.. with new name. Because nothing says "really solid kernel release"
like naming it after an extinct animal that just happened to be in the
news lately.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: append missing-syscalls to the default target list
genksyms: Regenerate lexer and parser
genksyms: Do not expand internal types
genksyms: Minor parser cleanup
Makefile: remove a duplicated line
fixdep: fix extraneous dependencies
scripts/Makefile.build: do not reference EXTRA_CFLAGS as CFLAGS replacement
kbuild: prevent make from deleting _shipped files
kbuild: Do not delete empty files in make distclean
This avoid an extra make invocation on `prepare0'.
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
There are two duplicated lines for 'make RECORDMCOUNT_WARN=1 [targets]'
in 'make help', remove the second one.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Commit 3d64b44 introduced an empty file under
arch/arm/mach-zynq/board_dt.c. While this was not intended and the file
was removed from the tree by a later commit, we really should only match
junk files by known name patterns and not their size.
Reported-by: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits)
kconfig: Introduce IS_ENABLED(), IS_BUILTIN() and IS_MODULE()
xconfig: Abort close if configuration cannot be saved
kconfig: fix missing "0x" prefix from S_HEX symbol in autoconf.h
kconfig/nconf: remove useless conditionnal
kconfig/nconf: prevent segfault on empty menu
kconfig/nconf: use the generic menu_get_ext_help()
nconfig: Avoid Wunused-but-set warning
kconfig/conf: mark xfgets() private
kconfig: remove pending prototypes for kconfig_load()
kconfig/conf: add command line options' description
kconfig/conf: reduce the scope of `defconfig_file'
kconfig: use calloc() for expr allocation
kconfig: introduce specialized printer
kconfig: do not overwrite symbol direct dependency in assignment
kconfig/gconf: silent missing prototype warnings
kconfig/gconf: kill deadcode
kconfig: nuke LKC_DIRECT_LINK cruft
kconfig: nuke reference to SWIG
kconfig: add missing <stdlib.h> inclusion
kconfig: add missing <ctype.h> inclusion
Fix up conflicts in scripts/kconfig/Makefile
Replace the config_is_*() macros with a variant that allows for grepping
for usage of CONFIG_* options in the code. Usage:
if (IS_ENABLED(CONFIG_NUMA))
or
#if IS_ENABLED(CONFIG_NUMA)
The IS_ENABLED() macro evaluates to 1 if the argument is set (to either 'y'
or 'm'), IS_BUILTIN() tests if the option is 'y' and IS_MODULE() test if
the option is 'm'. Only boolean and tristate options are supported.
Reviewed-by: Arnaud Lacombe <lacombar@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits)
perf: Remove the nmi parameter from the oprofile_perf backend
x86, perf: Make copy_from_user_nmi() a library function
perf: Remove perf_event_attr::type check
x86, perf: P4 PMU - Fix typos in comments and style cleanup
perf tools: Make test use the preset debugfs path
perf tools: Add automated tests for events parsing
perf tools: De-opt the parse_events function
perf script: Fix display of IP address for non-callchain path
perf tools: Fix endian conversion reading event attr from file header
perf tools: Add missing 'node' alias to the hw_cache[] array
perf probe: Support adding probes on offline kernel modules
perf probe: Add probed module in front of function
perf probe: Introduce debuginfo to encapsulate dwarf information
perf-probe: Move dwarf library routines to dwarf-aux.{c, h}
perf probe: Remove redundant dwarf functions
perf probe: Move strtailcmp to string.c
perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END
tracing/kprobe: Update symbol reference when loading module
tracing/kprobes: Support module init function probing
kprobes: Return -ENOENT if probe point doesn't exist
Merge reason: Pick up the latest fixes.
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: Call depmod.sh via shell
perf: clear out make flags when calling kernel make kernelver
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
Makefile
The script has the executable bit in git, but plain old patch(1) can't
create executable files.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
perf: Use make kernelversion instead of parsing the Makefile
kbuild: Hack for depmod not handling X.Y versions
kbuild: Move depmod call to a separate script
kbuild: Fix <linux/version.h> for empty SUBLEVEL or PATCHLEVEL
kbuild: Fix KERNELVERSION for empty SUBLEVEL or PATCHLEVEL
kbuild: silence Nothing to be done for 'all' message
Do not bloat the Makefile with multiline shell statements. No
user-visible change intended.
expr treats all numbers as decimals, so prepending a zero is safe. Note
that the KERNEL_VERSION() macro still takes three arguments, 3.0 has to be
written as KERNEL_VERSION(3,0,0).
