path: root/Makefile
2010-05-30Linux 2.6.35-rc1v2.6.35-rc1Linus Torvalds
.. and thus endeth the merge window.
2010-05-16Linus 2.6.34v2.6.34Linus Torvalds
2010-05-09Linux 2.6.34-rc7v2.6.34-rc7Linus Torvalds
2010-04-29Linux 2.6.34-rc6v2.6.34-rc6Linus Torvalds
2010-04-19Linux 2.6.34-rc5v2.6.34-rc5Linus Torvalds
2010-04-12Linux 2.6.34-rc4v2.6.34-rc4Linus Torvalds
2010-03-30Linux 2.6.34-rc3v2.6.34-rc3Linus Torvalds
2010-03-19Linux 2.6.34-rc2v2.6.34-rc2Linus Torvalds
2010-03-08Linux 2.6.34-rc1v2.6.34-rc1Linus Torvalds
2010-02-24Linux 2.6.33v2.6.33Linus Torvalds
2010-02-12Linux 2.6.33-rc8v2.6.33-rc8Linus Torvalds
2010-02-06Linux 2.6.33-rc7v2.6.33-rc7Linus Torvalds
2010-01-29Linux 2.6.33-rc6v2.6.33-rc6Linus Torvalds
2010-01-21Linux 2.6.33-rc5v2.6.33-rc5Linus Torvalds
2010-01-13Makefile: do not override LC_CTYPEMichal Marek
Setting LC_CTYPE=C breaks localized messages in some setups. With only LC_COLLATE=C and LC_NUMERIC=C, we get almost all we need, except for not so defined character classes and tolower()/toupper(). The former is not a big issue, because we can assume that e.g. [:alpha:] will always include a-zA-Z and we only ever process ASCII input. The latter seems only affect arch/sh/tools/gen-mach-types, which we can handle separately. So after this patch the meaning of ranges like [a-z], the behavior of sort and join, etc. should be the same everywhere and at the same time gcc should be able to print localized waring and error messages. LC_NUMERIC=C might not be necessary, but setting it doesn't hurt. Reported-by: Simon Horman <horms@verge.net.au> Reported-by: Sergei Trofimovich <slyfox@inbox.ru> Acked-by: H. Peter Anvin <hpa@zytor.com> Tested-by: Simon Horman <horms@verge.net.au> Tested-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-01-12Linux 2.6.33-rc4v2.6.33-rc4Linus Torvalds
2010-01-05Linux 2.6.33-rc3v2.6.33-rc3Linus Torvalds
2009-12-24Linux 2.6.33-rc2v2.6.33-rc2Linus Torvalds
2009-12-19Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system Makefile: Unexport LC_ALL instead of clearing it x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk x86: Reenable TSC sync check at boot, even with NONSTOP_TSC x86: Don't use POSIX character classes in gen-insn-attr-x86.awk Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA x86: Fix checking of SRAT when node 0 ram is not from 0 x86, cpuid: Add "volatile" to asm in native_cpuid() x86, msr: msrs_alloc/free for CONFIG_SMP=n x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space x86: Add IA32_TSC_AUX MSR and use it x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers initramfs: add missing decompressor error check bzip2: Add missing checks for malloc returning NULL bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
2009-12-17Linux 2.6.33-rc1v2.6.33-rc1Linus Torvalds
2009-12-17Makefile: Unexport LC_ALL instead of clearing itH. Peter Anvin
Apparently not all versions of glibc and utilities treat an empty LC_ALL as nonexistent, causing error messages to be garbled. Instead, explicitly unexport it from the environment. Reported-and-tested-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> LKML-Reference: <4B2AC394.4030108@redhat.com> Cc: Michal Marek <mmarek@sues.cz> Cc: Roland Dreier <rdreier@cisco.com> Cc: Sam Ravnborg <sam@ravnborg.org>
2009-12-17Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to CH. Peter Anvin
There are a number of common Unix constructs like character ranges in grep/sed/awk which don't work as expected with LC_COLLATE set to other than C. Similarly, set LC_CTYPE and LC_NUMERIC to C to avoid other nasty surprises. In order to make sure these actually take effect we also have to clear LC_ALL. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Michal Marek <mmarek@sues.cz> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Roland Dreier <rdreier@cisco.com> Cc: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <4B2A1761.4070904@suse.cz>
2009-12-12kbuild: fix make clean after mismergeMichal Marek
Fix typo / thinko in commit bc081dd. Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: generate modules.builtinMichal Marek
To make it easier for module-init-tools and scripts like mkinitrd to distinguish builtin and missing modules, install a modules.builtin file listing all builtin modules. This is done by generating an additional config file (tristate.conf) with tristate options set to uppercase 'Y' or 'M'. If we source that config file, the builtin modules appear in obj-Y. Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: create include/generated in silentoldconfigMichal Marek
