path: root/MAINTAINERS
2011-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (54 commits) ipv6: check for IPv4 mapped addresses when connecting IPv6 sockets mlx4: decreasing ref count when removing mac net: Fix security_socket_sendmsg() bypass problem. net: Cap number of elements for sendmmsg net: sendmmsg should only return an error if no messages were sent ixgbe: fix PHY link setup for 82599 ixgbe: fix __ixgbe_notify_dca() bail out code igb: fix WOL on second port of i350 device e1000e: minor re-order of #include files e1000e: remove unnecessary check for NULL pointer intel drivers: repair missing flush operations macb: restore wrap bit when performing underrun cleanup cdc_ncm: fix endianness problem. irda: use PCI_VENDOR_ID_* mlx4: Fixing Ethernet unicast packet steering net: fix NULL dereferences in check_peer_redir() bnx2x: Clear MDIO access warning during first driver load bnx2x: Fix BCM578xx MAC test bnx2x: Fix BCM54618se invalid link indication bnx2x: Fix BCM84833 link ...
2011-08-03Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: cpuidle: stop depending on pm_idle x86 idle: move mwait_idle_with_hints() to where it is used cpuidle: replace xen access to x86 pm_idle and default_idle cpuidle: create bootparam "cpuidle.off=1" mrst_pmu: driver for Intel Moorestown Power Management Unit
2011-08-03Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: tcm_fc: Handle DDP/SW fc_frame_payload_get failures in ft_recv_write_data target: Fix bug for transport_generic_wait_for_tasks with direct operation target: iscsi_target depends on NET target: Fix WRITE_SAME_16 lba assignment breakage MAINTAINERS: Add target-devel list for drivers/target/ iscsi-target: Fix CONFIG_SMP=n and CONFIG_MODULES=n build failure iscsi-target: Fix snprintf usage with MAX_PORTAL_LEN iscsi-target: Fix uninitialized usage of cmd->pad_bytes iscsi-target: strlen() doesn't count the terminator iscsi-target: Fix NULL dereference on allocation failure
2011-08-03mrst_pmu: driver for Intel Moorestown Power Management UnitLen Brown
The Moorestown (MRST) Power Management Unit (PMU) driver directs the SOC power states in the "Langwell" south complex (SCU). It hooks pci_platform_pm_ops[] and thus observes all PCI ".set_state" requests. For devices in the SC, the pmu driver translates those PCI requests into the appropriate commands for the SCU. The PMU driver helps implement S0i3, a deep system idle power idle state. Entry into S0i3 is via cpuidle, just like regular processor c-states. S0i3 depends on pre-conditions including uni-processor, graphics off, and certain IO devices in the SC must be off. If those pre-conditions are met, then the PMU allows cpuidle to enter S0i3, otherwise such requests are demoted, either to Atom C4 or Atom C6. This driver is based on prototype work by Bruce Flemming, Illyas Mansoor, Rajeev D. Muralidhar, Vishwesh M. Rudramuni, Hari Seshadri and Sujith Thomas. The current driver also includes contributions from H. Peter Anvin, Arjan van de Ven, Kristen Accardi, and Yong Wang. Thanks for additional review feedback from Alan Cox and Randy Dunlap. Acked-by: Alan Cox <alan@linux.intel.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-02MAINTAINERS: Add keyword match for of_match_table to device tree sectionMark Brown
If a patch is working with an of_match_table it's probably adding an OF binding to a driver in which case the binding ought to be reviewed by the device tree folks to make sure that things like the device matches are set up correctly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-01doc: Update the MAINTAINERS info for Paul MoorePaul Moore
My @hp.com will no longer be valid starting August 5, 2011 so an update is necessary. My new email address is employer independent so we don't have to worry about doing this again any time soon. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01MAINTAINERS: Remove Pekka Savola from ipv6.David S. Miller
2011-07-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutilsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils: cpupower: Do detect IDA (opportunistic processor performance) via cpuid cpupower: Show Intel turbo ratio support via ./cpupower frequency-info cpupowerutils: increase MAX_LINE_LEN cpupower: Rename package from cpupowerutils to cpupower cpupowerutils: Rename: libcpufreq->libcpupower cpupowerutils: use kernel version-derived version string cpupowerutils: utils - ConfigStyle bugfixes cpupowerutils: helpers - ConfigStyle bugfixes cpupowerutils: idle_monitor - ConfigStyle bugfixes cpupowerutils: lib - ConfigStyle bugfixes cpupowerutils: bench - ConfigStyle bugfixes cpupowerutils: do not update po files on each and every compile cpupowerutils: remove ccdv, use kernel quiet/verbose mechanism cpupowerutils: use COPYING, CREDITS from top-level directory cpupowerutils - cpufrequtils extended with quite some features
