Gaah. Delayed. But all the better for it!
Rebuilding a previously built tree while using make's -j option from
time to time results in the version.h check running at the same time as
the updating of .kernelrelease, resulting in UTS_RELEASE remaining an
empty string (and as a side effect causing the entire kernel to be
rebuilt).
Signed-Off-By: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Commit 296e0855b0f9a4ec9be17106ac541745a55b2ce1:
"kbuild: fix make -jN with multiple targets with O=..."
causes a ~95% increase in build time for the kernel. Before: 4m21s
after: 8m1.403s. Can we revert this until another approach is found?
.kernelrelease was saved in same directory as kernel source also
with make O=...
Make sure we kick in the normal logic to shift to the output directory
when we build .kernelrelease after executing *config.
Currently the CPU subtype options are cluttering up arch/sh/Kconfig somewhat.
Given that, this moves all of that in to its own arch/sh/mm/Kconfig. Things
like cache configuration are also moved to this new location.
This also adds support for strict CPU tuning on newer cores, which requires
the addition of as-option.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The command 'make all modules_install install' would fail
in a virgin tree - pointing at a non-existing directory under
/lib/modules/xxx
KERNELRELEASE is part of MODLIB and we need to create .kernelrelease
before we can properly evaluate KERNELRELEASE,
Changing MODLIB to the recursively expanded flavor let it pick up
the correct KERNELRELEASE value.
Reported by: "Hemmann, Volker Armin" <volker.armin.hemmann@tu-clausthal.de>
To enable 'make kernelrelease' earlier now create .kernelrelease when
one of the *config targets are used.
Also introduce KERNELVERSION - only user is kconfig.
KERNELVERSION was needed to display kernel version in menuconfig -
KERNELRELEASE is not valid until configuration has completed.
kconfig files modified to use KERNELVERSION.
Bug reported by: Rene Rebe <rene@exactcode.de>
The way multiple targets was handled with make O=...
broke because for each high-level target make spawned
a parallel make resulting in a broken build.
Reported by Keith Owens <kaos@ocs.com.au>
This makes ARCH=powerpc the default on 32-bit powerpc machines,
where uname -m returns ppc, as well as on 64-bit powerpc machines.
Most people who would be likely to build their own kernels on
32-bit powerpc machines would be using powermacs or CHRP machines,
both of which are supported with ARCH=powerpc now. Embedded ppc
developers whose ports haven't been moved over to arch/powerpc
yet will have to explicitly set ARCH=ppc now.
Fix up some trivial conflicts in {i386|ia64}/Makefile
Eric Sandeen <sandeen@sgi.com> pointed out that it is usefull to have
access to VERSION, PATCHLEVEL, SUBLEVEL in external modules, and gooling
a litte confirmed this.
So re-export them.
Usage within the kernel is still discouraged but possible.
To avoid running setlocalversion as root no longer (re-)define
KERNELRELEASE for each run. With this patch KERNELRELEASE is
only re-read when we do an actual kernel build.
Rationale behind this is "do as little as possible" when executing
make install - as root!
A new file named .kernelrelease is strored in the root of the kernel
tree containing the actual version string.
So when we use do a kernel build the .kernelrelease file will be updated.
But in all other situations it is left as-is.
To make it more visible the kernel now prints out the version being build.
Sample:
Building kernel 2.6.15-g63b794bf-dirty
The patch also un-exports VERSION PATCHLEVEL SUBLEVEL EXTRAVERSION LOCALVERSION
since all users of these are anyway broken - and none is left in the
tree.
If the final linking of vmlinux fails, the file .old_version are left
behind. This patch ensures the mrproper target will remove it if
present.
Signed-off-by: Tore Anderson <tore@fud.no>
Hey, it's fifteen years today since I bought the machine that got Linux
started. January 2nd is a good date.
If the file .kconfig.d is missing then make sure to run
'make silentoldconfig', since we have no way to detect if
a Kconfig file has been updated.
-kconfig.d is created by kconfig and is removed as part
of 'make clean' so the situation is likely to occur in reality.
Jan Beulich <JBeulich@novell.com> reported this bug.
Here is a fixup for tags file generation, for proper tags of
__releases/__acquires functions.
Signed-off-by: samuel.thibault@ens-lyon.org
declarations
This patch adds function prototypes and external variable declarations
to the set of tag kinds when running ctags. I find this useful when
perusing the kernel. Please apply.
