path: root/MAINTAINERS
2012-02-24MAINTAINERS: drop me from PA-RISC maintenanceKyle McMartin
I don't even live in the same country as any of my PA-RISC hardware these days, so the odds of me touching the code are pretty low. (Also re-order things to ensure jejb gets CC'd since he's been the primary maintainer for the last few years.) Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-22maintainers: update my email addressJames Morris
Update my email address. Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-02-09Merge tag 'staging-3.3-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Staging tree patches for 3.3-rc3 Big things here is the deletion of the Android pmem driver, as it's obsolete and no one uses it, the gma500 driver as it's already in the drm portion of the kernel tree, and the pohmelfs filesystem as it's obsolete and a rewritten version is being proposed for the fs/ section of the kernel. Other than that, a smattering of different bugfixes and regressions, and some omap drm api merge fixups that were needed due to api changes in the main portion of the drm tree, allowing this code to build properly again. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> * tag 'staging-3.3-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (28 commits) staging: pohmelfs: remove drivers/staging/pohmelfs staging: android/ram_console: Don't build on arches w/o ioremap staging: r8712u: Use asynchronous firmware loading staging: usbip: fix to prevent potentially using uninitialized spinlock staging: r8712u: Fix problem when CONFIG_R8712_AP is set staging: tidspbridge: fix incorrect free to drv_datap staging: tidspbridge: fix bridge_open memory leaks staging: android: lowmemorykiller: Don't wait more than one second for a process to die MAINTAINERS: staging: iio: add iio information staging: zcache: fix serialization bug in zv stats staging: fix go7007-usb license Staging: android: binder: Fix crashes when sharing a binder file between processes Staging: android: Remove pmem driver Staging: asus_oled: fix NULL-ptr crash on unloading Staging: asus_oled: fix image processing Staging: android: binder: Don't call dump_stack in binder_vma_open staging: r8712u: Add new Sitecom UsB ID zcache: Set SWIZ_BITS to 8 to reduce tmem bucket lock contention. zcache: fix deadlock condition staging: drm/omap: fix locking issue ...
2012-02-08MAINTAINERS: staging: iio: add iio informationAmeya Palande
Signed-off-by: Ameya Palande <ameya.palande@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-06Documentation: update quilt tree location for Documentation patchesRandy Dunlap
Update quilt tree location for Documentation/ patches. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-03MAINTAINERS: update lguest F: patternsJoe Perches
commit 07fe9977b623 ("lguest: move the lguest tool to the tools directory") moved the files, update the patterns. Sort F: patterns alphabetically too. Signed-off-by: Joe Perches <joe@perches.com> Cc: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-03MAINTAINERS: remove staging sectionsJoe Perches
Two commits moved files from staging to drivers/media/ commit d6ce55de3abcc ("[media] move cx25821 out of staging") commit be30497085080 ("[media] move tm6000 to drivers/media/video") Remove the sections. Signed-off-by: Joe Perches <joe@perches.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-03MAINTAINERS: remove iMX5 sectionJoe Perches
commit 784a90c0a7d8f5 ("ARM i.MX: Merge i.MX5 support into mach-imx") merged the files, remove the iMX5 section. Signed-off-by: Joe Perches <joe@perches.com> Cc: Amit Kucheria <amit.kucheria@canonical.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-03MAINTAINERS: update partitions block F: patternsJoe Perches
Commit 9be96f3fd101 ("move fs/partitions to block/") moved the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-01MAINTAINERS: Greg's suse email address is deadGreg KH
My email address has changed, the suse.de one is now dead, so update all of my MAINTAINER entries with the correct one so that patches don't get lost. Also change the status of some of my entries as I'm supposed to be doing this stuff now for real. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-31Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstreamLinus Torvalds
There are few important bug fixes for LogFS * tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream: Logfs: Allow NULL block_isbad() methods logfs: Grow inode in delete path logfs: Free areas before calling generic_shutdown_super() logfs: remove useless BUG_ON MAINTAINERS: Add Prasad Joshi in LogFS maintiners logfs: Propagate page parameter to __logfs_write_inode logfs: set superblock shutdown flag after generic sb shutdown logfs: take write mutex lock during fsync and sync logfs: Prevent memory corruption logfs: update page reference count for pined pages Fix up conflict in fs/logfs/dev_mtd.c due to semantic change in what "mtd->block_isbad" means in commit f2933e86ad93: "Logfs: Allow NULL block_isbad() methods" clashing with the abstraction changes in the commits 7086c19d0742: "mtd: introduce mtd_block_isbad interface" and d58b27ed58a3: "logfs: do not use 'mtd->block_isbad' directly". This resolution takes the semantics from commit f2933e86ad93, and just makes mtd_block_isbad() return zero (false) if the 'block_isbad' function is NULL. But that also means that now "mtd_can_have_bb()" always returns 0. Now, "mtd_block_markbad()" will obviously return an error if the low-level driver doesn't support bad blocks, so this is somewhat non-symmetric, but it actually makes sense if a NULL "block_isbad" function is considered to mean "I assume that all my blocks are always good".
