path: root/Makefile
2013-11-29Linux 3.13-rc2v3.13-rc2Linus Torvalds
2013-11-22Linux 3.13-rc1v3.13-rc1Linus Torvalds
2013-11-15Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - LTO fixes, but the kallsyms part had to be reverted - Pass -Werror=implicit-int and -Werror=strict-prototypes to the compiler by default - snprintf fix in modpost - remove GREP_OPTIONS from the environment to be immune against exotic grep option settings * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kallsyms: Revert back to 128 max symbol length Kbuild: Ignore GREP_OPTIONS env variable scripts: kallsyms: Use %zu to print 'size_t' scripts/bloat-o-meter: use .startswith rather than fragile slicing scripts/bloat-o-meter: ignore changes in the size of linux_banner kbuild: replace unbounded sprintf call in modpost kbuild, bloat-o-meter: fix static detection Kbuild: Handle longer symbols in kallsyms.c kbuild: Increase kallsyms max symbol length Makefile: enable -Werror=implicit-int and -Werror=strict-prototypes by default
2013-11-13./Makefile: export initial ramdisk compression config optionP J P
Make menuconfig allows one to choose compression format of an initial ramdisk image. But this choice does not result in duly compressed ramdisk image. Because - $ make install - does not pass on the selected compression choice to the dracut(8) tool, which creates the initramfs file. dracut(8) generates the image with the default compression, ie. gzip(1). This patch exports the selected compression option to a sub-shell environment, so that it could be used by dracut(8) tool to generate appropriately compressed initramfs images. There isn't a straightforward way to pass on options to dracut(8) via positional parameters. Because it is indirectly invoked at the end of a $ make install sequence. # make install -> arch/$arch/boot/Makefile -> arch/$arch/boot/install.sh -> /sbing/installkernel ... -> /sbin/new-kernel-pkg ... -> /sbin/dracut ... Signed-off-by: P J P <ppandit@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-11Kbuild: Ignore GREP_OPTIONS env variableBorislav Petkov
When building the kernel in a shell which defines GREP_OPTIONS so that grep behavior is modified, we can break the generation of the syscalls table like so: __SYSCALL_COMMON(^[[01;31m^[[K0^[[m^[[K, sys_read, sys_read) __SYSCALL_COMMON(^[[01;31m^[[K1^[[m^[[K, sys_write, sys_write) __SYSCALL_COMMON(^[[01;31m^[[K1^[[m^[[K0, sys_mprotect, sys_mprotect) ... This is just the initial breakage, later we barf when generating modules. In this case, GREP_OPTIONS contains "--color=always" which adds the shell colors markup and completely fudges the headers under ...generated/asm/. Fix that by unexporting the GREP_OPTIONS variable for the whole kernel build as we tend to use grep at a bunch of places. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-11-03Linux 3.12v3.12Linus Torvalds
2013-10-27Linux 3.12-rc7v3.12-rc7Linus Torvalds
2013-10-23Makefile: enable -Werror=implicit-int and -Werror=strict-prototypes by defaultSergei Trofimovich
The common error found in forward-ported/backported patches is missing headers. One recent example (files and function names are mangled): void foo(){} EXPORT_SYMBOL(foo); gave only warning foo.c:12345678:5: warning: function declaration isn't a prototype [-Wstrict-prototypes] void foo(){} ^ foo.c:12345679:5: warning: data definition has no type or storage class [enabled by default] EXPORT_SYMBOL(foo); foo.c:12345679:5: warning: type defaults to 'int' in declaration of 'EXORT_SYMBOL' [-Werror=implicit-int] Now it's a fatal error. Tested on x86_64 allyesconfig. [akpm@linux-foundation.org: fix typos in comments] Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-10-19Linux 3.12-rc6v3.12-rc6Linus Torvalds
2013-10-13Linux 3.12-rc5v3.12-rc5Linus Torvalds
2013-10-06Linux 3.12-rc4v3.12-rc4Linus Torvalds
2013-09-29Linux 3.12-rc3v3.12-rc3Linus Torvalds
2013-09-23Linux 3.12-rc2v3.12-rc2Linus Torvalds
2013-09-16Linux 3.12-rc1v3.12-rc1Linus Torvalds
2013-09-11Bye, bye, WfW flagLinus Torvalds
This reverts the Linux for Workgroups thing. And no, before somebody asks, we're not doing Linux95. Not for a few years, at least. Sure, the flag added some color to the logo, and could have remained as a testament to my leet gimp skills. But no. And I'll do this early, to avoid the chance of forgetting when I'm doing the actual rc1 release on the road. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-07Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild update from Michal Marek: "Only these two commits are in the kbuild branch this time: - Using filechk for include/config/kernel.release - Cleanup in scripts/sortextable.c" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Do not overwrite include/config/kernel.release needlessly scripts: remove unused function in sortextable.c
