* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
kbuild: add ARCH=sparc32 target
sparc32: fix build failure on CONFIG_SPARC_LEON
sparc: Fixed random SPARC/LEON SMP CPU Stuck problem.
sparc32: remove CONFIG_HAVE_PERF_EVENTS option
sparc: don't #include asm/system.h in asm/jump_label.h
sparc32: Fix unaligned stack handling on trap return.
sparc: keep calling do_signal() as long as pending signals remain
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
initramfs: Fix build break on symbol-prefixed archs
initramfs: fix initramfs size calculation
initramfs: generalize initramfs_data.xxx.S variants
scripts/kallsyms: Enable error messages while hush up unnecessary warnings
scripts/setlocalversion: update comment
kbuild: Use a single clean rule for kernel and external modules
kbuild: Do not run make clean in $(srctree)
scripts/mod/modpost.c: fix commentary accordingly to last changes
kbuild: Really don't clean bounds.h and asm-offsets.h
Add 'sparc32' ARCH target to test all{yes,mod}config for 32-bit build.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (278 commits)
arm: remove machine_desc.io_pg_offst and .phys_io
arm: use addruart macro to establish debug mappings
arm: return both physical and virtual addresses from addruart
arm/debug: consolidate addruart macros for CONFIG_DEBUG_ICEDCC
ARM: make struct machine_desc definition coherent with its comment
eukrea_mbimxsd-baseboard: Pass the correct GPIO to gpio_free
cpuimx27: fix compile when ULPI is selected
mach-pcm037_eet: fix compile errors
Fixing ethernet driver compilation error for i.MX31 ADS board
cpuimx51: update board support
mx5: add cpuimx51sd module and its baseboard
iomux-mx51: fix GPIO_1_xx 's IOMUX configuration
imx-esdhc: update devices registration
mx51: add resources for SD/MMC on i.MX51
iomux-mx51: fix SD1 and SD2's iomux configuration
clock-mx51: rename CLOCK1 to CLOCK_CCGR for better readability
clock-mx51: factorize clk_set_parent and clk_get_rate
eukrea_mbimxsd: add support for DVI displays
cpuimx25 & cpuimx35: fix OTG port registration in host mode
i.MX31 and i.MX35 : fix errate TLSbo65953 and ENGcm09472
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits)
tracing: Fix compile issue for trace_sched_wakeup.c
[S390] hardirq: remove pointless header file includes
[IA64] Move local_softirq_pending() definition
perf, powerpc: Fix power_pmu_event_init to not use event->ctx
ftrace: Remove recursion between recordmcount and scripts/mod/empty
jump_label: Add COND_STMT(), reducer wrappery
perf: Optimize sw events
perf: Use jump_labels to optimize the scheduler hooks
jump_label: Add atomic_t interface
jump_label: Use more consistent naming
perf, hw_breakpoint: Fix crash in hw_breakpoint creation
perf: Find task before event alloc
perf: Fix task refcount bugs
perf: Fix group moving
irq_work: Add generic hardirq context callbacks
perf_events: Fix transaction recovery in group_sched_in()
perf_events: Fix bogus AMD64 generic TLB events
perf_events: Fix bogus context time tracking
tracing: Remove parent recording in latency tracer graph options
tracing: Use one prologue for the preempt irqs off tracer function tracers
'st-ux' and 'unwind' into devel
The config option used by archs to let the build system know that
the C version of the recordmcount works for said arch is currently
called HAVE_C_MCOUNT_RECORD which enables BUILD_C_RECORDMCOUNT. To
be more consistent with the name that all archs may use, it has been
renamed to HAVE_C_RECORDMCOUNT. This will be less confusing since
we are building a C recordmcount and not a mcount_record.
Suggested-by: Ingo Molnar <mingo@elte.hu>
Cc: <linux-arch@vger.kernel.org>
Cc: Michal Marek <mmarek@suse.cz>
Cc: linux-kbuild@vger.kernel.org
Cc: John Reiser <jreiser@bitwagon.com>
This patch adds the support for the C version of recordmcount and
compile times show ~ 12% improvement.
After verifying this works, other archs can add:
in its Kconfig and it will use the C version of recordmcount
instead of the perl version.
arch/x86/kernel/module.c
Merge reason: Resolve the conflict, pick up fixes.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
base patch to implement 'jump labeling'. Based on a new 'asm goto' inline
assembly gcc mechanism, we can now branch to labels from an 'asm goto'
statment. This allows us to create a 'no-op' fastpath, which can subsequently
be patched with a jump to the slowpath code. This is useful for code which
might be rarely used, but which we'd like to be able to call, if needed.