2011-07-30Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits) hwmon: (lm90) Refactor reading of config2 register hwmon: (lm90) Make SA56004 detection more robust hwmon: (lm90) Simplify handling of extended local temp register hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066 hwmon: (max34440) Add support for peak attributes hwmon: (max8688) Add support for peak attributes hwmon: (max16064) Add support for peak attributes hwmon: (adm1275) Add support for peak attributes hwmon: (pmbus) Add support for peak attributes hwmon: Add new attributes to sysfs ABI hwmon: (pmbus) Strengthen check for status register existence hwmon: (pmbus) Add support for virtual pages hwmon: (pmbus) Support reading and writing of word registers in device specific code hwmon: (pmbus) Increase attribute name size hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devices hwmon: (pmbus) Add support for VID output voltage mode hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbus hwmon: (coretemp) Add core/pkg threshold support to Coretemp hwmon: (lm95241) Add support for LM95231 hwmon: LM95245 driver ...
2011-07-29cpupowerutils - cpufrequtils extended with quite some featuresDominik Brodowski
CPU power consumption vs performance tuning is no longer limited to CPU frequency switching anymore: deep sleep states, traditional dynamic frequency scaling and hidden turbo/boost frequencies are tied close together and depend on each other. The first two exist on different architectures like PPC, Itanium and ARM, the latter (so far) only on X86. On X86 the APU (CPU+GPU) will only run most efficiently if CPU and GPU has proper power management in place. Users and Developers want to have *one* tool to get an overview what their system supports and to monitor and debug CPU power management in detail. The tool should compile and work on as many architectures as possible. Once this tool stabilizes a bit, it is intended to replace the Intel-specific tools in tools/power/x86 Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-07-28MAINTAINERS: orphan FrameRelay DLCIJoe Perches
Mike McLagan hasn't contributed in many years and his email bounces. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-28hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbusGuenter Roeck
Since the number of PMBus drivers is getting large, move them into directory drivers/hwmon/pmbus to improve readability and scalability. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-07-28hwmon: Driver for MAX1668David George
This patch adds support for MAX1668 and compatible temperature sensors. Signed-off-by: David George <david.george@ska.ac.za> [guenter.roeck@ericsson.com: minor cleanup of probe error path] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits) tpm_nsc: Fix bug when loading multiple TPM drivers tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block tpm: Fix compilation warning when CONFIG_PNP is not defined TOMOYO: Update kernel-doc. tpm: Fix a typo tpm_tis: Probing function for Intel iTPM bug tpm_tis: Fix the probing for interrupts tpm_tis: Delay ACPI S3 suspend while the TPM is busy tpm_tis: Re-enable interrupts upon (S3) resume tpm: Fix display of data in pubek sysfs entry tpm_tis: Add timeouts sysfs entry tpm: Adjust interface timeouts if they are too small tpm: Use interface timeouts returned from the TPM tpm_tis: Introduce durations sysfs entry tpm: Adjust the durations if they are too small tpm: Use durations returned from TPM TOMOYO: Enable conditional ACL. TOMOYO: Allow using argv[]/envp[] of execve() as conditions. TOMOYO: Allow using executable's realpath and symlink's target as conditions. TOMOYO: Allow using owner/group etc. of file objects as conditions. ... Fix up trivial conflict in security/tomoyo/realpath.c
2011-07-27MAINTAINERS: Add target-devel list for drivers/target/Nicholas Bellinger
Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-07-26Merge branch 'next/soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: MAINTAINERS: add maintainer of CSR SiRFprimaII machine ARM: CSR: initializing L2 cache ARM: CSR: mapping early DEBUG_LL uart ARM: CSR: Adding CSR SiRFprimaII board support OMAP4: clocks: Update the clock tree with 4460 clock nodes OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts OMAP4: ID: add omap_has_feature for max freq supported OMAP: ID: introduce chip detection for OMAP4460 ARM: Xilinx: merge board file into main platform code ARM: Xilinx: Adding Xilinx board support Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
