2013-04-25 | Linux 3.2.44v3.2.44 | Ben Hutchings | |
2013-04-10 | Linux 3.2.43v3.2.43 | Ben Hutchings | |
2013-03-27 | Linux 3.2.42v3.2.42 | Ben Hutchings | |
2013-03-20 | Linux 3.2.41v3.2.41 | Ben Hutchings | |
2013-03-06 | Linux 3.2.40v3.2.40 | Ben Hutchings | |
2013-02-20 | Linux 3.2.39v3.2.39 | Ben Hutchings | |
2013-02-06 | Linux 3.2.38v3.2.38 | Ben Hutchings | |
2013-01-16 | Linux 3.2.37v3.2.37 | Ben Hutchings | |
2013-01-03 | Linux 3.2.36v3.2.36 | Ben Hutchings | |
2012-12-06 | Linux 3.2.35v3.2.35 | Ben Hutchings | |
2012-11-16 | Linux 3.2.34v3.2.34 | Ben Hutchings | |
2012-10-30 | Linux 3.2.33v3.2.33 | Ben Hutchings | |
2012-10-17 | Linux 3.2.32v3.2.32 | Ben Hutchings | |
2012-10-10 | Linux 3.2.31v3.2.31 | Ben Hutchings | |
2012-09-19 | Linux 3.2.30v3.2.30 | Ben Hutchings | |
2012-09-12 | Linux 3.2.29v3.2.29 | Ben Hutchings | |
2012-08-19 | Linux 3.2.28v3.2.28 | Ben Hutchings | |
2012-08-10 | Linux 3.2.27v3.2.27 | Ben Hutchings | |
2012-08-04 | Linux 3.2.26v3.2.26 | Ben Hutchings | |
2012-08-02 | Linux 3.2.25v3.2.25 | Ben Hutchings | |
2012-07-25 | Linux 3.2.24v3.2.24 | Ben Hutchings | |
2012-07-12 | Linux 3.2.23v3.2.23 | Ben Hutchings | |
2012-07-04 | Linux 3.2.22v3.2.22 | Ben Hutchings | |
2012-06-19 | Linux 3.2.21v3.2.21 | Ben Hutchings | |
2012-06-10 | Linux 3.2.20v3.2.20 | Ben Hutchings | |
2012-05-31 | Linux 3.2.19v3.2.19 | Ben Hutchings | |
2012-05-31 | x86, realmode: 16-bit real-mode code support for relocs tool | H. Peter Anvin | |
commit 6520fe5564acf07ade7b18a1272db1184835c487 upstream. A new option is added to the relocs tool called '--realmode'. This option causes the generation of 16-bit segment relocations and 32-bit linear relocations for the real-mode code. When the real-mode code is moved to the low-memory during kernel initialization, these relocation entries can be used to relocate the code properly. In the assembly code 16-bit segment relocations must be relative to the 'real_mode_seg' absolute symbol. Linear relocations must be relative to a symbol prefixed with 'pa_'. 16-bit segment relocation is used to load cs:ip in 16-bit code. Linear relocations are used in the 32-bit code for relocatable data references. They are declared in the linker script of the real-mode code. The relocs tool is moved to arch/x86/tools/relocs.c, and added new target archscripts that can be used to build scripts needed building an architecture. be compiled before building the arch/x86 tree. [ hpa: accelerating this because it detects invalid absolute relocations, a serious bug in binutils 2.22.52.0.x which currently produces bad kernels. ] Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org> [bwh: Backported to 3.2: - Adjust context (no archheaders; no insn_sanity) - Expand put_unaligned_le32()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> | |||
2012-05-20 | Linux 3.2.18v3.2.18 | Ben Hutchings | |
2012-05-11 | Linux 3.2.17v3.2.17 | Ben Hutchings | |
2012-04-22 | Linux 3.2.16v3.2.16 | Greg Kroah-Hartman | |
2012-04-13 | Linux 3.2.15v3.2.15 | Greg Kroah-Hartman | |
2012-04-02 | Linux 3.2.14v3.2.14 | Greg Kroah-Hartman | |
2012-03-23 | Linux 3.2.13v3.2.13 | Greg Kroah-Hartman | |
2012-03-19 | Linux 3.2.12v3.2.12 | Greg Kroah-Hartman | |
2012-03-13 | Linux 3.2.11v3.2.11 | Greg Kroah-Hartman | |
2012-03-12 | Linux 3.2.10v3.2.10 | Greg Kroah-Hartman | |
2012-02-29 | Linux 3.2.9v3.2.9 | Greg Kroah-Hartman | |
2012-02-27 | Linux 3.2.8v3.2.8 | Greg Kroah-Hartman | |
2012-02-20 | Linux 3.2.7v3.2.7 | Greg Kroah-Hartman | |
2012-02-13 | Linux 3.2.6v3.2.6 | Greg Kroah-Hartman | |
2012-02-06 | Linux 3.2.5v3.2.5 | Greg Kroah-Hartman | |
2012-02-03 | Linux 3.2.4v3.2.4 | Greg Kroah-Hartman | |
2012-02-03 | Linux 3.2.3v3.2.3 | Greg Kroah-Hartman | |
2012-01-25 | Linux 3.2.2v3.2.2 | Greg Kroah-Hartman | |
2012-01-12 | Linux 3.2.1v3.2.1 | Greg Kroah-Hartman | |
2012-01-04 | Linux 3.2v3.2 | Linus Torvalds | |
2011-12-23 | Linux 3.2-rc7v3.2-rc7 | Linus Torvalds | |
2011-12-16 | Linux 3.2-rc6v3.2-rc6 | Linus Torvalds | |
2011-12-09 | Linux 3.2-rc5v3.2-rc5 | Linus Torvalds | |
2011-12-01 | Linux 3.2-rc4v3.2-rc4 | Linus Torvalds | |
