git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Documentation improvements: conversion of all non-DocBook documents
to Sphinx and lots of fixes to the uAPI media book
- New PCI driver for Techwell TW5864 media grabber boards
- New SoC driver for ATMEL Image Sensor Controller
- Removal of some obsolete SoC drivers (s5p-tv driver and soc_camera
drivers)
- Addition of ST CEC driver
- Lots of drivers fixes, improvements and additions
* tag 'media/v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (464 commits)
[media] ttusb_dec: avoid the risk of go past buffer
[media] cx23885: Fix some smatch warnings
[media] si2165: switch to regmap
[media] si2165: use i2c_client->dev instead of i2c_adapter->dev for logging
[media] si2165: Remove legacy attach
[media] cx231xx: attach si2165 driver via i2c_client
[media] cx231xx: Prepare for attaching new style i2c_client DVB demod drivers
[media] cx23885: attach si2165 driver via i2c_client
[media] si2165: support i2c_client attach
[media] si2165: avoid division by zero
[media] rcar-vin: add R-Car gen2 fallback compatibility string
[media] lgdt3306a: remove 20*50 msec unnecessary timeout
[media] cx25821: Remove deprecated create_singlethread_workqueue
[media] cx25821: Drop Freeing of Workqueue
[media] cxd2841er: force 8MHz bandwidth for DVB-C if specified bw not supported
[media] redrat3: hardware-specific parameters
[media] redrat3: remove hw_timeout member
[media] cxd2841er: BER and SNR reading for ISDB-T
[media] dvb-usb: avoid link error with dib3000m{b,c|
[media] dvb-usb: split out common parts of dibusb
Pull networking fixes from David Miller:
1) Netfilter list handling fix, from Linus.
2) RXRPC/AFS bug fixes from David Howells (oops on call to serviceless
endpoints, build warnings, missing notifications, etc.) From David
Howells.
3) Kernel log message missing newlines, from Colin Ian King.
4) Don't enter direct reclaim in netlink dumps, the idea is to use a
high order allocation first and fallback quickly to a 0-order
allocation if such a high-order one cannot be done cheaply and
without reclaim. From Eric Dumazet.
5) Fix firmware download errors in btusb bluetooth driver, from Ethan
Hsieh.
6) Missing Kconfig deps for QCOM_EMAC, from Geert Uytterhoeven.
7) Fix MDIO_XGENE dup Kconfig entry. From Laura Abbott.
8) Constrain ipv6 rtr_solicits sysctl values properly, from Maciej
Żenczykowski.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits)
netfilter: Fix slab corruption.
be2net: Enable VF link state setting for BE3
be2net: Fix TX stats for TSO packets
be2net: Update Copyright string in be_hw.h
be2net: NCSI FW section should be properly updated with ethtool for BE3
be2net: Provide an alternate way to read pf_num for BEx chips
wan/fsl_ucc_hdlc: Fix size used in dma_free_coherent()
net: macb: NULL out phydev after removing mdio bus
xen-netback: make sure that hashes are not send to unaware frontends
Fixing a bug in team driver due to incorrect 'unsigned int' to 'int' conversion
MAINTAINERS: add myself as a maintainer of xen-netback
ipv6 addrconf: disallow rtr_solicits < -1
Bluetooth: btusb: Fix atheros firmware download error
drivers: net: phy: Correct duplicate MDIO_XGENE entry
ethernet: qualcomm: QCOM_EMAC should depend on HAS_DMA and HAS_IOMEM
net: ethernet: mediatek: remove hwlro property in the device tree
net: ethernet: mediatek: get hw lro capability by the chip id instead of by the dtsi
net: ethernet: mediatek: get the chip id by ETHDMASYS registers
net: bgmac: Fix errant feature flag check
netlink: do not enter direct reclaim from netlink_dump()
Pull MTD updates from Brian Norris:
"I've not been very active this cycle, so these are mostly from Boris,
for the NAND flash subsystem.
NAND:
- Add the infrastructure to automate NAND timings configuration
- Provide a generic DT property to maximize ECC strength
- Some refactoring in the core bad block table handling, to help with
improving some of the logic in error cases.
- Minor cleanups and fixes
MTD:
- Add APIs for handling page pairing; this is necessary for reliably
supporting MLC and TLC NAND flash, where paired-page disturbance
affects reliability. Upper layers (e.g., UBI) should make use of
these in the near future"
* tag 'for-linus-20161008' of git://git.infradead.org/linux-mtd: (35 commits)
mtd: nand: fix trivial spelling error
mtdpart: Propagate _get/put_device()
mtd: nand: Provide nand_cleanup() function to free NAND related resources
mtd: Kill the OF_MTD Kconfig option
mtd: nand: mxc: Test CONFIG_OF instead of CONFIG_OF_MTD
mtd: nand: Fix nand_command_lp() for 8bits opcodes
mtd: nand: sunxi: Support ECC maximization
mtd: nand: Support maximizing ECC when using software BCH
mtd: nand: Add an option to maximize the ECC strength
mtd: nand: mxc: Add timing setup for v2 controllers
mtd: nand: mxc: implement onfi get/set features
mtd: nand: sunxi: switch from manual to automated timing config
mtd: nand: automate NAND timings selection
mtd: nand: Expose data interface for ONFI mode 0
mtd: nand: Add function to convert ONFI mode to data_interface
mtd: nand: convert ONFI mode into data interface
mtd: nand: Introduce nand_data_interface
mtd: nand: Create a NAND reset function
mtd: nand: remove unnecessary 'extern' from function declarations
MAINTAINERS: Add maintainer entry for Ingenic JZ4780 NAND driver
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull main rdma updates from Doug Ledford:
"This is the main pull request for the rdma stack this release. The
code has been through 0day and I had it tagged for linux-next testing
for a couple days.
Summary:
- updates to mlx5
- updates to mlx4 (two conflicts, both minor and easily resolved)
- updates to iw_cxgb4 (one conflict, not so obvious to resolve,
proper resolution is to keep the code in cxgb4_main.c as it is in
Linus' tree as attach_uld was refactored and moved into
cxgb4_uld.c)
- improvements to uAPI (moved vendor specific API elements to uAPI
area)
- add hns-roce driver and hns and hns-roce ACPI reset support
- conversion of all rdma code away from deprecated
- security improvement: remove unsafe ib_get_dma_mr (breaks lustre in
staging)"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (75 commits)
staging/lustre: Disable InfiniBand support
iw_cxgb4: add fast-path for small REG_MR operations
cxgb4: advertise support for FR_NSMR_TPTE_WR
IB/core: correctly handle rdma_rw_init_mrs() failure
IB/srp: Fix infinite loop when FMR sg[0].offset != 0
IB/srp: Remove an unused argument
IB/core: Improve ib_map_mr_sg() documentation
IB/mlx4: Fix possible vl/sl field mismatch in LRH header in QP1 packets
IB/mthca: Move user vendor structures
IB/nes: Move user vendor structures
IB/ocrdma: Move user vendor structures
IB/mlx4: Move user vendor structures
IB/cxgb4: Move user vendor structures
IB/cxgb3: Move user vendor structures
IB/mlx5: Move and decouple user vendor structures
IB/{core,hw}: Add constant for node_desc
ipoib: Make ipoib_warn ratelimited
IB/mlx4/alias_GUID: Remove deprecated create_singlethread_workqueue
IB/ipoib_verbs: Remove deprecated create_singlethread_workqueue
IB/ipoib: Remove deprecated create_singlethread_workqueue
Pull ARM DT updates from Arnd Bergmann:
"These are as usual a very large number of mostly boring updates to
enable devices in existing machines, or to fix minor bugs. Notably, an
ongoing treewide effort to fix warnings caused by an update to the
device tree compiler. These are enabled with "make W=1" at the moment
but can hopefully become the default once all issues have been
addressed.
No new SoC platform is added this time around (Armada 395 and Orion
mv88f5181 are slight variations of existing ones), but a significant
number of new dts files are added, which I list by platform:
- Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets,
Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite,
Olimex A33-Olinuxino, and Nano Pi Neo single-board computers
- ARM Realview: all supported machines (ported from board files)
- Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and
BCM958622hr reference boards for Northstar platform, Raspberry Pi
Zero single-board computer
- Marvell EBU: Netgear WNR854T router (ported from board file),
Armada 395 SoC platform and GP board Armada 390 DB development
board
- NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x
single-board computer, Technologic Systems TS-4900 and Engicam
IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board
- Qualcomm: LG Nexus 5 Phone
- Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards
- Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288
Reload platform
- ST Microelectronics STi: B2260 (96boards) single-board computer
- TI Davinci: OMAP-L138 LCDK Development kit
- TI OMAP: beagleboard-x15 rev B1 single-board computer"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits)
ARM: dts: sony-nsz-gs7: add missing unit name to /memory node
ARM: dts: chromecast: add missing unit name to /memory node
ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node
ARM: dts: berlin2: Add missing unit name to /soc node
ARM: dts: berlin2cd: Add missing unit name to /soc node
ARM: dts: berlin2q: Add missing unit name to /soc node
ARM: dts: berlin2: Remove skeleton.dtsi inclusion
ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion
ARM: dts: berlin2q: Remove skeleton.dtsi inclusion
arm: dts: berlin2q: enable all wdt nodes unconditionally
arm: dts: berlin2: enable all wdt nodes unconditionally
ARM: dts: omap5-igep0050.dts: Use tabs for indentation
ARM: dts: Fix igepv5 power button GPIO direction
ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node
ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes
ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- The Qualcomm external bus interface 2 (EBI2), used in some of their
mobile phone chips for connecting flash memory, LCD displays or
other peripherals
- Secure monitor firmware for Amlogic SoCs, and an NVMEM driver for
the EFUSE based on that firmware interface.
- Perf support for the AppliedMicro X-Gene performance monitor unit
- Reset driver for STMicroelectronics STM32
- Reset driver for SocioNext UniPhier SoCs
Aside from these, there are minor updates to SoC-specific bus,
clocksource, firmware, pinctrl, reset, rtc and pmic drivers"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
bus: qcom-ebi2: depend on HAS_IOMEM
pinctrl: mvebu: orion5x: Generalise mv88f5181l support for 88f5181
clk: mvebu: Add clk support for the orion5x SoC mv88f5181
dt-bindings: EXYNOS: Add Exynos5433 PMU compatible
clocksource: exynos_mct: Add the support for ARM64
perf: xgene: Add APM X-Gene SoC Performance Monitoring Unit driver
Documentation: Add documentation for APM X-Gene SoC PMU DTS binding
MAINTAINERS: Add entry for APM X-Gene SoC PMU driver
bus: qcom: add EBI2 driver
bus: qcom: add EBI2 device tree bindings
rtc: rtc-pm8xxx: Add support for pm8018 rtc
nvmem: amlogic: Add Amlogic Meson EFUSE driver
firmware: Amlogic: Add secure monitor driver
soc: qcom: smd: Reset rx tail rather than tx
memory: atmel-sdramc: fix a possible NULL dereference
reset: hi6220: allow to compile test driver on other architectures
reset: zynq: add driver Kconfig option
reset: sunxi: add driver Kconfig option
reset: stm32: add driver Kconfig option
reset: socfpga: add driver Kconfig option
Pull ARM SoC platform updates from Arnd Bergmann:
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- We get support for running in big-endian mode on two platforms:
sunxi (Allwinner) and s3c24xx (old Samsung).
