path: root/Makefile
2007-12-03Linux 2.6.24-rc4v2.6.24-rc4Linus Torvalds
2007-11-17x86: simplify "make ARCH=x86" and fix kconfig all.configSam Ravnborg
Simplify "make ARCH=x86" and fix kconfig so we again can set 64BIT in all.config. For a fix the diffstat is nice: 6 files changed, 3 insertions(+), 36 deletions(-) The patch reverts these commits: 0f855aa64b3f63d35a891510cf7db932a435c116 -> kconfig: add helper to set config symbol from environment variable 2a113281f5cd2febbab21a93c8943f8d3eece4d3 -> kconfig: use $K64BIT to set 64BIT with all*config targets Roman Zippel pointed out that kconfig supported string compares so the additional complexity introduced by the above two patches were not needed. With this patch we have following behaviour: # make {allno,allyes,allmod,rand}config [ARCH=...] option \ host arch | 32bit | 64bit ===================================================== ./. | 32bit | 64bit ARCH=x86 | 32bit | 32bit ARCH=i386 | 32bit | 32bit ARCH=x86_64 | 64bit | 64bit The general rule are that ARCH= and native architecture takes precedence over the configuration. So make ARCH=i386 [whatever] will always build a 32-bit kernel no matter what the configuration says. The configuration will be updated to 32-bit if it was configured to 64-bit and the other way around. This behaviour is consistent with previous behaviour so no suprises here. make ARCH=x86 will per default result in a 32-bit kernel but as the only ARCH= value x86 allow the user to select between 32-bit and 64-bit using menuconfig. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Herrmann <aherrman@arcor.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2007-11-17Remove x86 merge artifact from top MakefileThomas Gleixner
The x86 merge modified the tags target to handle the two separate source directories. Remove it now that i386/x86_64 are gone completely. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-16Linux 2.6.24-rc3v2.6.24-rc3Linus Torvalds
2007-11-12x86: enable "make ARCH=x86"Sam Ravnborg
After unification of the Kconfig files and introducing K64BIT support in kconfig it required only trivial changes to enable "make ARCH=x86". With this patch you can build for x86_64 in several ways: 1) make ARCH=x86_64 2) make ARCH=x86 K64BIT=y 3) make ARCH=x86 menuconfig => select 64-bit Likewise for i386 with the addition that i386 is default is you say ARCH=x86. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2007-11-12x86: do not use $(ARCH) when not neededSam Ravnborg
For x86 ARCH may say i386 or x86_64 and soon x86. Rely on CONFIG_X64_32 to select between 32/64 or just hardcode the value as appropriate. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2007-11-06Linux 2.6.24-rc2v2.6.24-rc2Linus Torvalds
2007-11-04kbuild: do not pick up CFLAGS from the environmentSam Ravnborg
Too many people have CFLAGS set to support building userspace. And now Kbuild picks up CFLAGS this caused troubles. Although people should realise that setting CFLAGS has a 'global' effect the impact on the kernel build is a suprise. So change kbuild to pick up value from KCFLAGS that is much less used. When kbuild pick up a value it will warn like this: Makefile:544: "WARNING: Appending $KCFLAGS (-O3) from environment to kernel $CFLAGS" Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Bächler <thomas@archlinux.org> Cc: David Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@redhat.com>
2007-11-02sh: Correct SUBARCH matching.Paul Mundt
When configuring the kernel natively the uname matching is off, so fix up the uname mangling to get the proper SUBARCH. Needs an explicit range so that SH-5 doesn't break. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-10-25x86: move i386 and x86_64 Makefiles to arch/x86Sam Ravnborg
Moving the ARCH specific Makefiles for i386 and x86_64 required a litle bit tweaking in the top-lvel Makefile. SRCARCH is now set in the top-level Makefile because we need this info to include the correct arch Makefile. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-23Linux 2.6.24-rc1v2.6.24-rc1Linus Torvalds
The patch is big. Really big. You just won't believe how vastly hugely mindbogglingly big it is. I mean you may think it's a long way down the road to the chemist, but that's just peanuts to how big the patch from 2.6.23 is. But it's all good. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22kbuild: allow depmod in cross builds againSam Ravnborg
depmod from module-init-tools 3.3-pre2 are reported to work fine in cross build. depmod from module-init-tools 3.1-pre5 are known to SEGV Do not workaround older module-init-tools bugs here. The right fix is for users to upgrade module-init-tools. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org>