2012-01-30Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (w83627ehf) Disable setting DC mode for pwm2, pwm3 on NCT6776F hwmon: (sht15) fix bad error code MAINTAINERS: Drop maintainer for MAX1668 hwmon driver MAINTAINERS: Add hwmon entries for Wolfson hwmon: (f71805f) Fix clamping of temperature limits
2012-01-30Merge tag 'tty-3.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Here are some tty/serial patches for 3.3-rc1 Big thing here is the movement of the 8250 serial drivers to their own directory, now that the patch churn has calmed down. Other than that, only minor stuff (omap patches were reverted as they were found to be wrong), and another broken driver removed from the system. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> * tag 'tty-3.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: serial: Kill off Moorestown code Revert "tty: serial: OMAP: ensure FIFO levels are set correctly in non-DMA mode" Revert "tty: serial: OMAP: transmit FIFO threshold interrupts don't wake the chip" serial: Fix wakeup init logic to speed up startup docbook: don't use serial_core.h in device-drivers book serial: amba-pl011: lock console writes against interrupts amba-pl011: do not disable RTS during shutdown tty: serial: OMAP: transmit FIFO threshold interrupts don't wake the chip tty: serial: OMAP: ensure FIFO levels are set correctly in non-DMA mode omap-serial: make serial_omap_restore_context depend on CONFIG_PM_RUNTIME omap-serial :Make the suspend/resume functions depend on CONFIG_PM_SLEEP. TTY: fix UV serial console regression jsm: Fixed EEH recovery error Updated TTY MAINTAINERS info serial: group all the 8250 related code together
2012-01-28MAINTAINERS: Add Prasad Joshi in LogFS maintinersPrasad Joshi
Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-27Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (31 commits) gma500: Fix suspend/resume functions drm/exynos: fixed pm feature for fimd module. MAINTAINERS: added maintainer entry for Exynos DRM Driver. drm/exynos: fixed build dependency for DRM_EXYNOS_FIMD drm/exynos: fix build dependency for DRM_EXYNOS_HDMI drm/exynos: use release_mem_region instead of release_resource agp: fix scratch page cleanup drm/i915: fixup forcewake spinlock fallout in drpc debugfs function drm/i915: debugfs: show semaphore registers also on gen7 drm/i915: allow userspace forcewake references also on gen7 drm/i915: Re-enable gen7 RC6 and GPU turbo after resume. drm/i915: Correct debugfs printout for RC1e. Revert "drm/i915: Work around gen7 BLT ring synchronization issues." drm/i915: rip out the HWSTAM missed irq workaround drm/i915: paper over missed irq issues with force wake voodoo drm/i915: Hold gt_lock across forcewake register reads drm/i915: Hold gt_lock during reset drm/i915: Move reset forcewake processing to gen6_do_reset drm/i915: protect force_wake_(get|put) with the gt_lock drm/i915: convert force_wake_get to func pointer in the gpu reset code ...
