.. with new name. Because nothing says "really solid kernel release"
like naming it after an extinct animal that just happened to be in the
news lately.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: append missing-syscalls to the default target list
genksyms: Regenerate lexer and parser
genksyms: Do not expand internal types
genksyms: Minor parser cleanup
Makefile: remove a duplicated line
fixdep: fix extraneous dependencies
scripts/Makefile.build: do not reference EXTRA_CFLAGS as CFLAGS replacement
kbuild: prevent make from deleting _shipped files
kbuild: Do not delete empty files in make distclean
This avoid an extra make invocation on `prepare0'.
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
There are two duplicated lines for 'make RECORDMCOUNT_WARN=1 [targets]'
in 'make help', remove the second one.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Commit 3d64b44 introduced an empty file under
arch/arm/mach-zynq/board_dt.c. While this was not intended and the file
was removed from the tree by a later commit, we really should only match
junk files by known name patterns and not their size.
Reported-by: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits)
kconfig: Introduce IS_ENABLED(), IS_BUILTIN() and IS_MODULE()
xconfig: Abort close if configuration cannot be saved
kconfig: fix missing "0x" prefix from S_HEX symbol in autoconf.h
kconfig/nconf: remove useless conditionnal
kconfig/nconf: prevent segfault on empty menu
kconfig/nconf: use the generic menu_get_ext_help()
nconfig: Avoid Wunused-but-set warning
kconfig/conf: mark xfgets() private
kconfig: remove pending prototypes for kconfig_load()
kconfig/conf: add command line options' description
kconfig/conf: reduce the scope of `defconfig_file'
kconfig: use calloc() for expr allocation
kconfig: introduce specialized printer
kconfig: do not overwrite symbol direct dependency in assignment
kconfig/gconf: silent missing prototype warnings
kconfig/gconf: kill deadcode
kconfig: nuke LKC_DIRECT_LINK cruft
kconfig: nuke reference to SWIG
kconfig: add missing <stdlib.h> inclusion
kconfig: add missing <ctype.h> inclusion
Fix up conflicts in scripts/kconfig/Makefile
Replace the config_is_*() macros with a variant that allows for grepping
for usage of CONFIG_* options in the code. Usage:
if (IS_ENABLED(CONFIG_NUMA))
or
#if IS_ENABLED(CONFIG_NUMA)
The IS_ENABLED() macro evaluates to 1 if the argument is set (to either 'y'
or 'm'), IS_BUILTIN() tests if the option is 'y' and IS_MODULE() test if
the option is 'm'. Only boolean and tristate options are supported.
Reviewed-by: Arnaud Lacombe <lacombar@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits)
perf: Remove the nmi parameter from the oprofile_perf backend
x86, perf: Make copy_from_user_nmi() a library function
perf: Remove perf_event_attr::type check
x86, perf: P4 PMU - Fix typos in comments and style cleanup
perf tools: Make test use the preset debugfs path
perf tools: Add automated tests for events parsing
perf tools: De-opt the parse_events function
perf script: Fix display of IP address for non-callchain path
perf tools: Fix endian conversion reading event attr from file header
perf tools: Add missing 'node' alias to the hw_cache[] array
perf probe: Support adding probes on offline kernel modules
perf probe: Add probed module in front of function
perf probe: Introduce debuginfo to encapsulate dwarf information
perf-probe: Move dwarf library routines to dwarf-aux.{c, h}
perf probe: Remove redundant dwarf functions
perf probe: Move strtailcmp to string.c
perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END
tracing/kprobe: Update symbol reference when loading module
tracing/kprobes: Support module init function probing
kprobes: Return -ENOENT if probe point doesn't exist
Merge reason: Pick up the latest fixes.
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: Call depmod.sh via shell
perf: clear out make flags when calling kernel make kernelver
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
Makefile
The script has the executable bit in git, but plain old patch(1) can't
create executable files.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
perf: Use make kernelversion instead of parsing the Makefile
kbuild: Hack for depmod not handling X.Y versions
kbuild: Move depmod call to a separate script
kbuild: Fix <linux/version.h> for empty SUBLEVEL or PATCHLEVEL
kbuild: Fix KERNELVERSION for empty SUBLEVEL or PATCHLEVEL
kbuild: silence Nothing to be done for 'all' message
Do not bloat the Makefile with multiline shell statements. No
user-visible change intended.
expr treats all numbers as decimals, so prepending a zero is safe. Note
that the KERNEL_VERSION() macro still takes three arguments, 3.0 has to be
written as KERNEL_VERSION(3,0,0).
Omit the second dot for releases without SUBLEVEL. If PATCHLEVEL is also
empty, only display VERSION.
.. except there are various scripts that really know that there are
three numbers, so it calls itself "3.0.0-rc1".
Hopefully by the time the final 3.0 is out, we'll have that extra zero
all figured out.
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits)
arch/tile: prefer "tilepro" as the name of the 32-bit architecture
compat: include aio_abi.h for aio_context_t
arch/tile: cleanups for tilegx compat mode
arch/tile: allocate PCI IRQs later in boot
arch/tile: support signal "exception-trace" hook
arch/tile: use better definitions of xchg() and cmpxchg()
include/linux/compat.h: coding-style fixes
tile: add an RTC driver for the Tilera hypervisor
arch/tile: finish enabling support for TILE-Gx 64-bit chip
compat: fixes to allow working with tile arch
arch/tile: update defconfig file to something more useful
tile: do_hardwall_trap: do not play with task->sighand
tile: replace mm->cpu_vm_mask with mm_cpumask()
tile,mn10300: add device parameter to dma_cache_sync()
audit: support the "standard" <asm-generic/unistd.h>
arch/tile: clarify flush_buffer()/finv_buffer() function names
arch/tile: kernel-related cleanups from removing static page size
arch/tile: various header improvements for building drivers
arch/tile: disable GX prefetcher during cache flush
arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD
With this change, you can (and should) build with ARCH=tilepro for the
current 32-bit chips. Building with ARCH=tile continues to work, but
we've renamed the defconfig file to tilepro_defconfig for consistency.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
