git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Kbuild changes for v3.16-rc1:
- cross-compilation fix so that cc-option is testing the right
compiler
- Fix for make defconfig all
- Using relative paths to the object and source directory where
possible, plus fixes for the fallout of the change
- several cleanups in the Makefiles and scripts
The powerpc fix is from today, because it was only discovered
recently. The rest has been in linux-next for some time"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
powerpc: Avoid circular dependency with zImage.%
kbuild: create include/config directory in scripts/kconfig/Makefile
kbuild: do not create include/linux directory
Makefile: Fix unrecognized cross-compiler command line options
kbuild: do not add "selinux" to subdir- twice
um: Fix for relative objtree when generating x86 headers
kbuild: Use relative path when building in a subdir of the source tree
kbuild: Use relative path when building in the source tree
kbuild: Use relative path for $(objtree)
firmware: Use $(quote) in the Makefile
firmware: Simplify directory creation
kbuild: trivial - fix comment block indent
kbuild: trivial - remove trailing spaces
kbuild: support simultaneous "make %config" and "make all"
kbuild: move extra gcc checks to scripts/Makefile.extrawarn
The directory include/config is used only for
silentoldconfig, localmodconfig, localyesconfig.
There are no generated files under include/linux directory.
On architectures that setup CROSS_COMPILE in their arch/*/Makefile
(arc, blackfin, m68k, mips, parisc, score, sh, tile, unicore32, xtensa),
cc-option and cc-disable-warning may check against the wrong compiler,
causing errors like
cc1: error: unrecognized command line option "-Wno-maybe-uninitialized"
if the host gcc supports a compiler option, while the cross compiler
doesn't support that option.
Move all logic using cc-option or cc-disable-warning below the inclusion
of the arch's Makefile to fix this.
Introduced by
- commit e74fc973b6e531fef1fce8b101ffff05ecfb774c ("Turn off
-Wmaybe-uninitialized when building with -Os"),
- commit 61163efae02040f66a95c8ed17f4407951ba58fa ("kbuild: LLVMLinux:
Add Kbuild support for building kernel with Clang").
As -Wno-maybe-uninitialized requires a quite recent gcc (gcc 4.6.3 on
Ubuntu 12.04 LTS doesn't support it), this only showed up recently (gcc
4.8.2 on Ubuntu 14.04 LTS does support it).
git://git.linuxfoundation.org/llvmlinux/kernel
Pull LLVM patches from Behan Webster:
"Next set of patches to support compiling the kernel with clang.
They've been soaking in linux-next since the last merge window.
More still in the works for the next merge window..."
* tag 'llvmlinux-for-v3.16' of git://git.linuxfoundation.org/llvmlinux/kernel:
arm, unwind, LLVMLinux: Enable clang to be used for unwinding the stack
ARM: LLVMLinux: Change "extern inline" to "static inline" in glue-cache.h
all: LLVMLinux: Change DWARF flag to support gcc and clang
net: netfilter: LLVMLinux: vlais-netfilter
crypto: LLVMLinux: aligned-attribute.patch
Both gcc (well, actually gnu as) and clang support the "-Wa,-gdwarf-2" option
(though clang does not support "-Wa,--gdwarf-2"). Since these flags are equivalent
in meaning, this patch uses the one which is better supported across compilers.
Signed-off-by: Behan Webster <behanw@converseincode.com>
When doing make O=<subdir>, use '..' to refer to the source tree. This
allows for more readable compiler messages, and, more importantly, it
sets the VPATH to '..', so filenames in WARN_ON() etc. will be shorter.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
When not using O=, $(srctree) refers to the same directory as
$(objtree), so we can set it to '.' as well. This makes the default
include path more compact and results in more readable messages from the
compiler. The only case where we need the absolute path is when creating
the 'source' symlink in /lib/modules.
The main Makefile sets its working directory to the object tree and
never changes it again. Therefore, we can use '.' instead of the
absolute path. The only case where we need the absolute path is when
creating the 'build' symlink in /lib/modules.
Kbuild is supposed to support mixed targets. (%config and build targets)
But "make all" did nothing if it was run with configuration targets.
For example,
$ LANG=C make defconfig all
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
SHIPPED scripts/kconfig/zconf.tab.c
SHIPPED scripts/kconfig/zconf.lex.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
*** Default configuration is based on 'x86_64_defconfig'
# configuration written to .config
make: Nothing to be done for `all'.
This commits allows "make %config all" and makes sure
mixed targets are built one by one in the given order.
Cc: Michal Marek <mmarek@suse.cz>
CC: Sam Ravnborg <sam@ravnborg.org>
W=... provides extra gcc checks.
Having such code in scripts/Makefile.build results in the same flags
being added to KBUILD_CFLAGS multiple times becuase
scripts/Makefile.build is invoked every time Kbuild descends into
the subdirectories.
Since the top Makefile is already too cluttered, this commit moves
all of extra gcc check stuff to a new file scripts/Makefile.extrawarn,
which is included from the top Makefile.
