Commit 3d64b44 introduced an empty file under
arch/arm/mach-zynq/board_dt.c. While this was not intended and the file
was removed from the tree by a later commit, we really should only match
junk files by known name patterns and not their size.
Reported-by: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits)
kconfig: Introduce IS_ENABLED(), IS_BUILTIN() and IS_MODULE()
xconfig: Abort close if configuration cannot be saved
kconfig: fix missing "0x" prefix from S_HEX symbol in autoconf.h
kconfig/nconf: remove useless conditionnal
kconfig/nconf: prevent segfault on empty menu
kconfig/nconf: use the generic menu_get_ext_help()
nconfig: Avoid Wunused-but-set warning
kconfig/conf: mark xfgets() private
kconfig: remove pending prototypes for kconfig_load()
kconfig/conf: add command line options' description
kconfig/conf: reduce the scope of `defconfig_file'
kconfig: use calloc() for expr allocation
kconfig: introduce specialized printer
kconfig: do not overwrite symbol direct dependency in assignment
kconfig/gconf: silent missing prototype warnings
kconfig/gconf: kill deadcode
kconfig: nuke LKC_DIRECT_LINK cruft
kconfig: nuke reference to SWIG
kconfig: add missing <stdlib.h> inclusion
kconfig: add missing <ctype.h> inclusion
Fix up conflicts in scripts/kconfig/Makefile
Replace the config_is_*() macros with a variant that allows for grepping
for usage of CONFIG_* options in the code. Usage:
if (IS_ENABLED(CONFIG_NUMA))
or
#if IS_ENABLED(CONFIG_NUMA)
The IS_ENABLED() macro evaluates to 1 if the argument is set (to either 'y'
or 'm'), IS_BUILTIN() tests if the option is 'y' and IS_MODULE() test if
the option is 'm'. Only boolean and tristate options are supported.
Reviewed-by: Arnaud Lacombe <lacombar@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits)
perf: Remove the nmi parameter from the oprofile_perf backend
x86, perf: Make copy_from_user_nmi() a library function
perf: Remove perf_event_attr::type check
x86, perf: P4 PMU - Fix typos in comments and style cleanup
perf tools: Make test use the preset debugfs path
perf tools: Add automated tests for events parsing
perf tools: De-opt the parse_events function
perf script: Fix display of IP address for non-callchain path
perf tools: Fix endian conversion reading event attr from file header
perf tools: Add missing 'node' alias to the hw_cache[] array
perf probe: Support adding probes on offline kernel modules
perf probe: Add probed module in front of function
perf probe: Introduce debuginfo to encapsulate dwarf information
perf-probe: Move dwarf library routines to dwarf-aux.{c, h}
perf probe: Remove redundant dwarf functions
perf probe: Move strtailcmp to string.c
perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END
tracing/kprobe: Update symbol reference when loading module
tracing/kprobes: Support module init function probing
kprobes: Return -ENOENT if probe point doesn't exist
Merge reason: Pick up the latest fixes.
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: Call depmod.sh via shell
perf: clear out make flags when calling kernel make kernelver
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
Makefile
The script has the executable bit in git, but plain old patch(1) can't
create executable files.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
perf: Use make kernelversion instead of parsing the Makefile
kbuild: Hack for depmod not handling X.Y versions
kbuild: Move depmod call to a separate script
kbuild: Fix <linux/version.h> for empty SUBLEVEL or PATCHLEVEL
kbuild: Fix KERNELVERSION for empty SUBLEVEL or PATCHLEVEL
kbuild: silence Nothing to be done for 'all' message
Do not bloat the Makefile with multiline shell statements. No
user-visible change intended.
expr treats all numbers as decimals, so prepending a zero is safe. Note
that the KERNEL_VERSION() macro still takes three arguments, 3.0 has to be
written as KERNEL_VERSION(3,0,0).
