path: root/Makefile
2017-09-14Linux 4.1.44Sasha Levin
2017-08-05Linux 4.1.43Sasha Levin
2017-07-31jump label: fix passing kbuild_cflags when checking for asm goto supportGleb Fotengauer-Malinovskiy
[ Upstream commit 7292ae3d5a18fb922be496e6bb687647193569b4 ] The latest change of asm goto support check added passing of KBUILD_CFLAGS to compiler. When these flags reference gcc plugins that are not built yet, the check fails. When one runs "make bzImage" followed by "make modules", the kernel is always built with HAVE_JUMP_LABEL disabled, while the modules are built depending on CONFIG_JUMP_LABEL. If HAVE_JUMP_LABEL macro happens to be different, modules are built with undefined references, e.g.: ERROR: "static_key_slow_inc" [net/netfilter/xt_TEE.ko] undefined! ERROR: "static_key_slow_dec" [net/netfilter/xt_TEE.ko] undefined! ERROR: "static_key_slow_dec" [net/netfilter/nft_meta.ko] undefined! ERROR: "static_key_slow_inc" [net/netfilter/nft_meta.ko] undefined! ERROR: "nf_hooks_needed" [net/netfilter/ipvs/ip_vs.ko] undefined! ERROR: "nf_hooks_needed" [net/ipv6/ipv6.ko] undefined! ERROR: "static_key_count" [net/ipv6/ipv6.ko] undefined! ERROR: "static_key_slow_inc" [net/ipv6/ipv6.ko] undefined! This change moves the check before all these references are added to KBUILD_CFLAGS. This is correct because subsequent KBUILD_CFLAGS modifications are not relevant to this check. Reported-by: Anton V. Boyarshinov <boyarsh@altlinux.org> Fixes: 35f860f9ba6a ("jump label: pass kbuild_cflags when checking for asm goto support") Cc: stable@vger.kernel.org # v4.10 Signed-off-by: Gleb Fotengauer-Malinovskiy <glebfm@altlinux.org> Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Acked-by: David Lin <dtwlin@google.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-06-29Linux 4.1.42Sasha Levin
2017-06-25jump label: pass kbuild_cflags when checking for asm goto supportDavid Lin
[ Upstream commit 35f860f9ba6aac56cc38e8b18916d833a83f1157 ] Some versions of ARM GCC compiler such as Android toolchain throws in a '-fpic' flag by default. This causes the gcc-goto check script to fail although some config would have '-fno-pic' flag in the KBUILD_CFLAGS. This patch passes the KBUILD_CFLAGS to the check script so that the script does not rely on the default config from different compilers. Link: http://lkml.kernel.org/r/20170120234329.78868-1-dtwlin@google.com Signed-off-by: David Lin <dtwlin@google.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Michal Marek <mmarek@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-06-15Linux 4.1.41Sasha Levin
2017-05-28Linux 4.1.40Sasha Levin
2017-03-13Linux 4.1.39Sasha Levin
2017-01-18Linux 4.1.38Sasha Levin
2016-12-24Linux 4.1.37Sasha Levin
2016-11-29Linux 4.1.36Sasha Levin
2016-11-25kbuild: add -fno-PIESebastian Andrzej Siewior
[ Upstream commit 8ae94224c9d72fc4d9aaac93b2d7833cf46d7141 ] Debian started to build the gcc with -fPIE by default so the kernel build ends before it starts properly with: |kernel/bounds.c:1:0: error: code model kernel does not support PIC mode Also add to KBUILD_AFLAGS due to: |gcc -Wp,-MD,arch/x86/entry/vdso/vdso32/.note.o.d … -mfentry -DCC_USING_FENTRY … vdso/vdso32/note.S |arch/x86/entry/vdso/vdso32/note.S:1:0: sorry, unimplemented: -mfentry isn’t supported for 32-bit in combination with -fpic Tagging it stable so it is possible to compile recent stable kernels as well. Cc: stable@vger.kernel.org Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-23Linux 4.1.35Sasha Levin
2016-10-09Linux 4.1.34Sasha Levin
2016-09-17Linux 4.1.33Sasha Levin
2016-09-02Linux 4.1.32v4.1.32Sasha Levin
2016-08-22Linux 4.1.31v4.1.31Sasha Levin
2016-08-08Linux 4.1.30v4.1.30Sasha Levin
2016-07-29Linux 4.1.29v4.1.29Sasha Levin
2016-07-13Linux 4.1.28v4.1.28Sasha Levin
2016-06-22Linux 4.1.27v4.1.27Sasha Levin
2016-06-06Linux 4.1.26v4.1.26Sasha Levin
2016-06-06kbuild: move -Wunused-const-variable to W=1 warning levelArnd Bergmann
