path: root/Makefile
2014-09-05Linux 3.16.2v3.16.2Greg Kroah-Hartman
2014-08-14Linux 3.16.1v3.16.1Greg Kroah-Hartman
2014-08-03Linux 3.16v3.16Linus Torvalds
2014-07-27Linux 3.16-rc7v3.16-rc7Linus Torvalds
2014-07-26Fix gcc-4.9.0 miscompilation of load_balance() in schedulerLinus Torvalds
Michel Dänzer and a couple of other people reported inexplicable random oopses in the scheduler, and the cause turns out to be gcc mis-compiling the load_balance() function when debugging is enabled. The gcc bug apparently goes back to gcc-4.5, but slight optimization changes means that it now showed up as a problem in 4.9.0 and 4.9.1. The instruction scheduling problem causes gcc to schedule a spill operation to before the stack frame has been created, which in turn can corrupt the spilled value if an interrupt comes in. There may be other effects of this bug too, but that's the code generation problem seen in Michel's case. This is fixed in current gcc HEAD, but the workaround as suggested by Markus Trippelsdorf is pretty simple: use -fno-var-tracking-assignments when compiling the kernel, which disables the gcc code that causes the problem. This can result in slightly worse debug information for variable accesses, but that is infinitely preferable to actual code generation problems. Doing this unconditionally (not just for CONFIG_DEBUG_INFO) also allows non-debug builds to verify that the debug build would be identical: we can do export GCC_COMPARE_DEBUG=1 to make gcc internally verify that the result of the build is independent of the "-g" flag (it will make the compiler build everything twice, toggling the debug flag, and compare the results). Without the "-fno-var-tracking-assignments" option, the build would fail (even with 4.8.3 that didn't show the actual stack frame bug) with a gcc compare failure. See also gcc bugzilla: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=61801 Reported-by: Michel Dänzer <michel@daenzer.net> Suggested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Jakub Jelinek <jakub@redhat.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-20Linux 3.16-rc6v3.16-rc6Linus Torvalds
2014-07-13Linux 3.16-rc5v3.16-rc5Linus Torvalds
2014-07-10Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fixes from Michal Marek: "Three more fixes for the relative build dir feature: - Shut up make -s again - Fix for rpm/deb/tar-pkg with O=<subdir> - Fix for CONFIG_EXTRA_FIRMWARE" * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: firmware: Create directories for external firmware kbuild: Fix packaging targets with relative $(srctree) kbuild: Do not print the build directory with make -s
2014-07-06Linux 3.16-rc4v3.16-rc4Linus Torvalds
2014-07-04kbuild: Fix packaging targets with relative $(srctree)Michal Marek
All other users of Makefile.build set $(obj) to the name of the subdirectory to build. Do the same for the packaging targets, otherwise the build fails if $(srctree) is a relative directory: $ make O=build tar-pkg make[1]: Entering directory `/home/mmarek/linux-2.6/build' CHK include/config/kernel.release ../scripts/Makefile.build:44: ../../scripts/package/Makefile: No such file or directory make[2]: *** No rule to make target `../../scripts/package/Makefile'. Stop. Fixes: 9da0763b ("kbuild: Use relative path when building in a subdir of the source tree") Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-04kbuild: Do not print the build directory with make -sMichal Marek
Commit c2e28dc9 (kbuild: Print the name of the build directory) prints the name of the build directory for O= builds, but we should not be doing this in make -s mode, so that commands like make -s O=<dir> kernelrelease can be used by scripts. This matches the behavior of make itself, where the -s option implies --no-print-directory. Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-03Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fix from Michal Marek: "There is one more fix for the relative paths series from -rc1: Print the path to the build directory at the start of the build, so that editors and IDEs can match the relative paths to source files" * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Print the name of the build directory
2014-07-03kbuild: Print the name of the build directoryMichal Marek
With commit 9da0763b (kbuild: Use relative path when building in a subdir of the source tree), the compiler messages include relative paths. These are however relative to the build directory, not the directory where make was started. Print the "Entering directory ..." message once, so that IDEs/editors can find the source files. Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-29Linux 3.16-rc3v3.16-rc3Linus Torvalds
