functions
I am no longer with Marvell.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Provide the right e-mail and names for me and Peter.
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
linux-next commit 2ff8223957d901999bf76aaf2c6183e33a6ad14e
exposes an infinite loop defect in scripts/get_maintainer.pl
Fix the incorrect format of the MAINTAINERS "M:" entries.
Acked-by: Huang Shijie <shijie8@gmail.com>
pd-common.h contains the common data structures, while
vendorcmds.h contains the vendor commands for firmware.
[mchehab@redhat.com: Folded the 10 patches with the driver]
Signed-off-by: Huang Shijie <shijie8@gmail.com>
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/net/wireless/rt2x00/rt2800pci.c
Many of the drivers/platform/x86 drivers have nothing to do with ACPI, so
it's kind of inappropriate for them to be stuck under the ACPI mailing
list. Add a new mailing list (platform-driver-x86@vger.kernel.org) and,
with Len's blessing, add myself as subsystem maintainer.
Cc: Anisse Astier <anisse@astier.eu>
Cc: Carlos Corbacho <carlos@strangeworlds.co.uk>
Cc: Cezary Jackiewicz <cezary.jackiewicz@gmail.com>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Daniel Oliveira Nascimento <don@syst.com.br>
Cc: Harald Welte <laforge@gnumonks.org>
Cc: Henrique de Moraes Holschuh <ibm-acpi@hmh.eng.br>
Cc: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Cc: Jonathan Woithe <jwoithe@physics.adelaide.edu.au>
Cc: Karol Kozimor <sziwan@users.sourceforge.net>
Cc: Len Brown <lenb@kernel.org>
Cc: Lennart Poettering <mzxreary@0pointer.de>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Peter Feuerer <peter@piie.net>
Cc: Sujith Thomas <sujith.thomas@intel.com>
Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (44 commits)
Add MAINTAINERS entry for virtio_console
virtio: console: Fill ports' entire in_vq with buffers
virtio: console: Error out if we can't allocate buffers for control queue
virtio: console: Add ability to remove module
virtio: console: Ensure no memleaks in case of unused buffers
virtio: console: show error message if hvc_alloc fails for console ports
virtio: console: Add debugfs files for each port to expose debug info
virtio: console: Add ability to hot-unplug ports
virtio: console: Handle port hot-plug
virtio: console: Remove cached data on port close
virtio: console: Register with sysfs and create a 'name' attribute for ports
virtio: console: Ensure only one process can have a port open at a time
virtio: console: Add file operations to ports for open/read/write/poll
virtio: console: Associate each port with a char device
virtio: console: Prepare for writing to userspace buffers
virtio: console: Add a new MULTIPORT feature, support for generic ports
virtio: console: Introduce a send_buf function for a common path for sending data to host
virtio: console: Introduce function to hand off data from host to readers
virtio: console: Separate out find_vqs operation into a different function
virtio: console: Separate out console init into a new function
Merge reason: Update from -rc4 to -final.
I'm taking ownership of the virtio_console module; but I'll continue
feeding patches via Rusty.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net: bug fix for vlan + gro issue
tc35815: Remove a wrong netif_wake_queue() call which triggers BUG_ON
cdc_ether: new PID for Ericsson C3607w to the whitelist (resubmit)
IPv6: better document max_addresses parameter
MAINTAINERS: update mv643xx_eth maintenance status
e1000: Fix DMA mapping error handling on RX
iwlwifi: sanity check before counting number of tfds can be free
iwlwifi: error checking for number of tfds in queue
iwlwifi: set HT flags after channel in rxon
* master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: allow alignment fault mode to be configured at kernel boot
ARM: Update mach-types
ARM: 5951/1: ARM: fix documentation of the PrimeCell bus
ARM: 5950/1: ARM: Fix build error for arm1026ej-s processor
MAINTAINERS: fix my e-mail and status for Gemini and FA526
Gemini: wrong registers used to set reg_level in gpio_set_irq_type()
ARM: 5944/1: scsi: fix timer setup in fas216.c
ARM: 5938/1: ARM: L2: export outer_cache_fns
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
My nokia.com email address won't work anymore, use my private iki.fi address
instead.
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
Due to lack of time, space, motivation, hardware and probably expertise,
I have reluctantly decided to orphan the DECnet code in the kernel.
Judging by the deafening silence on the linux-decnet mailing list I
suspect it's either not being used anyway, or the few people that are
using it are happy with their older kernels.
Signed-Off-By: Christine Caulfield <christine.caulfield@googlemail.com>
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com>
Signed-off-by: Christine Caulfield <christine.caulfield@googlemail.com>
Adds device driver for Aeroflex Gaisler 10/100 and 10/100/1G Ethernet
MAC IP cores.
