commit 8417da6f2128008c431c7d130af6cd3d9079922e upstream.
Starting with 4.4, gcc will happily accept -Wno-<anything> in the
cc-option test and complain later when compiling a file that has some
other warning. This rather unexpected behavior is intentional as per
http://gcc.gnu.org/PR28322, so work around it by testing for support of
the opposite option (without the no-). Introduce a new Makefile function
cc-disable-warning that does this and update two uses of cc-option in
the toplevel Makefile.
Reported-and-tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
commit af0e5d565d2fffcd97d1e2d89669d627cc04e8b8 upstream.
Disable the new -Wunused-but-set-variable that was added in gcc 4.6.0
It produces more false positives than useful warnings.
This can still be enabled using W=1
Signed-off-by: Dave Jones <davej@redhat.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Tested-by: Sam Ravnborg <sam@ravnborg.org>
commit 28bc20dccadc610c56e27255aeef2938141a0cd3 upstream.
Building a kernel with "make W=1" produces far too much noise to be
useful.
Divide the warning options in three groups:
W=1 - warnings that may be relevant and does not occur too often
W=2 - warnings that occur quite often but may still be relevant
W=3 - the more obscure warnings, can most likely be ignored
When building the whole kernel, those levels produce:
W=1 - 4859 warnings
W=2 - 1394 warnings
W=3 - 86666 warnings
respectively. Warnings have been counted with Geert's script at
http://www.kernel.org/pub/linux/kernel/people/geert/linux-log/linux-log-summary.pl
Many warnings occur from .h files so fixing one file may have a nice
effect on the total number of warnings.
With these changes I am actually tempted to try W=1 now and then.
Previously there was just too much noise.
Borislav:
- make the W= levels exclusive
- move very noisy and making little sense for the kernel warnings to W=3
- drop -Woverlength-strings due to useless warning message
- copy explanatory text for the different warning levels to 'make help'
- recount warnings per level
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Borislav Petkov <bp@alien8.de>
Cc: Dave Jones <davej@redhat.com>
[PG: used for 2.6.34 to better control new compilers on older code]
commit 4a5838ad9d2d4f7354a310982483f4c76aa0abeb upstream.
Add a 'W=1' Makefile switch which adds additional checking per build
object.
The idea behind this option is targeted at developers who, in the
process of writing their code, want to do the occasional
make W=1 [target.o]
and let gcc do more extensive code checking for them. Then, they
could eyeball the output for valid gcc warnings about various
bugs/discrepancies which are not reported during the normal build
process.
For more background information and a use case, read through this
thread: http://marc.info/?l=kernel-janitors&m=129802065918147&w=2
Cc: Michal Marek <mmarek@suse.cz>
Cc: linux-kbuild@vger.kernel.org
Setting LC_CTYPE=C breaks localized messages in some setups. With only
LC_COLLATE=C and LC_NUMERIC=C, we get almost all we need, except for not
so defined character classes and tolower()/toupper(). The former is not
a big issue, because we can assume that e.g. [:alpha:] will always
include a-zA-Z and we only ever process ASCII input. The latter seems
only affect arch/sh/tools/gen-mach-types, which we can handle separately.
So after this patch the meaning of ranges like [a-z], the behavior of
sort and join, etc. should be the same everywhere and at the same time
gcc should be able to print localized waring and error messages.
LC_NUMERIC=C might not be necessary, but setting it doesn't hurt.
Reported-by: Simon Horman <horms@verge.net.au>
Reported-by: Sergei Trofimovich <slyfox@inbox.ru>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Tested-by: Simon Horman <horms@verge.net.au>
Tested-by: Masami Hiramatsu <mhiramat@redhat.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system
Makefile: Unexport LC_ALL instead of clearing it
x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk
x86: Reenable TSC sync check at boot, even with NONSTOP_TSC
x86: Don't use POSIX character classes in gen-insn-attr-x86.awk
Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C
x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA
x86: Fix checking of SRAT when node 0 ram is not from 0
x86, cpuid: Add "volatile" to asm in native_cpuid()
x86, msr: msrs_alloc/free for CONFIG_SMP=n
x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space
x86: Add IA32_TSC_AUX MSR and use it
x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers
initramfs: add missing decompressor error check
bzip2: Add missing checks for malloc returning NULL
bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
Apparently not all versions of glibc and utilities treat an empty
LC_ALL as nonexistent, causing error messages to be garbled. Instead,
explicitly unexport it from the environment.
Reported-and-tested-by: Masami Hiramatsu <mhiramat@redhat.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
LKML-Reference: <4B2AC394.4030108@redhat.com>
Cc: Michal Marek <mmarek@sues.cz>
Cc: Roland Dreier <rdreier@cisco.com>
There are a number of common Unix constructs like character ranges in
grep/sed/awk which don't work as expected with LC_COLLATE set to other
than C. Similarly, set LC_CTYPE and LC_NUMERIC to C to avoid other
nasty surprises.
In order to make sure these actually take effect we also have to
clear LC_ALL.
Acked-by: Michal Marek <mmarek@sues.cz>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Roland Dreier <rdreier@cisco.com>
LKML-Reference: <4B2A1761.4070904@suse.cz>
Fix typo / thinko in commit bc081dd.
To make it easier for module-init-tools and scripts like mkinitrd to
distinguish builtin and missing modules, install a modules.builtin file
listing all builtin modules. This is done by generating an additional
config file (tristate.conf) with tristate options set to uppercase 'Y'
or 'M'. If we source that config file, the builtin modules appear in
obj-Y.
The toplevel Makefile creates the directory if it runs silentoldconfig
automatically, but if run manually, it fails:
$ make mrproper
$ make defconfig && make silentoldconfig
*** Default configuration is based on 'x86_64_defconfig'
# configuration written to .config
scripts/kconfig/conf -s arch/x86/Kconfig
*** Error during update of the kernel configuration.
Move the mkdir command to the silentoldconfig target to make it work.
Drop Module.markers from cleaning list since marker
is removed.
Signed-off-by: Wenji Huang <wenji.huang@oracle.com>
Fix up all users of utsrelease.h
We no longer use this directory for generated files and
all architectures has moved their header files so no
symlink tricks are needed either.
Drop the symlink and drop the ARCH check.
If we really need to check that the SRCARCH has not changed
when we build a kernel we can add this check back - but then we will
find a more convenient way to store the info.
No architectures uses include/asm-$ARCH now.
So drop check for location of include files
There is no longer any use of the include2/ directory.
The generated files has moved to include/generated.
Drop all references to said directory.
The simplest method was to add an extra asm-offsets.h
file in arch/$ARCH/include/asm that references the generated file.
We can now migrate the architectures one-by-one to reference
the generated file direct - and when done we can delete the
temporary arch/$ARCH/include/asm/asm-offsets.h file.
