.. ok, enough waffling about it already. "Just do it!"
I tend to prefer to not have to cut an -rc7, but we still have some
network device driver and suspend issues. So here's -rc7.
.. perfect? Ahh, sure.
.. hopefully most of the fallout of the timer changes is contained now.
.. hopefully most of the resume/suspend problems introduced by the timer
and other changes are behind us.
Too many changes for comfort since -rc1. Some missed merges, and some
just annoyingly big fixes since. This is not how an -rc2 should look.
Need to really calm things down!
Add new headers_check_all target for checking all arches in one go.
Useful for distros (and people with too much time on their hands) that support
a ton of architectures, headers_check_all is to headers_check as
headers_install_all is to headers_install
Makefile
Remove references to the deprecated "make prepare-all" target from the
top-level Makefile; use just "make prepare" instead.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Acked-by: Oleg Verych <olecom@flower.upol.cz>
Since we look in both source and object directories for localversion*
files, we accidentally ended up getting them twice. Use 'sort -u' to
avoid that.
Reported-by: Tony Luck <tony.luck@intel.com>
Tildes as in path as in filenames are handled correctly now:
only files, containing tilde '~', are backups, thus are not valid.
[KJ]:
Definition of `space' was removed, scripts/Kbuild.include has one.
That definition was taken right from the GNU make manual, while Kbuild's
version is original.
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Bastian Blank <bastian@waldi.eu.org>
Signed-off-by: Oleg Verych <olecom@flower.upol.cz>
Ok, so I said there wouldn't be another -rc.
I lied.
`make help' in the build tree doesn't show the help texts about the
`headers_install' and `headers_check' targets because it looks for
include/asm-$(ARCH)/Kbuild in the wrong place.
Add the missing `$(srctree)' prefixes to fix this.
Also move the printing of the default install path for the headers inside the
`if/fi', where it belongs.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Revert previous attempts at messing with the linux banner string and
simply use a separate format string for proc.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Acked-by: Olaf Hering <olaf@aepfle.de>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: Andrey Borzenkov <arvidjaar@mail.ru>
Cc: Andrew Morton <akpm@osdl.org>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: Herbert Poetzl <herbert@13thfloor.at>
...because it's always a good idea to cut a release *before* you go out
to party and get drunk.
Remember kids: "Don't Drink and Release!"
include/linux/utsrelease.h and include/linux/version.h aren't removed any
more by mrproper in kernel 2.6.20-rc2. The patch below fixes this.
The definition of MRPROPER_FILES looks weird: generated-headers looks like
a misspelling of generated_headers, but that one is a Makefile target, not
a variable or a file, so I don't see how including it in MRPROPER_FILES
could have any effect.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
compile.h is created super-late in the build. But proc_misc.c want to include
it, and it's generally not sane to have a header file in include/linux be
created at the end of the build: it's either not present or, worse, wrong for
most of the build.
So the patch arranges for compile.h to be built at the start of the build
process. It also consolidates the compile.h rules with those for version.h
and utsname.h, so they all get built together.
I hope. My chances of having got this right are about 2%.
It has caused more problems than it ever really solved, and is
apparently not getting cleaned up and fixed. We can put it back when
it's stable and isn't likely to make warning or bug events worse.
In the meantime, enable frame pointers for more readable stack traces.
.. and so the stabilization phase starts.
The previous checkstack fix for UML, which needs to use the host's tools,
was wrong in the crossbuilding case. It would use the build host's, rather
than the target's, toolchain.
This patch removes the old fix and adds an explicit special case for UML,
leaving everyone else alone.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Signed-off-by: Samuel Tardieu <sam@rfc1149.net>
`make -d help | grep Makefile` shows patterns, where make tries to rebuild
included and top makefiles.
While `make -rR is now default' commit should fix this, actually, it was just
a little janitorial.
This fix is aimed to complete cancelling implicit rules.
It's all good.
Getting there. Hopefully the MSI and other interrupt problems are all
solved now.
Ok, things are clearly starting to calm down.. Finally.
Not halloween. Not scary. Just a regular -rc release.
This changes the dwarf2 unwinder to do a binary search for CIEs
instead of a linear work. The linker is unfortunately not
able to build a proper lookup table at link time, instead it creates
one at runtime as soon as the bootmem allocator is usable (so you'll continue
using the linear lookup for the first [hopefully] few calls).
The code should be ready to utilize a build-time created table once
a fixed linker becomes available.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Add functions defined using ENTRY macro to the tags file.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@gmail.com>
That was slightly more painful than really necessary..
* make header_check work with O=
headers_check'
In order to encourage people to notice when they break the exported
headers, add a config option which automatically runs the sanity checks
when building vmlinux. That way, those who use allyesconfig will notice
failures.
Merge window closed..
Not all architectures have a file named 'defconfig' (e.g. powerpc).
However the make TAGS and make tags targets search such files for tags,
causing an error message when they don't exist. This patch addresses the
problem by instructing xargs not to run the tags program if there are no
matching files.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Make checkstack work for UML. We need to pass the underlying architecture
name, rather than "um" to checkstack.pl.
Acked-by: Matt Mackall <mpm@selenic.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
* git://git.infradead.org/~dwmw2/khdrs-2.6:
New 'make headers_install_all' target.
Use dependencies for 'make headers_install'.
[S390] Unexport <asm/z90crypt.h>, export <asm/zcrypt.h> in its place.
Remove dead netfilter_logging.h from include/linux/Kbuild
Remove offsetof() from user-visible <linux/stddef.h>
Clean up exported headers on CRIS
Fix v850 exported headers
Don't advertise (or allow) headers_{install,check} where inappropriate.
Remove UML header export
Remove ARM26 header export.
Fix H8300 exported headers.
Fix m68knommu exported headers
Fix exported headers for SPARC, SPARC64
Fix 'make headers_check' on m32r
Fix 'make headers_check' on sh64
[HEADERS] Fix ARM 'make headers_check'
Initial pass of manual conflict resolution in top-level Makefile over
conflicting build rule and headers_install changes.
Add distclean info, that was previously missing, to 'make help'.
Also add a few more details to the 'make clean' help text.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The attached patch clarifies the creation of KERNELRELEASE and
corrects an error regarding the use of $(LOCALVERSION).
The following patch extends kbuild/defconfig tags support to exuberant
ctags. The previous support is only for emacs ctags/etags programs.
This patch also corrects the kconfig regex for the emacs invocation.
Previously it would miss some instances because it assumed /^config
instead of /^[ \t]*config
Signed-off-by: Aron Griffis <aron@hp.com>