2011-07-26Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (31 commits) MIPS: Close races in TLB modify handlers. MIPS: Add uasm UASM_i_SRL_SAFE macro. MIPS: RB532: Use hex_to_bin() MIPS: Enable cpu_has_clo_clz for MIPS Technologies' platforms MIPS: PowerTV: Provide cpu-feature-overrides.h MIPS: Remove pointless return statement from empty void functions. MIPS: Limit fixrange_init() to the FIXMAP region MIPS: Install handlers for software IRQs MIPS: Move FIXADDR_TOP into spaces.h MIPS: Add SYNC after cacheflush MIPS: pfn_valid() is broken on low memory HIGHMEM systems MIPS: HIGHMEM DMA on noncoherent MIPS32 processors MIPS: topdown mmap support MIPS: Remove redundant addr_limit assignment on exec. MIPS: AR7: Replace __attribute__((__packed__)) with __packed MIPS: AR7: Remove 'space before tabs' in platform.c MIPS: Lantiq: Add missing clk_enable and clk_disable functions. MIPS: AR7: Fix trailing semicolon bug in clock.c MAINTAINERS: Update MIPS entry. MIPS: BCM63xx: Remove duplicate PERF_IRQSTAT_REG definition ...
2011-07-25Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (741 commits) staging:iio:meter:ade7753 should be 16 bit read not 8 bit for mode register. staging:iio:kfifo_buf fix double initialization of the ring device structure. staging:iio:accel:lis3l02dq: fix incorrect pointer passed to spi_set_drvdata. staging:iio:imu fix missing register table index for some channels spectra: enable device before poking it staging: rts_pstor: Fix a miswriting staging/lirc_bt829: Return -ENODEV when no hardware is found. staging/lirc_parallel: remove pointless prototypes. staging/lirc_parallel: fix panic on rmmod staging:iio:adc:ad7476: Incorrect pointer into spi_set_drvdata. Staging: zram: Fix kunmapping order Revert "gma500: Fix dependencies" gma500: Add medfield header gma500: wire up the mrst i2c bus from chip_info gma500: Fix DPU build gma500: Clean up the DPU config and make it runtime gma500: resync with Medfield progress gma500: Use the mrst helpers and power control for mode commit gma500@ Fix backlight range error gma500: More Moorestown muddle meddling means MM maybe might modeset ... Fix up fairly trivial conflicts all over, mostly due to header file cleanup conflicts, but some deleted files and some just context changes: - Documentation/feature-removal-schedule.txt - drivers/staging/bcm/headers.h - drivers/staging/brcm80211/brcmfmac/dhd_linux.c - drivers/staging/brcm80211/brcmfmac/dhd_sdio.c - drivers/staging/brcm80211/brcmfmac/wl_cfg80211.h - drivers/staging/brcm80211/brcmfmac/wl_iw.c - drivers/staging/et131x/et131x_netdev.c - drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c - drivers/staging/rtl8192e/r8192E.h - drivers/staging/usbip/userspace/src/utils.h
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25MAINTAINERS: update HIGH RESOLUTION TIMERS patternsJoe Perches
clockchips.h was typoed as clockevents.h Signed-off-by: Joe Perches <joe@perches.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (lm78) Become the maintainer hwmon: (lm78) Make ISA interface depend on CONFIG_ISA hwmon: (lm78) Avoid forward declarations hwmon: (sht15) Correct a comment mistake hwmon: (max1111) Avoid extra memory allocations hwmon: (it87) Add chassis intrusion detection support hwmon: (via-cputemp) Add VID reporting support hwmon-vid: Add support for VIA family 6 model D CPU hwmon: New driver sch5636 hwmon: (sch5627) Factor out some code shared with sch5636 driver
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-25hwmon: (lm78) Become the maintainerJean Delvare
Declare myself the maintainer of the lm78 driver. I still have a running system with one of these chips. Also count myself as a co-author of the driver. With 34 commits over 6 years, it seems fair. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (145 commits) bnx2x: use pci_pcie_cap() bnx2x: fix bnx2x_stop_on_error flow in bnx2x_sp_rtnl_task bnx2x: enable internal target-read for 57712 and up only bnx2x: count statistic ramrods on EQ to prevent MC assert bnx2x: fix loopback for non 10G link bnx2x: dcb - send all unmapped priorities to same COS as L2 iwlwifi: Fix build with CONFIG_PM disabled. gre: fix improper error handling ipv4: use RT_TOS after some rt_tos conversions via-velocity: remove duplicated #include qlge: remove duplicated #include igb: remove duplicated #include can: c_can: remove duplicated #include bnad: remove duplicated #include net: allow netif_carrier to be called safely from IRQ bna: Header File Consolidation bna: HW Error Counter Fix bna: Add HW Semaphore Unlock Logic bna: IOC Event Name Change bna: Mboxq Flush When IOC Disabled ...
