As of v3.7, the UAPI changes relocated headers around such that the
kernel version header lived in a new place.
If a person is bisecting and if you go back to pre-UAPI days,
you will create an include/linux/version.h -- then if you checkout a
post-UAPI kernel, and even run "make distclean" it still won't delete
that old version file. So you get a situation like this:
$ grep -R LINUX_VERSION_CODE include/
include/generated/uapi/linux/version.h:#define LINUX_VERSION_CODE 200192
include/linux/version.h:#define LINUX_VERSION_CODE 132646
The value in that second line is representative of a v2.6.38 version.
And it will be sourced/used, hence leading to strange behaviours, such
as drivers/staging content (which typically hasn't been purged of version
ifdefs) failing to build.
Since it is a subtle mode of failure, lets always clobber the old
file when doing a distclean.
[shawn.guo: cherry-pick commit 9c8cdb71644a from upstream]
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
commit 2062afb4f804afef61cbe62a30cac9a46e58e067 upstream.
Michel Dänzer and a couple of other people reported inexplicable random
oopses in the scheduler, and the cause turns out to be gcc mis-compiling
the load_balance() function when debugging is enabled. The gcc bug
apparently goes back to gcc-4.5, but slight optimization changes means
that it now showed up as a problem in 4.9.0 and 4.9.1.
The instruction scheduling problem causes gcc to schedule a spill
operation to before the stack frame has been created, which in turn can
corrupt the spilled value if an interrupt comes in. There may be other
effects of this bug too, but that's the code generation problem seen in
Michel's case.
This is fixed in current gcc HEAD, but the workaround as suggested by
Markus Trippelsdorf is pretty simple: use -fno-var-tracking-assignments
when compiling the kernel, which disables the gcc code that causes the
problem. This can result in slightly worse debug information for
variable accesses, but that is infinitely preferable to actual code
generation problems.
Doing this unconditionally (not just for CONFIG_DEBUG_INFO) also allows
non-debug builds to verify that the debug build would be identical: we
can do
export GCC_COMPARE_DEBUG=1
to make gcc internally verify that the result of the build is
independent of the "-g" flag (it will make the compiler build everything
twice, toggling the debug flag, and compare the results).
Without the "-fno-var-tracking-assignments" option, the build would fail
(even with 4.8.3 that didn't show the actual stack frame bug) with a gcc
compare failure.
See also gcc bugzilla:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=61801
Reported-by: Michel Dänzer <michel@daenzer.net>
Suggested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Jakub Jelinek <jakub@redhat.com>