2013-09-02Linux 3.11v3.11Linus Torvalds
2013-08-28kbuild: Do not overwrite include/config/kernel.release needlesslyMichal Marek
Use filechk to detect if the content changed or not. Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-08-25Linux 3.11-rc7v3.11-rc7Linus Torvalds
2013-08-18Linux 3.11-rc6v3.11-rc6Linus Torvalds
2013-08-11Linux 3.11-rc5v3.11-rc5Linus Torvalds
2013-08-04Linux 3.11-rc4v3.11-rc4Linus Torvalds
2013-07-28Linux 3.11-rc3v3.11-rc3Linus Torvalds
2013-07-21Linux 3.11-rc2v3.11-rc2Linus Torvalds
2013-07-14Linux 3.11-rc1v3.11-rc1Linus Torvalds
2013-07-10Revert "Makefile: Fix install error with make -j option"Linus Torvalds
This reverts commit d2aae8477cd00325bb7c7c7e95be488088900c48. It is completely and utterly broken. Module install should not build any files, and adding broken dependencies to "help" it build files is complete and utter sh*t. The kernel should not be built by root, and "make install" and "make module_install" (that for obvious reasons need to be run as root) absolutely must not build any files. They should only ever copy the already-built files over. So having dependencies for the install targets is wrong, wrong, wrong. If you try to install a kernel without building it first, you *should* get errors. The build system shouldn't try to help root build the files. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - fix for make headers_install argv explosion with too long path - scripts/setlocalversion does not call git update-index needlessly - fix for the src.rpm produced by make rpm-pkg. The new make image_name can be useful also for other packaging tools. - scripts/mod/devicetable-offsets.o is not rebuilt during each make run - make modules_install dependency fix - scripts/sortextable portability fix - fix for kbuild to generate the output directory for all object files in subdirs. - a couple of minor fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: create directory for dir/file.o tools/include: use stdint types for user-space byteshift headers Makefile: Fix install error with make -j option Fix a build warning in scripts/mod/file2alias.c improve modalias building scripts/mod: Spelling s/DEVICEVTABLE/DEVICETABLE/ kbuild: fix error when building from src rpm scripts/setlocalversion on write-protected source tree Makefile.lib: align DTB quiet_cmd kbuild: fix make headers_install when path is too long
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-03Makefile: Fix install error with make -j optionRobert Richter
Make modules_install fails with -j option: DEPMOD Usage: .../.source/linux/scripts/depmod.sh /sbin/depmod <kernelrelease> make[1]: *** [_modinst_post] Error 1 Adding kernelrelease dependency to fix this. Signed-off-by: Robert Richter <robert.richter@calxeda.com> Cc: <stable@vger.kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-06-30Linux 3.10v3.10Linus Torvalds
2013-06-28treewide: relase -> releaseGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-06-24kbuild: fix error when building from src rpmMike Marciniszyn
The following issue can be reproduced with Linus' tree on an x86_64 server. >+ cp /home/user/rpmbuild-test/BUILDROOT/kernel-3.9.2.x86_64/boot/vmlinuz-3.9.2 >cp: missing destination file operand after >/home/user/rpmbuild-test/BUILDROOT/kernel-3.9.2-1.x86_64/boot/vmlinuz-3.9.2' >Try `cp --help' for more information. >error: Bad exit status from /var/tmp/rpm-tmp.R4o0iI (%install) Here are the commands to reproduce: make defconfig make rpm-pkg Use the resulting src rpm to build as follows: mkdir ~/rpmbuild-test cd ~/rpmbuild-test rpmbuild --rebuild --define "_topdir `pwd`" -vv ~/rpmbuild/SRPMS/kernel-3.10.0_rc1+-1.src.rpm The issue is because the %install script uses $KBUILD_IMAGE and it hasn't been set since it is only available in the kbuild system and not in the %install script. This patch adds a Makefile target to emit the image_name that can be used and modifies the mkspec to use the dynamic name in %install. Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-06-22Linux 3.10-rc7v3.10-rc7Linus Torvalds
2013-06-15Linux 3.10-rc6v3.10-rc6Linus Torvalds
2013-06-08Linux 3.10-rc5v3.10-rc5Linus Torvalds
2013-06-02Linux 3.10-rc4v3.10-rc4Linus Torvalds
2013-05-26Linux 3.10-rc3v3.10-rc3Linus Torvalds
2013-05-20Linux 3.10-rc2v3.10-rc2Linus Torvalds
2013-05-11Linux 3.10-rc1v3.10-rc1Linus Torvalds