2011-07-24Merge branch 'for-upstream' of git://openrisc.net/jonas/linuxLinus Torvalds
* 'for-upstream' of git://openrisc.net/jonas/linux: (24 commits) OpenRISC: Add MAINTAINERS entry OpenRISC: Miscellaneous OpenRISC: Library routines OpenRISC: Headers OpenRISC: Traps OpenRISC: Module support OpenRISC: GPIO OpenRISC: Scheduling/Process management OpenRISC: Idle/Power management OpenRISC: System calls OpenRISC: IRQ OpenRISC: Timekeeping OpenRISC: DMA OpenRISC: PTrace OpenRISC: Build infrastructure OpenRISC: Signal handling OpenRISC: Memory management OpenRISC: Device tree OpenRISC: Boot code iomap: make IOPORT/PCI mapping functions conditional ...
2011-07-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regulator: Convert tps65023 to use regmap API regmap: Add SPI bus support regmap: Add I2C bus support regmap: Add generic non-memory mapped register access API
2011-07-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (77 commits) [SCSI] fix crash in scsi_dispatch_cmd() [SCSI] sr: check_events() ignore GET_EVENT when TUR says otherwise [SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpu [SCSI] bfa: Update the driver version to 3.0.2.1 [SCSI] bfa: Driver and BSG enhancements. [SCSI] bfa: Added support to query PHY. [SCSI] bfa: Added HBA diagnostics support. [SCSI] bfa: Added support for flash configuration [SCSI] bfa: Added support to obtain SFP info. [SCSI] bfa: Added support for CEE info and stats query. [SCSI] bfa: Extend BSG interface. [SCSI] bfa: FCS bug fixes. [SCSI] bfa: DMA memory allocation enhancement. [SCSI] bfa: Brocade-1860 Fabric Adapter vHBA support. [SCSI] bfa: Brocade-1860 Fabric Adapter PLL init fixes. [SCSI] bfa: Added Fabric Assigned Address(FAA) support [SCSI] bfa: IOC bug fixes. [SCSI] bfa: Enable ASIC block configuration and query. [SCSI] bnx2i: Updated copyright and bump version [SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supported ... Fix up some trivial conflicts in: - drivers/scsi/bnx2fc/{bnx2fc.h,bnx2fc_fcoe.c}: Crazy broadcom version number conflicts - drivers/target/tcm_fc/tfc_cmd.c Just trivial cleanups done on adjacent lines
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits) ALSA: asihpi - Replace with snd_ctl_boolean_mono_info() ALSA: asihpi - HPI version 4.08 ALSA: asihpi - Add volume mute controls ALSA: asihpi - Control name updates ALSA: asihpi - Use size_t for sizeof result ALSA: asihpi - Explicitly include mutex.h ALSA: asihpi - Add new node and message defines ALSA: asihpi - Make local function static ALSA: asihpi - Fix minor typos and spelling ALSA: asihpi - Remove unused structures, macros and functions ALSA: asihpi - Remove spurious adapter index check ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro ALSA: asihpi - DSP code loader API now independent of OS ALSA: asihpi - Remove controlex structs and associated special data transfer code ALSA: asihpi - Increase request and response buffer sizes ALSA: asihpi - Give more meaningful name to hpi request message type ALSA: usb-audio - Add quirk for Roland / BOSS BR-800 ALSA: hda - Remove a superfluous argument of via_auto_init_output() ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs ALSA: hda - Add documentation for codec-specific mixer controls ...
