path: root/MAINTAINERS
2007-02-03Pull asus into test branchLen Brown
2007-02-02[PATCH] MAINTAINERS: ufs entryEvgeniy Dushistov
Mark ufs file system as maintainable, and add me as maintainer, to help people find appropriate person to assign bugs. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] Remove avr32@atmel.com from MAINTAINERSHaavard Skinnemoen
avr32@atmel.com is a technical support address and is not really appropriate for sending patches. Lots of annoying automatics getting in the way. I'm still the maintainer of all the entries touched by this patch, so nothing changes with regard to the "Supported" status of the AVR32 architecture or the macb driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[MAINTAINERS]: netfilter@ is subscribers-onlyRandy Dunlap
netfilter mailing list is subscribers-only. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-30asus-laptop: add base driverCorentin Chary
Adds the new driver and make ASUS_LAPTOP and ACPI_ASUS incompatible. It may be strange to use ASUS_CREATE_DEVICE_ATTR and ASUS_SET_DEVICE_ATTR now, but these macro will be very usefull in next patchs. ASUS_HANDLE and ASUS_HANDLE_INIT comes from IBM_HANDLE and IBM_HANDLE_INIT, with some modification, and will also be used in next patchs. Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-27ide: update MAINTAINERS entryBartlomiej Zolnierkiewicz
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-01-26[PATCH] netdev: add a MAINTAINERS entry for via-velocity and update my addressFrancois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] md: update email address and status for MD in MAINTAINERSNeilBrown
Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] knfsd: update email address and status for NFSD in MAINTAINERSNeilBrown
2007-01-23[PATCH] email change for shemminger@osdl.orgStephen Hemminger
Change my email address to reflect OSDL merger. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> [ The irony. Somebody still has his sign-off message hardcoded in a script or his brainstem ;^] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-21HID: update MAINTAINERS entry for USB-HIDJiri Kosina
Change USB-HID maintainer from Vojtech Pavlik to Jiri Kosina. Acked-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-01-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: Revert "ACPI: ibm-acpi: make non-generic bay support optional" ACPI: update MAINTAINERS ACPI: schedule obsolete features for deletion ACPI: delete two spurious ACPI messages ACPI: rename cstate_entry_s to cstate_entry ACPI: ec: enable printk on cmdline use ACPI: Altix: ACPI _PRT support
2007-01-11Pull trivial into release branchLen Brown
2007-01-11ACPI: update MAINTAINERSLen Brown
s/Maintained/Supported/ and document some sub-maintainers for ACPI drivers. Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-10[PATCH] MAINTAINERS: maintainer for sata_promiseMikael Pettersson
This patch adds myself as maintainer of the sata_promise libata driver. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-08Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] Provide basic printk_clock() implementation [ARM] Resolve fuse and direct-IO failures due to missing cache flushes [ARM] pass vma for flush_anon_page() [ARM] Fix potential MMCI bug [ARM] Fix kernel-mode undefined instruction aborts [ARM] 4082/1: iop3xx: fix iop33x gpio register offset [ARM] 4070/1: arch/arm/kernel: fix warnings from missing includes [ARM] 4079/1: iop: Update MAINTAINERS
2007-01-06[ARM] 4079/1: iop: Update MAINTAINERSDan Williams
Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-06Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c/m41t00: Do not forget to write year i2c-mv64xxx: Fix random oops at boot i2c: Migration aids for i2c_adapter.dev removal i2c-pnx: Add entry to MAINTAINERS i2c-pnx: Fix interrupt handler, get rid of EARLY config option
2007-01-04Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: asus_acpi: new MAINTAINER ACPI: fix section mis-match build warning ACPI: increase ACPI_MAX_REFERENCE_COUNT for larger systems ACPI: EC: move verbose printk to debug build only backlight: fix backlight_device_register compile failures
2007-01-04i2c-pnx: Add entry to MAINTAINERSVitaly Wool
Add me to MAINTAINERS for i2c-pnx. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-01-03[PATCH] ide-cd maintainerJens Axboe
Alan agreed to take over casual maintenance of the ide-cd atapi cdrom driver, so I'm happy to sign it over to him. Alan, I hope the address is the one you want to use. I also changed the list to linux-ide as that seems more appropriate. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-02ACPI: asus_acpi: new MAINTAINERLen Brown
2006-12-30[PATCH] Update CREDITS and MAINTAINERS entries for Lennert BuytenhekLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-30[PATCH] MAINTAINERS: email addr change for Eric MooreEric Moore
Update to maintainers list. My employer has changed the domain from lsil to lsi. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (68 commits) ACPI: replace kmalloc+memset with kzalloc ACPI: Add support for acpi_load_table/acpi_unload_table_id fbdev: update after backlight argument change ACPI: video: Add dev argument for backlight_device_register ACPI: Implement acpi_video_get_next_level() ACPI: Kconfig - depend on PM rather than selecting it ACPI: fix NULL check in drivers/acpi/osl.c ACPI: make drivers/acpi/ec.c:ec_ecdt static ACPI: prevent processor module from loading on failures ACPI: fix single linked list manipulation ACPI: ibm_acpi: allow clean removal ACPI: fix git automerge failure ACPI: ibm_acpi: respond to workqueue update ACPI: dock: add uevent to indicate change in device status ACPI: ec: Lindent once again ACPI: ec: Change #define to enums there possible. ACPI: ec: Style changes. ACPI: ec: Acquire Global Lock under EC mutex. ACPI: ec: Drop udelay() from poll mode. Loop by reading status field instead. ACPI: ec: Rename gpe_bit to gpe ...
