[ Upstream commit 8ae94224c9d72fc4d9aaac93b2d7833cf46d7141 ]
Debian started to build the gcc with -fPIE by default so the kernel
build ends before it starts properly with:
|kernel/bounds.c:1:0: error: code model kernel does not support PIC mode
Also add to KBUILD_AFLAGS due to:
|gcc -Wp,-MD,arch/x86/entry/vdso/vdso32/.note.o.d … -mfentry -DCC_USING_FENTRY … vdso/vdso32/note.S
|arch/x86/entry/vdso/vdso32/note.S:1:0: sorry, unimplemented: -mfentry isn’t supported for 32-bit in combination with -fpic
Tagging it stable so it is possible to compile recent stable kernels as
well.
Cc: stable@vger.kernel.org
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Michal Marek <mmarek@suse.com>
[ Upstream commit c9c6837d39311b0cc14cdbe7c18e815ab44aefb1 ]
gcc-6 started warning by default about variables that are not
used anywhere and that are marked 'const', generating many
false positives in an allmodconfig build, e.g.:
arch/arm/mach-davinci/board-da830-evm.c:282:20: warning: 'da830_evm_emif25_pins' defined but not used [-Wunused-const-variable=]
arch/arm/plat-omap/dmtimer.c:958:34: warning: 'omap_timer_match' defined but not used [-Wunused-const-variable=]
drivers/bluetooth/hci_bcm.c:625:39: warning: 'acpi_bcm_default_gpios' defined but not used [-Wunused-const-variable=]
drivers/char/hw_random/omap-rng.c:92:18: warning: 'reg_map_omap4' defined but not used [-Wunused-const-variable=]
drivers/devfreq/exynos/exynos5_bus.c:381:32: warning: 'exynos5_busfreq_int_pm' defined but not used [-Wunused-const-variable=]
drivers/dma/mv_xor.c:1139:34: warning: 'mv_xor_dt_ids' defined but not used [-Wunused-const-variable=]
This is similar to the existing -Wunused-but-set-variable warning
that was added in an earlier release and that we disable by default
now and only enable when W=1 is set, so it makes sense to do
the same here. Once we have eliminated the majority of the
warnings for both, we can put them back into the default list.
We probably want this in backport kernels as well, to allow building
them with gcc-6 without introducing extra warnings.
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit c87bf431448b404a6ef5fbabd74c0e3e42157a7f ]
Enabling CONFIG_GCOV_PROFILE_ALL produces us a lot of warnings like
lib/lz4/lz4hc_compress.c: In function 'lz4_compresshcctx':
lib/lz4/lz4hc_compress.c:514:1: warning: the frame size of 1504 bytes is larger than 1024 bytes [-Wframe-larger-than=]
After some investigation, I found that this behavior started with gcc-4.9,
and opened https://gcc.gnu.org/bugzilla/show_bug.cgi?id=69702.
A suggested workaround for it is to use the -fno-tree-loop-im
flag that turns off one of the optimization stages in gcc, so the
code runs a little slower but does not use excessive amounts
of stack.
We could make this conditional on the gcc version, but I could not
find an easy way to do this in Kbuild and the benefit would be
fairly small, given that most of the gcc version in production are
affected now.
I'm marking this for 'stable' backports because it addresses a bug
with code generation in gcc that exists in all kernel versions
with the affected gcc releases.
Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
commit 61754c18752ffb78145671e94f053fb202fff041 upstream.
Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command
line options), the arch Makefile is included earlier by the main
Makefile, preventing the arc architecture to set its -O3 compiler
option. Since there might be more use cases for an arch Makefile to
fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and
ARCH_CFLAGS variables that are appended to the respective kbuild
variables. The user still has the final say via the KCPPFLAGS, KAFLAGS
and KCFLAGS variables.
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