Omit the second dot for releases without SUBLEVEL. If PATCHLEVEL is also
empty, only display VERSION.
.. except there are various scripts that really know that there are
three numbers, so it calls itself "3.0.0-rc1".
Hopefully by the time the final 3.0 is out, we'll have that extra zero
all figured out.
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits)
arch/tile: prefer "tilepro" as the name of the 32-bit architecture
compat: include aio_abi.h for aio_context_t
arch/tile: cleanups for tilegx compat mode
arch/tile: allocate PCI IRQs later in boot
arch/tile: support signal "exception-trace" hook
arch/tile: use better definitions of xchg() and cmpxchg()
include/linux/compat.h: coding-style fixes
tile: add an RTC driver for the Tilera hypervisor
arch/tile: finish enabling support for TILE-Gx 64-bit chip
compat: fixes to allow working with tile arch
arch/tile: update defconfig file to something more useful
tile: do_hardwall_trap: do not play with task->sighand
tile: replace mm->cpu_vm_mask with mm_cpumask()
tile,mn10300: add device parameter to dma_cache_sync()
audit: support the "standard" <asm-generic/unistd.h>
arch/tile: clarify flush_buffer()/finv_buffer() function names
arch/tile: kernel-related cleanups from removing static page size
arch/tile: various header improvements for building drivers
arch/tile: disable GX prefetcher during cache flush
arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD
With this change, you can (and should) build with ARCH=tilepro for the
current 32-bit chips. Building with ARCH=tile continues to work, but
we've renamed the defconfig file to tilepro_defconfig for consistency.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
export_report: use warn() to issue WARNING, so they go to stderr
export_report: sort SECTION 2 output
export_report: do collectcfiles work in perl itself
kbuild: make versioncheck work in KBUILD_OUTDIR
kbuild: make includecheck work in KBUILD_OUTDIR
kbuild: make headerdep work in KBUILD_OUTDIR
kbuild: add targets to PHONY
kbuild: don't warn about include/linux/version.h not including itself
eradicate bashisms in scripts/patch-kernel
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: make KBUILD_NOCMDDEP=1 handle empty built-in.o
scripts/kallsyms.c: fix potential segfault
scripts/gen_initramfs_list.sh: Convert to a /bin/sh script
kbuild: Fix GNU make v3.80 compatibility
kbuild: Fix passing -Wno-* options to gcc 4.4+
kbuild: move scripts/basic/docproc.c to scripts/docproc.c
kbuild: Fix Makefile.asm-generic for um
kbuild: Allow to combine multiple W= levels
kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0
Fix handling of backlash character in LINUX_COMPILE_BY name
kbuild: asm-generic support
kbuild: implement several W= levels
kbuild: Fix build with binutils <= 2.19
initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entries
kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macros
kbuild: Drop unused LINUX_COMPILE_TIME and LINUX_COMPILE_DOMAIN macros
kbuild: Use the deterministic mode of ar
kbuild: Call gzip with -n
kbuild: move KALLSYMS_EXTRA_PASS from Kconfig to Makefile
Kconfig: improve KALLSYMS_ALL documentation
Fix up trivial conflict in Makefile
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (107 commits)
perf stat: Add more cache-miss percentage printouts
perf stat: Add -d -d and -d -d -d options to show more CPU events
ftrace/kbuild: Add recordmcount files to force full build
ftrace: Add self-tests for multiple function trace users
ftrace: Modify ftrace_set_filter/notrace to take ops
ftrace: Allow dynamically allocated function tracers
ftrace: Implement separate user function filtering
ftrace: Free hash with call_rcu_sched()
ftrace: Have global_ops store the functions that are to be traced
ftrace: Add ops parameter to ftrace_startup/shutdown functions
ftrace: Add enabled_functions file
ftrace: Use counters to enable functions to trace
ftrace: Separate hash allocation and assignment
ftrace: Create a global_ops to hold the filter and notrace hashes
ftrace: Use hash instead for FTRACE_FL_FILTER
ftrace: Replace FTRACE_FL_NOTRACE flag with a hash of ignored functions
perf bench, x86: Add alternatives-asm.h wrapper
x86, 64-bit: Fix copy_[to/from]_user() checks for the userspace address limit
x86, mem: memset_64.S: Optimize memset by enhanced REP MOVSB/STOSB
x86, mem: memmove_64.S: Optimize memmove by enhanced REP MOVSB/STOSB
When mcount is called in a section that ftrace will not modify it into
a nop, we want to warn about this. But not warn about this always. Now
if the user builds the kernel with the option RECORDMCOUNT_WARN=1 then
the build will warn about mcount callers that are ignored and will just
waste execution time.