2006-12-22[PATCH] kernel-doc: remove Martin from MAINTAINERSMartin Waitz
I don't have the time to work on Linux Documentation, so I really should document that in MAINTAINERS. With Randy, kernel-doc is in good hands anyway. Signed-off-by: Martin Waitz <tali@admingilde.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] MAINTAINERS: fix email for S3C2410 and S3C2440Ben Dooks
Change the email address for the S3C2410 and S3C2440 maintainer. The old addresses have been deleted due to spam issues. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-20USB: MAINTAINERS update, EHCI and OHCIDavid Brownell
Update maintainer records for two USB host controller drivers. I'm the main point of contact for both EHCI and OHCI, although I don't have much time for them any more. Roman hasn't submitted OHCI patches for years. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20merge linus into test branchLen Brown
2006-12-16Pull trivial into test branchLen Brown
Conflicts: drivers/acpi/ec.c
2006-12-14[PATCH] Generic HID layer - update MAINTAINERSJiri Kosina
Update MAINTAINERS entry for HID core layer. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2006-12-13Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: Add MAINTAINERS entry for new ams driver hwmon: New AMS hardware monitoring driver hwmon/w83793: Add documentation and maintainer hwmon: New Winbond W83793 hardware monitoring driver hwmon: Update Rudolf Marek's e-mail address hwmon/f71805f: Fix the device address decoding hwmon/f71805f: Always create all fan inputs hwmon/f71805f: Add support for the Fintek F71872F/FG chip hwmon: New PC87427 hardware monitoring driver hwmon/it87: Remove the SMBus interface support hwmon/hdaps: Update the list of supported devices hwmon/hdaps: Move the DMI detection data to .data hwmon/pc87360: Autodetect the VRM version hwmon/f71805f: Document the fan control features hwmon/f71805f: Add support for "speed mode" fan speed control hwmon/f71805f: Support DC fan speed control mode hwmon/f71805f: Let the user adjust the PWM base frequency hwmon/f71805f: Add manual fan speed control hwmon/f71805f: Store the fan control registers
2006-12-13[PATCH] KVM: Add MAINTAINERS entryAvi Kivity
Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Fix inotify maintainers entry Fix typo in new debug options. Jon needs a new shift key. fs: Convert kmalloc() + memset() to kzalloc() in fs/. configfs.h: Remove dead macro definitions. kconfig: Standardize "depends" -> "depends on" in Kconfig files e100: replace kmalloc with kcalloc um: replace kmalloc+memset with kzalloc fix typo in net/ipv4/ip_fragment.c include/linux/compiler.h: reject gcc 3 < gcc 3.2 Kconfig: fix spelling error in config KALLSYMS help text Remove duplicate "have to" in comment Fix small typo in drivers/serial/icom.c Use consistent casing in help message EXT{2,3,4}_FS: remove outdated part of the help text
2006-12-12Merge ../linusDave Jones
Conflicts: drivers/cpufreq/cpufreq.c
2006-12-12[CPUFREQ] Fix git URL.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com>
2006-12-12Fix inotify maintainers entryCal Peake
Update the inotify entry in MAINTAINERS to be consistent with the rest of the file. Signed-off-by: Cal Peake <cp@absolutedigital.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-12hwmon: Add MAINTAINERS entry for new ams driverStelian Pop
Signed-off-by: Stelian Pop <stelian@popies.net> Acked-by: Michael Hanselmann <linux-kernel@hansmi.ch> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-12hwmon/w83793: Add documentation and maintainerRudolf Marek
Documentation for the new w83793 hardware monitoring driver, originally provided by Yuan My from Winbond. Also add myself as the maintainer of this driver. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-12hwmon: Update Rudolf Marek's e-mail addressJean Delvare
The Silicon Hill club is not what it used to be. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10[PATCH] update MAINTAINERS with rtc-linux mailing list infoAlessandro Zummo