2012-01-26MAINTAINERS: Drop maintainer for MAX1668 hwmon driverGuenter Roeck
David no longer has access to MAX1688 hardware, so drop him from the maintainers list. Cc: David George <dgeorgester@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: David George <dgeorgester@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-01-26MAINTAINERS: Add hwmon entries for WolfsonMark Brown
The actual driver code seems to have been lost in the shuffle. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-27MAINTAINERS: added maintainer entry for Exynos DRM Driver.Inki Dae
I'd like to add my colleagues who dedicated to developing and improving our driver to maintainer entry. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-01-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Says Tyler: "Tim's logging message update will be really helpful to users when they're trying to locate a problematic file in the lower filesystem with filename encryption enabled. You'll recognize the fix from Li, as you commented on that. You should also be familiar with my setattr/truncate improvements, since you were the one that pointed them out to us (thanks again!). Andrew noted the /dev/ecryptfs write count sanitization needed to be improved, so I've got a fix in there for that along with some other less important cleanups of the /dev/ecryptfs read/write code." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: Fix oops when printing debug info in extent crypto functions eCryptfs: Remove unused ecryptfs_read() eCryptfs: Check inode changes in setattr eCryptfs: Make truncate path killable eCryptfs: Infinite loop due to overflow in ecryptfs_write() eCryptfs: Replace miscdev read/write magic numbers eCryptfs: Report errors in writes to /dev/ecryptfs eCryptfs: Sanitize write counts of /dev/ecryptfs ecryptfs: Remove unnecessary variable initialization ecryptfs: Improve metadata read failure logging MAINTAINERS: Update eCryptfs maintainer address
2012-01-25MAINTAINERS: Update eCryptfs maintainer addressDustin Kirkland
Update my email address in MAINTAINERS. Signed-off-by: Dustin Kirkland <dustin.kirkland@gazzang.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-01-24Updated TTY MAINTAINERS infoLucas Kannebley Tavares
Greg Kroah-Hartman is the current TTY maintainer, however he wouldn't appear listed as such upon running get_maintainers.pl for drivers under drivers/tty/serial. Signed-off-by: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-20MAINTAINERS: Add dma-buf sharing framework maintainerSumit Semwal
Adding maintainer info for dma-buf buffer sharing framework; some mailing lists interested in this work are also added. Signed-off-by: Sumit Semwal <sumit.semwal@ti.com> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Dave Airlie <airlied@redhat.com>
2012-01-18Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 SCSI updates on 20120118 * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (49 commits) [SCSI] libfc: remove redundant timer init for fcp [SCSI] fcoe: Move fcoe_debug_logging from fcoe.h to fcoe.c [SCSI] libfc: Declare local functions static [SCSI] fcoe: fix regression on offload em matching function for initiator/target [SCSI] qla4xxx: Update driver version to 5.02.00-k12 [SCSI] qla4xxx: Cleanup modinfo display [SCSI] qla4xxx: Update license [SCSI] qla4xxx: Clear the RISC interrupt bit during FW init [SCSI] qla4xxx: Added error logging for firmware abort [SCSI] qla4xxx: Disable generating pause frames in case of FW hung [SCSI] qla4xxx: Temperature monitoring for ISP82XX core. [SCSI] megaraid: fix sparse warnings [SCSI] sg: convert to kstrtoul_from_user() [SCSI] don't change sdev starvation list order without request dispatched [SCSI] isci: fix, prevent port from getting stuck in the 'configuring' state [SCSI] isci: fix start OOB [SCSI] isci: fix io failures while wide port links are coming up [SCSI] isci: allow more time for wide port targets [SCSI] isci: enable wide port targets [SCSI] isci: Fix IO fails when pull cable from phy in x4 wideport in MPC mode. ...
2012-01-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) tg3: Fix single-vector MSI-X code openvswitch: Fix multipart datapath dumps. ipv6: fix per device IP snmp counters inetpeer: initialize ->redirect_genid in inet_getpeer() net: fix NULL-deref in WARN() in skb_gso_segment() net: WARN if skb_checksum_help() is called on skb requiring segmentation caif: Remove bad WARN_ON in caif_dev caif: Fix typo in Vendor/Product-ID for CAIF modems bnx2x: Disable AN KR work-around for BCM57810 bnx2x: Remove AutoGrEEEn for BCM84833 bnx2x: Remove 100Mb force speed for BCM84833 bnx2x: Fix PFC setting on BCM57840 bnx2x: Fix Super-Isolate mode for BCM84833 net: fix some sparse errors net: kill duplicate included header net: sh-eth: Fix build error by the value which is not defined net: Use device model to get driver name in skb_gso_segment() bridge: BH already disabled in br_fdb_cleanup() net: move sock_update_memcg outside of CONFIG_INET mwl8k: Fixing Sparse ENDIAN CHECK warning ...