Acked-by: Michal Marek <mmarek@suse.cz>
Cc: linux-kbuild@vger.kernel.org
Link: http://lkml.kernel.org/r/20110421023738.714956282@goodmis.org
This support was partially present in the existing code (look for
"__tilegx__" ifdefs) but with this change you can build a working
kernel using the TILE-Gx toolchain and ARCH=tilegx.
Most of these files are new, generally adding a foo_64.c file
where previously there was just a foo_32.c file.
The ARCH=tilegx directive redirects to arch/tile, not arch/tilegx,
using the existing SRCARCH mechanism in the top-level Makefile.
Changes to existing files:
- <asm/bitops.h> and <asm/bitops_32.h> changed to factor the
include of <asm-generic/bitops/non-atomic.h> in the common header.
- <asm/compat.h> and arch/tile/kernel/compat.c changed to remove
the "const" markers I had put on compat_sys_execve() when trying
to match some recent similar changes to the non-compat execve.
It turns out the compat version wasn't "upgraded" to use const.
- <asm/opcode-tile_64.h> and <asm/opcode_constants_64.h> were
previously included accidentally, with the 32-bit contents. Now
they have the proper 64-bit contents.
Finally, I had to hack the existing hacky drivers/input/input-compat.h
to add yet another "#ifdef" for INPUT_COMPAT_TEST (same as x86_64).
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [drivers/input]
This patch fixes the versioncheck target so it works when make is
invoked in KBUILD_OUTDIR.
Signed-off-by: Peter Foley <pefoley2@verizon.net>
This patch fixes the includecheck target so it works when make is
This patch fixes the headerdep target so it works when make is invoked
in KBUILD_OUTDIR.
This patch adds some targets to PHONY so they are built even if a file
with the same name exists.
According to Documentation/Changes, the kernel should be buildable with
GNU make 3.80+. Commit 88d7be031f9f975bb3f50a0b5ef3796a671e7edf (kbuild:
Use a single clean rule for kernel and external modules) introduced the
"$(or" construct, which requires make 3.81. This causes "make clean" to
malfunction when it is used with external modules.
Replace "$(or" with an equivalent "$(if" expression, to restore backward
compatibility.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Cc: stable@kernel.org
Starting with 4.4, gcc will happily accept -Wno-<anything> in the
cc-option test and complain later when compiling a file that has some
other warning. This rather unexpected behavior is intentional as per
http://gcc.gnu.org/PR28322, so work around it by testing for support of
the opposite option (without the no-). Introduce a new Makefile function
cc-disable-warning that does this and update two uses of cc-option in
the toplevel Makefile.
Reported-and-tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
Move docproc from scripts/basic to scripts so it is only built for *doc
targets instead of every time the kernel is built.
Add support for make W=12, make W=123 and so on, to enable warnings from
multiple W= levels. Normally, make W=<level> does not include warnings
from the previous level.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Reviewed-By: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Disable the new -Wunused-but-set-variable that was added in gcc 4.6.0
It produces more false positives than useful warnings.
This can still be enabled using W=1
Signed-off-by: Dave Jones <davej@redhat.com>
Tested-by: Sam Ravnborg <sam@ravnborg.org>
There is an increasing amount of header files
shared between individual architectures in asm-generic.