The toplevel Makefile creates the directory if it runs silentoldconfig automatically, but if run manually, it fails: $ make mrproper $ make defconfig && make silentoldconfig *** Default configuration is based on 'x86_64_defconfig' # # configuration written to .config # scripts/kconfig/conf -s arch/x86/Kconfig *** Error during update of the kernel configuration. ... Move the mkdir command to the silentoldconfig target to make it work. Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12Kbuild: clean up markerWenji Huang
Drop Module.markers from cleaning list since marker is removed. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move autoconf.h to include/generatedSam Ravnborg
2009-12-12kbuild: drop include/asmSam Ravnborg
We no longer use this directory for generated files and all architectures has moved their header files so no symlink tricks are needed either. Drop the symlink and drop the ARCH check. If we really need to check that the SRCARCH has not changed when we build a kernel we can add this check back - but then we will find a more convenient way to store the info. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: do not check for include/asm-$ARCHSam Ravnborg
No architectures uses include/asm-$ARCH now. So drop check for location of include files Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: drop include2/ used for O=... buildsSam Ravnborg
There is no longer any use of the include2/ directory. The generated files has moved to include/generated. Drop all references to said directory. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move asm-offsets.h to include/generatedSam Ravnborg
The simplest method was to add an extra asm-offsets.h file in arch/$ARCH/include/asm that references the generated file. We can now migrate the architectures one-by-one to reference the generated file direct - and when done we can delete the temporary arch/$ARCH/include/asm/asm-offsets.h file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move bounds.h to include/generatedSam Ravnborg
2009-12-12kbuild: search arch/$ARCH/include before include/Sam Ravnborg
The namespace used in arch/$ARCH/include is different from what is used in include/ except for the include/asm directory. This patch gives the arch/$ARCH/include/asm directory priority over include/asm. When we add asm-offsets.h to arch/$ARCH/include/asm/ this patch makes sure we pick up the arch specific version and not the one we have in include/asm. The situation with an asm-offsets.h file located in both include/asm _and_ arch/$ARCH/include/asm will happen when we move more files over to include/generated. This happens because in some cases it is not practical to rename all users so we simply add a file in arch/$ARCH/include/asm that includes the generated version. This is the solution we use for asm-offsets.h as an example. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-05Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (40 commits) tracing: Separate raw syscall from syscall tracer ring-buffer-benchmark: Add parameters to set produce/consumer priorities tracing, function tracer: Clean up strstrip() usage ring-buffer benchmark: Run producer/consumer threads at nice +19 tracing: Remove the stale include/trace/power.h tracing: Only print objcopy version warning once from recordmcount tracing: Prevent build warning: 'ftrace_graph_buf' defined but not used ring-buffer: Move access to commit_page up into function used tracing: do not disable interrupts for trace_clock_local ring-buffer: Add multiple iterations between benchmark timestamps kprobes: Sanitize struct kretprobe_instance allocations tracing: Fix to use __always_unused attribute compiler: Introduce __always_unused tracing: Exit with error if a weak function is used in recordmcount.pl tracing: Move conditional into update_funcs() in recordmcount.pl tracing: Add regex for weak functions in recordmcount.pl tracing: Move mcount section search to front of loop in recordmcount.pl tracing: Fix objcopy revision check in recordmcount.pl tracing: Check absolute path of input file in recordmcount.pl tracing: Correct the check for number of arguments in recordmcount.pl ...