2007-10-22kbuild: fix modules_install after a 'make vmlinux'Sam Ravnborg
make vmlinux would delete the content of $(MODVERDIR) equals .tmp_versions. This caused a subsequent make modules_install to fail. Fix it so we clean the directory only for the modules build - but we still unconditionally create it so we can do: make dir/file.ko without a preceeding make modules. Reported by David Miller <davem@davemloft.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Miller <davem@davemloft.net>
2007-10-20kbuild: fix toplevel Makefile/depmodDavid Brownell
This removes a syntax error (seen building on Ubuntu Feisty). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: fix first module build kconfig: update kconfig-language text kbuild: introduce cc-cross-prefix kbuild: disable depmod in cross-compile kernel build kbuild: make deb-pkg - add 'Provides:' line kconfig: comment typo in scripts/kconfig/Makefile. kbuild: stop docproc segfaulting when SRCTREE isn't set. kbuild: modpost problem when symbols move from one module to another kbuild: cscope - filter out .tmp_* in find_sources kbuild: mailing list has moved kbuild: check asm symlink when building a kernel
2007-10-19kbuild: fix first module buildSam Ravnborg
When building a specific module before doing a total kernel build it failed because $(MORVERDIR) were missing. Creating the MODVERDIR explicit (independent of KBUILD_MODULES) fixed this. As a side-effect the MODVERDIR will be created also for a non-module build - but no harm done by that. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-19markers: Add samples subdirMathieu Desnoyers
Begin infrastructure for kernel code samples in the samples/ directory. Add its Kconfig and Kbuild files. Source its Kconfig file in all arch/ Kconfigs. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18kbuild: disable depmod in cross-compile kernel buildSam Ravnborg
When building embedded systems in a cross-compile environment and populating a target's file system image, we don't want to run the depmod on the host as we may be building for a completely different architecture. Since there's no such thing as a cross-depmod, we just disable running depmod in the cross-compile case and we just run depmod on the target at bootup. Inspired by patches from Christian, Armin and Deepak. This solves: http://bugzilla.kernel.org/show_bug.cgi?id=3881 Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Christian Bjølevik <nafallo@magicalforest.se> Cc: Deepak Saxena <dsaxena@mvista.com> and Cc: Armin Kuster <akuster@mvista.com>,
2007-10-18kbuild: cscope - filter out .tmp_* in find_sourcesYinghai Lu
remove .tmp_kallsyms*.S in cscope.files Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-18kbuild: check asm symlink when building a kernelSam Ravnborg
We often hit the situation where the asm symlink in include/ points to the wrong architecture. In 9 out of 10 cases thats because we forgot to set ARCH but sometimes we just reused the same tree for another ARCH. For the merged x86 tree we need to create a new symlink but this is not obvious. So with the following patch we check if the symlink points to the correct architecture and error out if this is not the case. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-17kbuild: fix typo SRCARCH in find_sourcesYinghai Lu
otherwise get the two copy file list in SRCARCH for cscope: C symbol: start_kernel File Function Line 0 proto.h <global> 11 extern void start_kernel(void ); 1 start_kernel.h <global> 10 extern asmlinkage void __init start_kernel(void ); 2 head32.c i386_start_kernel 37 start_kernel(); 3 head32.c i386_start_kernel 37 start_kernel(); 4 head64.c x86_64_start_kernel 85 start_kernel(); 5 head64.c x86_64_start_kernel 85 start_kernel(); 6 head_32.S options 199 cmpb $0,%cl #the first CPU calls start_kernel 7 head_32.S options 199 cmpb $0,%cl #the first CPU calls start_kernel 8 enlighten.c xen_start_kernel 1145 start_kernel(); 9 enlighten.c xen_start_kernel 1145 start_kernel(); a lguest.c lguest_init 1095 start_kernel(); b main.c start_kernel 513 asmlinkage void __init start_kernel(void ) after the patch: C symbol: start_kernel File Function Line 0 proto.h <global> 11 extern void start_kernel(void ); 1 start_kernel.h <global> 10 extern asmlinkage void __init start_kernel(void ); 2 head32.c i386_start_kernel 37 start_kernel(); 3 head64.c x86_64_start_kernel 85 start_kernel(); 4 head_32.S options 199 cmpb $0,%cl #the first CPU calls start_kernel 5 enlighten.c xen_start_kernel 1145 start_kernel(); 6 lguest.c lguest_init 1095 start_kernel(); 7 main.c start_kernel 513 asmlinkage void __init start_kernel(void ) Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-15kbuild: enable 'make CPPFLAGS=...' to add additional options to CPPSam Ravnborg