To avoid a lot of dummy wrapper files that just
include the corresponding file in asm-generic provide
some basic support in kbuild for this.
With the following patch an architecture can maintain
a list of files in the file arch/$(ARCH)/include/asm/Kbuild
To use a generic file just add:
generic-y += <name-of-header-file.h>
For each file listed kbuild will generate the necessary
wrapper in arch/$(ARCH)/include/generated/asm.
When installing userspace headers a wrapper is likewise created.
The original inspiration for this came from the unicore32
patchset - although a different method is used.
The patch includes several improvements from Arnd Bergmann.
Michael Marek contributed Makefile.asm-generic.
Remis Baima did an intial implementation along to achive
the same - see https://patchwork.kernel.org/patch/13352/
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn>
Tested-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn>
Cc: Remis Lima Baima <remis.developer@googlemail.com>
Building a kernel with "make W=1" produces far too much noise to be
useful.
Divide the warning options in three groups:
W=1 - warnings that may be relevant and does not occur too often
W=2 - warnings that occur quite often but may still be relevant
W=3 - the more obscure warnings, can most likely be ignored
When building the whole kernel, those levels produce:
W=1 - 4859 warnings
W=2 - 1394 warnings
W=3 - 86666 warnings
respectively. Warnings have been counted with Geert's script at
http://www.kernel.org/pub/linux/kernel/people/geert/linux-log/linux-log-summary.pl
Many warnings occur from .h files so fixing one file may have a nice
effect on the total number of warnings.
With these changes I am actually tempted to try W=1 now and then.
Previously there was just too much noise.
Borislav:
- make the W= levels exclusive
- move very noisy and making little sense for the kernel warnings to W=3
- drop -Woverlength-strings due to useless warning message
- copy explanatory text for the different warning levels to 'make help'
- recount warnings per level
Signed-off-by: Borislav Petkov <bp@alien8.de>
Cc: Dave Jones <davej@redhat.com>
The D option of ar is only available in newer versions.
At the moment we have the CONFIG_KALLSYMS_EXTRA_PASS Kconfig switch,
which users can enable or disable while configuring the kernel. This
option is then used by 'make' to determine whether an extra kallsyms
pass is needed or not.
However, this approach is not nice and confusing, and this patch moves
CONFIG_KALLSYMS_EXTRA_PASS from Kconfig to Makefile instead. The
rationale is below.
1. CONFIG_KALLSYMS_EXTRA_PASS is really about the build time, not
run-time. There is no real need for it to be in Kconfig. It is
just an additional work-around which should be used only in rare
cases, when someone breaks kallsyms, so Kbuild/Makefile is much
better place for this option.
2. Grepping CONFIG_KALLSYMS_EXTRA_PASS shows that many defconfigs have
it enabled, probably not because they try to work-around a kallsyms
bug, but just because the Kconfig help text is confusing and does
not really make it clear that this option should not be used unless
except when kallsyms is broken.
3. And since many people have CONFIG_KALLSYMS_EXTRA_PASS enabled in
their Kconfig, we do might fail to notice kallsyms bugs in time. E.g.,
many testers use "make allyesconfig" to test builds, which will enable
CONFIG_KALLSYMS_EXTRA_PASS and kallsyms breakage will not be noticed.
To address that, this patch:
1. Kills CONFIG_KALLSYMS_EXTRA_PASS
2. Changes Makefile so that people can use "make KALLSYMS_EXTRA_PASS=1"
to enable the extra pass if needed. Additionally, they may define
KALLSYMS_EXTRA_PASS as an environment variable.
3. By default KALLSYMS_EXTRA_PASS is disabled and if kallsyms has issues,
"make" should print a warning and suggest using KALLSYMS_EXTRA_PASS
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
[mmarek: Removed make help text, is not necessary]