- The recently added Uniphier platform now uses standard PSCI methods
for SMP booting and we remove support for old bootloader versions
that did not support it yet.
- In sunxi, we gain support for the "Nextthing GR8" SoC, which is a
close relative of the Allwinner A13 and R8 chips.
- PXA completes its move over to the generic dmaengine framework and
removes its old private API
- mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC
with integrated 802.11ac wireless networking"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
ARM: imx legacy: pca100: move peripheral initialization to .init_late
ARM: imx legacy: mx27ads: move peripheral initialization to .init_late
ARM: imx legacy: mx21ads: move peripheral initialization to .init_late
ARM: imx legacy: pcm043: move peripheral initialization to .init_late
ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late
ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late
ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late
ARM: imx legacy: vpr200: move peripheral initialization to .init_late
ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late
ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late
ARM: imx legacy: qong: move peripheral initialization to .init_late
ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late
ARM: imx legacy: pcm037: move peripheral initialization to .init_late
ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late
ARM: imx legacy: mx31ads: move peripheral initialization to .init_late
ARM: imx legacy: mx31lite: move peripheral initialization to .init_late
ARM: imx legacy: kzm: move peripheral initialization to .init_late
MAINTAINERS: update list of Oxnas maintainers
ARM: orion5x: remove extraneous NO_IRQ
ARM: orion: simplify orion_ge00_switch_init
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Major rework of Book3S 64-bit exception vectors (Nicholas Piggin)
- Use gas sections for arranging exception vectors et. al.
- Large set of TM cleanups and selftests (Cyril Bur)
- Enable transactional memory (TM) lazily for userspace (Cyril Bur)
- Support for XZ compression in the zImage wrapper (Oliver
O'Halloran)
- Add support for bpf constant blinding (Naveen N. Rao)
- Beginnings of upstream support for PA Semi Nemo motherboards
(Darren Stevens)
Fixes:
- Ensure .mem(init|exit).text are within _stext/_etext (Michael
Ellerman)
- xmon: Don't use ld on 32-bit (Michael Ellerman)
- vdso64: Use double word compare on pointers (Anton Blanchard)
- powerpc/nvram: Fix an incorrect partition merge (Pan Xinhui)
- powerpc: Fix usage of _PAGE_RO in hugepage (Christophe Leroy)
- powerpc/mm: Update FORCE_MAX_ZONEORDER range to allow hugetlb w/4K
(Aneesh Kumar K.V)
- Fix memory leak in queue_hotplug_event() error path (Andrew
Donnellan)
- Replay hypervisor maintenance interrupt first (Nicholas Piggin)
Various performance optimisations (Anton Blanchard):
- Align hot loops of memset() and backwards_memcpy()
- During context switch, check before setting mm_cpumask
- Remove static branch prediction in atomic{, 64}_add_unless
- Only disable HAVE_EFFICIENT_UNALIGNED_ACCESS on POWER7 little
endian
- Set default CPU type to POWER8 for little endian builds
Cleanups & features:
- Sparse fixes/cleanups (Daniel Axtens)
- Preserve CFAR value on SLB miss caused by access to bogus address
(Paul Mackerras)
- Radix MMU fixups for POWER9 (Aneesh Kumar K.V)
- Support for setting used_(vsr|vr|spe) in sigreturn path (for CRIU)
(Simon Guo)
- Optimise syscall entry for virtual, relocatable case (Nicholas
Piggin)
- Optimise MSR handling in exception handling (Nicholas Piggin)
- Support for kexec with Radix MMU (Benjamin Herrenschmidt)
- powernv EEH fixes (Russell Currey)
- Suprise PCI hotplug support for powernv (Gavin Shan)
- Endian/sparse fixes for powernv PCI (Gavin Shan)
- Defconfig updates (Anton Blanchard)
- KVM: PPC: Book3S HV: Migrate pinned pages out of CMA (Balbir Singh)
- cxl: Flush PSL cache before resetting the adapter (Frederic Barrat)
- cxl: replace loop with for_each_child_of_node(), remove unneeded
of_node_put() (Andrew Donnellan)
- Fix HV facility unavailable to use correct handler (Nicholas
Piggin)
- Remove unnecessary syscall trampoline (Nicholas Piggin)
- fadump: Fix build break when CONFIG_PROC_VMCORE=n (Michael
Ellerman)
- Quieten EEH message when no adapters are found (Anton Blanchard)
- powernv: Add PHB register dump debugfs handle (Russell Currey)
- Use kprobe blacklist for exception handlers & asm functions
(Nicholas Piggin)
- Document the syscall ABI (Nicholas Piggin)
- MAINTAINERS: Update cxl maintainers (Michael Neuling)
- powerpc: Remove all usages of NO_IRQ (Michael Ellerman)
Minor cleanups:
- Andrew Donnellan, Christophe Leroy, Colin Ian King, Cyril Bur,
Frederic Barrat, Pan Xinhui, PrasannaKumar Muralidharan, Rui Teng,
Simon Guo"
* tag 'powerpc-4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (156 commits)
powerpc/bpf: Add support for bpf constant blinding
powerpc/bpf: Implement support for tail calls
powerpc/bpf: Introduce accessors for using the tmp local stack space
powerpc/fadump: Fix build break when CONFIG_PROC_VMCORE=n
powerpc: tm: Enable transactional memory (TM) lazily for userspace
powerpc/tm: Add TM Unavailable Exception
powerpc: Remove do_load_up_transact_{fpu,altivec}
powerpc: tm: Rename transct_(*) to ck(\1)_state
powerpc: tm: Always use fp_state and vr_state to store live registers
selftests/powerpc: Add checks for transactional VSXs in signal contexts
selftests/powerpc: Add checks for transactional VMXs in signal contexts
selftests/powerpc: Add checks for transactional FPUs in signal contexts
selftests/powerpc: Add checks for transactional GPRs in signal contexts
selftests/powerpc: Check that signals always get delivered
selftests/powerpc: Add TM tcheck helpers in C
selftests/powerpc: Allow tests to extend their kill timeout
selftests/powerpc: Introduce GPR asm helper header file
selftests/powerpc: Move VMX stack frame macros to header file
selftests/powerpc: Rework FPU stack placement macros and move to header file
selftests/powerpc: Check for VSX preservation across userspace preemption
Pull block layer updates from Jens Axboe:
"This is the main pull request for block layer changes in 4.9.
As mentioned at the last merge window, I've changed things up and now
do just one branch for core block layer changes, and driver changes.
This avoids dependencies between the two branches. Outside of this
main pull request, there are two topical branches coming as well.
This pull request contains:
- A set of fixes, and a conversion to blk-mq, of nbd. From Josef.
- Set of fixes and updates for lightnvm from Matias, Simon, and Arnd.
Followup dependency fix from Geert.
- General fixes from Bart, Baoyou, Guoqing, and Linus W.
- CFQ async write starvation fix from Glauber.
- Add supprot for delayed kick of the requeue list, from Mike.
- Pull out the scalable bitmap code from blk-mq-tag.c and make it
generally available under the name of sbitmap. Only blk-mq-tag uses
it for now, but the blk-mq scheduling bits will use it as well.
From Omar.
- bdev thaw error progagation from Pierre.
- Improve the blk polling statistics, and allow the user to clear
them. From Stephen.
- Set of minor cleanups from Christoph in block/blk-mq.
- Set of cleanups and optimizations from me for block/blk-mq.
- Various nvme/nvmet/nvmeof fixes from the various folks"
* 'for-4.9/block' of git://git.kernel.dk/linux-block: (54 commits)
fs/block_dev.c: return the right error in thaw_bdev()
nvme: Pass pointers, not dma addresses, to nvme_get/set_features()
nvme/scsi: Remove power management support
nvmet: Make dsm number of ranges zero based
nvmet: Use direct IO for writes
admin-cmd: Added smart-log command support.
nvme-fabrics: Add host_traddr options field to host infrastructure
nvme-fabrics: revise host transport option descriptions
nvme-fabrics: rework nvmf_get_address() for variable options
nbd: use BLK_MQ_F_BLOCKING
blkcg: Annotate blkg_hint correctly
cfq: fix starvation of asynchronous writes
blk-mq: add flag for drivers wanting blocking ->queue_rq()
blk-mq: remove non-blocking pass in blk_mq_map_request
blk-mq: get rid of manual run of queue with __blk_mq_run_hw_queue()
block: export bio_free_pages to other modules
lightnvm: propagate device_add() error code
lightnvm: expose device geometry through sysfs
lightnvm: control life of nvm_dev in driver
blk-mq: register device instead of disk
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Here is the 4.9 pull request from I2C including:
- centralized error messages when registering to the core
- improved lockdep annotations to prevent false positives
- DT support for muxes, gates, and arbitrators
- bus speeds can now be obtained from ACPI
- i2c-octeon got refactored and now supports ThunderX SoCs, too
- i2c-tegra and i2c-designware got a bigger bunch of updates
- a couple of standard driver fixes and improvements"
* 'i2c/for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (71 commits)
i2c: axxia: disable clks in case of failure in probe
i2c: octeon: thunderx: Limit register access retries
i2c: uniphier-f: fix misdetection of incomplete STOP condition
gpio: pca953x: variable 'id' was used twice
i2c: i801: Add support for Kaby Lake PCH-H
gpio: pca953x: fix an incorrect lockdep warning
i2c: add a warning to i2c_adapter_depth()
lockdep: make MAX_LOCKDEP_SUBCLASSES unconditionally visible
i2c: export i2c_adapter_depth()
i2c: rk3x: Fix variable 'min_total_ns' unused warning
i2c: rk3x: Fix sparse warning
i2c / ACPI: Do not touch an I2C device if it belongs to another adapter
i2c: octeon: Fix high-level controller status check
i2c: octeon: Avoid sending STOP during recovery
i2c: octeon: Fix set SCL recovery function
i2c: rcar: add support for r8a7796 (R-Car M3-W)
i2c: imx: make bus recovery through pinctrl optional
i2c: meson: add gxbb compatible string
i2c: uniphier-f: set the adapter to master mode when probing
i2c: uniphier-f: avoid WARN_ON() of clk_disable() in failure path
This patch moves nes vendor's specific structures to
common UAPI folder which will be visible to all consumers.
These structures are used by user-space library driver
(libmlx4) and currently manually copied to that library.
This move will allow cross-compile against these files and
simplify introduction of vendor specific data.
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
This patch moves ocrdma vendor's specific structures to
In addition, it changes types to be __uXX instead of uXX.
Acked-By: Devesh Sharma <devesh.sharma@broadcom.com>
This patch moves mlx4 vendor's specific structures to
This patch moves cxgb4 vendor's specific structures to
(libcxgb4) and currently manually copied to that library.
