commit a137802ee839ace40079bebde24cfb416f73208a upstream.
This causes kernel images that don't run init to completion with certain
broken gcc versions.
This fixes kernel bugzilla entry:
http://bugzilla.kernel.org/show_bug.cgi?id=13012
I suspect the gcc problem is this:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=28230
Fix the problem by using the -fno-strict-overflow flag instead, which
not only does not exist in the known-to-be-broken versions of gcc (it
was introduced later than fwrapv), but seems to be much less disturbing
to gcc too: the difference in the generated code by -fno-strict-overflow
are smaller (compared to using neither flag) than when using -fwrapv.
Reported-by: Barry K. Nathan <barryn@pobox.com>
Pushed-by: Frans Pop <elendil@planet.nl>
commit a3ca86aea507904148870946d599e07a340b39bf upstream.
Turning on this flag could prevent the compiler from optimising away
some "useless" checks for null pointers. Such bugs can sometimes become
exploitable at compile time because of the -O2 optimisation.
See http://gcc.gnu.org/onlinedocs/gcc-4.1.2/gcc/Optimize-Options.html
An example that clearly shows this 'problem' is commit 6bf67672.
static void __devexit agnx_pci_remove(struct pci_dev *pdev)
struct ieee80211_hw *dev = pci_get_drvdata(pdev);
- struct agnx_priv *priv = dev->priv;
+ struct agnx_priv *priv;
AGNX_TRACE;
if (!dev)
return;
+ priv = dev->priv;
By reverting this patch, and compile it with and without
-fno-delete-null-pointer-checks flag, we can see that the check for dev
is compiled away.
call printk #
- testq %r12, %r12 # dev
- je .L94 #,
movq %r12, %rdi # dev,
Clearly the 'fix' is to stop using dev before it is tested, but building
with -fno-delete-null-pointer-checks flag at least makes it harder to
abuse.
Signed-off-by: Eugene Teo <eugeneteo@kernel.sg>
Acked-by: Eric Paris <eparis@redhat.com>
Acked-by: Wang Cong <amwang@redhat.com>
commit d0115552cdb0b4d4146975889fee2e9355515c4b upstream.
Sam Ravnborg says:
"We have several architectures that plays strange games with $(CC) and
$(CROSS_COMPILE).
So we need to postpone any use of $(call cc-option..) until we have
included the arch specific Makefile so we try with the correct $(CC)
version."
Requested-by: Sam Ravnborg <sam@ravnborg.org>
commit 68df3755e383e6fecf2354a67b08f92f18536594 upstream.
This makes sure that gcc doesn't try to optimize away wrapping
arithmetic, which the kernel occasionally uses for overflow testing, ie
things like
if (ptr + offset < ptr)
which technically is undefined for non-unsigned types. See
http://bugzilla.kernel.org/show_bug.cgi?id=12597
for details.
Not all versions of gcc support it, so we need to make it conditional
(it looks like it was introduced in gcc-3.4).
Reminded-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Currently source files in the Documentation/ sub-dir can easily bit-rot
since they are not generally buildable, either because they are hidden in
text files or because there are no Makefile rules for them. This needs to
be fixed so that the source files remain usable and good examples of code
instead of bad examples.
Add the ability to build source files that are in the Documentation/ dir.
Add to Kconfig as "BUILD_DOCSRC" config symbol.
Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the
Documentation/ sources. Or enable BUILD_DOCSRC in the *config system.
However, this symbol depends on HEADERS_CHECK since the header files need
to be installed (for userspace builds).
Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32,
sparc64, powerpc, sh, m68k, & mips.
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
It's a problem about cscope target of kernel Makefile, and the cscope
plugin of emacs:
1. `make cscope` will generate cscope.files cscope.{in,po,}.out;
2. the cscope plugin expect a cscope.out.{in,po,};
3. the default `cscope -b` would generate cscope.{in,po,}.out;
There are three approach to solve it:
1. modify the cscope C code;
2. modify the cscope emacs plugin lisp code;
3. modify the Makefile;
I have tried to communicate with the cscope upstream, but later I
realize the third approach is most meaningful.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
With a make O=... build kbuild would only create
the include2/asm symlink for archs that not yet
had moved headers to include/$ARCH/include
There is no longer any reason to avoid the symlink
for archs that has moved their headers so create it
unconditionally.
This fixes arm because kbuild checked for include/asm-$ARCH/errno.h
and that file was not present for arm but the platform files
are not yet moved.
