[ Upstream commit 35f860f9ba6aac56cc38e8b18916d833a83f1157 ]
Some versions of ARM GCC compiler such as Android toolchain throws in a
'-fpic' flag by default. This causes the gcc-goto check script to fail
although some config would have '-fno-pic' flag in the KBUILD_CFLAGS.
This patch passes the KBUILD_CFLAGS to the check script so that the
script does not rely on the default config from different compilers.
Link: http://lkml.kernel.org/r/20170120234329.78868-1-dtwlin@google.com
Signed-off-by: David Lin <dtwlin@google.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Michal Marek <mmarek@suse.com>
commit c6a385539175ebc603da53aafb7753d39089f32e upstream.
So Sebastian turned off the PIE for kernel builds but that was too late
- Kbuild.include already uses KBUILD_CFLAGS and trying to disable gcc
options with, say cc-disable-warning, fails:
gcc -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs
-Wno-sign-compare -fno-asynchronous-unwind-tables -Wframe-address -c -x c /dev/null -o .31392.tmp
/dev/null:1:0: error: code model kernel does not support PIC mode
because that returns an error and we can't disable the warning. For
example in this case:
KBUILD_CFLAGS += $(call cc-disable-warning,frame-address,)
which leads to gcc issuing all those warnings again.
So let's turn off PIE/PIC at the earliest possible moment, when we
declare KBUILD_CFLAGS so that cc-disable-warning picks it up too.
Also, we need the $(call cc-option ...) because -fno-PIE is supported
since gcc v3.4 and our lowest supported gcc version is 3.2 right now.
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Michal Marek <mmarek@suse.com>
commit 8ae94224c9d72fc4d9aaac93b2d7833cf46d7141 upstream.
Debian started to build the gcc with -fPIE by default so the kernel
build ends before it starts properly with:
|kernel/bounds.c:1:0: error: code model kernel does not support PIC mode
Also add to KBUILD_AFLAGS due to:
|gcc -Wp,-MD,arch/x86/entry/vdso/vdso32/.note.o.d … -mfentry -DCC_USING_FENTRY … vdso/vdso32/note.S
|arch/x86/entry/vdso/vdso32/note.S:1:0: sorry, unimplemented: -mfentry isn’t supported for 32-bit in combination with -fpic
Tagging it stable so it is possible to compile recent stable kernels as
well.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 124a3d88fa20e1869fc229d7d8c740cc81944264 upstream.
Newer versions of gcc warn about the use of __builtin_return_address()
with a non-zero argument when "-Wall" is specified:
kernel/trace/trace_irqsoff.c: In function ‘stop_critical_timings’:
kernel/trace/trace_irqsoff.c:433:86: warning: calling ‘__builtin_return_address’ with a nonzero argument is unsafe [-Wframe-address]
stop_critical_timing(CALLER_ADDR0, CALLER_ADDR1);
[ .. repeats a few times for other similar cases .. ]
It is true that a non-zero argument is somewhat dangerous, and we do not
actually have very many uses of that in the kernel - but the ftrace code
does use it, and as Stephen Rostedt says:
"We are well aware of the danger of using __builtin_return_address() of
> 0. In fact that's part of the reason for having the "thunk" code in
x86 (See arch/x86/entry/thunk_{64,32}.S). [..] it adds extra frames
when tracking irqs off sections, to prevent __builtin_return_address()
from accessing bad areas. In fact the thunk_32.S states: 'Trampoline to
trace irqs off. (otherwise CALLER_ADDR1 might crash)'."
For now, __builtin_return_address() with a non-zero argument is the best
we can do, and the warning is not helpful and can end up making people
miss other warnings for real problems.
So disable the frame-address warning on compilers that need it.