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
This patch moves cxgb3 vendor's specific structures to
(libcxgb3) and currently manually copied to that library.
This patch decouples and moves vendors specific structures to
(libmlx5) and currently manually copied to that library.
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID updates from Jiri Kosina:
- Integrated Sensor Hub support (Cherrytrail+) from Srinivas Pandruvada
- Big cleanup of Wacom driver; namely it's now using devres, and the
standardized LED API so that libinput doesn't need to have root
access any more, with substantial amount of other cleanups
piggy-backing on top. All this from Benjamin Tissoires
- Report descriptor parsing would now ignore and out-of-range System
controls in case of the application actually being System Control.
This fixes quite some issues with several devices, and allows us to
remove a few ->report_fixup callbacks. From Benjamin Tissoires
- ... a lot of other assorted small fixes and device ID additions
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (76 commits)
HID: add missing \n to end of dev_warn messages
HID: alps: fix multitouch cursor issue
HID: hid-logitech: Documentation updates/corrections
HID: hid-logitech: Improve Wingman Formula Force GP support
HID: hid-logitech: Rewrite of descriptor for all DF wheels
HID: hid-logitech: Compute combined pedals value
HID: hid-logitech: Add combined pedal support Logitech wheels
HID: hid-logitech: Introduce control for combined pedals feature
HID: sony: Update copyright and add Dualshock 4 rate control note
HID: sony: Defer the initial USB Sixaxis output report
HID: sony: Relax duplicate checking for USB-only devices
Revert "HID: microsoft: fix invalid rdesc for 3k kbd"
HID: alps: fix error return code in alps_input_configured()
HID: alps: fix stick device not working after resume
HID: support for keyboard - Corsair STRAFE
HID: alps: Fix memory leak
HID: uclogic: Add support for UC-Logic TWHA60 v3
HID: uclogic: Override constant descriptors
HID: uclogic: Support UGTizer GP0610 partially
HID: uclogic: Add support for several more tablets
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Summary of PCI changes for the v4.9 merge window:
Enumeration:
- microblaze: Add multidomain support for procfs (Bharat Kumar Gogada)
Resource management:
- Ignore requested alignment for PROBE_ONLY and fixed resources (Yongji Xie)
- Ignore requested alignment for VF BARs (Yongji Xie)
PCI device hotplug:
- Make core explicitly non-modular (Paul Gortmaker)
PCIe native device hotplug:
- Rename pcie_isr() locals for clarity (Bjorn Helgaas)
- Return IRQ_NONE when we can't read interrupt status (Bjorn Helgaas)
- Remove unnecessary guard (Bjorn Helgaas)
- Clean up dmesg "Slot(%s)" messages (Bjorn Helgaas)
- Remove useless pciehp_get_latch_status() calls (Bjorn Helgaas)
- Clear attention LED on device add (Keith Busch)
- Allow exclusive userspace control of indicators (Keith Busch)
- Process all hotplug events before looking for new ones (Mayurkumar Patel)
- Don't re-read Slot Status when queuing hotplug event (Mayurkumar Patel)
- Don't re-read Slot Status when handling surprise event (Mayurkumar Patel)
- Make explicitly non-modular (Paul Gortmaker)
Power management:
- Afford direct-complete to devices with non-standard PM (Lukas Wunner)
- Query platform firmware for device power state (Lukas Wunner)
- Recognize D3cold in pci_update_current_state() (Lukas Wunner)
- Avoid unnecessary resume after direct-complete (Lukas Wunner)
Virtualization:
- Mark Atheros AR9580 to avoid bus reset (Maik Broemme)
- Check for pci_setup_device() failure in pci_iov_add_virtfn() (Po Liu)
MSI:
- Enable PCI_MSI_IRQ_DOMAIN support for ARC (Joao Pinto)
AER:
- Remove aerdriver.nosourceid kernel parameter (Bjorn Helgaas)
- Remove aerdriver.forceload kernel parameter (Bjorn Helgaas)
- Fix aer_probe() kernel-doc comment (Cao jin)
- Add bus flag to skip source ID matching (Jon Derrick)
- Avoid memory allocation in interrupt handling path (Jon Derrick)
- Cache capability position (Keith Busch)
- Remove duplicate AER severity translation (Tyler Baicar)
- Send correct severity to calculate AER severity (Tyler Baicar)
Precision Time Measurement:
- Add Precision Time Measurement (PTM) support (Jonathan Yong)
- Add PTM clock granularity information (Bjorn Helgaas)
- Add pci_enable_ptm() for drivers to enable PTM on endpoints (Bjorn Helgaas)
Generic host bridge driver:
- Fix pci_remap_iospace() failure path (Lorenzo Pieralisi)
Altera host bridge driver:
- Remove redundant platform_get_resource() return value check (Bjorn Helgaas)
- Poll for link training status after retraining the link (Ley Foon Tan)
- Rework config accessors for use without a struct pci_bus (Ley Foon Tan)
- Move retrain from fixup to altera_pcie_host_init() (Ley Foon Tan)
- Make MSI explicitly non-modular (Paul Gortmaker)
- Relax device number checking to allow SR-IOV (Po Liu)
ARM Versatile host bridge driver:
Axis ARTPEC-6 host bridge driver:
- Drop __init from artpec6_add_pcie_port() (Niklas Cassel)
Freescale i.MX6 host bridge driver:
Intel VMD host bridge driver:
- Add quirk for AER to ignore source ID (Jon Derrick)
- Allocate IRQ lists with correct MSI-X count (Jon Derrick)
- Convert to use pci_alloc_irq_vectors() API (Jon Derrick)
- Eliminate vmd_vector member from list type (Jon Derrick)
- Eliminate index member from IRQ list (Jon Derrick)
- Synchronize with RCU freeing MSI IRQ descs (Keith Busch)
- Request userspace control of PCIe hotplug indicators (Keith Busch)
- Move VMD driver to drivers/pci/host (Keith Busch)
Marvell Aardvark host bridge driver:
- Remove redundant dev_err call in advk_pcie_probe() (Wei Yongjun)
Microsoft Hyper-V host bridge driver:
- Use zero-length array in struct pci_packet (Dexuan Cui)
- Use pci_function_description[0] in struct definitions (Dexuan Cui)
- Remove the unused 'wrk' in struct hv_pcibus_device (Dexuan Cui)
- Handle vmbus_sendpacket() failure in hv_compose_msi_msg() (Dexuan Cui)
- Handle hv_pci_generic_compl() error case (Dexuan Cui)
- Use list_move_tail() instead of list_del() + list_add_tail() (Wei Yongjun)
NVIDIA Tegra host bridge driver:
- Remove redundant _data suffix (Thierry Reding)
- Use of_device_get_match_data() (Thierry Reding)
Qualcomm host bridge driver:
Renesas R-Car host bridge driver:
- Consolidate register space lookup and ioremap (Bjorn Helgaas)
- Don't disable/unprepare clocks on prepare/enable failure (Geert Uytterhoeven)
- Add multi-MSI support (Grigory Kletsko)
- Fix some checkpatch warnings (Sergei Shtylyov)
- Try increasing PCIe link speed to 5 GT/s at boot (Sergei Shtylyov)
Rockchip host bridge driver:
- Add DT bindings for Rockchip PCIe controller (Shawn Lin)
- Add Rockchip PCIe controller support (Shawn Lin)
- Improve the deassert sequence of four reset pins (Shawn Lin)
- Fix wrong transmitted FTS count (Shawn Lin)
- Increase the Max Credit update interval (Rajat Jain)
Samsung Exynos host bridge driver:
ST Microelectronics SPEAr13xx host bridge driver:
Synopsys DesignWare host bridge driver:
- Return data directly from dw_pcie_readl_rc() (Bjorn Helgaas)
- Exchange viewport of `MEMORYs' and `CFGs/IOs' (Dong Bo)
- Check LTSSM training bit before deciding link is up (Jisheng Zhang)
- Move link wait definitions to .c file (Joao Pinto)
- Wait for iATU enable (Joao Pinto)
- Add iATU Unroll feature (Joao Pinto)
- Keep viewport fixed for IO transaction if num_viewport > 2 (Pratyush Anand)
- Remove redundant platform_get_resource() return value check (Wei Yongjun)
TI DRA7xx host bridge driver:
TI Keystone host bridge driver:
- Propagate request_irq() failure (Wei Yongjun)
Xilinx AXI host bridge driver:
- Keep both legacy and MSI interrupt domain references (Bharat Kumar Gogada)
- Clear interrupt register for invalid interrupt (Bharat Kumar Gogada)
- Clear correct MSI set bit (Bharat Kumar Gogada)
- Dispose of MSI virtual IRQ (Bharat Kumar Gogada)
Xilinx NWL host bridge driver:
- Expand error logging (Bharat Kumar Gogada)
- Enable all MSI interrupts using MSI mask (Bharat Kumar Gogada)
Miscellaneous:
- Drop CONFIG_KEXEC_CORE ifdeffery (Lukas Wunner)
- portdrv: Make explicitly non-modular (Paul Gortmaker)
- Make DPC explicitly non-modular (Paul Gortmaker)"
* tag 'pci-v4.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (105 commits)
x86/PCI: VMD: Move VMD driver to drivers/pci/host
PCI: rockchip: Fix wrong transmitted FTS count
PCI: rockchip: Improve the deassert sequence of four reset pins
PCI: rockchip: Increase the Max Credit update interval
PCI: rcar: Try increasing PCIe link speed to 5 GT/s at boot
PCI/AER: Fix aer_probe() kernel-doc comment
PCI: Ignore requested alignment for VF BARs
PCI: Ignore requested alignment for PROBE_ONLY and fixed resources
PCI: Avoid unnecessary resume after direct-complete
PCI: Recognize D3cold in pci_update_current_state()
PCI: Query platform firmware for device power state
PCI: Afford direct-complete to devices with non-standard PM
PCI/AER: Cache capability position
PCI/AER: Avoid memory allocation in interrupt handling path
x86/PCI: VMD: Request userspace control of PCIe hotplug indicators
PCI: pciehp: Allow exclusive userspace control of indicators
ACPI / APEI: Send correct severity to calculate AER severity
PCI/AER: Remove duplicate AER severity translation
x86/PCI: VMD: Synchronize with RCU freeing MSI IRQ descs
x86/PCI: VMD: Eliminate index member from IRQ list
Pull SCSI updates from James Bottomley:
"This update includes the usual round of major driver updates (hpsa,
be2iscsi, hisi_sas, zfcp, cxlflash). There's a new incarnation of hpsa
called smartpqi for which a driver is added, there's some cleanup work
of the ibm vscsi target and updates to libfc, plus a whole host of
minor fixes and updates and finally the removal of several ISA drivers
which seem not to have been used for years"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (173 commits)
scsi: mvsas: Mark symbols static where possible
scsi: pm8001: Mark symbols static where possible
scsi: arcmsr: Simplify user_len checking
scsi: fcoe: fix off by one in eth2fc_speed()
scsi: dtc: remove from tree
scsi: t128: remove from tree
scsi: pas16: remove from tree
scsi: u14-34f: remove from tree
scsi: ultrastor: remove from tree
scsi: in2000: remove from tree
scsi: wd7000: remove from tree
scsi: scsi_dh_alua: Fix memory leak in alua_rtpg()
scsi: lpfc: Mark symbols static where possible
scsi: hpsa: correct call to hpsa_do_reset
scsi: ufs: Get a TM service response from the correct offset
scsi: ibmvfc: Fix I/O hang when port is not mapped
scsi: megaraid_sas: clean function declarations in megaraid_sas_base.c up
scsi: ipr: Remove redundant messages at adapter init time
scsi: ipr: Don't log unnecessary 9084 error details