2012-01-17Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) ARM: mach-shmobile: specify CHCLR registers on SH7372 dma: shdma: fix runtime PM: clear channel buffers on reset dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit dmaengine/ste_dma40: clear LNK on channel startup dmaengine: intel_mid_dma: remove legacy pm interface ASoC: mxs: correct 'direction' of device_prep_dma_cyclic dmaengine: intel_mid_dma: error path fix dmaengine: intel_mid_dma: locking and freeing fixes mtd: gpmi-nand: move to dma_transfer_direction mtd: fix compile error for gpmi-nand mmc: mxs-mmc: fix the dma_transfer_direction migration dmaengine: add DMA_TRANS_NONE to dma_transfer_direction dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled. dma: mxs-dma: fix a typo in comment DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove video i.MX IPU: Fix display connections i.MX IPU DMA: Fix wrong burstsize settings dmaengine/ste_dma40: allow fixed physical channel ... Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c} The conflicts looked pretty trivial, but I'll ask people to verify them.
2012-01-18security: update MAINTAINERS file with new git repoJames Morris
Update MAINTAINERS file with new git repo: git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security.git Signed-off-by: James Morris <jmorris@namei.org>
2012-01-16MAINTAINERS: add b43 mailing listRafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-16MAINTAINERS: move BCMA to keep the list sortedRafał Miłecki
2012-01-16[SCSI] MAINTAINERS: pvscsi maintainers updateAlok Kataria
Welcome to Arvind Kumar, our new pvscsi maintainer. Signed-off-by: Alok N Kataria <akataria@vmware.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-01-15Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (655 commits) [media] revert patch: HDIC HD29L2 DMB-TH USB2.0 reference design driver mb86a20s: Add a few more register settings at the init seq mb86a20s: Group registers into the same line [media] [PATCH] don't reset the delivery system on DTV_CLEAR [media] [BUG] it913x-fe fix typo error making SNR levels unstable [media] cx23885: Query the CX25840 during enum_input for status [media] cx25840: Add support for g_input_status [media] rc-videomate-m1f.c Rename to match remote controler name [media] drivers: media: au0828: Fix dependency for VIDEO_AU0828 [media] convert drivers/media/* to use module_platform_driver() [media] drivers: video: cx231xx: Fix dependency for VIDEO_CX231XX_DVB [media] Exynos4 JPEG codec v4l2 driver [media] doc: v4l: selection: choose pixels as units for selection rectangles [media] v4l: s5p-tv: mixer: fix setup of VP scaling [media] v4l: s5p-tv: mixer: add support for selection API [media] v4l: emulate old crop API using extended crop/compose API [media] doc: v4l: add documentation for selection API [media] doc: v4l: add binary images for selection API [media] v4l: add support for selection api [media] hd29l2: fix review findings ...
2012-01-14Merge branch 'fbdev-next' of git://github.com/schandinat/linux-2.6Linus Torvalds
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (175 commits) module_param: make bool parameters really bool (drivers/video/i810) Revert "atmel_lcdfb: Adjust HFP calculation so it matches the manual." OMAPDSS: HDMI: Disable DDC internal pull up OMAPDSS: HDMI: Move duplicate code from boardfile OMAPDSS: add OrtusTech COM43H4M10XTC display support OMAP: DSS2: Support for UMSH-8173MD TFT panel ASoC: OMAP: HDMI: Move HDMI codec trigger function to generic HDMI driver OMAPDSS: HDMI: Create function to enable HDMI audio ASoC: OMAP: HDMI: Correct signature of ASoC functions ASoC: OMAP: HDMI: Introduce driver data for audio codec grvga: fix section mismatch warnings video: s3c-fb: Don't keep device runtime active when open video: s3c-fb: Hold runtime PM references when touching registers video: s3c-fb: Take a runtime PM reference when unblanked video: s3c-fb: Disable runtime PM in error paths from probe video: s3c-fb: Use s3c_fb_enable() to enable the framebuffer video: s3c-fb: Make runtime PM functional again drivers/video: fsl-diu-fb: merge fsl_diu_alloc() into map_video_memory() drivers/video: fsl-diu-fb: add default platform ops functions drivers/video: fsl-diu-fb: remove broken reference count enabling the display ...