Signed-off-by: John Kacur <jkacur@rogers.com>
Ho ho ho.
Also renamed in honor of Portland being snowed in and everybody sliding
around on the highways like greased pumpkins.
Signed-Off-By: Bodo Eggert <7eggert@gmx.de>
check_gcc has been deprecated for quite some time.
Sam Ravnborg <sam@ravnborg.org> writes:
> Author: Uwe Zeisberger <zeisberg@informatik.uni-freiburg.de>
> [PATCH] kbuild: make kernelrelease in unconfigured kernel prints an error
> Do not include .config for target kernelrelease
This is wrong. KERNELRELEASE depends on CONFIG_LOCALVERSION, thus you
need .config.
Signed-off-by: Andreas Schwab <schwab@suse.de>
Hey, for no other reason than the fact that I'll be off-line for a
week.
Of course, I could force everybody to just use git (and when I'm emperor
of the world, don't think I won't!), but it seems some people want to
just test official releases. Even if they are just -rc's.
By the time I'm back, Andrew will have fixed all my bugs, and I'll
release it as 2.6.15 and take all the credit.
Mwahahahaaa
In Uml, many definitions are borrowed from underlying subarch headers (with
#include <asm/arch/stuff.h>). And it has become annoying to keep switching
tag files all time, so by default index the underlying subarch headers too.
Btw, it adds negligible space to the tags file (less than 1M surely, IIRC it
was around 500k over 40M).
Finally, preserve the ALLSOURCE_ARCHS command line option (I hope) - if it is
set, it is used for headers too as before. But check my construct please, I
didn't test this.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Acked-by: Jeff Dike <jdike@addtoit.com>
As per the new release rules: two weeks of merging, and then an -rc1 and
calming down for the next release.
After the last merge of the new unified 'powerpc' architecture, ppc64 no
longer compiles cleanly as a standalone architecture. Some bits and
pieces still exist as files under the old ppc64 hierarchy, but the old
"ARCH=ppc64" is dead.
So if "uname" says ppc64, that now implies that the default architecture
should be "powerpc".
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
I have to revert the recent addition of -imacros to the Makefile to get my
tool chain to build. Without the change, below, I get:
Note that this looks entirely like a toolchain bug. Here is the offending command:
[pid 12163] execve("/usr/lib/gcc-lib/i386-redhat-linux/3.2.2/tradcpp0", ["/usr/lib/gcc-lib/i386-redhat-linux/3.2.2/tradcpp0", "-lang-asm", "-nostdinc", "-Iinclude", "-Iinclude/asm-i386/mach-default", "-D__GNUC__=3", "-D__GNUC_MINOR__=2", "-D__GNUC_PATCHLEVEL__=2", "-D__GXX_ABI_VERSION=102", "-D__ELF__", "-Dunix", "-D__gnu_linux__", "-Dlinux", "-D__ELF__", "-D__unix__", "-D__gnu_linux__", "-D__linux__", "-D__unix", "-D__linux", "-Asystem=posix", "-D__NO_INLINE__", "-D__STDC_HOSTED__=1", "-Acpu=i386", "-Amachine=i386", "-Di386", "-D__i386", "-D__i386__", "-D__tune_i386__", "-D__KERNEL__", "-D__ASSEMBLY__", "-isystem", "/usr/lib/gcc-lib/i386-redhat-linux/3.2.2/include", "-imacros", "include/linux/autoconf.h", "-MD", "arch/i386/kernel/.entry.o.d", "arch/i386/kernel/entry.S", "-o", "/tmp/ccOlsFJR.s"]
Which should execute properly, I think. But it does not:
zach-dev:linux-2.6.14-zach-work $ make
CHK include/linux/version.h
CHK include/linux/compile.h
CHK usr/initramfs_list
AS arch/i386/kernel/entry.o
/usr/lib/gcc-lib/i386-redhat-linux/3.2.2/tradcpp0: output filename specified twice
make[1]: *** [arch/i386/kernel/entry.o] Error 1
make: *** [arch/i386/kernel] Error 2
gcc (GCC) 3.2.2 20030222 (Red Hat Linux 3.2.2-5)
Deprecating the -imacros fixes the build for me. It does not appear to be a
simple argument overflow problem in trapcpp0, since deprecating all the defines
reproduces the problem as well. Also, switching -imacros to -include fixes the
problem.
Signed-off-by: Zachary Amsden <zach@vmware.com>