Signed-off-by: Kristoffer Glembo <kristoffer@gaisler.com>
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Change the LTP maintainer responsibities from 2010.
Ref: http://marc.info/?l=ltp-list&m=126502242912536&w=2
Signed-off-by : Rishikesh K Rajak <risrajak@linux.vnet.ibm.com>
Cc: Subrata Modak <subrata@linux.vnet.ibm.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Garrett Cooper <yanegomi@gmail.com>
Add self to MAINTAINERS for Freescale i.MX5 SoCs
Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com>
During the rc period, patches that are not bugfixes
should be done using the net-next tree.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Add igbvf to the list of supported Intel drivers and Alex to the list of
maintainers.
Mark ivtv-devel@ivtvdriver.org as 'moderated for non-subscribers'.
Acked-by: Andy Walls <awalls@radix.net>
Replaces Hans Verkuil by Andy Walls as the ivtv maintainer.
After 4 1/2 years, Hans decided to hand over the ivtv driver to Andy.
Andy was already doing more work on ivtv than him, so this just makes
official what was happening in practice.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Andy Walls <awalls@radix.net>
o Separate Ethernet driver for Qlogic CNA devices
Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com>
Dan Williams takes over I/OAT from Maciej Sosnowski
Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
What it is: vhost net is a character device that can be used to reduce
the number of system calls involved in virtio networking.
Existing virtio net code is used in the guest without modification.
There's similarity with vringfd, with some differences and reduced scope
- uses eventfd for signalling
- structures can be moved around in memory at any time (good for
migration, bug work-arounds in userspace)
- write logging is supported (good for migration)
- support memory table and not just an offset (needed for kvm)
common virtio related code has been put in a separate file vhost.c and
can be made into a separate module if/when more backends appear. I used
Rusty's lguest.c as the source for developing this part : this supplied
me with witty comments I wouldn't be able to write myself.
What it is not: vhost net is not a bus, and not a generic new system
call. No assumptions are made on how guest performs hypercalls.
Userspace hypervisors are supported as well as kvm.
How it works: Basically, we connect virtio frontend (configured by
userspace) to a backend. The backend could be a network device, or a tap
device. Backend is also configured by userspace, including vlan/mac
etc.
Status: This works for me, and I haven't see any crashes.
Compared to userspace, people reported improved latency (as I save up to
4 system calls per packet), as well as better bandwidth and CPU
utilization.
Features that I plan to look at in the future:
- mergeable buffers
- zero copy
- scalability tuning: figure out the best threading model to use
Note on RCU usage (this is also documented in vhost.h, near
private_pointer which is the value protected by this variant of RCU):
what is happening is that the rcu_dereference() is being used in a
workqueue item. The role of rcu_read_lock() is taken on by the start of
execution of the workqueue item, of rcu_read_unlock() by the end of
execution of the workqueue item, and of synchronize_rcu() by
flush_workqueue()/flush_work(). In the future we might need to apply
some gcc attribute or sparse annotation to the function passed to
INIT_WORK(). Paul's ack below is for this RCU usage.
(Includes fixes by Alan Cox <alan@linux.intel.com>,
David L Stevens <dlstevens@us.ibm.com>,
Chris Wright <chrisw@redhat.com>)
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
CC: Richard Henderson <rth@twiddle.net>
CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
CC: linux-alpha@vger.kernel.org
Signed-off-by: Matt Turner <mattst88@gmail.com>
Both rcutorture and RCU are supported. Also, update the files
to match the new layout.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <12626498422334-git-send-email->
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux:
OMAP: DSS2: OMAPFB: fix crash when panel driver was not loaded
OMAP: DSS2: Reject scaling settings when they cannot be supported
OMAP: DSS2: Make check-delay-loops consistent
OMAP: DSS2: OMAPFB: fix omapfb_free_fbmem()
video/omap: add __init/__exit macros to drivers/video/omap/lcd_htcherald.c
OMAP: DSS2: Fix compile warning
MAINTAINERS: Combine DSS2 and OMAPFB2 into one entry
MAINTAINERS: change omapfb maintainer
OMAP: OMAPFB: add dummy release function for omapdss
OMAP: OMAPFB: fix clk_get for RFBI
OMAP: DSS2: RFBI: convert to new kfifo API
OMAP: DSS2: Fix crash when panel doesn't define enable_te()
OMAP: DSS2: Collect interrupt statistics
OMAP: DSS2: DSI: print debug DCS cmd in hex
OMAP: DSS2: DSI: fix VC channels in send_short and send_null
There isn't really any reason to divide those.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
Acked-by: Imre Deak <imre.deak@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2:
nilfs2: update mailing list address
nilfs2: Storage class should be before const qualifier
nilfs2: trivial coding style fix