2012-01-14Merge branch 'for-3.3' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.3' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: nfsd4_create_clid_dir return value is unused NFSD: Change name of extended attribute containing junction svcrpc: don't revert to SVC_POOL_DEFAULT on nfsd shutdown svcrpc: fix double-free on shutdown of nfsd after changing pool mode nfsd4: be forgiving in the absence of the recovery directory nfsd4: fix spurious 4.1 post-reboot failures NFSD: forget_delegations should use list_for_each_entry_safe NFSD: Only reinitilize the recall_lru list under the recall lock nfsd4: initialize special stateid's at compile time NFSd: use network-namespace-aware cache registering routines SUNRPC: create svc_xprt in proper network namespace svcrpc: update outdated BKL comment nfsd41: allow non-reclaim open-by-fh's in 4.1 svcrpc: avoid memory-corruption on pool shutdown svcrpc: destroy server sockets all at once svcrpc: make svc_delete_xprt static nfsd: Fix oops when parsing a 0 length export nfsd4: Use kmemdup rather than duplicating its implementation nfsd4: add a separate (lockowner, inode) lookup nfsd4: fix CONFIG_NFSD_FAULT_INJECTION compile error ...
2012-01-12MAINTAINERS: List i2c-omap and i2c-davinci driversJean Delvare
This will ensure that the right people and lists are notified when these drivers are modified. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Sekhar Nori <nsekhar@ti.com> Cc: Kevin Hilman <khilman@ti.com>
2012-01-12MAINTAINERS: i2c: Add third maintainerWolfram Sang
Add me as a third maintainer to help out in the i2c subsystem. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org>
2012-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits) ASoC: twl6040 - Add method to query optimum PDM_DL1 gain ALSA: hda - Fix the lost power-setup of seconary pins after PM resume ALSA: usb-audio: add Yamaha MOX6/MOX8 support ALSA: virtuoso: add S/PDIF input support for all Xonars ALSA: ice1724 - Support for ooAoo SQ210a ALSA: ice1724 - Allow card info based on model only ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations ALSA: hdspm - Provide unique driver id based on card serial ASoC: Dynamically allocate the rtd device for a non-empty release() ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs ALSA: hda - Use auto-parser for HP laptops with cx20459 codec ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info() ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref() ALSA: hda/cirrus - support for iMac12,2 model ASoC: cx20442: add bias control over a platform provided regulator ALSA: usb-audio - Avoid flood of frame-active debug messages ALSA: snd-usb-us122l: Delete calls to preempt_disable mfd: Put WM8994 into cache only mode when suspending ... Fix up trivial conflicts in: - arch/arm/mach-s3c64xx/mach-crag6410.c: renamed speyside_wm8962 to tobermory, added littlemill right next to it - drivers/base/regmap/{regcache.c,regmap.c}: duplicate diff that had already come in with other changes in the regmap tree
2012-01-10Merge tag 'for-linux-3.3-merge-window' of ↵Linus Torvalds
git://linux-c6x.org/git/projects/linux-c6x-upstreaming * tag 'for-linux-3.3-merge-window' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: (29 commits) C6X: replace tick_nohz_stop/restart_sched_tick calls C6X: add register_cpu call C6X: deal with memblock API changes C6X: fix timer64 initialization C6X: fix layout of EMIFA registers C6X: MAINTAINERS C6X: DSCR - Device State Configuration Registers C6X: EMIF - External Memory Interface C6X: general SoC support C6X: library code C6X: headers C6X: ptrace support C6X: loadable module support C6X: cache control C6X: clocks C6X: build infrastructure C6X: syscalls C6X: interrupt handling C6X: time management C6X: signal management ...