scsi: smartpqi: raid bypass lba calculation fix
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Core framework:
- Add the MFD bindings doc to MAINTAINERS
New drivers:
- X-Powers AC100 Audio CODEC and RTC
- TI LP873x PMIC
- Rockchip RK808 PMIC
- Samsung Exynos Low Power Audio
New device support:
- Add support for STMPE1600 variant to stmpe
- Add support for PM8018 PMIC to pm8921-core
- Add support for AXP806 PMIC in axp20x
- Add support for AXP209 GPIO in axp20x
New functionality:
- Add support for Reset to all STMPE variants
- Add support for MKBP event support to cros_ec
- Add support for USB to intel_soc_pmic_bxtwc
- Add support for IRQs and Power Button to tps65217
Fix-ups:
- Clean-up defunct author emails (da9063, max14577)
- Kconfig fixups (wm8350-i2c, as37220
- Constify (altera-a10sr, sm501)
- Supply PCI IDs (intel-lpss-pci)
- Improve clocking (qcom_rpm)
- Fix IRQ probing (ucb1x00-core)
- Ensure fault log is cleared (da9052)
- Remove NO_IRQ check (ucb1x00-core)
- Supply I2C properties (intel-lpss-acpi, intel-lpss-pci)
- Non standard declaration (tps65217, max8997-irq)
- Remove unused code (lp873x, db8500-prcmu, ab8500-debugfs,
cros_ec_spi)
- Make non-modular (altera-a10sr, intel_msic, smsc-ece1099,
sun6i-prcm, twl-core)
- OF bindings (ac100, stmpe, qcom-pm8xxx, qcom-rpm, rk808, axp20x,
lp873x, exynos5433-lpass, act8945a, aspeed-scu, twl6040, arizona)
Bugfixes:
- Release OF pointer (qcom_rpm)
- Avoid double shifting in suspend/resume (88pm80x)
- Fix 'defined but not used' error (exynos-lpass)
- Fix 'sleeping whilst attomic' (atmel-hlcdc)"
* tag 'mfd-for-linus-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (69 commits)
mfd: arizona: Handle probe deferral for reset GPIO
mfd: arizona: Remove arizona_of_get_named_gpio helper function
mfd: arizona: Add DT options for max_channels_clocked and PDM speaker config
mfd: twl6040: Register child device for twl6040-pdmclk
mfd: cros_ec_spi: Remove unused variable 'request'
mfd: omap-usb-host: Return value is not 'const int'
mfd: ab8500-debugfs: Remove 'weak' function suspend_test_wake_cause_interrupt_is_mine()
mfd: ab8500-debugfs: Remove ab8500_dump_all_banks_to_mem()
mfd: db8500-prcmu: Remove unused *prcmu_set_ddr_opp() calls
mfd: ab8500-debugfs: Prevent initialised field from being over-written
mfd: max8997-irq: 'inline' should be at the beginning of the declaration
mfd: rk808: Fix RK818_IRQ_DISCHG_ILIM initializer
mfd: tps65217: Fix nonstandard declaration
mfd: lp873x: Remove unused mutex lock from struct lp873x
mfd: atmel-hlcdc: Do not sleep in atomic context
mfd: exynos-lpass: Mark PM functions as __maybe_unused
mfd: intel-lpss: Add default I2C device properties for Apollo Lake
mfd: twl-core: Make it explicitly non-modular
mfd: sun6i-prcm: Make it explicitly non-modular
mfd: smsc-ece1099: Make it explicitly non-modular
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply
Pull power supply and reset updates from Sebastian Reichel:
- move power supply drivers to drivers/power/supply
- unify location of power supply DT documentation
- tps65217-charger: IRQ support
- act8945a-charger: misc. cleanups & improvements
- sbs-battery cleanup
- fix users of deprecated create_singlethread_workqueue()
- misc fixes.
* tag 'for-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (46 commits)
power: supply: bq27xxx_battery: allow kernel poll_interval parameter runtime update
power: supply: sbs-battery: Cleanup removal of chip->pdata
power: reset: st: Remove obsolete platforms from dt doc
power: reset: st-poweroff: Remove obsolete platforms.
power: reset: zx-reboot: Unmap region obtained by of_iomap
power: reset: xgene-reboot: Unmap region obtained by of_iomap
power: supply: ab8500: cleanup with list_first_entry_or_null()
power: reset: add in missing white space in error message text
sbs-battery: make writes to ManufacturerAccess optional
power: bq24257: Fix use of uninitialized pointer bq->charger
power: supply: sbs-battery: simplify DT parsing
power: supply: bq24735-charger: Request status GPIO with initial input setup
power: supply: sbs-battery: Use gpio_desc and sleeping calls for battery detect
power: supply: act8945a_charger: Add max current property
power: supply: act8945a_charger: Add capacity level property
doc: bindings: power: act8945a-charger: Update properties.
power: supply: act8945a_charger: Fix the power supply type
power: supply: act8945a_charger: Add status change update support
power: supply: act8945a_charger: Improve state handling
power: supply: act8945a_charger: Remove "battery_temperature"
Madalin Bucur says:
fsl/fman: cleanup and small fixes
This series contains fixes for the DPAA FMan driver.
Adding myself as maintainer of the driver.
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"In this round, we've investigated how f2fs deals with errors given by
our fault injection facility. With this, we could fix several corner
cases. And, in order to improve the performance, we set inline_dentry
by default and enhance the exisiting discard issue flow. In addition,
we added f2fs_migrate_page for better memory management.
Enhancements:
- set inline_dentry by default
- improve discard issue flow
- add more fault injection cases in f2fs
- allow block preallocation for encrypted files
- introduce migrate_page callback function
- avoid truncating the next direct node block at every checkpoint
Bug fixes:
- set page flag correctly between write_begin and write_end
- missing error handling cases detected by fault injection
- preallocate blocks regarding to 4KB alignement correctly
- dentry and filename handling of encryption
- lost xattrs of directories"
* tag 'for-f2fs-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (69 commits)
f2fs: introduce update_ckpt_flags to clean up
f2fs: don't submit irrelevant page
f2fs: fix to commit bio cache after flushing node pages
f2fs: introduce get_checkpoint_version for cleanup
f2fs: remove dead variable
f2fs: remove redundant io plug
f2fs: support checkpoint error injection
f2fs: fix to recover old fault injection config in ->remount_fs
f2fs: do fault injection initialization in default_options
f2fs: remove redundant value definition
f2fs: support configuring fault injection per superblock
f2fs: adjust display format of segment bit
f2fs: remove dirty inode pages in error path
f2fs: do not unnecessarily null-terminate encrypted symlink data
f2fs: handle errors during recover_orphan_inodes
f2fs: avoid gc in cp_error case
f2fs: should put_page for summary page
f2fs: assign return value in f2fs_gc
f2fs: add customized migrate_page callback
f2fs: introduce cp_lock to protect updating of ckpt_flags
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs
Pull xfs and iomap updates from Dave Chinner:
"The main things in this update are the iomap-based DAX infrastructure,
an XFS delalloc rework, and a chunk of fixes to how log recovery
schedules writeback to prevent spurious corruption detections when
recovery of certain items was not required.
The other main chunk of code is some preparation for the upcoming
reflink functionality. Most of it is generic and cleanups that stand
alone, but they were ready and reviewed so are in this pull request.
Speaking of reflink, I'm currently planning to send you another pull
request next week containing all the new reflink functionality. I'm
working through a similar process to the last cycle, where I sent the
reverse mapping code in a separate request because of how large it
was. The reflink code merge is even bigger than reverse mapping, so
I'll be doing the same thing again....
Summary for this update:
- change of XFS mailing list to linux-xfs@vger.kernel.org
- iomap-based DAX infrastructure w/ XFS and ext2 support
- small iomap fixes and additions
- more efficient XFS delayed allocation infrastructure based on iomap
- a rework of log recovery writeback scheduling to ensure we don't
fail recovery when trying to replay items that are already on disk
- some preparation patches for upcoming reflink support
- configurable error handling fixes and documentation
- aio access time update race fixes for XFS and
generic_file_read_iter"
* tag 'xfs-for-linus-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (40 commits)
fs: update atime before I/O in generic_file_read_iter
xfs: update atime before I/O in xfs_file_dio_aio_read
ext2: fix possible integer truncation in ext2_iomap_begin
xfs: log recovery tracepoints to track current lsn and buffer submission
xfs: update metadata LSN in buffers during log recovery
xfs: don't warn on buffers not being recovered due to LSN
xfs: pass current lsn to log recovery buffer validation
xfs: rework log recovery to submit buffers on LSN boundaries
xfs: quiesce the filesystem after recovery on readonly mount
xfs: remote attribute blocks aren't really userdata
ext2: use iomap to implement DAX
ext2: stop passing buffer_head to ext2_get_blocks
xfs: use iomap to implement DAX
xfs: refactor xfs_setfilesize
xfs: take the ilock shared if possible in xfs_file_iomap_begin
xfs: fix locking for DAX writes
dax: provide an iomap based fault handler
dax: provide an iomap based dax read/write path
dax: don't pass buffer_head to copy_user_dax
dax: don't pass buffer_head to dax_insert_mapping
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging and IIO updates from Greg KH:
"Here is the big staging and IIO driver pull request for 4.9-rc1.
There are a lot of patches in here, the majority due to the
drivers/staging/greybus/ subsystem being merged in with full
development history that went back a few years, in order to preserve
the work that those developers did over time.
Lots and lots of tiny cleanups happened in the tree as well, due to
the Outreachy application process and lots of other developers showing
up for the first time to clean code up. Along with those changes, we
deleted a wireless driver, and added a raspberrypi driver (currently
marked broken), and lots of new iio drivers.
Overall the tree still shrunk with more lines removed than added,
about 10 thousand lines removed in total. Full details are in the very
long shortlog below.
All of this has been in the linux-next tree with no issues. There will
be some merge problems with other subsystem trees, but those are all
minor problems and shouldn't be hard to work out when they happen
(MAINTAINERS and some lustre build problems with the IB tree)"
And furter from me asking for clarification about greybus:
"Right now there is a phone from Motorola shipping with this code (a
slightly older version, but the same tree), so even though Ara is not
alive in the same form, the functionality is happening. We are working
with the developers of that phone to merge the newer stuff in with
their fork so they can use the upstream version in future versions of
their phone product line.
