Sasha Levin reports:
"gcc5 changes the default standard to c11, which makes kernel build
unhappy
Explicitly define the kernel standard to be gnu89 which should keep
everything working exactly like it was before gcc5"
There are multiple small issues with the new default, but the biggest
issue seems to be that the old - and very useful - GNU extension to
allow a cast in front of an initializer has gone away.
Patch updated by Kirill:
"I'm pretty sure all gcc versions you can build kernel with supports
-std=gnu89. cc-option is redunrant.
We also need to adjust HOSTCFLAGS otherwise allmodconfig fails for me"
Note by Andrew Pinski:
"Yes it was reported and both problems relating to this extension has
been added to gnu99 and gnu11. Though there are other issues with the
kernel dealing with extern inline have different semantics between
gnu89 and gnu99/11"
End result: we may be able to move up to a newer stdc model eventually,
but right now the newer models have some annoying deficiencies, so the
traditional "gnu89" model ends up being the preferred one.
Singed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild changes from Michal Marek:
- fix for handling dependencies of *-objs targets by Masahiro Yamada
- lots of cleanups in the kbuild machinery, also by Masahiro
- fixes for the kconfig build to use an UTF-8 capable ncurses library
if possible and to build on not-so-standard installs
- some more minor fixes
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: Do not reference *-n variables in the Makefile
kbuild: simplify build, clean, modbuiltin shorthands
kbuild: arm: Do not define "comma" twice
kbuild: remove obj-n and lib-n handling
kbuild: remove unnecessary variable initializaions
kbuild: remove unnecessary "obj- := dummy.o" trick
kbuild: handle C=... and M=... after entering into build directory
kbuild: use $(Q) for sub-make target
kbuild: fake the "Entering directory ..." message more simply
kconfig/lxdialog: get ncurses CFLAGS with pkg-config
kconfig: nconfig: fix multi-byte UTF handling
kconfig: lxdialog: fix spelling
kbuild: Make scripts executable
kbuild: remove redundant clean-files from scripts/kconfig/Makefile
kbuild: refactor script/kconfig/Makefile
kbuild: handle the dependency of multi-objs hostprogs appropriately
kbuild: handle multi-objs dependency appropriately
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc
Pull documentation updates from Jiri Kosina:
"Updates to kernel documentation.
I took this over (hopefully temporarily) from Randy who was not
willing to maintain it any longer. This pile mostly is a relay of
queue that Randy already had in his tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc:
Documentation: fix broken v4l-utils URL
Documentation: update include path for mpssd
Documentation: correct parameter error for dma_mapping_error
MAINTAINERS: update location of linux-doc tree
Documentation: remove networking/.gitignore
tools: add more endian.h macros
Make Documenation depend on headers_install
Docs: this_cpu_ops: remove redundant add forms
Documentation: disable vdso_test to avoid breakage with old glibc
Documentation: update vDSO makefile to build portable examples
Documentation: update .gitignore files
Documentation: support glibc versions without htole macros
v4l2-pci-skeleton: Only build if PCI is available
Documentation: fix misc. warnings
Documentation: make functions static to avoid prototype warnings
Documentation: add makefiles for more targets
Documentation: use subdir-y to avoid unnecessary built-in.o files
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing major: support for compressing modules, and auto-tainting
params.
PS. My virtio-next tree is empty: DaveM took the patches I had. There
might be a virtio-rng starvation fix, but so far it's a bit voodoo
so I will get to that in the next two days or it will wait"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
moduleparam: Resolve missing-field-initializer warning
kbuild: handle module compression while running 'make modules_install'.
modinst: wrap long lines in order to enhance cmd_modules_install
modsign: lookup lines ending in .ko in .mod files
modpost: simplify file name generation of *.mod.c files
modpost: reduce visibility of symbols and constify r/o arrays
param: check for tainting before calling set op.
drm/i915: taint the kernel if unsafe module parameters are set
module: add module_param_unsafe and module_param_named_unsafe
module: make it possible to have unsafe, tainting module params
module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
Kconfig options are either 'y', 'm', or undefined.