2012-01-10Merge branch 'akpm' (aka "Andrew's patch-bomb")Linus Torvalds
Andrew elucidates: - First installmeant of MM. We have a HUGE number of MM patches this time. It's crazy. - MAINTAINERS updates - backlight updates - leds - checkpatch updates - misc ELF stuff - rtc updates - reiserfs - procfs - some misc other bits * akpm: (124 commits) user namespace: make signal.c respect user namespaces workqueue: make alloc_workqueue() take printf fmt and args for name procfs: add hidepid= and gid= mount options procfs: parse mount options procfs: introduce the /proc/<pid>/map_files/ directory procfs: make proc_get_link to use dentry instead of inode signal: add block_sigmask() for adding sigmask to current->blocked sparc: make SA_NOMASK a synonym of SA_NODEFER reiserfs: don't lock root inode searching reiserfs: don't lock journal_init() reiserfs: delay reiserfs lock until journal initialization reiserfs: delete comments referring to the BKL drivers/rtc/interface.c: fix alarm rollover when day or month is out-of-range drivers/rtc/rtc-twl.c: add DT support for RTC inside twl4030/twl6030 drivers/rtc/: remove redundant spi driver bus initialization drivers/rtc/rtc-jz4740.c: make jz4740_rtc_driver static drivers/rtc/rtc-mc13xxx.c: make mc13xxx_rtc_idtable static rtc: convert drivers/rtc/* to use module_platform_driver() drivers/rtc/rtc-wm831x.c: convert to devm_kzalloc() drivers/rtc/rtc-wm831x.c: remove unused period IRQ handler ...
2012-01-10devfreq: add devfreq maintainer entryKyungmin Park
As devfreq is merged at mainline. Also update the maintainer entry. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Kevin Hilman <khilman@ti.com> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: spi: update F: patternsJoe Perches
commit ca632f55669 ("spi: reorganize drivers") renamed the files, update the F: patterns. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: serial:blackfin: update F: patternJoe Perches
commit 0c6967b5a0 ("serial:blackfin: rename Blackfin serial driver to bfin_uart.c") renamed the file, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: staging: media: update F: patternsJoe Perches
commit 4860c73804c ("staging: Move media drivers to staging/media") moved the files, update the F: patterns. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Mauro Carvalho Chehab<mchehab@redhat.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update encrypted-keys F: patternsJoe Perches
commit 61cf45d0199 ("encrypted-keys: create encrypted-keys directory") moved the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update greth F: patternsJoe Perches
commit 1fe003fd424 ("greth: Move the Aeroflex Gaisler driver") moved the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Kristoffer Glembo <kristoffer@gaisler.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update tulip F: patternsJoe Perches
commit a88394cfb58 ("ewrk3/tulip: Move the DEC - Tulip drivers") moved the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Tobias Ringstrom <tori@unhappy.mine.nu> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: David Davies <davies@maniac.ultranet.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update sdhci F: patternsJoe Perches
commit 38576af1f8c ("mmc: sdhci: make sdhci-of device drivers self registered") moved the files around. Update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Chris Ball <cjb@laptop.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update mfd F: patternsJoe Perches
commit 8959e74399c ("mfd: Delete ab3550 driver") removed the driver, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update marvell ccic F: patternsJoe Perches
Commit f8fc729870ee ("[media] marvell-cam: Move cafe-ccic into its own directory") moved the files, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Cc: Jonathan Corbet <corbet@lwn.net> Acked-by: Mauro Carvalho Chehab<mchehab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update bt8xx gpio F: patternsJoe Perches
Commit c103de240439d ("gpio: reorganize drivers") renamed the file, update the pattern. Signed-off-by: Joe Perches <joe@perches.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Michael Buesch <m@bues.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update adp gpio F: patternsJoe Perches
Commit c103de240439df ("gpio: reorganize drivers") renamed the files, update the patterns. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10MAINTAINERS: update various arm F: patternsJoe Perches
Track renames and missing or deleted files. Signed-off-by: Joe Perches <joe@perches.com> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