2011-07-23Merge branch 'scsi-fixes'James Bottomley
2011-07-23regmap: Add generic non-memory mapped register access APIMark Brown
There are many places in the tree where we implement register access for devices on non-memory mapped buses, especially I2C and SPI. Since hardware designers seem to have settled on a relatively consistent set of register interfaces this can be effectively factored out into shared code. There are a standard set of formats for marshalling data for exchange with the device, with the actual I/O mechanisms generally being simple byte streams. We create an abstraction for marshaling data into formats which can be sent on the control interfaces, and create a standard method for plugging in actual transport underneath that. This is mostly a refactoring and renaming of the bottom level of the existing code for sharing register I/O which we have in ASoC. A subsequent patch in this series converts ASoC to use this. The main difference in interface is that reads return values by writing to a location provided by a pointer rather than in the return value, ensuring we can use the full range of the type for register data. We also use unsigned types rather than ints for the same reason. As some of the devices can have very large register maps the existing ASoC code also contains infrastructure for managing register caches. This cache work will be moved over in a future stage to allow for separate review, the current patch only deals with the physical I/O. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-22Merge branch 'for-davem' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-07-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (26 commits) IB/qib: Defer HCA error events to tasklet mlx4_core: Bump the driver version to 1.0 RDMA/cxgb4: Use printk_ratelimited() instead of printk_ratelimit() IB/mlx4: Support PMA counters for IBoE IB/mlx4: Use flow counters on IBoE ports IB/pma: Add include file for IBA performance counters definitions mlx4_core: Add network flow counters mlx4_core: Fix location of counter index in QP context struct mlx4_core: Read extended capabilities into the flags field mlx4_core: Extend capability flags to 64 bits IB/mlx4: Generate GID change events in IBoE code IB/core: Add GID change event RDMA/cma: Don't allow IPoIB port space for IBoE RDMA: Allow for NULL .modify_device() and .modify_port() methods IB/qib: Update active link width IB/qib: Fix potential deadlock with link down interrupt IB/qib: Add sysfs interface to read free contexts IB/mthca: Remove unnecessary read of PCI_CAP_ID_EXP IB/qib: Remove double define IB/qib: Remove unnecessary read of PCI_CAP_ID_EXP ...
2011-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1287 commits) icmp: Fix regression in nexthop resolution during replies. net: Fix ppc64 BPF JIT dependencies. acenic: include NET_SKB_PAD headroom to incoming skbs ixgbe: convert to ndo_fix_features ixgbe: only enable WoL for magic packet by default ixgbe: remove ifdef check for non-existent define ixgbe: Pass staterr instead of re-reading status and error bits from descriptor ixgbe: Move interrupt related values out of ring and into q_vector ixgbe: add structure for containing RX/TX rings to q_vector ixgbe: inline the ixgbe_maybe_stop_tx function ixgbe: Update ATR to use recorded TX queues instead of CPU for routing igb: Fix for DH89xxCC near end loopback test e1000: always call e1000_check_for_link() on e1000_ce4100 MACs. netxen: add fw version compatibility check be2net: request native mode each time the card is reset ipv4: Constrain UFO fragment sizes to multiples of 8 bytes virtio_net: Fix panic in virtnet_remove ipv6: make fragment identifications less predictable ipv6: unshare inetpeers can: make function can_get_bittiming static ...