$(if $(KBUILD_SRC),$(srctree)/) was a useful strategy
to omit a long absolute path for in-source-tree build
prior to commit 890676c65d699db3ad82e7dddd0cf8fb449031af
(kbuild: Use relative path when building in the source tree).
Now $(srctree) is "." when building in the source tree.
It would not be annoying to add "$(srctree)/" all the time.
This commit avoids processing C=... and M=... twice
when O=... is also given.
Besides, we can also remove KBUILD_EXTMOD="$(KBUILD_EXTMOD)"
in the sub-make target.
Acked-by: Peter Foley <pefoley2@pefoley.com>
Since commit 066b7ed9558087a7957a1128f27d7a3462ff117f
(kbuild: Do not print the build directory with make -s),
"Q" is defined above the sub-make target.
This commit takes advantage of that and replaces
"$(if $(KBUILD_VERBOSE:1=),@)" with "$(Q)".
Commit c2e28dc975ea87feed84415006ae143424912ac7
(kbuild: Print the name of the build directory)
added a gimmick to show the "Entering directory ...".
Instead of echoing the hard-coded message (that is, we need to know
the exact message), moving --no-print-directory would be easier.
Cc: rdunlap@infradead.org
Cc: linux-doc@vger.kernel.org
Cc: sudeep.dutt@intel.com
Cc: nikhil.rao@intel.com
Cc: ashutosh.dixit@intel.com
Cc: akpm@linux-foundation.org
Cc: gregkh@linuxfoundation.org
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Since module-init-tools (gzip) and kmod (gzip and xz) support compressed
modules, it could be useful to include a support for compressing modules
right after having them installed. Doing this in kbuild instead of per
distro can permit to make this kind of usage more generic.
This patch add a Kconfig entry to "Enable loadable module support" menu
and let you choose to compress using gzip (default) or xz.
Both gzip and xz does not used any extra -[1-9] option since Andi Kleen
and Rusty Russell prove no gain is made using them. gzip is called with -n
argument to avoid storing original filename inside compressed file, that
way we can save some more bytes.
On a v3.16 kernel, 'make allmodconfig' generated 4680 modules for a
total of 378MB (no strip, no sign, no compress), the following table
shows observed disk space gain based on the allmodconfig .config :
| time |
| manual .ko | make | size | percent
| compression | modules_install | | gain
- | | 18.61s | 378M |
GZIP | 3m16s | 3m37s | 102M | 73.41%
XZ | 5m22s | 5m39s | 77M | 79.83%
The gain for restricted environnement seems to be interesting while
uncompress can be time consuming but happens only while loading a module,
that is generally done only once.
This is fully compatible with signed modules while the signed module is
compressed. module-init-tools or kmod handles decompression
and provide to other layer the uncompressed but signed payload.
Reviewed-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Bertrand Jacquin <beber@meleeweb.net>
Pull misc kbuild updates from Michal Marek:
"This is the non-critical part of kbuild for 3.17-rc1:
- make help hint to use make -s with make kernelrelease et al.
- moved a kbuild document to Documentation/kbuild where it belongs
- four new Coccinelle scripts, one dropped and one fixed
- new make kselftest target to run various tests on the kernel"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: kselftest - new make target to build and run kernel selftests
Coccinelle: Script to replace if and BUG with BUG_ON
Coccinelle: Script to detect incorrect argument to sizeof
Coccinelle: Script to use ARRAY_SIZE instead of division of two sizeofs
Coccinelle: Script to detect cast after memory allocation
coccinelle/null: solve parse error
Documentation: headers_install.txt is part of kbuild
kbuild: make -s should be used with kernelrelease/kernelversion/image_name
Pull kbuild updates from Michal Marek:
- make clean also considers $(extra-m) and $(extra-) to be consistent
- cleanup and fixes in scripts/Makefile.host
- allow to override the name of the Python 2 executable with make
PYTHON=... (only needed for ia64 in practice)
- option to split debugingo into *.dwo files to save disk space if the
compiler supports it (CONFIG_DEBUG_INFO_SPLIT)
- option to use dwarf4 debuginfo if the compiler supports it
(CONFIG_DEBUG_INFO_DWARF4)
- fix for disabling certain warnings with clang
- fix for unneeded rebuild with dash when a command contains
backslashes
kbuild: Fix handling of backslashes in *.cmd files
kbuild, LLVMLinux: Supress warnings unless W=1-3
Kbuild: Add a option to enable dwarf4 v2
kbuild: Support split debug info v4
kbuild: allow to override Python command name
kbuild: clean-up and bug fix of scripts/Makefile.host
kbuild: clean up scripts/Makefile.host
kbuild: drop shared library support from Makefile.host
kbuild: fix a bug of C++ host program handling
kbuild: fix a typo in scripts/Makefile.host
scripts/Makefile.clean: clean also $(extra-m) and $(extra-)
Add a new make target "kselftest" to enable kernel testing. This
new target builds and runs kernel selftests. Running as root is
recommended for a complete test run as some tests don't run when
run by non-root user. Build, install, and boot kernel before
running kselftest on it.