2009-12-02Linux 2.6.32v2.6.32Linus Torvalds
2009-11-19Linux 2.6.32-rc8v2.6.32-rc8Linus Torvalds
2009-11-17Merge branch 'hostprogs-wmissing-prototypes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc * 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc: Makefile: Add -Wmising-prototypes to HOSTCFLAGS oss: Mark loadhex static in hex2hex.c dtc: Mark various internal functions static dtc: Set "noinput" in the lexer to avoid an unused function drm: radeon: Mark several functions static in mkregtable arch/sparc/boot/*.c: Mark various internal functions static arch/powerpc/boot/addRamDisk.c: Mark several internal functions static arch/alpha/boot/tools/objstrip.c: Mark "usage" static Documentation/vm/page-types.c: Declare checked_open static genksyms: Mark is_reserved_word static kconfig: Mark various internal functions static kconfig: Make zconf.y work with current bison
2009-11-17tracing: Only print objcopy version warning once from recordmcountSteven Rostedt
If the user has an older version of objcopy, that can not handle converting local symbols to global and vice versa, then some functions will not be part of the dynamic function tracer. The current code in recordmcount.pl will print a warning in this case. Unfortunately, there exists lots of files that may have this issue with older objcopys and this will cause a warning for every file compiled with this issue. This patch solves this overwhelming output by creating a .tmp_quiet_recordmcount file on the first instance the warning is encountered. The warning will not print if this file exists. The temp file is deleted at the beginning of the compile to ensure that the warning will happen once again on new compiles (because the issue is still present). Reported-by: Andrew Morton <akpm@linux-foundation.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-11-15Makefile: Add -Wmising-prototypes to HOSTCFLAGSJosh Triplett
Now that all host programs use static for all private functions and forward prototypes for all extern functions, add -Wmissing-prototypes to HOSTCFLAGS in the hopes of keeping it that way. All versions of GCC supported by the kernel handle -Wmissing-prototypes. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-12Linux 2.6.32-rc7v2.6.32-rc7Linus Torvalds
2009-11-03Linux 2.6.32-rc6v2.6.32-rc6Linus Torvalds
2009-10-15Linux 2.6.32-rc5v2.6.32-rc5Linus Torvalds
2009-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: revert "save ARCH & CROSS_COMPILE ..." warn about use of uninstalled kernel headers kbuild: mkcompile_h: trivial cleanups kbuild: fix warning when domainname is not available kbuild: Fix size_append issue for bzip2/lzma kernel kbuild,scripts: use non-builtin echo for '-e' kbuild: fix the binrpm-pkg target to work with KBUILD_OUTPUT set
2009-10-11Linux 2.6.32-rc4v2.6.32-rc4Linus Torvalds
2009-10-11kbuild: revert "save ARCH & CROSS_COMPILE ..."Sam Ravnborg
Revert commit 575543347b5baed0ca927cb90ba8807396fe9cc9 It caused following issues: - On architectures where ARCH= setting is used to select between 32 and 64 bit this was no longer possible without "make mrproper" - If ARCH was changed then kbuild refused to run "make mrproper" because ARCH had changed - When CROSS_COMPILE was changed people were asked to run "make mrproper" but kbuild refused to run "make mrproper" because CROSS_COMPILE changed. - Spaces in CROSS_COMPILE was not 'supported' - If an non-existing ARCH= was used kbuild could get stuck Lessons learned: . Despite being simple and straghtforward people uses very different approaches when building the kernel. . CROSS_COMPILE is sometimes used for ccache despite cache being only a CC frontend so one would have expected CC to be used for this purpose. . And obviously this was not tested widely enough. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Pavel Machek <pavel@ucw.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2009-10-04Linux 2.6.32-rc3v2.6.32-rc3Linus Torvalds
I'm skipping -rc2 because the -rc1 Makefile mistakenly said -rc2, so in order to avoid confusion, I'm jumping from -rc1 to -rc3. That way, when 'uname' (or an oops report) says 2.6.32-rc2, there's no confusion about whether people perhaps meant -rc1 or -rc2.
2009-09-27Linux 2.6.32-rc1v2.6.32-rc2v2.6.32-rc1Linus Torvalds
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: set -fconserve-stack option for gcc 4.5Andi Kleen
The upcomming gcc 4.5 has a new -fconserve-stack option that tells the inliner to take stack frame size in account. Set it if the compiler supports it. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
