path: root/Makefile
2008-06-12Linux 2.6.26-rc6v2.6.26-rc6Linus Torvalds
.. and a new name, courtesy of Alan.
2008-06-04Linux 2.6.26-rc5v2.6.26-rc5Linus Torvalds
2008-05-26Linux 2.6.26-rc4v2.6.26-rc4tip-x86-setup-2008-05-31_10.10_SatLinus Torvalds
2008-05-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: Don't clean bounds.h and asm-offsets.h kconfig: incorrect 'len' field initialisation ? kernel-doc: allow unnamed bit-fields kbuild: filter away debug symbols from kernel symbols Remove *.rej pattern from .gitignore MAINTAINERS: document names of new kbuild trees kbuild: disable modpost warnings for linkonce sections kbuild: escape meta characters in regular expression in make TAGS
2008-05-19Don't clean bounds.h and asm-offsets.hJan Blunck
Since 97965478a66fbdf0f4ad5e4ecc4828f0cb548a45 ("mm: Get rid of __ZONE_COUNT") mmzone.h includes bounds.h. Calling make clean after make prepare removes bounds.h again so when building external modules this fails. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> --
2008-05-18Linux 2.6.26-rc3v2.6.26-rc3Linus Torvalds
2008-05-11Linux 2.6.26-rc2v2.6.26-rc2tip-x86-timers-2008-05-12-10-09-40tip-x86-threadinfo-2008-05-12-10-09-30tip-x86-ptemask-2008-05-12-10-09-30tip-x86-pebs-2008-05-12-10-09-30tip-x86-pat-2008-05-12-10-09-30tip-x86-numa-2008-05-12-10-09-30tip-x86-nmi-2008-05-12-10-09-30tip-x86-memtest-2008-05-12-10-09-30tip-x86-mce-2008-05-12-10-09-30tip-x86-kconfig-2008-05-12-10-09-30tip-x86-irq-2008-05-12-10-09-30tip-x86-intel-2008-05-12-10-09-30tip-x86-gart-2008-05-12-10-09-30tip-x86-defconfig-2008-05-12-10-09-30tip-x86-cpa-2008-05-12-10-09-30tip-x86-cleanups-2008-05-12-10-09-30tip-x86-build-2008-05-12-10-09-30Linus Torvalds
2008-05-11kbuild: escape meta characters in regular expression in make TAGSMasatake YAMATO
Alexey Dobriyan <adobriyan@gmail.com> introduced a code adds menuconfig SOMETHING in Kconfig to tags output when you did "make tags". See http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=80ff26241623875636674a31c0540a78c0fb5433 "make tags" may work fine with his code. However make TAGS doesn't work well because etags command requires backslashes to escape meta characters like `(', `)' and `|'. Here is a patch. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-03Linux 2.6.26-rc1v2.6.26-rc1Linus Torvalds
2008-05-01kbuild: fix vmlinux.o linkSam Ravnborg
We always linked vmliux.o. Remove init/built-in.o dependency so we avoid this Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kbuild: fix help output to show correct archAndres Salomon
Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kbuild: show defconfig subdirs in make helpSegher Boessenkool
PowerPC will start moving board defconfigs into subarch-specific subdirs soon. "make help" currently does not look in subdirs to find the defconfigs to show. This is partially a good thing, since there are way too many defconfigs for one list. This patch makes the main "make help" display something like help-40x - Show 40x-specific targets help-44x - Show 44x-specific targets help-boards - Show all of the above and wires up stuff so those new help-* commands actually work. [sam: fixed it up to display x86 defconfigs too] Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: fix depmod commentUwe Kleine-König
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: trivial@kernel.org Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25Add option to enable -Wframe-larger-than= on gcc 4.4Andi Kleen
Add option to enable -Wframe-larger-than= on gcc 4.4 gcc mainline (upcoming 4.4) added a new -Wframe-larger-than=... option to warn at build time about too large stack frames. Add a config option to enable this warning, since this very useful for the kernel. I choose (somewhat arbitarily) 2048 as default warning threshold for 64bit and 1024 as default for 32bit architectures. With some research and fixing all the code for smaller values these defaults should be probably lowered. With the default allyesconfigs have some new warnings, but I think that is all code that should be just fixed. At some point (when gcc 4.4 is released and widely used) this should obsolete make checkstack Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: add kconfig symbols to tags outputAlexey Dobriyan