Signed-off-by: Shuah Khan <shuah.kh@samsung.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
We have been chasing a memory corruption bug, which turned out to be
caused by very old gcc (4.3.4), which happily turned conditional load
into a non-conditional one, and that broke correctness (the condition
was met only if lock was held) and corrupted memory.
This particular problem with that particular code did not happen when
never gccs were used. I've brought this up with our gcc folks, as I
wanted to make sure that this can't really happen again, and it turns
out it actually can.
Quoting Martin Jambor <mjambor@suse.cz>:
"More current GCCs are more careful when it comes to replacing a
conditional load with a non-conditional one, most notably they check
that a store happens in each iteration of _a_ loop but they assume
loops are executed. They also perform a simple check whether the
store cannot trap which currently passes only for non-const
variables. A simple testcase demonstrating it on an x86_64 is for
example the following:
$ cat cond_store.c
int g_1 = 1;
int g_2[1024] __attribute__((section ("safe_section"), aligned (4096)));
int c = 4;
int __attribute__ ((noinline))
foo (void)
int l;
for (l = 0; (l != 4); l++) {
if (g_1)
return l;
for (g_2[0] = 0; (g_2[0] >= 26); ++g_2[0])
return 2;
int main (int argc, char* argv[])
if (mprotect (g_2, sizeof(g_2), PROT_READ) == -1)
int e = errno;
error (e, e, "mprotect error %i", e);
foo ();
__builtin_printf("OK\n");
return 0;
/* EOF */
$ ~/gcc/trunk/inst/bin/gcc cond_store.c -O2 --param allow-store-data-races=0
$ ./a.out
OK
$ ~/gcc/trunk/inst/bin/gcc cond_store.c -O2 --param allow-store-data-races=1
$ ./a.out
Segmentation fault
The testcase fails the same at least with 4.9, 4.8 and 4.7. Therefore
I would suggest building kernels with this parameter set to zero. I
also agree with Jikos that the default should be changed for -O2. I
have run most of the SPEC 2k6 CPU benchmarks (gamess and dealII
failed, at -O2, not sure why) compiled with and without this option
and did not see any real difference between respective run-times"
Hopefully the default will be changed in newer gccs, but let's force it
for kernel builds so that we are on a safe side even when older gcc are
used.
The code in question was out-of-tree printk-in-NMI (yeah, surprise
suprise, once again) patch written by Petr Mladek, let me quote his
comment from our internal bugzilla:
"I have spent few days investigating inconsistent state of kernel ring buffer.
It went out that it was caused by speculative store generated by
gcc-4.3.4.