The variable CPPFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. This patch replace use of CPPFLAGS with KBUILD_CPPFLAGS all over the tree and enabling one to use: make CPPFLAGS=... to specify additional CPP commandline options. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: enable use of AFLAGS and CFLAGS on commandlineSam Ravnborg
The previous patches was preparation. With this patch we can now say: make CFLAGS=-Os vmlinux And the option specified will be appended to the options passed to gcc for C files. For assembler use: make AFLAGS=-foo vmlinux for the same functionality. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: call export_report from the MakefileAdrian Bunk
The main feature is that export_report now automatically works for O= builds. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: call make once for all targets when O=.. is usedMilton Miller
Change the invocations of make in the output directory Makefile and the main Makefile for separate object trees to pass all goals to one $(MAKE) via a new phony target "sub-make" and the existing target _all. When compiling with separate object directories, a separate make is called in the context of another directory (from the output directory the main Makefile is called, the Makefile is then restarted with current directory set to the object tree). Before this patch, when multiple make command goals are specified, each target results in a separate make invocation. With make -j, these invocations may run in parallel, resulting in multiple commands running in the same directory clobbering each others results. I did not try to address make -j for mixed dot-config and no-dot-config targets. Because the order does matter, a solution was not obvious. Perhaps a simple check for MAKEFLAGS having -j and refusing to run would be appropriate. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: pass -g to assembler under CONFIG_DEBUG_INFORoland McGrath
The assembler for a while now supports -gdwarf to generate source line info just like the C compiler does. Source-level assembly debugging sounds like an oxymoron, but it is handy to be able to see the right source file and read its comments rather than just the disassembly. This patch enables -gdwarf for assembly files when CONFIG_DEBUG_INFO=y and the assembler supports the option. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix infinite make recursionSam Ravnborg
Jan Engelhardt <jengelh@computergmbh.de> reported: You can cause a recursion in kbuild/make with the following: make O=$PWD kernel/time.o make mrproper Of course no one would use O=$PWD (that's just the testcase), but this happened too often: /ws/linux/linux-2.6.23$ make O=/ws/linux/linux-2.6.23 kernel/time.o (Oops - should have been O=/ws/linux/obj-2.6.23!) Fixed by an explicit test for this case - we error out if output directory and source directory are the same. Tested-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: clean Modules.symvers in external module dirsMike Frysinger
At the moment, running `make clean` in an external module directory does a nice job of cleaning up with one exception: it leaves behind Modules.symvers. Attached patch adds this file to the clean list for external modules. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-11x86: Fix the $(ARCH) dependent help output in the top MakefileThomas Gleixner
Change the $(ARCH) dependency to $(SRCARCH) to honor the x86 namespace for i386 and x86_64. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-11Kbuild: prepare scope and tags for arch/x86Thomas Gleixner
Preparatory patch for the source merge of arch/i386 and arch/x86_64 into arch/x86. Make scope and tags aware of SRCARCH Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11Kbuild: allow arch/xxx to use a different source pathThomas Gleixner
Preparatory patch for the source merge of arch/i386 and arch/x86_64 into arch/x86. This allows to keep the original arch directories as stubs for the main Makefiles, Kconfigs et. al during the transition phase while having the code in the new arch/x86 directory. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-09Linux 2.6.23v2.6.23Linus Torvalds
2007-10-01Linux 2.6.23-rc9v2.6.23-rc9Linus Torvalds
No, I didn't want to do this, but we had more stuff go in after -rc8 than we had in the previous -rc. Gaah.