Pull misc kbuild changes from Michal Marek:
"Here is the non-critical part of kbuild:
- One bogus coccinelle check removed, one check fixed not to suggest
the obsolete PTR_RET macro
- scripts/tags.sh does not index the generated *.mod.c files
- new objdiff tool to list differences between two versions of an
object file
- A fix for scripts/bootgraph.pl"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts/coccinelle: Use PTR_ERR_OR_ZERO
scripts/bootgraph.pl: Add graphic header
scripts: objdiff: detect object code changes between two commits
Coccicheck: Remove memcpy to struct assignment test
scripts/tags.sh: Ignore *.mod.c
Add support to toplevel Makefile for compiling with clang, both for
HOSTCC and CC. Use cc-option to prevent gcc option from breaking clang, and
from clang options from breaking gcc.
Clang 3.4 semantics are the same as gcc semantics for unsupported flags. For
unsupported warnings clang 3.4 returns true but shows a warning and gcc shows
a warning and returns false.
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
Cc: PaX Team <pageexec@freemail.hu>
objdiff is useful when doing large code cleanups. For example, when
removing checkpatch warnings and errors from new drivers in the staging
tree.
objdiff can be used in conjunction with a git rebase to confirm that
each commit made no changes to the resulting object code. It has the
same return values as diff(1).
This was written specifically to support adding the skein and threefish
cryto drivers to the staging tree. I needed a programmatic way to
confirm that commits changing >90% of the lines didn't inadvertently
change the code.
Temporary files (objdump output) are stored in
/path/to/linux/.tmp_objdiff
'make mrproper' will remove this directory.
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Pull kbuild changes from Michal Marek:
- cleanups in the main Makefiles and Documentation/DocBook/Makefile
- make O=... directory is automatically created if needed
- mrproper/distclean removes the old include/linux/version.h to make
life easier when bisecting across the commit that moved the version.h
file
kbuild: docbook: fix the include error when executing "make help"
kbuild: create a build directory automatically for out-of-tree build
kbuild: remove redundant '.*.cmd' pattern from make distclean
kbuild: move "quote" to Kbuild.include to be consistent
kbuild: docbook: use $(obj) and $(src) rather than specific path
kbuild: unconditionally clobber include/linux/version.h on distclean
kbuild: docbook: specify KERNELDOC dependency correctly
kbuild: docbook: include cmd files more simply
kbuild: specify build_docproc as a phony target
Pull devicetree changes from Grant Likely:
"Updates to devicetree core code. This branch contains the following
notable changes:
- add reserved memory binding
- make struct device_node a kobject and remove legacy
/proc/device-tree
- ePAPR conformance fixes
- update in-kernel DTC copy to version v1.4.0
- preparatory changes for dynamic device tree overlays
- minor bug fixes and documentation changes
The most significant change in this branch is the conversion of struct
device_node to be a kobject that is exposed via sysfs and removal of
the old /proc/device-tree code. This simplifies the device tree
handling code and tightens up the lifecycle on device tree nodes.
[updated: added fix for dangling select PROC_DEVICETREE]"
* tag 'dt-for-linus' of git://git.secretlab.ca/git/linux: (29 commits)
dt: Remove dangling "select PROC_DEVICETREE"
of: Add support for ePAPR "stdout-path" property
of: device_node kobject lifecycle fixes
of: only scan for reserved mem when fdt present
powerpc: add support for reserved memory defined by device tree
arm64: add support for reserved memory defined by device tree
of: add missing major vendors
of: add vendor prefix for SMSC
of: remove /proc/device-tree
of/selftest: Add self tests for manipulation of properties
of: Make device nodes kobjects so they show up in sysfs
arm: add support for reserved memory defined by device tree
drivers: of: add support for custom reserved memory drivers
drivers: of: add initialization code for dynamic reserved memory
drivers: of: add initialization code for static reserved memory
of: document bindings for reserved-memory nodes
Revert "of: fix of_update_property()"
kbuild: dtbs_install: new make target
ARM: mvebu: Allows to get the SoC ID even without PCI enabled
of: Allows to use the PCI translator without the PCI core
Kbuild supports saving output files in a separate directory.
But the build directory must be created beforehand. For example,
$ mkdir -p dir/to/store/output/files
$ make O=dir/to/store/output/files defconfig
Creating a build directory automatically would be useful.
'.*.cmd' files are cleaned-up by "make clean".
The same pattern in "make distclean" is unnecessary.
As of v3.7, the UAPI changes relocated headers around such that the
kernel version header lived in a new place.
If a person is bisecting and if you go back to pre-UAPI days,
you will create an include/linux/version.h -- then if you checkout a
post-UAPI kernel, and even run "make distclean" it still won't delete
that old version file. So you get a situation like this:
$ grep -R LINUX_VERSION_CODE include/
include/generated/uapi/linux/version.h:#define LINUX_VERSION_CODE 200192
include/linux/version.h:#define LINUX_VERSION_CODE 132646
The value in that second line is representative of a v2.6.38 version.