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (78 commits) mmc: MAINTAINERS: add myself as a tmio-mmc maintainer mmc: print debug messages for runtime PM actions mmc: fix runtime PM with -ENOSYS suspend case mmc: at91_mci: move register header from include/ to drivers/ mmc: mxs-mmc: fix clock rate setting mmc: tmio: fix a deadlock mmc: tmio: fix a recently introduced bug in DMA code mmc: sh_mmcif: maximize power saving mmc: tmio: maximize power saving mmc: tmio: fix recursive spinlock, don't schedule with interrupts disabled mmc: Added quirks for Ricoh 1180:e823 lower base clock frequency mmc: omap_hsmmc: fix oops in omap_hsmmc_dma_cb() mmc: omap_hsmmc: refactor duplicated code mmc: omap_hsmmc: fix a few bugs when setting the clock divisor mmc: omap_hsmmc: introduce start_clock and re-use stop_clock mmc: omap_hsmmc: split duplicate code to calc_divisor() function mmc: omap_hsmmc: move hardcoded frequency constants to defines mmc: omap_hsmmc: correct debug report error status mnemonics mmc: block: fixed NULL pointer dereference mmc: documentation of mmc non-blocking request usage and design. ...
2011-07-22Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (32 commits) MAINTAINERS: change e-mail of Adrian Hunter UBIFS: fix master node recovery UBIFS: improve power cut emulation testing UBIFS: rename recovery testing variables UBIFS: remove custom list of superblocks UBIFS: stop re-defining UBI operations UBIFS: switch to I/O helpers UBIFS: switch to ubifs_leb_write UBIFS: switch to ubifs_leb_read UBIFS: introduce more I/O helpers UBIFS: always print stacktrace when switching to R/O mode UBIFS: remove unused and unneeded debugging function UBIFS: add global debugfs knobs UBIFS: introduce debugfs helpers UBIFS: re-arrange debugging code a bit UBIFS: be more informative in failure mode UBIFS: switch self-check knobs to debugfs UBIFS: lessen amount of debugging check types UBIFS: introduce helper functions for debugging checks and tests UBIFS: amend debugging inode size check function prototype ...
2011-07-22OpenRISC: Add MAINTAINERS entryJonas Bonn
Signed-off-by: Jonas Bonn <jonas@southpole.se> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22MAINTAINERS: change e-mail of Adrian HunterArtem Bityutskiy
... he does not work in Nokia any longer. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2011-07-21mmc: MAINTAINERS: add myself as a tmio-mmc maintainerGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-20MAINTAINERS: Update MIPS entry.Ralf Baechle
o Add entry for MIPS patchworks o Reorder entries for readability. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-20mmc: MAINTAINERS: change omap_hsmmc maintainence to orphanMadhusudhan Chikkature
Update the OMAP HSMMC entry from the MAINTAINERS file as I will no longer be able to maintain this driver. Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com> [khilman@ti.com: change to Orphan rather than complete removal] Signed-off-by: Kevin Hilman <khilman@ti.com> Acked-by: Venkatraman S <svenkatr@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-07-18MAINTAINERS: change maintainer of the wl1251 driverLuciano Coelho
Kalle Valo has asked me to take over the maintenance of the wl1251 driver. Thanks Kalle for all his work on the wl1251 driver, I'll try to keep up with his good work from now on. At the same time, update the Web URL to something more specific. There's not much in that page, but we will try to update it soon. Signed-off-by: Luciano Coelho <coelho@ti.com> Acked-by: Kalle Valo <kvalo@adurom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-15MAINTAINERS: add entry for Marvell mwifiex wireless driverBing Zhao
Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/bluetooth/l2cap_core.c
2011-07-13MAINTAINERS: Update ipath/qib (QLogic IB adapter) entriesMike Marciniszyn
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@qlogic.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-07-12MAINTAINERS: add maintainer of CSR SiRFprimaII machineBarry Song
Signed-off-by: Barry Song <baohua.song@csr.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12MAINTAINERS: Update PowerPC 4xx entryJosh Boyer
Update my email address Signed-off-by: Josh Boyer <jwboyer@gmail.com>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-10Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6994/1: smp_twd: Fix typo in 'twd_timer_rate' printing ARM: 6987/1: l2x0: fix disabling function to avoid deadlock ARM: 6966/1: ep93xx: fix inverted RTS/DTR signals on uart1 ARM: 6980/1: mmci: use StartBitErr to detect bad connections ARM: 6979/1: mach-vt8500: add forgotten irq_data conversion ARM: move memory layout sanity checking before meminfo initialization ARM: 6990/1: MAINTAINERS: add entry for ARM PMU profiling and debugging ARM: 6989/1: perf: do not start the PMU when no events are present ARM: dmabounce: fix map_single() error return value