2007-09-24Linux 2.6.23-rc8v2.6.23-rc8Linus Torvalds
Getting there...
2007-09-19Linux 2.6.23-rc7v2.6.23-rc7Linus Torvalds
2007-09-10Linux 2.6.23-rc6v2.6.23-rc6Linus Torvalds
2007-08-31Linux 2.6.23-rc5v2.6.23-rc5Linus Torvalds
2007-08-27Linux 2.6.23-rc4v2.6.23-rc4Linus Torvalds
2007-08-12Linux 2.6.23-rc3v2.6.23-rc3Linus Torvalds
2007-08-03Linux 2.6.23-rc2v2.6.23-rc2Linus Torvalds
2007-07-25kbuild: use LDFLAGS_MODULE only for .ko linksRoland McGrath
Sam Ravnborg pointed out that Documentation/kbuild/makefiles.txt already says this is what it's for. This patch makes the reality live up to the documentation. This fixes the problem of LDFLAGS_BUILD_ID getting into too many places. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-22Linux 2.6.23-rc1v2.6.23-rc1Linus Torvalds
2007-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (33 commits) xtensa: use DATA_DATA in xtensa powerpc: add missing DATA_DATA to powerpc cris: use DATA_DATA in cris kallsyms: remove usage of memmem and _GNU_SOURCE from scripts/kallsyms.c kbuild: use -fno-optimize-sibling-calls unconditionally kconfig: reset generated values only if Kconfig and .config agree. kbuild: fix the warning when running make tags kconfig: strip 'CONFIG_' automatically in kernel configuration search kbuild: use POSIX BRE in headers install target Whitelist references from __dbe_table to .init modpost white list pattern adjustment kbuild: do section mismatch check on full vmlinux kbuild: whitelist references from variables named _timer to .init.text kbuild: remove hardcoded _logo names from modpost kbuild: remove hardcoded apic_es7000 from modpost kbuild: warn about references from .init.text to .exit.text kbuild: consolidate section checks kbuild: refactor code in modpost to improve maintainability kbuild: ignore section mismatch warnings originating from .note section kbuild: .paravirtprobe section is obsolete, so modpost doesn't need to handle it ...
2007-07-19Use --build-id ld optionRoland McGrath
This change passes the --build-id when linking the kernel and when linking modules, if ld supports it. This is a new GNU ld option that synthesizes an ELF note section inside the read-only data. The note in this section contains unique identifying bits called the "build ID", which are generated so as to be different for any two linked ELF files that aren't identical. The build ID can be recovered from stripped files, memory dumps, etc. and used to look up the original program built, locate debuginfo or other details or history associated with it. For normal program linking, the compiler passes --build-id to ld by default, but the option is needed when using ld directly as we do. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17kbuild: use -fno-optimize-sibling-calls unconditionallyAdrian Bunk
We don't have to check for -fno-optimize-sibling-calls since even gcc 3.2 supports it. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17kbuild: fix the warning when running make tagsAneesh Kumar K.V
make tags was giving the below warning. ctags: Warning: arch/x86_64/kernel/head.S:124: null expansion of name pattern "\1" Fix the same by making sure we taken only ENTRY pattern found at the begining of the line. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17kbuild: do section mismatch check on full vmlinuxSam Ravnborg
Previously we did do the check on the .o files used to link vmlinux but that failed to find questionable references across the .o files. Create a dedicated vmlinux.o file used only for section mismatch checks that uses the defualt linker script so section does not get renamed. The vmlinux.o may later be used as part of the the final link of vmlinux but for now it is used fo section mismatch only. For a defconfig build this is instant but for an allyesconfig this add two minutes to a full build (that anyways takes ~2 hours). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