2014-06-21Linux 3.16-rc2v3.16-rc2Linus Torvalds
2014-06-15Linux 3.16-rc1v3.16-rc1Linus Torvalds
2014-06-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: "Kbuild changes for v3.16-rc1: - cross-compilation fix so that cc-option is testing the right compiler - Fix for make defconfig all - Using relative paths to the object and source directory where possible, plus fixes for the fallout of the change - several cleanups in the Makefiles and scripts The powerpc fix is from today, because it was only discovered recently. The rest has been in linux-next for some time" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: powerpc: Avoid circular dependency with zImage.% kbuild: create include/config directory in scripts/kconfig/Makefile kbuild: do not create include/linux directory Makefile: Fix unrecognized cross-compiler command line options kbuild: do not add "selinux" to subdir- twice um: Fix for relative objtree when generating x86 headers kbuild: Use relative path when building in a subdir of the source tree kbuild: Use relative path when building in the source tree kbuild: Use relative path for $(objtree) firmware: Use $(quote) in the Makefile firmware: Simplify directory creation kbuild: trivial - fix comment block indent kbuild: trivial - remove trailing spaces kbuild: support simultaneous "make %config" and "make all" kbuild: move extra gcc checks to scripts/Makefile.extrawarn
2014-06-10kbuild: create include/config directory in scripts/kconfig/MakefileMasahiro Yamada
The directory include/config is used only for silentoldconfig, localmodconfig, localyesconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-10kbuild: do not create include/linux directoryMasahiro Yamada
There are no generated files under include/linux directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-09Makefile: Fix unrecognized cross-compiler command line optionsGeert Uytterhoeven
On architectures that setup CROSS_COMPILE in their arch/*/Makefile (arc, blackfin, m68k, mips, parisc, score, sh, tile, unicore32, xtensa), cc-option and cc-disable-warning may check against the wrong compiler, causing errors like cc1: error: unrecognized command line option "-Wno-maybe-uninitialized" if the host gcc supports a compiler option, while the cross compiler doesn't support that option. Move all logic using cc-option or cc-disable-warning below the inclusion of the arch's Makefile to fix this. Introduced by - commit e74fc973b6e531fef1fce8b101ffff05ecfb774c ("Turn off -Wmaybe-uninitialized when building with -Os"), - commit 61163efae02040f66a95c8ed17f4407951ba58fa ("kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang"). As -Wno-maybe-uninitialized requires a quite recent gcc (gcc 4.6.3 on Ubuntu 12.04 LTS doesn't support it), this only showed up recently (gcc 4.8.2 on Ubuntu 14.04 LTS does support it). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-08Merge tag 'llvmlinux-for-v3.16' of ↵Linus Torvalds
git://git.linuxfoundation.org/llvmlinux/kernel Pull LLVM patches from Behan Webster: "Next set of patches to support compiling the kernel with clang. They've been soaking in linux-next since the last merge window. More still in the works for the next merge window..." * tag 'llvmlinux-for-v3.16' of git://git.linuxfoundation.org/llvmlinux/kernel: arm, unwind, LLVMLinux: Enable clang to be used for unwinding the stack ARM: LLVMLinux: Change "extern inline" to "static inline" in glue-cache.h all: LLVMLinux: Change DWARF flag to support gcc and clang net: netfilter: LLVMLinux: vlais-netfilter crypto: LLVMLinux: aligned-attribute.patch
2014-06-08Linux 3.15v3.15Linus Torvalds
2014-06-07all: LLVMLinux: Change DWARF flag to support gcc and clangBehan Webster
Both gcc (well, actually gnu as) and clang support the "-Wa,-gdwarf-2" option (though clang does not support "-Wa,--gdwarf-2"). Since these flags are equivalent in meaning, this patch uses the one which is better supported across compilers. Signed-off-by: Behan Webster <behanw@converseincode.com>
2014-06-01Linux 3.15-rc8v3.15-rc8Linus Torvalds
2014-05-25Linux 3.15-rc7v3.15-rc7Linus Torvalds
2014-05-22Linux 3.15-rc6v3.15-rc6Linus Torvalds
2014-05-14kbuild: Use relative path when building in a subdir of the source treeMichal Marek
When doing make O=<subdir>, use '..' to refer to the source tree. This allows for more readable compiler messages, and, more importantly, it sets the VPATH to '..', so filenames in WARN_ON() etc. will be shorter. Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-05-14kbuild: Use relative path when building in the source treeMichal Marek