The problem is in assembly generated for make_free_space(). The functions is
called the following way:
+ vprintk_emit();
+ log = MAIN_LOG; // with logbuf_lock
or
log = NMI_LOG; // with nmi_logbuf_lock
cont_add(log, ...);
+ cont_flush(log, ...);
+ log_store(log, ...);
+ log_make_free_space(log, ...);
If called with log = NMI_LOG then only nmi_log_* global variables are safe to
modify but the generated code does store also into (main_)log_* global
variables:
<log_make_free_space>:
55 push %rbp
89 f6 mov %esi,%esi
48 8b 05 03 99 51 01 mov 0x1519903(%rip),%rax # ffffffff82620868 <nmi_log_next_id>
44 8b 1d ec 98 51 01 mov 0x15198ec(%rip),%r11d # ffffffff82620858 <log_next_idx>
8b 35 36 60 14 01 mov 0x1146036(%rip),%esi # ffffffff8224cfa8 <log_buf_len>
44 8b 35 33 60 14 01 mov 0x1146033(%rip),%r14d # ffffffff8224cfac <nmi_log_buf_len>
4c 8b 2d d0 98 51 01 mov 0x15198d0(%rip),%r13 # ffffffff82620850 <log_next_seq>
4c 8b 25 11 61 14 01 mov 0x1146111(%rip),%r12 # ffffffff8224d098 <log_buf>
49 89 c2 mov %rax,%r10
48 21 c2 and %rax,%rdx
48 8b 1d 0c 99 55 01 mov 0x155990c(%rip),%rbx # ffffffff826608a0 <nmi_log_buf>
49 c1 ea 20 shr $0x20,%r10
48 89 55 d0 mov %rdx,-0x30(%rbp)
44 29 de sub %r11d,%esi
45 29 d6 sub %r10d,%r14d
4c 8b 0d 97 98 51 01 mov 0x1519897(%rip),%r9 # ffffffff82620840 <log_first_seq>
eb 7e jmp ffffffff81107029 <log_make_free_space+0xe9>
85 ff test %edi,%edi # edi = 1 for NMI_LOG
4c 89 e8 mov %r13,%rax
4c 89 ca mov %r9,%rdx
74 0a je ffffffff8110703d <log_make_free_space+0xfd>
8b 15 27 98 51 01 mov 0x1519827(%rip),%edx # ffffffff82620860 <nmi_log_first_id>
48 8b 45 d0 mov -0x30(%rbp),%rax
48 39 c2 cmp %rax,%rdx # end of loop
0f 84 da 00 00 00 je ffffffff81107120 <log_make_free_space+0x1e0>
4c 89 0d 17 97 51 01 mov %r9,0x1519717(%rip) # ffffffff82620840 <log_first_seq>
KABOOOM
74 35 je ffffffff81107160 <log_make_free_space+0x220>
It stores log_first_seq when edi == NMI_LOG. This instructions are used also
when edi == MAIN_LOG but the store is done speculatively before the condition
is decided. It is unsafe because we do not have "logbuf_lock" in NMI context
and some other process migh modify "log_first_seq" in parallel"
I believe that the best course of action is both
- building kernel (and anything multi-threaded, I guess) with that
optimization turned off
- persuade gcc folks to change the default for future releases
Cc: Martin Jambor <mjambor@suse.cz>
Cc: Petr Mladek <pmladek@suse.cz>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Marek Polacek <polacek@redhat.com>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Steven Noonan <steven@uplinklabs.net>
Cc: Richard Biener <richard.guenther@gmail.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
This adds a hopefully helpful comment above the (seemingly weird) compiler
flag selection logic.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Michal Marek <mmarek@suse.cz>
clang has more warnings enabled by default. Turn them off unless W is
set. This patch fixes a logic bug where warnings in clang were disabled
when W was set.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
Cc: bp@alien8.de
I found that a lot of unresolvable variables when using gdb on the
kernel become resolvable when dwarf4 is enabled. So add a Kconfig flag
to enable it.
It definitely increases the debug information size, but on the other
hand this isn't so bad when debug fusion is used.
v2: Use cc-option
This is an alternative approach to lower the overhead of debug info
(as we discussed a few days ago)
gcc 4.7+ and newer binutils have a new "split debug info" debug info
model where the debug info is only written once into central ".dwo" files.
This avoids having to copy it around multiple times, from the object
files to the final executable. It lowers the disk space
requirements. In addition it defaults to compressed debug data.
More details here: http://gcc.gnu.org/wiki/DebugFission
This patch adds a new option to enable it. It has to be an option,
because it'll undoubtedly break everyone's debuginfo packaging scheme.
gdb/objdump/etc. all still work, if you have new enough versions.
