Gaah. Delayed. But all the better for it!
Rebuilding a previously built tree while using make's -j option from
time to time results in the version.h check running at the same time as
the updating of .kernelrelease, resulting in UTS_RELEASE remaining an
empty string (and as a side effect causing the entire kernel to be
rebuilt).
Signed-Off-By: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Commit 296e0855b0f9a4ec9be17106ac541745a55b2ce1:
"kbuild: fix make -jN with multiple targets with O=..."
causes a ~95% increase in build time for the kernel. Before: 4m21s
after: 8m1.403s. Can we revert this until another approach is found?
.kernelrelease was saved in same directory as kernel source also
with make O=...
Make sure we kick in the normal logic to shift to the output directory
when we build .kernelrelease after executing *config.
Currently the CPU subtype options are cluttering up arch/sh/Kconfig somewhat.
Given that, this moves all of that in to its own arch/sh/mm/Kconfig. Things
like cache configuration are also moved to this new location.
This also adds support for strict CPU tuning on newer cores, which requires
the addition of as-option.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The command 'make all modules_install install' would fail
in a virgin tree - pointing at a non-existing directory under
/lib/modules/xxx
KERNELRELEASE is part of MODLIB and we need to create .kernelrelease
before we can properly evaluate KERNELRELEASE,
Changing MODLIB to the recursively expanded flavor let it pick up
the correct KERNELRELEASE value.
Reported by: "Hemmann, Volker Armin" <volker.armin.hemmann@tu-clausthal.de>
To enable 'make kernelrelease' earlier now create .kernelrelease when
one of the *config targets are used.
Also introduce KERNELVERSION - only user is kconfig.
KERNELVERSION was needed to display kernel version in menuconfig -
KERNELRELEASE is not valid until configuration has completed.
kconfig files modified to use KERNELVERSION.
Bug reported by: Rene Rebe <rene@exactcode.de>
The way multiple targets was handled with make O=...
broke because for each high-level target make spawned
a parallel make resulting in a broken build.
Reported by Keith Owens <kaos@ocs.com.au>
This makes ARCH=powerpc the default on 32-bit powerpc machines,
where uname -m returns ppc, as well as on 64-bit powerpc machines.
Most people who would be likely to build their own kernels on
32-bit powerpc machines would be using powermacs or CHRP machines,
both of which are supported with ARCH=powerpc now. Embedded ppc
developers whose ports haven't been moved over to arch/powerpc
yet will have to explicitly set ARCH=ppc now.
Fix up some trivial conflicts in {i386|ia64}/Makefile
