[ Upstream commit c9c6837d39311b0cc14cdbe7c18e815ab44aefb1 ]
gcc-6 started warning by default about variables that are not
used anywhere and that are marked 'const', generating many
false positives in an allmodconfig build, e.g.:
arch/arm/mach-davinci/board-da830-evm.c:282:20: warning: 'da830_evm_emif25_pins' defined but not used [-Wunused-const-variable=]
arch/arm/plat-omap/dmtimer.c:958:34: warning: 'omap_timer_match' defined but not used [-Wunused-const-variable=]
drivers/bluetooth/hci_bcm.c:625:39: warning: 'acpi_bcm_default_gpios' defined but not used [-Wunused-const-variable=]
drivers/char/hw_random/omap-rng.c:92:18: warning: 'reg_map_omap4' defined but not used [-Wunused-const-variable=]
drivers/devfreq/exynos/exynos5_bus.c:381:32: warning: 'exynos5_busfreq_int_pm' defined but not used [-Wunused-const-variable=]
drivers/dma/mv_xor.c:1139:34: warning: 'mv_xor_dt_ids' defined but not used [-Wunused-const-variable=]
This is similar to the existing -Wunused-but-set-variable warning
that was added in an earlier release and that we disable by default
now and only enable when W=1 is set, so it makes sense to do
the same here. Once we have eliminated the majority of the
warnings for both, we can put them back into the default list.
We probably want this in backport kernels as well, to allow building
them with gcc-6 without introducing extra warnings.
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Lee Jones <lee.jones@linaro.org>
Cc: stable@vger.kernel.org
Signed-off-by: Michal Marek <mmarek@suse.com>
[ Upstream commit c87bf431448b404a6ef5fbabd74c0e3e42157a7f ]
Enabling CONFIG_GCOV_PROFILE_ALL produces us a lot of warnings like
lib/lz4/lz4hc_compress.c: In function 'lz4_compresshcctx':
lib/lz4/lz4hc_compress.c:514:1: warning: the frame size of 1504 bytes is larger than 1024 bytes [-Wframe-larger-than=]
After some investigation, I found that this behavior started with gcc-4.9,
and opened https://gcc.gnu.org/bugzilla/show_bug.cgi?id=69702.
A suggested workaround for it is to use the -fno-tree-loop-im
flag that turns off one of the optimization stages in gcc, so the
code runs a little slower but does not use excessive amounts
of stack.
We could make this conditional on the gcc version, but I could not
find an easy way to do this in Kbuild and the benefit would be
fairly small, given that most of the gcc version in production are
affected now.
I'm marking this for 'stable' backports because it addresses a bug
with code generation in gcc that exists in all kernel versions
with the affected gcc releases.
Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
commit 61754c18752ffb78145671e94f053fb202fff041 upstream.
Since commit a1c48bb1 (Makefile: Fix unrecognized cross-compiler command
line options), the arch Makefile is included earlier by the main
Makefile, preventing the arc architecture to set its -O3 compiler
option. Since there might be more use cases for an arch Makefile to
fine-tune the options, add support for ARCH_CPPFLAGS, ARCH_AFLAGS and
ARCH_CFLAGS variables that are appended to the respective kbuild
variables. The user still has the final say via the KCPPFLAGS, KAFLAGS
and KCFLAGS variables.
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Here is the first round of kbuild changes for v4.1-rc1:
- kallsyms fix for ARM and cleanup
- make dep(end) removed (developers have no sense of nostalgia these
days...)
- include Makefiles by relative path
- stop useless rebuilds of asm-offsets.h and bounds.h"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: kallsyms: drop special handling of pre-3.0 GCC symbols
Kbuild: kallsyms: ignore veneers emitted by the ARM linker
kbuild: ia64: use $(src)/Makefile.gate rather than particular path
kbuild: include $(src)/Makefile rather than $(obj)/Makefile
kbuild: use relative path more to include Makefile
kbuild: use relative path to include Makefile
kbuild: do not add $(bounds-file) and $(offsets-file) to targets
kbuild: remove warning about "make depend"
kbuild: Don't reset timestamps in include/generated if not needed
Pull core locking changes from Ingo Molnar:
"Main changes:
- jump label asm preparatory work for PowerPC (Anton Blanchard)
- rwsem optimizations and cleanups (Davidlohr Bueso)
- mutex optimizations and cleanups (Jason Low)
- futex fix (Oleg Nesterov)
- remove broken atomicity checks from {READ,WRITE}_ONCE() (Peter
Zijlstra)"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
powerpc, jump_label: Include linux/jump_label.h to get HAVE_JUMP_LABEL define
jump_label: Allow jump labels to be used in assembly
jump_label: Allow asm/jump_label.h to be included in assembly
locking/mutex: Further simplify mutex_spin_on_owner()
locking: Remove atomicy checks from {READ,WRITE}_ONCE
locking/rtmutex: Rename argument in the rt_mutex_adjust_prio_chain() documentation as well
locking/rwsem: Fix lock optimistic spinning when owner is not running
locking: Remove ACCESS_ONCE() usage
locking/rwsem: Check for active lock before bailing on spinning
locking/rwsem: Avoid deceiving lock spinners
locking/rwsem: Set lock ownership ASAP
locking/rwsem: Document barrier need when waking tasks
locking/futex: Check PF_KTHREAD rather than !p->mm to filter out kthreads
locking/mutex: Refactor mutex_spin_on_owner()
locking/mutex: In mutex_spin_on_owner(), return true when owner changes
To use jump labels in assembly we need the HAVE_JUMP_LABEL
define, so we select a fallback version if the toolchain does
not support them.
Modify linux/jump_label.h so it can be included by assembly
files. We also need to add -DCC_HAVE_ASM_GOTO to KBUILD_AFLAGS.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: benh@kernel.crashing.org
Cc: catalin.marinas@arm.com
Cc: davem@davemloft.net
Cc: heiko.carstens@de.ibm.com
Cc: jbaron@akamai.com
Cc: linux@arm.linux.org.uk
Cc: linuxppc-dev@lists.ozlabs.org
Cc: liuj97@gmail.com
Cc: mgorman@suse.de
Cc: mmarek@suse.cz
Cc: mpe@ellerman.id.au
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: rostedt@goodmis.org
Cc: schwidefsky@de.ibm.com
Cc: will.deacon@arm.com
Link: http://lkml.kernel.org/r/1428551492-21977-2-git-send-email-anton@samba.org
Prior to this commit, it was impossible to use relative path to
include Makefiles from the top level Makefile because the option
"--include-dir=$(srctree)" becomes effective when Make enters into
sub Makefiles.
To use relative path in any places, this commit moves the option
above the "sub-make" target.