Toshiba has at least one chip shipping in their catalog that
needs/uses this protocol over a Unipro link, and rumor has it that
there might be more in the future.
There are also other users of the greybus protocols, there is a talk
next week at ELC that shows how it is being used across a network
connection to control a device, and previous ELC talks have showed the
protocol stack being used over USB to drive embedded Linux boards.
I've also talked to some people who are starting to work to add a host
controller driver to control arduinos as the greybus PHY protocols are
very useful to control a serial/i2c/spio/whatever device across a
random physical link, as it is a way to have a self-describing device
be attached to a host without needing manual configuration.
So yes, people are using it, and there is still the chance that it
will show up in a phone/laptop/tablet/whatever from Google in the
future as well, the tech isn't dead, even if the original large phone
project happens to be"
* tag 'staging-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (3703 commits)
Staging: fbtft: Fix bug in fbtft-core
staging: rtl8188eu: fix double unlock error in rtw_resume_process()
staging:r8188eu: remove GEN_MLME_EXT_HANDLER macro
staging:r8188eu: remove GEN_DRV_CMD_HANDLER macro
staging:r8188eu: remove GEN_EVT_CODE macro
staging:r8188eu: remove GEN_CMD_CODE macro
staging:r8188eu: remove pkt_newalloc member of the recv_buf structure
staging:r8188eu: remove rtw_handle_dualmac declaration
staging:r8188eu: remove (RGTRY|BSSID)_(OFT|SZ) macros
staging:r8188eu: change rtl8188e_process_phy_info function argument type
Staging: fsl-mc: Remove blank lines
Staging: fsl-mc: Fix unaligned * in block comments
Staging: comedi: Align the * in block comments
Staging : ks7010 : Fix block comments warninig
Staging: vt6655: Remove explicit NULL comparison using Coccinelle
staging: rtl8188eu: core: rtw_xmit: Use macros instead of constants
staging: rtl8188eu: core: rtw_xmit: Move constant of the right side
staging: dgnc: Fix lines longer than 80 characters
Staging: dgnc: constify attribute_group structures
Staging: most: hdm-dim2: constify attribute_group structures
Linux 4.8
* tag 'v4.8': (1761 commits)
Linux 4.8
ARM: 8618/1: decompressor: reset ttbcr fields to use TTBR0 on ARMv7
MIPS: CM: Fix mips_cm_max_vp_width for non-MT kernels on MT systems
include/linux/property.h: fix typo/compile error
ocfs2: fix deadlock on mmapped page in ocfs2_write_begin_nolock()
mm: workingset: fix crash in shadow node shrinker caused by replace_page_cache_page()
MAINTAINERS: Switch to kernel.org email address for Javi Merino
x86/entry/64: Fix context tracking state warning when load_gs_index fails
x86/boot: Initialize FPU and X86_FEATURE_ALWAYS even if we don't have CPUID
x86/vdso: Fix building on big endian host
x86/boot: Fix another __read_cr4() case on 486
sctp: fix the issue sctp_diag uses lock_sock in rcu_read_lock
sctp: change to check peer prsctp_capable when using prsctp polices
sctp: remove prsctp_param from sctp_chunk
sctp: move sent_count to the memory hole in sctp_chunk
tg3: Avoid NULL pointer dereference in tg3_io_error_detected()
x86/init: Fix cr4_init_shadow() on CR4-less machines
MIPS: Fix detection of unsupported highmem with cache aliases
MIPS: Malta: Fix IOCU disable switch read for MIPS64
MIPS: Fix BUILD_ROLLBACK_PROLOGUE for microMIPS
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.9 series:
Subsystem improvements:
- do away with the last users of the obsolete Kconfig options
ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB (the latter
always sounded like an item on a wishlist to Santa Claus to me). We
can now select GPIOLIB and be done with it, for all archs. After
some struggle it even work on UM. Not that it has GPIO, but if it
wants to, it can select the library.
- continued efforts to make drivers properly either tristate or bool.
- introduce a warning for drivers assigning default triggers to their
irqchip lines when probed from device tree, so we find and fix
these ambigous drivers. It is agreed that in the OF config path,
the device tree defines trigger characteristics.
- the same warning, mutatis mutandis, for ACPI-probed GPIO irqchips.
- we introduce the ability to mark certain IRQ lines as "unusable" as
they can be taken by BIOS/firmware, unrouted in silicon and
generally nasty if you use them, and such things. This is put to
good use in the STMPE driver and also in the Cherryview pin control
driver.
- a new "mockup" virtual GPIO device that can be used for testing.
The plan is to add unit tests under tools/* for exercising this
device and verify that the kernel code paths are working as they
should.
- make memory-mapped I/O-drivers depend on HAS_IOMEM. This was
implicit all the time, but when people started building UM with
allyesconfig or allmodconfig it exploded in their face.
- move some stray bits of device tree and ACPI HW description
callbacks down into their respective implementation silo. These
were causing issues when compiling on !HAS_IOMEM as well, so now
eventually UM compiles the GPIOLIB library if it wants to.
New drivers:
- new driver for the Aspeed GPIO front-end companion to the pin
controller merged through the pin control tree.
- new driver for the LP873x PMIC GPIO portions.
- new driver for Technologic Systems' I2C FPGA GPIO such as TS4900,
TS-7970, TS-7990 and TS-4100.
- new driver for the Broadcom BCM63xx series including BCM6338 and
BCM6345.
- new driver for the Intel WhiskeyCove PMIC GPIO.
- new driver for the Allwinner AXP209 PMIC GPIO portions.
- new driver for Diamond Systems 48 line GPIO-MM, another of these
port-mapped I/O expansion cards.
- support the STMicroelectronics STMPE1600 variant in the STMPE
driver.
Driver improvements:
- the STMPE driver now supports rising/falling edge detection
properly for IRQs.
- the PCA954x will now fetch and enable its VCC regulator properly.
- major rework of the PCA953x driver with the goal of eventually
switching it over to use regmap and thus modernize it even more.
- switch the IOP driver to use the generic MMIO GPIO library.
- move the ages old HTC EGPIO (extended GPIO) GPIO expander driver
over to this subsystem from MFD, achieveing some separation of
concerns"
* tag 'gpio-v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (81 commits)
gpio: add missing static inline
gpio: OF: localize some gpiochip init functions
gpio: acpi: separation of concerns
gpio: OF: separation of concerns
gpio: make memory-mapped drivers depend on HAS_IOMEM
gpio: stmpe: use BIT() macro
gpio: stmpe: forbid unused lines to be mapped as IRQs
mfd/gpio: Move HTC GPIO driver to GPIO subsystem
gpio: MAINTAINERS: Add an entry for GPIO mockup driver
gpio/mockup: add virtual gpio device
gpio: Added zynq specific check for special pins on bank zero
gpio: axp209: Implement get_direction
gpio: aspeed: remove redundant return value check
gpio: loongson1: remove redundant return value check
ARM: omap2: fix missing include
gpio: tc3589x: fix up complaints on unsigned
gpio: tc3589x: add .get_direction() and small cleanup
gpio: f7188x: use gpiochip_get_data instead of container_of
gpio: tps65218: use devm_gpiochip_add_data() for gpio registration
gpio: aspeed: fix return value check in aspeed_gpio_probe()
Pull networking updates from David Miller:
1) BBR TCP congestion control, from Neal Cardwell, Yuchung Cheng and
co. at Google. https://lwn.net/Articles/701165/
2) Do TCP Small Queues for retransmits, from Eric Dumazet.
3) Support collect_md mode for all IPV4 and IPV6 tunnels, from Alexei
Starovoitov.
4) Allow cls_flower to classify packets in ip tunnels, from Amir Vadai.
5) Support DSA tagging in older mv88e6xxx switches, from Andrew Lunn.
6) Support GMAC protocol in iwlwifi mwm, from Ayala Beker.
7) Support ndo_poll_controller in mlx5, from Calvin Owens.
8) Move VRF processing to an output hook and allow l3mdev to be
loopback, from David Ahern.
9) Support SOCK_DESTROY for UDP sockets. Also from David Ahern.
10) Congestion control in RXRPC, from David Howells.
11) Support geneve RX offload in ixgbe, from Emil Tantilov.
12) When hitting pressure for new incoming TCP data SKBs, perform a
partial rathern than a full purge of the OFO queue (which could be
huge). From Eric Dumazet.
13) Convert XFRM state and policy lookups to RCU, from Florian Westphal.
14) Support RX network flow classification to igb, from Gangfeng Huang.
15) Hardware offloading of eBPF in nfp driver, from Jakub Kicinski.
16) New skbmod packet action, from Jamal Hadi Salim.
17) Remove some inefficiencies in snmp proc output, from Jia He.
18) Add FIB notifications to properly propagate route changes to
hardware which is doing forwarding offloading. From Jiri Pirko.
19) New dsa driver for qca8xxx chips, from John Crispin.
20) Implement RFC7559 ipv6 router solicitation backoff, from Maciej
Żenczykowski.
21) Add L3 mode to ipvlan, from Mahesh Bandewar.
22) Support 802.1ad in mlx4, from Moshe Shemesh.
23) Support hardware LRO in mediatek driver, from Nelson Chang.
24) Add TC offloading to mlx5, from Or Gerlitz.
25) Convert various drivers to ethtool ksettings interfaces, from
Philippe Reynes.
26) TX max rate limiting for cxgb4, from Rahul Lakkireddy.
27) NAPI support for ath10k, from Rajkumar Manoharan.
28) Support XDP in mlx5, from Rana Shahout and Saeed Mahameed.
29) UDP replicast support in TIPC, from Richard Alpe.
30) Per-queue statistics for qed driver, from Sudarsana Reddy Kalluru.
31) Support BQL in thunderx driver, from Sunil Goutham.
32) TSO support in alx driver, from Tobias Regnery.
33) Add stream parser engine and use it in kcm.
34) Support async DHCP replies in ipconfig module, from Uwe
Kleine-König.
