path: root/Makefile
2010-08-20Linux 2.6.32.20v2.6.32.20Greg Kroah-Hartman
2010-08-13Linux 2.6.32.19v2.6.32.19Greg Kroah-Hartman
2010-08-10Linux 2.6.32.18v2.6.32.18Greg Kroah-Hartman
2010-08-02Linux 2.6.32.17v2.6.32.17Greg Kroah-Hartman
2010-07-05Linux 2.6.32.16v2.6.32.16Greg Kroah-Hartman
2010-06-01Linux 2.6.32.15v2.6.32.15Greg Kroah-Hartman
2010-05-26Linux 2.6.32.14v2.6.32.14Greg Kroah-Hartman
2010-05-12Linux 2.6.32.13v2.6.32.13Greg Kroah-Hartman
2010-04-26Linux 2.6.32.12v2.6.32.12Greg Kroah-Hartman
2010-04-01Linux 2.6.32.11v2.6.32.11Greg Kroah-Hartman
2010-03-15Linux 2.6.32.10v2.6.32.10Greg Kroah-Hartman
2010-02-23Linux 2.6.32.9v2.6.32.9Greg Kroah-Hartman
2010-02-09Linux 2.6.32.8v2.6.32.8Greg Kroah-Hartman
2010-01-28Linux 2.6.32.7v2.6.32.7Greg Kroah-Hartman
2010-01-25Linux 2.6.32.6v2.6.32.6Greg Kroah-Hartman
2010-01-22Linux 2.6.32.5v2.6.32.5Greg Kroah-Hartman
2010-01-18Linux 2.6.32.4v2.6.32.4Greg Kroah-Hartman
2010-01-06Linux 2.6.32.3v2.6.32.3Greg Kroah-Hartman
2009-12-18Linux 2.6.32.2v2.6.32.2Greg Kroah-Hartman
2009-12-14Linux 2.6.32.1v2.6.32.1Greg Kroah-Hartman
2009-12-02Linux 2.6.32v2.6.32Linus Torvalds
2009-11-19Linux 2.6.32-rc8v2.6.32-rc8Linus Torvalds
2009-11-17Merge branch 'hostprogs-wmissing-prototypes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc * 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc: Makefile: Add -Wmising-prototypes to HOSTCFLAGS oss: Mark loadhex static in hex2hex.c dtc: Mark various internal functions static dtc: Set "noinput" in the lexer to avoid an unused function drm: radeon: Mark several functions static in mkregtable arch/sparc/boot/*.c: Mark various internal functions static arch/powerpc/boot/addRamDisk.c: Mark several internal functions static arch/alpha/boot/tools/objstrip.c: Mark "usage" static Documentation/vm/page-types.c: Declare checked_open static genksyms: Mark is_reserved_word static kconfig: Mark various internal functions static kconfig: Make zconf.y work with current bison
2009-11-15Makefile: Add -Wmising-prototypes to HOSTCFLAGSJosh Triplett
Now that all host programs use static for all private functions and forward prototypes for all extern functions, add -Wmissing-prototypes to HOSTCFLAGS in the hopes of keeping it that way. All versions of GCC supported by the kernel handle -Wmissing-prototypes. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-12Linux 2.6.32-rc7v2.6.32-rc7Linus Torvalds
2009-11-03Linux 2.6.32-rc6v2.6.32-rc6Linus Torvalds
2009-10-15Linux 2.6.32-rc5v2.6.32-rc5Linus Torvalds
2009-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: revert "save ARCH & CROSS_COMPILE ..." warn about use of uninstalled kernel headers kbuild: mkcompile_h: trivial cleanups kbuild: fix warning when domainname is not available kbuild: Fix size_append issue for bzip2/lzma kernel kbuild,scripts: use non-builtin echo for '-e' kbuild: fix the binrpm-pkg target to work with KBUILD_OUTPUT set
2009-10-11Linux 2.6.32-rc4v2.6.32-rc4Linus Torvalds
2009-10-11kbuild: revert "save ARCH & CROSS_COMPILE ..."Sam Ravnborg
Revert commit 575543347b5baed0ca927cb90ba8807396fe9cc9 It caused following issues: - On architectures where ARCH= setting is used to select between 32 and 64 bit this was no longer possible without "make mrproper" - If ARCH was changed then kbuild refused to run "make mrproper" because ARCH had changed - When CROSS_COMPILE was changed people were asked to run "make mrproper" but kbuild refused to run "make mrproper" because CROSS_COMPILE changed. - Spaces in CROSS_COMPILE was not 'supported' - If an non-existing ARCH= was used kbuild could get stuck Lessons learned: . Despite being simple and straghtforward people uses very different approaches when building the kernel. . CROSS_COMPILE is sometimes used for ccache despite cache being only a CC frontend so one would have expected CC to be used for this purpose. . And obviously this was not tested widely enough. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Pavel Machek <pavel@ucw.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2009-10-04Linux 2.6.32-rc3v2.6.32-rc3Linus Torvalds
I'm skipping -rc2 because the -rc1 Makefile mistakenly said -rc2, so in order to avoid confusion, I'm jumping from -rc1 to -rc3. That way, when 'uname' (or an oops report) says 2.6.32-rc2, there's no confusion about whether people perhaps meant -rc1 or -rc2.