Steps to reproduce: vi -t NETFILTER Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-24Remove -numa from EXTRAVERSIONSebastian Siewior
This snuck in through 919ee677b656c52c5f86d3d916786891220d5452 ("[SPARC64]: Add NUMA support") Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-23[SPARC64]: Add NUMA support.David S. Miller
Currently there is only code to parse NUMA attributes on sun4v/niagara systems, but later on we will add such parsing for older systems. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21fix typo "is" -> "if" in MakefileUwe Kleine-König
It should be "if" but is written as "is".. Signed-off-by: Uwe Kleine-Koenig <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-04-16Linux 2.6.25v2.6.25Linus Torvalds
2008-04-11Linux 2.6.25-rc9v2.6.25-rc9Linus Torvalds
2008-04-01Linux 2.6.25-rc8v2.6.25-rc8Linus Torvalds
2008-03-25Linux 2.6.25-rc7v2.6.25-rc7Linus Torvalds
2008-03-23kbuild: soften modpost checks when doing cross buildsSam Ravnborg
The module alias support in the kernel have a consistency check where it is checked that the size of a structure in the kernel and on the build host are the same. For cross builds this check does not make sense so detect when we do cross builds and silently skip the check in these situations. This fixes a build bug for a wireless driver when cross building for arm. Acked-by: Michael Buesch <mb@bu3sch.de> Tested-by: Gordon Farquharson <gordonfarquharson@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: stable@kernel.org
2008-03-16Linux 2.6.25-rc6v2.6.25-rc6Linus Torvalds
2008-03-09Linux 2.6.25-rc5v2.6.25-rc5Linus Torvalds
2008-03-04Linux 2.6.25-rc4v2.6.25-rc4Linus Torvalds
2008-02-24Linux 2.6.25-rc3v2.6.25-rc3Linus Torvalds
2008-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: explain why DEBUG_SECTION_MISMATCH is UNDEFINED kbuild: fix building vmlinux.o kbuild: allow -fstack-protector to take effect kconfig: fix select in combination with default
2008-02-15Linux 2.6.25-rc2v2.6.25-rc2Linus Torvalds
2008-02-14kbuild: fix building vmlinux.oSam Ravnborg
Ingo Molnar wrote: > > i've got a build log from a weird build error below: > > LD init/built-in.o > distcc[12023] ERROR: compile (null) on localhost failed > make: *** [vmlinux.o] Error 1 > make: *** Waiting for unfinished jobs.... > LD .tmp_vmlinux1 > Building vmlinux.o were moved up in the dependency chain so we started to build it before the kallsym stuff. This was done to let modpost report section mismatch bugs even when the final link failed. Originally I had expected the dependency of $(kallsyms.o) to cover this but it turns out that we need to be even more explicit. Fix this by adding a conditional dependency on firat target used in the kallsyms serie of builds. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com>
2008-02-14kbuild: allow -fstack-protector to take effectSam Ravnborg
Arjan van de Ven <arjan@infradead.org> wrote: === I just read the excellent LWN writeup of the vmsplice security thing, and that got me wondering why this attack wasn't stopped by the CONFIG_CC_STACKPROTECTOR option... because it plain should have been... Some analysis later.. it turns out that the following line in the top level Makefile, added by you in October 2007, entirely disables CONFIG_CC_STACKPROTECTOR ;( With this line removed the exploit will be nicely stopped. CFLAGS += $(call cc-option, -fno-stack-protector) Now I realize that certain distros have patched gcc to compensate for their lack of distro wide CFLAGS, and it's great to work around that... but would there be a way to NOT disable this for CONFIG_CC_STACKPROTECTOR please? It would have made this exploit not possible for those kernels that enable this feature (and that includes distros like Fedora) === Move the assignment to KBUILD_CFLAGS up before including the arch specific Makefile so arch makefiles may override the setting. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: stable@kernel.org
2008-02-10Linux 2.6.25-rc1v2.6.25-rc1Linus Torvalds
.. and I really need to call it something else. Maybe it is time to bring back the weasel series, since weasels always make me feel good about a kernel.