35) DSA port fast aging for mv88e6xxx driver, from Vivien Didelot.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1715 commits)
mlxsw: switchx2: Fix misuse of hard_header_len
mlxsw: spectrum: Fix misuse of hard_header_len
net/faraday: Stop NCSI device on shutdown
net/ncsi: Introduce ncsi_stop_dev()
net/ncsi: Rework the channel monitoring
net/ncsi: Allow to extend NCSI request properties
net/ncsi: Rework request index allocation
net/ncsi: Don't probe on the reserved channel ID (0x1f)
net/ncsi: Introduce NCSI_RESERVED_CHANNEL
net/ncsi: Avoid unused-value build warning from ia64-linux-gcc
net: Add netdev all_adj_list refcnt propagation to fix panic
net: phy: Add Edge-rate driver for Microsemi PHYs.
vmxnet3: Wake queue from reset work
i40e: avoid NULL pointer dereference and recursive errors on early PCI error
qed: Add RoCE ll2 & GSI support
qed: Add support for memory registeration verbs
qed: Add support for QP verbs
qed: PD,PKEY and CQ verb support
qed: Add support for RoCE hw init
qede: Add qedr framework
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"The new features and main improvements in this merge for v4.9
- Support for the UBSAN sanitizer
- Set HAVE_EFFICIENT_UNALIGNED_ACCESS, it improves the code in some
places
- Improvements for the in-kernel fpu code, in particular the overhead
for multiple consecutive in kernel fpu users is recuded
- Add a SIMD implementation for the RAID6 gen and xor operations
- Add RAID6 recovery based on the XC instruction
- The PCI DMA flush logic has been improved to increase the speed of
the map / unmap operations
- The time synchronization code has seen some updates
And bug fixes all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (48 commits)
s390/con3270: fix insufficient space padding
s390/con3270: fix use of uninitialised data
MAINTAINERS: update DASD maintainer
s390/cio: fix accidental interrupt enabling during resume
s390/dasd: add missing \n to end of dev_err messages
s390/config: Enable config options for Docker
s390/dasd: make query host access interruptible
s390/dasd: fix panic during offline processing
s390/dasd: fix hanging offline processing
s390/pci_dma: improve lazy flush for unmap
s390/pci_dma: split dma_update_trans
s390/pci_dma: improve map_sg
s390/pci_dma: simplify dma address calculation
s390/pci_dma: remove dma address range check
iommu/s390: simplify registration of I/O address translation parameters
s390: migrate exception table users off module.h and onto extable.h
s390: export header for CLP ioctl
s390/vmur: fix irq pointer dereference in int handler
s390/dasd: add missing KOBJ_CHANGE event for unformatted devices
s390: enable UBSAN
Pull documentation updates from Jonathan Corbet:
"This is the documentation update pull for the 4.9 merge window.
The Sphinx transition is still creating a fair amount of work. Here we
have a number of fixes and, importantly, a proper PDF output solution,
thanks to Jani Nikula, Mauro Carvalho Chehab and Markus Heiser.
I've started a couple of new books: a driver API book (based on the
old device-drivers.tmpl) and a development tools book. Both are meant
to show how we can integrate together our existing documentation into
a more coherent and accessible whole. It involves moving some stuff
around and formatting changes, but, I think, the results are worth it.
The good news is that most of our existing Documentation/*.txt files
are *almost* in RST format already; the amount of messing around
required is minimal.
And, of course, there's the usual set of updates, typo fixes, and
more"
* tag 'docs-4.9' of git://git.lwn.net/linux: (120 commits)
URL changed for Linux Foundation TAB
dax : Fix documentation with respect to struct pages
iio: Documentation: Correct the path used to create triggers.
docs: Remove space-before-label guidance from CodingStyle
docs-rst: add inter-document cross references
Documentation/email-clients.txt: convert it to ReST markup
Documentation/kernel-docs.txt: reorder based on timestamp
Documentation/kernel-docs.txt: Add dates for online docs
Documentation/kernel-docs.txt: get rid of broken docs
Documentation/kernel-docs.txt: move in-kernel docs
Documentation/kernel-docs.txt: remove more legacy references
Documentation/kernel-docs.txt: add two published books
Documentation/kernel-docs.txt: sort books per publication date
Documentation/kernel-docs.txt: adjust LDD references
Documentation/kernel-docs.txt: some improvements on the ReST output
Documentation/kernel-docs.txt: Consistent indenting: 4 spaces
Documentation/kernel-docs.txt: Add 4 paper/book references
Documentation/kernel-docs.txt: Improve layouting of book list
Documentation/kernel-docs.txt: Remove offline or outdated entries
docs: Clean up bare :: lines
Pull EDAC updates from Borislav Petkov:
"A lot of movement in the EDAC tree this time around, coarse summary
below:
- Altera Arria10 enablement of NAND, DMA, USB, QSPI and SD-MMC FIFO
buffers (Thor Thayer)
- split the memory controller part out of mpc85xx and share it with a
new Freescale ARM Layerscape driver (York Sun)
- amd64_edac fixes (Yazen Ghannam)
- misc cleanups, refactoring and fixes all over the place"
* tag 'edac_for_4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (37 commits)
EDAC, altera: Add IRQ Flags to disable IRQ while handling
EDAC, altera: Correct EDAC IRQ error message
EDAC, amd64: Autoload module using x86_cpu_id
EDAC, sb_edac: Remove NULL pointer check on array pci_tad
EDAC: Remove NO_IRQ from powerpc-only drivers
EDAC, fsl_ddr: Fix error return code in fsl_mc_err_probe()
EDAC, fsl_ddr: Add entry to MAINTAINERS
EDAC: Move Doug Thompson to CREDITS
EDAC, I3000: Orphan driver
EDAC, fsl_ddr: Replace simple_strtoul() with kstrtoul()
EDAC, layerscape: Add Layerscape EDAC support
EDAC, fsl_ddr: Fix IRQ dispose warning when module is removed
EDAC, fsl_ddr: Add support for little endian
EDAC, fsl_ddr: Add missing DDR DRAM types
EDAC, fsl_ddr: Rename macros and names
EDAC, fsl-ddr: Separate FSL DDR driver from MPC85xx
EDAC, mpc85xx: Replace printk() with pr_* format
EDAC, mpc85xx: Drop setting/clearing RFXE bit in HID1
EDAC, altera: Rename MC trigger to common name
EDAC, altera: Rename device trigger to common name
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"The SPI subsystem has also had quite a quiet release, though with a
fairly large set of per-driver changes and several new drivers. The
bulk of the changes are:
- lots and lots of cleanups and improvements for the fsl-espi driver
- new drivers for Broadcom MSPI/iProc/STB, Cavium ThunderX and
J-Core"
* tag 'spi-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (80 commits)
spi: sc18is602: Change gpiod_set_value to gpiod_set_value_cansleep
spi: pxa2xx: Fix build error because of missing header
spi: imx: fix error return code in spi_imx_probe()
spi: pxa2xx: Add support for GPIO descriptor chip selects
spi: imx: Gracefully handle NULL master->cs_gpios
spi: iproc-qspi: Add Broadcom iProc SoCs support
spi: fsl-espi: improve return value handling in fsl_espi_probe
spi: fsl-espi: simplify of_fsl_espi_probe
spi: fsl-espi: remove unused variable in fsl_espi_setup
spi: bcm-qspi: Fix error return code in bcm_qspi_probe()
spi: bcm-qspi: Fix return value check in bcm_qspi_probe()
spi: bcm-qspi: fix suspend/resume #ifdef
spi: bcm-qspi: don't include linux/mtd/cfi.h
spi: core: Use spi_sync_transfer() in spi_write()/spi_read()
spi: fsl-espi: improve and extend register bit definitions
spi: fsl-espi: align register access with other drivers
spi: fsl-espi: improve and simplify interrupt handler
spi: fsl-espi: simplify fsl_espi_setup_transfer
spi: imx: support loopback mode on imx35
spi: imx: set spi_bus_clk for mx1, mx31 and mx35
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk framework updates from Stephen Boyd:
"The core clk framework changes are small again. They're mostly minor
fixes that weren't causing enough problems (or any problems when we're
just clarifying things) to warrant sending outside the merge window.
The majority of changes are in drivers for various SoCs. Full details
are in the logs, but here's the summary.
Core:
- Better support for DeviceTree overlays with the addition of the
CLK_OF_DECLARE_DRIVER macro. Now we won't probe a clk driver for a
device node that matched during of_clk_init(), unless the driver
uses CLK_OF_DECLARE_DRIVER instead of CLK_OF_DECLARE. This allows
overlays to work cleanly for drivers that must probe before the
device model is ready, and also after it's ready when an overlay is
loaded.
- Clarification in the code around how clk_hw pointers are returned
from of clk providers
- Proper migration of prepare/enable counts to parents when the clk
tree is constructed
New Drivers:
- Socionext's UniPhier SoCs
- Loongson1C
- ZTE ZX296718
- Qualcomm MDM9615
- Amlogic GXBB AO clocks and resets
- Broadcom BCM53573 ILP
- Maxim MAX77620
Updates:
- Four Allwinner SoCs are migrated to the new style clk driver (A31,
A31s, A23 and A33)
- Exynos 5xxx audio and DRAM clks
- Loongson1B AC97, DMA and NAND clks
- Rockchip DDR clks and rk3399 driver tweaks
- Renesas R-Car M3-W (r8a7796) SoC SDHI interface and Watchdog timer
clks
- Renasas R-Car H3 and M3-W CMT clks and RAVB+Thermal clks for M3-W
- Amlogic GXBB MMC gate clks
- at91 sama5d4 sckc
- Removal of STiH415 and STiH416 clk support as the SoC is being
removed
- Rework of STiH4xx clk support for new style bindings
- Continuation of driver migration to clk_hw based registration APIs
- xgene PMD support
- bcm2835 critical clk markings
- ARM versatile ICST"
* tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (199 commits)
CLK: Add Loongson1C clock support
clk: Loongson1: Make use of GENMASK
clk: Loongson1: Update clocks of Loongson1B
clk: Loongson1: Refactor Loongson1 clock
clk: change the type of clk_hw_onecell_data.num to unsigned int
clk: zx296718: register driver earlier with core_initcall
clk: mvebu: dynamically allocate resources in Armada CP110 system controller
clk: mvebu: fix setting unwanted flags in CP110 gate clock
clk: nxp: clk-lpc32xx: Unmap region obtained by of_iomap
clk: mediatek: clk-mt8173: Unmap region obtained by of_iomap
clk: sunxi-ng: Fix reset offset for the A23 and A33
clk: at91: sckc: optimize boot time
clk: at91: Add sama5d4 sckc support
clk: at91: move slow clock controller clocks to sckc.c
clk: imx6: initialize GPU clocks
clk: imx6: fix i.MX6DL clock tree to reflect reality
clk: imx53: Add clocks configuration
clk: uniphier: add clock data for UniPhier SoCs
clk: uniphier: add core support code for UniPhier clock driver
clk: bcm: Add driver for BCM53573 ILP clock
git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds
Pull LED driver updates from Jacek Anaszewski:
"Three new LED class drivers and some minor fixes and improvementes to
the leds-gpio driver, LED Trigger core and documentation"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds:
leds: triggers: Check return value of kobject_uevent_env()
leds: triggers: Return from led_trigger_set() if there is nothing to do
leds: gpio: fix and simplify error handling in gpio_leds_create
leds: gpio: switch to managed version of led_classdev_register
leds: gpio: fix and simplify reading property "label"
leds: gpio: simplify gpio_leds_create
leds: gpio: add helper cdev_to_gpio_led_data
leds: gpio: fix an unhandled error case in create_gpio_led
leds: gpio: introduce gpio_blink_set_t
leds: add driver for Mellanox systems LEDs
Documentation: move oneshot trigger attributes documentation to ABI
leds: centralize definition of "default-state" property
leds: add PM8058 LEDs driver
leds: pm8058: add device tree bindings
leds: do not overflow sysfs buffer in led_trigger_show
leds: make triggers explicitly non-modular
DT: leds: Add bindings for ISSI is31fl319x
leds: is31fl319x: 1/3/6/9-channel light effect led driver
Reviewed-by: Andrew Jeffery <andrew@aj.id.au>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Add record for Freescale QORIQ DPAA FMan driver adding myself as
maintainer.