Tracepoints are the current usecase that these are being implemented for.
Signed-off-by: Jason Baron <jbaron@redhat.com>
LKML-Reference: <ee8b3595967989fdaf84e698dc7447d315ce972a.1284733808.git.jbaron@redhat.com>
[ cleaned up some formating ]
The list of patterns for the external modules case was constantly
lagging behind.
With current gcc, compiling with both -pg and -fomit-frame-pointer is
not allowed. However, -pg can be used to build without actually
specifying -fno-omit-frame-pointer, upon which the default behaviour
for the target will be used.
On ARM, it is not possible to build a Thumb-2 kernel with
-fno-omit-frame-pointer (FRAME_POINTERS depends on !THUMB2_KERNEL). In
order to support ftrace for Thumb-2, we need to be able to allow a
combination of FUNCTION_TRACER and !FRAME_POINTER. We do this by
omitting -fomit-frame-pointer if ftrace is enabled.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Signed-off-by: Rabin Vincent <rabin@rab.in>
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
setlocalversion: Ignote SCMs above the linux source tree
makefile: not need to regenerate kernel.release file when make kernelrelease
fixes for using make 3.82
kconfig: fix segfault when detecting recursive dependency
kconfig: fix savedefconfig with choice marked optional
Brice reported that 'kernelrelease' has a dependence on include/config/kernel.release,
causes this file to be regenerated every time when invoke it. It doesn't have to.
Reported-by: Brice Goglin <Brice.Goglin@inria.fr>
Tested-by: Brice Goglin <Brice.Goglin@inria.fr>
Signed-off-by: WANG Cong <amwang@redhat.com>
setlocalversion: fix version for untaged nontip mercurial revs
Fix CONFIG_CROSS_COMPILE issue in .config
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
scripts/dtc: Fix a resource leak
Documentation: fix ubuntu distro name
MAINTAINERS: Update kbuild git URLs
Add support for the C variable in the coccicheck script
Add scripts/coccinelle/deref_null.cocci
Add scripts/coccinelle/err_cast.cocci
Add scripts/coccinelle/resource_size.cocci
Add scripts/coccinelle/alloc/kzalloc-simple.cocci
Add scripts/coccinelle/alloc/drop_kmalloc_cast.cocci
Add Documentation/coccinelle.txt
Add a target to use the Coccinelle checker
scripts: decodecode: remove bashisms
Makefile: clarify a comment
checkkconfigsymbols.sh: Kconfig symbols sometimes have lowercase letters
scripts: add nconf into gitignore file
arch/powerpc/Makefile
It is now possible to assign options to AS and CC
on the command line - which is only used for built-in code.
{A,C}FLAGS_KERNEL was used both in the top-level Makefile
in the arch makefiles, thus users had no way to specify
additional options to AS, CC without overriding
the original value.
Introduce a new set of variables KBUILD_{A,C}FLAGS_KERNEL
that is used by arch specific files and free up
{A,C}FLAGS_KERNEL so they can be assigned on
the command line.
All arch Makefiles that used the old variables has been updated.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Hirokazu Takata <takata@linux-m32r.org>
It is now possible to assign options to AS, CC and LD
on the command line - which is only used when building modules.
{A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile
additional options to AS, CC, LD when building modules
without overriding the original value.
Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE
{A,C,LD}FLAGS_MODULE so they can be assigned on
the command line.
Note: Previously we had a MODFLAGS variable for both
AS and CC. But in favour of consistency this was dropped.
So in some cases arch Makefile has one assignmnet replaced by
two assignmnets.
Note2: MODFLAGS was not documented and is dropped
without any notice. I do not expect much/any breakage
from this.
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32]
tools/perf/Makefile
tools/perf/util/hist.c
Merge reason: Resolve the conflicts and update to latest upstream.
Merge reason: Pick up the latest perf fixes.
Newer gcc has a -femit-struct-debug-baseonly option that dramatically
reduces the size of object files with debug info. What it does
is to only emit type information for structures when the structures
are defined in the same file or in a header file.
This means the type information for most headers are not included.
This is not good when the type information is actually
needed (e.g. with kgdb or systemtap)
But often kernel hackers only care about line numbers and don't
need all the type information anyways. In this case setting
the option can be a big win:
A build dir for a specific x86-64 configuration with gcc 4.5
shrunk from 2.3G to 1.2G. The compilation was also nearly a minute
faster.
[mmarek: reformatted help text]