And it will be sourced/used, hence leading to strange behaviours, such
as drivers/staging content (which typically hasn't been purged of version
ifdefs) failing to build.
Since it is a subtle mode of failure, lets always clobber the old
file when doing a distclean.
Linux 3.14-rc5
According to Documentation/Changes, make 3.80 is still being supported
for building the kernel, hence make files must not make (unconditional)
use of features introduced only in newer versions. Commit 8779657d29c0
("stackprotector: Introduce CONFIG_CC_STACKPROTECTOR_STRONG") however
introduced an "else ifdef" construct which make 3.80 doesn't understand.
Also correct a warning message still referencing the old config option
name.
Apart from that I question the use of "ifdef" here (but it was used that
way already prior to said commit): ifeq (,y) would seem more to the
point.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
An extra parenthesis typo introduced in 19952a92037e ("stackprotector:
Unify the HAVE_CC_STACKPROTECTOR logic between architectures") is
causing the following error when CONFIG_CC_STACKPROTECTOR_REGULAR is
enabled:
Makefile:608: Cannot use CONFIG_CC_STACKPROTECTOR: -fstack-protector not supported by compiler
Makefile:608: *** missing separator. Stop.
Signed-off-by: Fathi Boudra <fathi.boudra@linaro.org>
Cc: <stable@vger.kernel.org>
Unlike other build products in the Linux kernel, there is no 'make
*install' mechanism to put devicetree blobs in a standard place.
This commit adds a new 'dtbs_install' make target which copies all of
the dtbs into the INSTALL_DTBS_PATH directory. INSTALL_DTBS_PATH can be
set before calling make to change the default install directory. If not
set then it defaults to:
$INSTALL_PATH/dtbs/$KERNELRELEASE.
This is done to keep dtbs from different kernel versions separate until
things have settled down. Once the dtbs are stable, and not so strongly
linked to the kernel version, the devicetree files will most likely move
to their own repo. Users will need to upgrade install scripts at that
time.
v7: (reworked by Grant Likely)
- Moved rules from arch/arm/Makefile to arch/arm/boot/dts/Makefile so
that each dtb install could have a separate target and be reported as
part of the make output.
- Fixed dependency problem to ensure $KERNELRELEASE is calculated before
attempting to install
- Removed option to call external script. Copying the files should be
sufficient and a build system can post-process the install directory.
Despite the fact an external script is used for installing the kernel,
I don't think that is a pattern that should be encouraged. I would
rather see buildroot type tools post process the install directory to
rename or move dtb files after installing to a staging directory.
- Plus it is easy to add a hook after the fact without blocking the
rest of this feature.
- Move the helper targets into scripts/Makefile.lib with the rest of the
common dtb rules
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
CONFIG_MODVERSIONS=y results in a .mod.c for every compiled file in the
kernel. Issuing a 'make cscope' on a compiled kernel tree results in
the cscope files containing *.mod.c files.
[prarit@prarit linux]# make cscope
[prarit@prarit linux]# cat cscope.files | grep mod.c | wc -l
4807
These files are not useful for cscope and should be ignored. For example,
# line filename / context / line
1 105 arch/x86/kvm/kvm-intel.mod.c <<GLOBAL>>
{ 0x618911fc, __VMLINUX_SYMBOL_STR(numa_node) },
2 508 drivers/block/mtip32xx/mtip32xx.h <<GLOBAL>>
int numa_node;
3 55 drivers/block/mtip32xx/mtip32xx.mod.c <<GLOBAL>>
4 37 drivers/cpufreq/acpi-cpufreq.mod.c <<GLOBAL>>
<snip>
Add an export to RCS_FIND_IGNORE so it can be used in scripts/tags.sh
and add explicitly ignore *.mod.c files.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Kirill Tkhai <tkhai@yandex.ru>
Cc: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Pull __TIME__/__DATE__ removal from Michal Marek:
"This series by Josh finishes the removal of __DATE__ and __TIME__ from
the kernel. The last patch adds -Werror=date-time to KBUILD_CFLAGS to
stop these from reappearing.
Part of the series went through Greg's trees during this merge window,
which is why this pull request is not based on v3.13-rc1"
* 'drop-time' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Makefile: Build with -Werror=date-time if the compiler supports it
x86: math-emu: Drop already-disabled print of build date
net: wireless: brcm80211: Drop debug version with build date/time
mtd: denali: Drop print of build date/time
- fix make -s detection with make-4.0
- fix for scripts/setlocalversion when the kernel repository is a
submodule
- do not hardcode ';' in macros that expand to assembler code, as some
architectures' assemblers use a different character for newline
- Fix passing --gdwarf-2 to the assembler
frv: Remove redundant debugging info flag
mn10300: Remove redundant debugging info flag
kbuild: Fix debugging info generation for .S files
arch: use ASM_NL instead of ';' for assembler new line character in the macro
kbuild: Fix silent builds with make-4
Fix detectition of kernel git repository in setlocalversion script [take #2]