2009-09-27Linux 2.6.32-rc1v2.6.32-rc2v2.6.32-rc1Linus Torvalds
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: set -fconserve-stack option for gcc 4.5Andi Kleen
The upcomming gcc 4.5 has a new -fconserve-stack option that tells the inliner to take stack frame size in account. Set it if the compiler supports it. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: Check if linker supports the -X optionAndi Kleen
The new alternative `gold' linker in recent binutils doesn't support the -X option. This breaks allyesconfig builds that have CONFIG_STRIP_ASM_SYMS enabled. Check if the linker really supports the option using ld-option. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: rename ld-option to cc-ldoptionSam Ravnborg
ld-option is misnamed as it test options to gcc, not to ld. Renamed it to reflect this. Cc: Andi Kleen <andi@firstfloor.org> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-20kbuild: save ARCH & CROSS_COMPILE when building a kernelSam Ravnborg
When building a kernel for a different architecture kbuild requires the user always to specify ARCH and CROSS_COMPILE on the command-line. We use the asm symlink to detect if user forgets to specify the correct ARCH value - but that symlink is about to die. And we do now want to loose this check. This patch save the settings of ARCH and CROSS_COMPILE in two files named: include/generated/kernel.arch include/generated/kernel.cross The settings are saved during "make *config" time and always read. If user try to change the settings we error out. This works both for plain builds and for O=... builds. So now you can do: $ mkdir sparc64 $ make O=sparc64 ARCH=sparc64 CROSS_COMPILE=sparc64-linux- defconfig $ cd sparc64 $ make Notice that you no longer need to tell kbuild the settings of ARCH and CROSS_COMPILE when you type make in the output directory. Likewise for plain builds where you do not use O=... Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roland McGrath <roland@redhat.com>
2009-09-20kbuild: use INSTALLKERNEL to select customized installkernel scriptSam Ravnborg
Replace the use of CROSS_COMPILE to select a customized installkernel script with the possibility to set INSTALLKERNEL to select a custom installkernel script when running make: make INSTALLKERNEL=arm-installkernel install With this patch we are now more consistent across different architectures - they did not all support use of CROSS_COMPILE. The use of CROSS_COMPILE was a hack as this really belongs to gcc/binutils and the installkernel script does not change just because we change toolchain. The use of CROSS_COMPILE caused troubles with an upcoming patch that saves CROSS_COMPILE when a kernel is built - it would no longer be installable. [Thanks to Peter Z. for this hint] This patch undos what Ian did in commit: 0f8e2d62fa04441cd12c08ce521e84e5bd3f8a46 ("use ${CROSS_COMPILE}installkernel in arch/*/boot/install.sh") The patch has been lightly tested on x86 only - but all changes looks obvious. Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin] Acked-by: Russell King <linux@arm.linux.org.uk> [arm] Acked-by: Paul Mundt <lethal@linux-sh.org> [sh] Acked-by: "H. Peter Anvin" <hpa@zytor.com> [x86] Cc: Ian Campbell <icampbell@arcom.com> Cc: Tony Luck <tony.luck@intel.com> [ia64] Cc: Fenghua Yu <fenghua.yu@intel.com> [ia64] Cc: Hirokazu Takata <takata@linux-m32r.org> [m32r] Cc: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Cc: Kyle McMartin <kyle@mcmartin.ca> [parisc] Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> [powerpc] Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Cc: Thomas Gleixner <tglx@linutronix.de> [x86] Cc: Ingo Molnar <mingo@redhat.com> [x86] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-09Linux 2.6.31v2.6.31Linus Torvalds
2009-09-05Linux 2.6.31-rc9v2.6.31-rc9Linus Torvalds
2009-08-27Linux 2.6.31-rc8v2.6.31-rc8Linus Torvalds
2009-08-21Linux 2.6.31-rc7v2.6.31-rc7Linus Torvalds
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-13Linux 2.6.31-rc6v2.6.31-rc6Linus Torvalds
2009-07-31Linux 2.6.31-rc5v2.6.31-rc5Linus Torvalds
2009-07-22Linux 2.6.31-rc4v2.6.31-rc4Linus Torvalds
2009-07-16Add '-fno-delete-null-pointer-checks' to gcc CFLAGSEugene Teo
Turning on this flag could prevent the compiler from optimising away some "useless" checks for null pointers. Such bugs can sometimes become exploitable at compile time because of the -O2 optimisation. See http://gcc.gnu.org/onlinedocs/gcc-4.1.2/gcc/Optimize-Options.html An example that clearly shows this 'problem' is commit 6bf67672. static void __devexit agnx_pci_remove(struct pci_dev *pdev) { struct ieee80211_hw *dev = pci_get_drvdata(pdev); - struct agnx_priv *priv = dev->priv; + struct agnx_priv *priv; AGNX_TRACE; if (!dev) return; + priv = dev->priv; By reverting this patch, and compile it with and without -fno-delete-null-pointer-checks flag, we can see that the check for dev is compiled away. call printk # - testq %r12, %r12 # dev - je .L94 #, movq %r12, %rdi # dev, Clearly the 'fix' is to stop using dev before it is tested, but building with -fno-delete-null-pointer-checks flag at least makes it harder to abuse. Signed-off-by: Eugene Teo <eugeneteo@kernel.sg> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: Wang Cong <amwang@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-13Linux 2.6.31-rc3v2.6.31-rc3Linus Torvalds
2009-07-12Don't use '-fwrapv' compiler option: it's buggy in gcc-4.1.xLinus Torvalds
This causes kernel images that don't run init to completion with certain broken gcc versions. This fixes kernel bugzilla entry: http://bugzilla.kernel.org/show_bug.cgi?id=13012 I suspect the gcc problem is this: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=28230 Fix the problem by using the -fno-strict-overflow flag instead, which not only does not exist in the known-to-be-broken versions of gcc (it was introduced later than fwrapv), but seems to be much less disturbing to gcc too: the difference in the generated code by -fno-strict-overflow are smaller (compared to using neither flag) than when using -fwrapv. Reported-by: Barry K. Nathan <barryn@pobox.com> Pushed-by: Frans Pop <elendil@planet.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