2006-12-08[PATCH] linux-fbdev-devel is subscribers-onlyRandy Dunlap
Update linux-fbdev mailing list to subscribers-only. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] isicom, mxser MAINTAINERS updateJiri Slaby
I can maintain moxa and isicom char drivers, because I've rewritten them to the new API. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (76 commits) [ARM] 4002/1: S3C24XX: leave parent IRQs unmasked [ARM] 4001/1: S3C24XX: shorten reboot time [ARM] 3983/2: remove unused argument to __bug() [ARM] 4000/1: Osiris: add third serial port in [ARM] 3999/1: RX3715: suspend to RAM support [ARM] 3998/1: VR1000: LED platform devices [ARM] 3995/1: iop13xx: add iop13xx support [ARM] 3968/1: iop13xx: add iop13xx_defconfig [ARM] Update mach-types [ARM] Allow gcc to optimise arm_add_memory a little more [ARM] 3991/1: i.MX/MX1 high resolution time source [ARM] 3990/1: i.MX/MX1 more precise PLL decode [ARM] 3986/1: H1940: suspend to RAM support [ARM] 3985/1: ixp4xx clocksource cleanup [ARM] 3984/1: ixp4xx/nslu2: Fix disk LED numbering (take 2) [ARM] 3994/1: ixp23xx: fix handling of pci master aborts [ARM] 3981/1: sched_clock for PXA2xx [ARM] 3980/1: extend the ARM Versatile sched_clock implementation from 32 to 63 bit [ARM] 3979/1: extend the SA11x0 sched_clock implementation from 32 to 63 bit period [ARM] 3978/1: macro to provide a 63-bit value from a 32-bit hardware counter ...
2006-12-07[PATCH] Update ext[23] mailing list addressErik Mouw
The ext[23] mailing list moved from sf.net to vger.kernel.org so update the MAINTAINERS file. Signed-off-by: Erik Mouw <erik@harddisk-recovery.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] MAINTAINERS: remove the non-existing sun3 listAdrian Bunk
sun3-list@redhat.com does no longer exist. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] MAINTAINERS: Update the i2c and hwmon subsystems infoJean Delvare
The i2c and hwmon trees have moved to a new location. The lm-sensors project moved to a new home as well. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] serial uartlite driverPeter Korsgaard
Add a driver for the Xilinx uartlite serial controller used in boards with the PPC405 core in the Xilinx V2P/V4 fpgas. The hardware is very simple (baudrate/start/stopbits fixed and no break support). See the datasheet for details: http://www.xilinx.com/bvdocs/ipcenter/data_sheet/opb_uartlite.pdf See http://thread.gmane.org/gmane.linux.serial/1237/ for the email thread. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Olof Johansson <olof@lixom.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04Merge master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc: (194 commits) [POWERPC] Add missing EXPORTS for mpc52xx support [POWERPC] Remove obsolete PPC_52xx and update CLASSIC32 comment [POWERPC] ps3: add a default zImage target [POWERPC] Add of_platform_bus support to mpc52xx psc uart driver [POWERPC] typo fix and whitespace cleanup on mpc52xx-uart driver [POWERPC] Fix debug printks for 32-bit resources in the PCI code [POWERPC] Replace kmalloc+memset with kzalloc [POWERPC] Linkstation / kurobox support [POWERPC] Add the e300c3 core to the CPU table. [POWERPC] ppc: m48t35 add missing bracket [POWERPC] iSeries: don't build head_64.o unnecessarily [POWERPC] iSeries: stop dt_mod.o being rebuilt unnecessarily [POWERPC] Fix cputable.h for combined build [POWERPC] Allow CONFIG_BOOTX_TEXT on iSeries [POWERPC] Allow xmon to build on legacy iSeries [POWERPC] Change ppc64_defconfig to use AUTOFS_V4 not V3 [POWERPC] Tell firmware we can handle POWER6 compatible mode [POWERPC] Clean images in arch/powerpc/boot [POWERPC] Fix OF pci flags parsing [POWERPC] defconfig for lite5200 board ...
2006-12-04[ARM] 3976/1: AT91: MAINTAINERS entryAndrew Victor
Added MAINTAINERS entry for the Atmel AT91RM9200. Accept (some) responsibility... Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