2008-02-03Typoes: "whith" -> "with"Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-28kbuild: link vmlinux.o before kallsyms passesSam Ravnborg
link vmlinux.o so we may report section mismatch bugs before we start with the real link - that may error out. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: introduce new option to enhance section mismatch analysisSam Ravnborg
Setting the option DEBUG_SECTION_MISMATCH will report additional section mismatch'es but this should in the end makes it possible to get rid of all of them. See help text in lib/Kconfig.debug for details. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: document 'make prepare' in 'make help'Valdis.Kletnieks@vt.edu
The output of 'make help' covers a lot of options, but doesn't include a listing for 'make prepare'. Here's a one-liner to fix that... Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: ignore cache modifiers for generating the tags filesUwe Kleine-König
With this patch I'm able to find the definition of _xmit_lock defined in include/linux/netdevice.h as follows: struct net_device { ... spinlock_t _xmit_lock ____cacheline_aligned_in_smp; } Otherwise this counts as definition of ____cacheline_aligned_in_smp. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28Kbuild: Clarify the rpm-related make packaging targetsRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: implement modules.orderTejun Heo
When multiple built-in modules (especially drivers) provide the same capability, they're prioritized by link order specified by the order listed in Makefile. This implicit ordering is lost for loadable modules. When driver modules are loaded by udev, what comes first in modules.alias file is selected. However, the order in this file is indeterministic (depends on filesystem listing order of installed modules). This causes confusion. The solution is two-parted. This patch updates kbuild such that it generates and installs modules.order which contains the name of modules ordered according to Makefile. The second part is update to depmod such that it generates output files according to this file. Note that both obj-y and obj-m subdirs can contain modules and ordering information between those two are lost from beginning. Currently obj-y subdirs are put before obj-m subdirs. Sam Ravnborg cleaned up Makefile modifications and suggested using awk to remove duplicate lines from modules.order instead of using separate C program. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Bill Nottingham <notting@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jon Masters <jonathan@jonmasters.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: Add missing srctree prefix for includecheck and versioncheckGeert Uytterhoeven
Add missing $(srctree)/ prefix for scripts used by the includecheck and versioncheck make targets Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: document versioncheck in make helpSam Ravnborg
2008-01-28kbuild: add 'includecheck' help textRandy Dunlap
Add 'includecheck' to the Static analyzers help list. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28sh: Fix up uname -m matching for native sh64.Paul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-24Linux 2.6.24v2.6.24Linus Torvalds
2008-01-21Makefile: Change typoed 'behavour' to 'behaviour'Linus Nilsson
Change two occurances of "behavour" to "behaviour". Signed-off-by: Linus Nilsson <lajnold@acc.umu.se> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-15Linux 2.6.24-rc8v2.6.24-rc8Linus Torvalds
2008-01-06Linux 2.6.24-rc7v2.6.24-rc7Linus Torvalds
2007-12-20Linux 2.6.24-rc6v2.6.24-rc6Linus Torvalds
2007-12-10Linux 2.6.24-rc5v2.6.24-rc5Linus Torvalds
2007-12-09kbuild: fix building with O=.. optionsSam Ravnborg
The check introduced in commit: 4f1127e204377cbd2a56d112d323466f668e8334 "kbuild: fix infinite make recursion" caused certain external modules not to build and also caused 'make targz-pkg' to fail. This is a minimal fix so we revert to previous behaviour - but we do not overwrite the Makefile in the top-level directory. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Tested-by: Jay Cliburn <jacliburn@bellsouth.net> Cc: Jay Cliburn <jacliburn@bellsouth.net>