I don't see big compile wins (maybe a second or two faster or so), but the
object dirs with debuginfo get significantly smaller. My standard kernel
config (slightly bigger than defconfig) shrinks from 2.9G disk space
to 1.1G objdir (with non reduced debuginfo). I presume if you are IO limited
the compile time difference will be larger.
Only problem I've seen so far is that it doesn't play well with older
versions of ccache (apparently fixed, see
https://bugzilla.samba.org/show_bug.cgi?id=10005)
v2: various fixes from Dirk Gouders. Improve commit message slightly.
v3: Fix clean rules and improve Kconfig slightly
v4: Fix merge error in last version (Sam Ravnborg)
Clarify description that it mainly helps disk size.
Cc: Dirk Gouders <dirk@gouders.net>
Michel Dänzer and a couple of other people reported inexplicable random
oopses in the scheduler, and the cause turns out to be gcc mis-compiling
the load_balance() function when debugging is enabled. The gcc bug
apparently goes back to gcc-4.5, but slight optimization changes means
that it now showed up as a problem in 4.9.0 and 4.9.1.
The instruction scheduling problem causes gcc to schedule a spill
operation to before the stack frame has been created, which in turn can
corrupt the spilled value if an interrupt comes in. There may be other
effects of this bug too, but that's the code generation problem seen in
Michel's case.
This is fixed in current gcc HEAD, but the workaround as suggested by
Markus Trippelsdorf is pretty simple: use -fno-var-tracking-assignments
when compiling the kernel, which disables the gcc code that causes the
problem. This can result in slightly worse debug information for
variable accesses, but that is infinitely preferable to actual code
generation problems.
Doing this unconditionally (not just for CONFIG_DEBUG_INFO) also allows
non-debug builds to verify that the debug build would be identical: we
can do
export GCC_COMPARE_DEBUG=1
to make gcc internally verify that the result of the build is
independent of the "-g" flag (it will make the compiler build everything
twice, toggling the debug flag, and compare the results).
Without the "-fno-var-tracking-assignments" option, the build would fail
(even with 4.8.3 that didn't show the actual stack frame bug) with a gcc
compare failure.
See also gcc bugzilla:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=61801
Reported-by: Michel Dänzer <michel@daenzer.net>
Suggested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: stable@kernel.org
The specification of Python 3 is largely different from that of
Python 2.
For example, arch/ia64/scripts/unwcheck.py seems to be written
in Python 2, not compatible with Python 3.
It is not a good idea to invoke python scripts with the hard-coded
command name 'python'. The command 'python' could possibly be
Python 3 on some systems.
For that case, it is reasonable to allow to override the command name
by giving 'PYTHON=python2' from the command line.
The 'python' in arch/ia64/Makefile should be replaced with '$(PYTHON)'.
Cc: linux-ia64@vger.kernel.org
If .config has been edited, there will be a silentoldconfig run:
$ make defconfig
$ make kernelrelease
scripts/kconfig/conf --silentoldconfig Kconfig
3.16.0-rc1+
Recently, kbuild started to print the name of the build directory when
using O=
$ make O=build kernelrelease
make[1]: Entering directory `/dev/shm/mmarek/linux-2.6/build'
3.16.0-rc1+
Since these targets are often used in scripts, add a hint to use make -s
to the help text.
Suggested-by: Russell King <linux@arm.linux.org.uk>
Pull kbuild fixes from Michal Marek:
"Three more fixes for the relative build dir feature:
- Shut up make -s again
- Fix for rpm/deb/tar-pkg with O=<subdir>
- Fix for CONFIG_EXTRA_FIRMWARE"
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
firmware: Create directories for external firmware
kbuild: Fix packaging targets with relative $(srctree)
All other users of Makefile.build set $(obj) to the name of the
subdirectory to build. Do the same for the packaging targets, otherwise
the build fails if $(srctree) is a relative directory:
$ make O=build tar-pkg
make[1]: Entering directory `/home/mmarek/linux-2.6/build'
CHK include/config/kernel.release
../scripts/Makefile.build:44: ../../scripts/package/Makefile: No such file or directory
make[2]: *** No rule to make target `../../scripts/package/Makefile'. Stop.
Fixes: 9da0763b ("kbuild: Use relative path when building in a subdir of the source tree")