When not using O=, $(srctree) refers to the same directory as $(objtree), so we can set it to '.' as well. This makes the default include path more compact and results in more readable messages from the compiler. The only case where we need the absolute path is when creating the 'source' symlink in /lib/modules. Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-05-14kbuild: Use relative path for $(objtree)Michal Marek
The main Makefile sets its working directory to the object tree and never changes it again. Therefore, we can use '.' instead of the absolute path. The only case where we need the absolute path is when creating the 'build' symlink in /lib/modules. Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-05-09Linux 3.15-rc5v3.15-rc5Linus Torvalds
2014-05-04Linux 3.15-rc4v3.15-rc4Linus Torvalds
2014-04-30kbuild: trivial - fix comment block indentMasahiro Yamada
2014-04-30kbuild: trivial - remove trailing spacesMasahiro Yamada
2014-04-30kbuild: support simultaneous "make %config" and "make all"Masahiro Yamada
Kbuild is supposed to support mixed targets. (%config and build targets) But "make all" did nothing if it was run with configuration targets. For example, $ LANG=C make defconfig all HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o SHIPPED scripts/kconfig/zconf.tab.c SHIPPED scripts/kconfig/zconf.lex.c SHIPPED scripts/kconfig/zconf.hash.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf *** Default configuration is based on 'x86_64_defconfig' # # configuration written to .config # make: Nothing to be done for `all'. This commits allows "make %config all" and makes sure mixed targets are built one by one in the given order. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Marek <mmarek@suse.cz> CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-27Linux 3.15-rc3v3.15-rc3Linus Torvalds
2014-04-20Linux 3.15-rc2v3.15-rc2Linus Torvalds
2014-04-16kbuild: move extra gcc checks to scripts/Makefile.extrawarnMasahiro Yamada
W=... provides extra gcc checks. Having such code in scripts/Makefile.build results in the same flags being added to KBUILD_CFLAGS multiple times becuase scripts/Makefile.build is invoked every time Kbuild descends into the subdirectories. Since the top Makefile is already too cluttered, this commit moves all of extra gcc check stuff to a new file scripts/Makefile.extrawarn, which is included from the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-13Linux 3.15-rc1v3.15-rc1Linus Torvalds
2014-04-12Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild changes from Michal Marek: "Here is the non-critical part of kbuild: - One bogus coccinelle check removed, one check fixed not to suggest the obsolete PTR_RET macro - scripts/tags.sh does not index the generated *.mod.c files - new objdiff tool to list differences between two versions of an object file - A fix for scripts/bootgraph.pl" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/coccinelle: Use PTR_ERR_OR_ZERO scripts/bootgraph.pl: Add graphic header scripts: objdiff: detect object code changes between two commits Coccicheck: Remove memcpy to struct assignment test scripts/tags.sh: Ignore *.mod.c
2014-04-09kbuild: LLVMLinux: Add Kbuild support for building kernel with ClangBehan Webster
Add support to toplevel Makefile for compiling with clang, both for HOSTCC and CC. Use cc-option to prevent gcc option from breaking clang, and from clang options from breaking gcc. Clang 3.4 semantics are the same as gcc semantics for unsupported flags. For unsupported warnings clang 3.4 returns true but shows a warning and gcc shows a warning and returns false. Signed-off-by: Behan Webster <behanw@converseincode.com> Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de> Signed-off-by: Mark Charlebois <charlebm@gmail.com> Cc: PaX Team <pageexec@freemail.hu>
2014-04-08scripts: objdiff: detect object code changes between two commitsJason Cooper
objdiff is useful when doing large code cleanups. For example, when removing checkpatch warnings and errors from new drivers in the staging tree. objdiff can be used in conjunction with a git rebase to confirm that each commit made no changes to the resulting object code. It has the same return values as diff(1). This was written specifically to support adding the skein and threefish cryto drivers to the staging tree. I needed a programmatic way to confirm that commits changing >90% of the lines didn't inadvertently change the code. Temporary files (objdump output) are stored in /path/to/linux/.tmp_objdiff 'make mrproper' will remove this directory. Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-07Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - cleanups in the main Makefiles and Documentation/DocBook/Makefile - make O=... directory is automatically created if needed - mrproper/distclean removes the old include/linux/version.h to make life easier when bisecting across the commit that moved the version.h file * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: docbook: fix the include error when executing "make help" kbuild: create a build directory automatically for out-of-tree build kbuild: remove redundant '.*.cmd' pattern from make distclean kbuild: move "quote" to Kbuild.include to be consistent kbuild: docbook: use $(obj) and $(src) rather than specific path kbuild: unconditionally clobber include/linux/version.h on distclean kbuild: docbook: specify KERNELDOC dependency correctly kbuild: docbook: include cmd files more simply kbuild: specify build_docproc as a phony target
2014-04-02Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull devicetree changes from Grant Likely: "Updates to devicetree core code. This branch contains the following notable changes: - add reserved memory binding - make struct device_node a kobject and remove legacy /proc/device-tree - ePAPR conformance fixes - update in-kernel DTC copy to version v1.4.0 - preparatory changes for dynamic device tree overlays - minor bug fixes and documentation changes The most significant change in this branch is the conversion of struct device_node to be a kobject that is exposed via sysfs and removal of the old /proc/device-tree code. This simplifies the device tree handling code and tightens up the lifecycle on device tree nodes. [updated: added fix for dangling select PROC_DEVICETREE]" * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux: (29 commits) dt: Remove dangling "select PROC_DEVICETREE" of: Add support for ePAPR "stdout-path" property of: device_node kobject lifecycle fixes of: only scan for reserved mem when fdt present powerpc: add support for reserved memory defined by device tree arm64: add support for reserved memory defined by device tree of: add missing major vendors of: add vendor prefix for SMSC of: remove /proc/device-tree of/selftest: Add self tests for manipulation of properties of: Make device nodes kobjects so they show up in sysfs arm: add support for reserved memory defined by device tree drivers: of: add support for custom reserved memory drivers drivers: of: add initialization code for dynamic reserved memory drivers: of: add initialization code for static reserved memory of: document bindings for reserved-memory nodes Revert "of: fix of_update_property()" kbuild: dtbs_install: new make target ARM: mvebu: Allows to get the SoC ID even without PCI enabled of: Allows to use the PCI translator without the PCI core ...
2014-03-31kbuild: create a build directory automatically for out-of-tree buildMasahiro Yamada
Kbuild supports saving output files in a separate directory. But the build directory must be created beforehand. For example, $ mkdir -p dir/to/store/output/files $ make O=dir/to/store/output/files defconfig Creating a build directory automatically would be useful. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-03-31kbuild: remove redundant '.*.cmd' pattern from make distcleanMasahiro Yamada
'.*.cmd' files are cleaned-up by "make clean". The same pattern in "make distclean" is unnecessary. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-03-31Merge remote-tracking branch 'robh/for-next' into devicetree/nextGrant Likely
2014-03-30Linux 3.14v3.14Linus Torvalds
2014-03-29kbuild: unconditionally clobber include/linux/version.h on distcleanPaul Gortmaker
As of v3.7, the UAPI changes relocated headers around such that the kernel version header lived in a new place. If a person is bisecting and if you go back to pre-UAPI days, you will create an include/linux/version.h -- then if you checkout a post-UAPI kernel, and even run "make distclean" it still won't delete that old version file. So you get a situation like this: $ grep -R LINUX_VERSION_CODE include/ include/generated/uapi/linux/version.h:#define LINUX_VERSION_CODE 200192 include/linux/version.h:#define LINUX_VERSION_CODE 132646 The value in that second line is representative of a v2.6.38 version. And it will be sourced/used, hence leading to strange behaviours, such as drivers/staging content (which typically hasn't been purged of version ifdefs) failing to build. Since it is a subtle mode of failure, lets always clobber the old file when doing a distclean. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-03-24Linux 3.14-rc8v3.14-rc8Linus Torvalds
2014-03-16Linux 3.14-rc7v3.14-rc7Linus Torvalds