[ Upstream commit c9c6837d39311b0cc14cdbe7c18e815ab44aefb1 ] gcc-6 started warning by default about variables that are not used anywhere and that are marked 'const', generating many false positives in an allmodconfig build, e.g.: arch/arm/mach-davinci/board-da830-evm.c:282:20: warning: 'da830_evm_emif25_pins' defined but not used [-Wunused-const-variable=] arch/arm/plat-omap/dmtimer.c:958:34: warning: 'omap_timer_match' defined but not used [-Wunused-const-variable=] drivers/bluetooth/hci_bcm.c:625:39: warning: 'acpi_bcm_default_gpios' defined but not used [-Wunused-const-variable=] drivers/char/hw_random/omap-rng.c:92:18: warning: 'reg_map_omap4' defined but not used [-Wunused-const-variable=] drivers/devfreq/exynos/exynos5_bus.c:381:32: warning: 'exynos5_busfreq_int_pm' defined but not used [-Wunused-const-variable=] drivers/dma/mv_xor.c:1139:34: warning: 'mv_xor_dt_ids' defined but not used [-Wunused-const-variable=] This is similar to the existing -Wunused-but-set-variable warning that was added in an earlier release and that we disable by default now and only enable when W=1 is set, so it makes sense to do the same here. Once we have eliminated the majority of the warnings for both, we can put them back into the default list. We probably want this in backport kernels as well, to allow building them with gcc-6 without introducing extra warnings. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Lee Jones <lee.jones@linaro.org> Cc: stable@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-06gcov: disable tree-loop-im to reduce stack usageArnd Bergmann
[ Upstream commit c87bf431448b404a6ef5fbabd74c0e3e42157a7f ] Enabling CONFIG_GCOV_PROFILE_ALL produces us a lot of warnings like lib/lz4/lz4hc_compress.c: In function 'lz4_compresshcctx': lib/lz4/lz4hc_compress.c:514:1: warning: the frame size of 1504 bytes is larger than 1024 bytes [-Wframe-larger-than=] After some investigation, I found that this behavior started with gcc-4.9, and opened https://gcc.gnu.org/bugzilla/show_bug.cgi?id=69702. A suggested workaround for it is to use the -fno-tree-loop-im flag that turns off one of the optimization stages in gcc, so the code runs a little slower but does not use excessive amounts of stack. We could make this conditional on the gcc version, but I could not find an easy way to do this in Kbuild and the benefit would be fairly small, given that most of the gcc version in production are affected now. I'm marking this for 'stable' backports because it addresses a bug with code generation in gcc that exists in all kernel versions with the affected gcc releases. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: stable@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-20Linux 4.1.25v4.1.25Sasha Levin
2016-05-11Linux 4.1.24v4.1.24Sasha Levin
2016-04-25Linux 4.1.23v4.1.23Sasha Levin
2016-04-19Linux 4.1.22v4.1.22Sasha Levin
2016-04-03Linux 4.1.21v4.1.21Sasha Levin
2016-03-17Linux 4.1.20v4.1.20Sasha Levin
2016-03-04Linux 4.1.19v4.1.19Sasha Levin
2016-02-15Linux 4.1.18v4.1.18Sasha Levin
2016-01-31Linux 4.1.17v4.1.17Greg Kroah-Hartman
2016-01-22Linux 4.1.16v4.1.16Greg Kroah-Hartman
2015-12-14Linux 4.1.15v4.1.15Greg Kroah-Hartman
2015-12-09Linux 4.1.14v4.1.14Greg Kroah-Hartman
2015-11-09Linux 4.1.13v4.1.13Greg Kroah-Hartman
2015-10-27Linux 4.1.12v4.1.12Greg Kroah-Hartman
2015-10-22Linux 4.1.11v4.1.11Greg Kroah-Hartman
2015-10-03Linux 4.1.10v4.1.10Greg Kroah-Hartman
2015-09-29Linux 4.1.9v4.1.9Greg Kroah-Hartman
2015-09-21Linux 4.1.8v4.1.8Greg Kroah-Hartman
2015-09-13Linux 4.1.7v4.1.7Greg Kroah-Hartman
2015-08-16Linux 4.1.6v4.1.6Greg Kroah-Hartman
2015-08-10Linux 4.1.5v4.1.5Greg Kroah-Hartman
2015-08-10kbuild: Allow arch Makefiles to override {cpp,ld,c}flagsMichal Marek
commit 61754c18752ffb78145671e94f053fb202fff041 upstream. Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command line options), the arch Makefile is included earlier by the main Makefile, preventing the arc architecture to set its -O3 compiler option. Since there might be more use cases for an arch Makefile to fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and ARCH_CFLAGS variables that are appended to the respective kbuild variables. The user still has the final say via the KCPPFLAGS, KAFLAGS and KCFLAGS variables. Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03Linux 4.1.4v4.1.4Greg Kroah-Hartman
2015-07-21Linux 4.1.3v4.1.3Greg Kroah-Hartman
2015-07-10Linux 4.1.2v4.1.2Greg Kroah-Hartman
2015-06-29Linux 4.1.1v4.1.1Greg Kroah-Hartman