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull usb/phy/extcon updates from Greg KH:
"Here is the big USB, and PHY, and extcon, patchsets for 4.9-rc1.
Full details are in the shortlog, but generally a lot of new hardware
support, usb gadget updates, and Wolfram's great cleanup of USB error
message handling, making the kernel image a tad bit smaller.
All of this has been in linux-next with no reported issues"
* tag 'usb-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (343 commits)
Revert "usbtmc: convert to devm_kzalloc"
USB: serial: cp210x: Add ID for a Juniper console
usb: Kconfig: using select for USB_COMMON dependency
bluetooth: bcm203x: don't print error when allocating urb fails
mmc: host: vub300: don't print error when allocating urb fails
usb: hub: change CLEAR_FEATURE to SET_FEATURE
usb: core: Introduce a USB port LED trigger
USB: bcma: drop Northstar PHY 2.0 initialization code
usb: core: hcd: add missing header dependencies
usb: musb: da8xx: fix error handling message in probe
usb: musb: Fix session based PM for first invalid VBUS
usb: musb: Fix PM runtime for disconnect after unconfigure
musb: Export musb_root_disconnect for use in modules
usb: misc: legousbtower: Fix NULL pointer deference
cdc-acm: hardening against malicious devices
Revert "usb: gadget: NCM: Protect dev->port_usb using dev->lock"
include: extcon: Fix compilation error caused because of incomplete merge
MAINTAINERS: add tree entry for USB Serial
phy-twl4030-usb: initialize charging-related stuff via pm_runtime
phy-twl4030-usb: better handle musb_mailbox() failure
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty and serial updates from Greg KH:
"Here is the big tty and serial patch set for 4.9-rc1.
It also includes some drivers/dma/ changes, as those were needed by
some serial drivers, and they were all acked by the DMA maintainer.
Also in here is the long-suffering ACPI SPCR patchset, which was
passed around from maintainer to maintainer like a hot-potato. Seems I
was the sucker^Wlucky one. All of those patches have been acked by the
various subsystem maintainers as well.
* tag 'tty-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (111 commits)
Revert "serial: pl011: add console matching function"
MAINTAINERS: update entry for atmel_serial driver
ARM64: ACPI: enable ACPI_SPCR_TABLE
ACPI: parse SPCR and enable matching console
of/serial: move earlycon early_param handling to serial
Revert "drivers/tty: Explicitly pass current to show_stack"
tty: amba-pl011: Don't complain on -EPROBE_DEFER when no irq
nios2: dts: 10m50: Add tx-threshold parameter
serial: 8250: Set Altera 16550 TX FIFO Threshold
serial: 8250: of: Load TX FIFO Threshold from DT
Documentation: dt: serial: Add TX FIFO threshold parameter
serial: imx: Fix DCD reading
serial: stm32: mark symbols static where possible
serial: xuartps: Add some register initialisation to cdns_early_console_setup()
serial: xuartps: Removed unwanted checks while reading the error conditions
serial: xuartps: Rewrite the interrupt handling logic
serial: stm32: use mapbase instead of membase for DMA
tty/serial: atmel: fix fractional baud rate computation
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here are the "big" driver core patches for 4.9-rc1. Also in here are a
number of debugfs fixes that cropped up due to the changes that
happened in 4.8 for that filesystem. Overall, nothing major, just a
few fixes and cleanups.
All of these have been in linux-next with no reported issues"
* tag 'driver-core-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (23 commits)
drivers: dma-coherent: Move spinlock in dma_alloc_from_coherent()
drivers: dma-coherent: Fix DMA coherent size for less than page
MAINTAINERS: extend firmware_class maintainer list
debugfs: propagate release() call result
driver-core: platform: Catch errors from calls to irq_get_irq_data
sysfs print name of undiscoverable attribute group
carl9170: fix debugfs crashes
b43legacy: fix debugfs crash
b43: fix debugfs crash
debugfs: introduce a public file_operations accessor
device core: Remove deprecated create_singlethread_workqueue
drivers/base dmam_declare_coherent_memory leaks
platform: don't return 0 from platform_get_irq[_byname]() on error
cpu: clean up register_cpu func
dma-mapping: use vma_pages().
drivers: dma-coherent: use vma_pages().
attribute_container: Fix typo
base: soc: make it explicitly non-modular
drivers: base: dma-mapping: page align the size when unmap_kernel_range
platform driver: fix use-after-free in platform_device_del()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the "big" char and misc driver update for 4.9-rc1.
Lots of little things here, all over the driver tree for subsystems
that flow through me. Nothing major that I can discern, full details
are in the shortlog.
All have been in the linux-next tree with no reported issues"
* tag 'char-misc-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (144 commits)
drivers/misc/hpilo: Changes to support new security states in iLO5 FW
at25: fix debug and error messaging
misc/genwqe: ensure zero initialization
vme: fake: remove unexpected unlock in fake_master_set()
vme: fake: mark symbols static where possible
spmi: pmic-arb: Return an error code if sanity check fails
Drivers: hv: get rid of id in struct vmbus_channel
Drivers: hv: make VMBus bus ids persistent
mcb: Add a dma_device to mcb_device
mcb: Enable PCI bus mastering by default
mei: stop the stall timer worker if not needed
clk: probe common clock drivers earlier
vme: fake: fix build for 64-bit dma_addr_t
ttyprintk: Neaten and simplify printing
mei: me: add kaby point device ids
coresight: tmc: mark symbols static where possible
coresight: perf: deal with error condition properly
Drivers: hv: hv_util: Avoid dynamic allocation in time synch
fpga manager: Add hardware dependency to Zynq driver
Drivers: hv: utils: Support TimeSync version 4.0 protocol samples.
Pull x86 platform changes from Ingo Molnar:
"The main changes in this cycle were:
- SGI UV updates (Andrew Banman)
- Intel MID updates (Andy Shevchenko)
- Initial Mellanox systems platform (Vadim Pasternak)"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/platform/mellanox: Fix return value check in mlxplat_init()
x86/platform/mellanox: Introduce support for Mellanox systems platform
x86/platform/uv/BAU: Add UV4-specific functions
x86/platform/uv/BAU: Fix payload queue setup on UV4 hardware
x86/platform/uv/BAU: Disable software timeout on UV4 hardware
x86/platform/uv/BAU: Populate ->uvhub_version with UV4 version information
x86/platform/uv/BAU: Use generic function pointers
x86/platform/uv/BAU: Add generic function pointers
x86/platform/uv/BAU: Convert uv_physnodeaddr() use to uv_gpa_to_offset()
x86/platform/uv/BAU: Clean up pq_init()
x86/platform/uv/BAU: Clean up and update printks
x86/platform/uv/BAU: Clean up vertical alignment
x86/platform/intel-mid: Keep SRAM powered on at boot
x86/platform/intel-mid: Add Intel Penwell to ID table
x86/cpu: Rename Merrifield2 to Moorefield
x86/platform/intel-mid: Implement power off sequence
x86/platform/intel-mid: Enable SD card detection on Merrifield
x86/platform/intel-mid: Enable WiFi on Intel Edison
x86/platform/intel-mid: Run PWRMU command immediately
Pull perf updates from Ingo Molnar:
"The main kernel side changes were:
- uprobes enhancements (Masami Hiramatsu)
- Uncore group events enhancements (David Carrillo-Cisneros)
- x86 Intel: Add support for Skylake server uncore PMUs (Kan Liang)
- x86 Intel: LBR cleanups and enhancements, for better branch
annotation tracking (Peter Zijlstra)
- x86 Intel: Add support for PTWRITE and power event tracing
(Alexander Shishkin)
- ... various fixes, cleanups and smaller enhancements.
Lots of tooling changes - a couple of highlights:
- Support event group view with hierarchy mode in 'perf top' and
'perf report' (Namhyung Kim)
e.g.:
$ perf record -e '{cycles,instructions}' make
$ perf report --hierarchy --stdio
# Overhead Command / Shared Object / Symbol
25.74% 27.18%sh
19.96% 24.14%libc-2.24.so
9.55% 14.64%[.] __strcmp_sse2
1.54% 0.00%[.] __tfind
1.07% 1.13%[.] _int_malloc
0.95% 0.00%[.] __strchr_sse2
0.89% 1.39%[.] __tsearch
0.76% 0.00%[.] strlen
- Add branch stack / basic block info to 'perf annotate --stdio',
where for each branch, we add an asm comment after the instruction
with information on how often it was taken and predicted. See
example with color output at:
http://vger.kernel.org/~acme/perf/annotate_basic_blocks.png
(Peter Zijlstra)
- Add support for using symbols in address filters with Intel PT and
ARM CoreSight (hardware assisted tracing facilities) (Adrian
Hunter, Mathieu Poirier)
- Add support for interacting with Coresight PMU ETMs/PTMs, that are
IP blocks to perform hardware assisted tracing on a ARM CPU core
(Mathieu Poirier)
- Support generating cross arch probes, i.e. if you specify a vmlinux
file for different arch than the one in the host machine,
$ perf probe --definition function_name args
will generate the probe definition string needed to append to the
target machine /sys/kernel/debug/tracing/kprobes_events file, using
scripting (Masami Hiramatsu).
- Allow configuring the default 'perf report -s' sort order in
~/.perfconfig, for instance, "sym,dso" may be more fitting for
kernel developers. (Arnaldo Carvalho de Melo)
- ... plus lots of other changes, refactorings, features and fixes"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (149 commits)
perf tests: Add dwarf unwind test for powerpc
perf probe: Match linkage name with mangled name
perf probe: Fix to cut off incompatible chars from group name
perf probe: Skip if the function address is 0
perf probe: Ignore the error of finding inline instance
perf intel-pt: Fix decoding when there are address filters
perf intel-pt: Enable decoder to handle TIP.PGD with missing IP
perf intel-pt: Read address filter from AUXTRACE_INFO event
perf intel-pt: Record address filter in AUXTRACE_INFO event
perf intel-pt: Add a helper function for processing AUXTRACE_INFO
perf intel-pt: Fix missing error codes processing auxtrace_info
perf intel-pt: Add support for recording the max non-turbo ratio
perf intel-pt: Fix snapshot overlap detection decoder errors
perf probe: Increase debug level of SDT debug messages
perf record: Add support for using symbols in address filters
perf symbols: Add dso__last_symbol()
perf record: Fix error paths
perf record: Rename label 'out_symbol_exit'
perf script: Fix vanished idle symbols
perf evsel: Add support for address filters
Pull EFI updates from Ingo Molnar:
"Main changes in this cycle were:
- Refactor the EFI memory map code into architecture neutral files
and allow drivers to permanently reserve EFI boot services regions
on x86, as well as ARM/arm64. (Matt Fleming)
- Add ARM support for the EFI ESRT driver. (Ard Biesheuvel)
- Make the EFI runtime services and efivar API interruptible by
swapping spinlocks for semaphores. (Sylvain Chouleur)
- Provide the EFI identity mapping for kexec which allows kexec to
work on SGI/UV platforms with requiring the "noefi" kernel command
line parameter. (Alex Thorlton)
- Add debugfs node to dump EFI page tables on arm64. (Ard Biesheuvel)
- Merge the EFI test driver being carried out of tree until now in
the FWTS project. (Ivan Hu)
- Expand the list of flags for classifying EFI regions as "RAM" on
arm64 so we align with the UEFI spec. (Ard Biesheuvel)
- Optimise out the EFI mixed mode if it's unsupported (CONFIG_X86_32)
or disabled (CONFIG_EFI_MIXED=n) and switch the early EFI boot
services function table for direct calls, alleviating us from
having to maintain the custom function table. (Lukas Wunner)
- Miscellaneous cleanups and fixes"
* 'efi-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (30 commits)
x86/efi: Round EFI memmap reservations to EFI_PAGE_SIZE
x86/efi: Allow invocation of arbitrary boot services
x86/efi: Optimize away setup_gop32/64 if unused
x86/efi: Use kmalloc_array() in efi_call_phys_prolog()
efi/arm64: Treat regions with WT/WC set but WB cleared as memory
efi: Add efi_test driver for exporting UEFI runtime service interfaces
x86/efi: Defer efi_esrt_init until after memblock_x86_fill
efi/arm64: Add debugfs node to dump UEFI runtime page tables
x86/efi: Remove unused find_bits() function
fs/efivarfs: Fix double kfree() in error path
x86/efi: Map in physical addresses in efi_map_region_fixed
lib/ucs2_string: Speed up ucs2_utf8size()
firmware-gsmi: Delete an unnecessary check before the function call "dma_pool_destroy"
x86/efi: Initialize status to ensure garbage is not returned on small size
efi: Replace runtime services spinlock with semaphore
efi: Don't use spinlocks for efi vars
efi: Use a file local lock for efivars
efi/arm*: esrt: Add missing call to efi_esrt_init()
efi/esrt: Use memremap not ioremap to access ESRT table in memory
x86/efi-bgrt: Use efi_mem_reserve() to avoid copying image data
Pull core SMP updates from Ingo Molnar:
"Two main change is generic vCPU pinning and physical CPU SMP-call
support, for Xen to be able to perform certain calls on specific
physical CPUs - by Juergen Gross"
* 'core-smp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
smp: Allocate smp_call_on_cpu() workqueue on stack too
hwmon: Use smp_call_on_cpu() for dell-smm i8k
dcdbas: Make use of smp_call_on_cpu()
xen: Add xen_pin_vcpu() to support calling functions on a dedicated pCPU
smp: Add function to execute a function synchronously on a CPU
virt, sched: Add generic vCPU pinning support
xen: Sync xen header
Pull power management updates from Rafael Wysocki:
"Traditionally, cpufreq is the area with the greatest number of
changes, but there are fewer of them than last time. There also is
some activity in the generic power domains and the devfreq frameworks,
a couple of system suspend and hibernation fixes and some assorted
changes in other places.
One new feature is the cpufreq change to allow the scheduler to pass
hints to the governors' utilization update callbacks and some code
rework based on that. Another one is the support for domain removal in
the generic power domains framework. Also it is now possible to use
hibernation with PAGE_POISONING_ZERO enabled and devfreq supports the
RockChip DFI controller and the rk3399 DMC.
The rest of the changes is mostly fixes and cleanups in a number of
places.
Specifics:
- Add a mechanism for passing hints from the scheduler to cpufreq
governors via their utilization update callbacks and use it to
introduce "IOwait boosting" into the schedutil governor and
intel_pstate that will make them boost performance if the enqueued
task was previously waiting on I/O (Rafael Wysocki).
- Fix a schedutil governor problem that causes it to overestimate
utilization if SMT is in use (Steve Muckle).
- Update defconfigs trying to use the schedutil governor as a module
which is not possible any more (Javier Martinez Canillas).
- Update the intel_pstate's pstate_sample tracepoint to take "IOwait
boosting" into account (Srinivas Pandruvada).
- Fix a problem in the cpufreq core causing it to mishandle the
initialization of CPUs registered after the cpufreq driver (Viresh
Kumar, Rafael Wysocki).
- Make the cpufreq-dt driver support per-policy governor tunables,
clean it up and update its Kconfig description (Viresh Kumar).
- Add support for more ARM platforms to the cpufreq-dt driver
(Chanwoo Choi, Dave Gerlach, Geert Uytterhoeven).
- Make the cpufreq CPPC driver report frequencies in KHz to avoid
user space compatiblility issues (Al Stone, Hoan Tran).
- Clean up a few cpufreq drivers (st, kirkwood, SCPI) a bit (Colin
Ian King, Markus Elfring).
- Constify some local structures in the intel_pstate driver (Julia
Lawall).
- Add a Documentation/cpu-freq/ entry to MAINTAINERS (Jean Delvare).
- Add support for PM domain removal to the generic power domains
(genpd) framework, add new DT helper functions to it and make it
always enable debugfs support if available (Jon Hunter, Tomeu
Vizoso).
- Clean up the generic power domains (genpd) framework and make it
avoid measuring power-on and power-off latencies during system-wide
PM transitions (Ulf Hansson).
- Add support for the RockChip DFI controller and the rk3399 DMC to
the devfreq framework (Lin Huang, Axel Lin, Arnd Bergmann).
- Add COMPILE_TEST to the devfreq framework (Krzysztof Kozlowski,
Stephen Rothwell).
- Fix a minor issue in the exynos-ppmu devfreq driver and fix up
devfreq Kconfig indentation style (Wei Yongjun, Jisheng Zhang).
- Fix the system suspend interface to make suspend-to-idle work if
platform suspend operations have not been registered (Sudeep
Holla).
- Make it possible to use hibernation with PAGE_POISONING_ZERO
enabled (Anisse Astier).
- Increas the default timeout of the system suspend/resume watchdog
and make it depend on EXPERT (Chen Yu).
- Make the operating performance points (OPP) framework avoid using
OPPs that aren't supported by the platform and fix a build warning
in it (Dave Gerlach, Arnd Bergmann).
- Fix the ARM cpuidle driver's return value (Christophe Jaillet).
- Make the SmartReflex AVS (Adaptive Voltage Scaling) driver use more
common logging style (Joe Perches)"
* tag 'pm-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (58 commits)
PM / OPP: Don't support OPP if it provides supported-hw but platform does not
cpufreq: st: add missing \n to end of dev_err message
cpufreq: kirkwood: add missing \n to end of dev_err messages
PM / Domains: Rename pm_genpd_sync_poweron|poweroff()
PM / Domains: Don't measure latency of ->power_on|off() during system PM
PM / Domains: Remove redundant system PM callbacks
PM / Domains: Simplify detaching a device from its genpd
PM / devfreq: rk3399_dmc: Remove explictly regulator_put call in .remove
PM / devfreq: rockchip: add PM_DEVFREQ_EVENT dependency
PM / OPP: avoid maybe-uninitialized warning
PM / Domains: Allow holes in genpd_data.domains array
cpufreq: CPPC: Avoid overflow when calculating desired_perf
cpufreq: ti: Use generic platdev driver
cpufreq: intel_pstate: Add io_boost trace
partial revert of "PM / devfreq: Add COMPILE_TEST for build coverage"
cpufreq: intel_pstate: Use IOWAIT flag in Atom algorithm
cpufreq: schedutil: Add iowait boosting
cpufreq / sched: SCHED_CPUFREQ_IOWAIT flag to indicate iowait condition
PM / Domains: Add support for removing nested PM domains by provider
PM / Domains: Add support for removing PM domains
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"It's a bit all over the place this time with no "killer feature" to
speak of. Support for mismatched cache line sizes should help people
seeing whacky JIT failures on some SoCs, and the big.LITTLE perf
updates have been a long time coming, but a lot of the changes here
are cleanups.
We stray outside arch/arm64 in a few areas: the arch/arm/ arch_timer
workaround is acked by Russell, the DT/OF bits are acked by Rob, the
arch_timer clocksource changes acked by Marc, CPU hotplug by tglx and
jump_label by Peter (all CC'd).
Summary:
- Support for execute-only page permissions
- Support for hibernate and DEBUG_PAGEALLOC
- Support for heterogeneous systems with mismatches cache line sizes
- Errata workarounds (A53 843419 update and QorIQ A-008585 timer bug)
- arm64 PMU perf updates, including cpumasks for heterogeneous systems
- Set UTS_MACHINE for building rpm packages
- Yet another head.S tidy-up
- Some cleanups and refactoring, particularly in the NUMA code
- Lots of random, non-critical fixes across the board"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (100 commits)
arm64: tlbflush.h: add __tlbi() macro
arm64: Kconfig: remove SMP dependence for NUMA
arm64: Kconfig: select OF/ACPI_NUMA under NUMA config
arm64: fix dump_backtrace/unwind_frame with NULL tsk
arm/arm64: arch_timer: Use archdata to indicate vdso suitability
arm64: arch_timer: Work around QorIQ Erratum A-008585
arm64: arch_timer: Add device tree binding for A-008585 erratum
arm64: Correctly bounds check virt_addr_valid
arm64: migrate exception table users off module.h and onto extable.h
arm64: pmu: Hoist pmu platform device name
arm64: pmu: Probe default hw/cache counters
arm64: pmu: add fallback probe table
MAINTAINERS: Update ARM PMU PROFILING AND DEBUGGING entry
arm64: Improve kprobes test for atomic sequence
arm64/kvm: use alternative auto-nop
arm64: use alternative auto-nop
arm64: alternative: add auto-nop infrastructure
arm64: lse: convert lse alternatives NOP padding to use __nops
arm64: barriers: introduce nops and __nops macros for NOP sequences
arm64: sysreg: replace open-coded mrs_s/msr_s with {read,write}_sysreg_s
Three sets of overlapping changes. Nothing serious.
Some Greybus Audio Device Class Protocol driver files are missing
in the MAINTAINERS file even though they are maintained so add
them.
CC: Vaibhav Agarwal <vaibhav.sr@gmail.com>
Signed-off-by: Mark Greer <mgreer@animalcreek.com>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
* pm-cpufreq: (24 commits)
cpufreq: CPPC: Force reporting values in KHz to fix user space interface
cpufreq: create link to policy only for registered CPUs
intel_pstate: constify local structures
cpufreq: dt: Support governor tunables per policy
cpufreq: dt: Update kconfig description
cpufreq: dt: Remove unused code
MAINTAINERS: Add Documentation/cpu-freq/
cpufreq: dt: Add support for r8a7792
cpufreq / sched: ignore SMT when determining max cpu capacity
cpufreq: Drop unnecessary check from cpufreq_policy_alloc()
ARM: multi_v7_defconfig: Don't attempt to enable schedutil governor as module
ARM: exynos_defconfig: Don't attempt to enable schedutil governor as module