2013-05-07Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "Non-critical kbuild changes: - make coccicheck improvements, but no new semantic patches this time - make rpm improvements - make tar-pkg change to include the architecture in the filename. This is a deliberate incompatibility, but nobody has complained so far and it is useful if you build for different architectures. It also matches what the deb-pkg and rpm-pkg targets produce. - kbuild documentation fix" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: rpm-pkg: Remove pointless set -e statements rpm-pkg: Always regenerate the specfile rpm-pkg: Do not write to the parent directory rpm-pkg: Do not package the whole source directory buildtar: Add ARCH to the archive name Coccinelle: Fix patch output when coccicheck is used with M= and C= Coccinelle: Add support to the SPFLAGS variable Coccinelle: Cleanup the setting of the FLAGS and OPTIONS variables Coccinelle: Restore coccicheck verbosity in ONLINE mode (C=1 or C=2) scripts/package/Makefile: compare objtree with srctree instead of test KBUILD_OUTPUT doc: change example to existing Makefile fragment scripts/tags.sh: Add magic for OFFSET and DEFINE
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-05-02Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC non-critical fixes from Olof Johansson: "Here is a collection of fixes (and some intermixed cleanups) that were considered less important and thus not included in the later parts of the 3.9-rc cycle. It's a bit all over the map, contents wise. A series of ux500 fixes and cleanups, a bunch of various fixes for OMAP and tegra, and some for Freescale i.MX and even Qualcomm MSM. Note that there's also a patch on this branch to globally turn off -Wmaybe-uninitialized when building with -Os. It's been posted several times by Arnd and no dissent was raised, but nobody seemed interested to pick it up. So here it is, as the topmost patch." * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) Turn off -Wmaybe-uninitialized when building with -Os ARM: orion5x: include linux/cpu.h ARM: tegra: call cpu_do_idle from C code ARM: u300: fix ages old copy/paste bug ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7 ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled ARM: tegra: fix build error when THUMB2_KERNEL enabled ARM: msm: Fix uncompess.h tx underrun check ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS" ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD" ARM: mach-imx: mach-imx6q: Fix sparse warnings ARM: mach-imx: src: Include "common.h ARM: mach-imx: gpc: Include "common.h" ARM: mach-imx: avic: Staticize *avic_base ARM: mach-imx: tzic: Staticize *tzic_base ARM: mach-imx: clk: Include "clk.h" ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops ...
2013-04-30Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Features: - Add "uretprobes" - an optimization to uprobes, like kretprobes are an optimization to kprobes. "perf probe -x file sym%return" now works like kretprobes. By Oleg Nesterov. - Introduce per core aggregation in 'perf stat', from Stephane Eranian. - Add memory profiling via PEBS, from Stephane Eranian. - Event group view for 'annotate' in --stdio, --tui and --gtk, from Namhyung Kim. - Add support for AMD NB and L2I "uncore" counters, by Jacob Shin. - Add Ivy Bridge-EP uncore support, by Zheng Yan - IBM zEnterprise EC12 oprofile support patchlet from Robert Richter. - Add perf test entries for checking breakpoint overflow signal handler issues, from Jiri Olsa. - Add perf test entry for for checking number of EXIT events, from Namhyung Kim. - Add perf test entries for checking --cpu in record and stat, from Jiri Olsa. - Introduce perf stat --repeat forever, from Frederik Deweerdt. - Add --no-demangle to report/top, from Namhyung Kim. - PowerPC fixes plus a couple of cleanups/optimizations in uprobes and trace_uprobes, by Oleg Nesterov. Various fixes and refactorings: - Fix dependency of the python binding wrt libtraceevent, from Naohiro Aota. - Simplify some perf_evlist methods and to allow 'stat' to share code with 'record' and 'trace', by Arnaldo Carvalho de Melo. - Remove dead code in related to libtraceevent integration, from Namhyung Kim. - Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf sched lat' back working, by Arnaldo Carvalho de Melo - We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho de Melo. - Kill a bunch of die() calls, from Namhyung Kim. - Fix build on non-glibc systems due to libio.h absence, from Cody P Schafer. - Remove some perf_session and tracing dead code, from David Ahern. - Honor parallel jobs, fix from Borislav Petkov - Introduce tools/lib/lk library, initially just removing duplication among tools/perf and tools/vm. from Borislav Petkov ... and many more I missed to list, see the shortlog and git log for more details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits) perf/x86/intel/P4: Robistify P4 PMU types perf/x86/amd: Fix AMD NB and L2I "uncore" support perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c perf/x86: Check all MSRs before passing hw check perf/x86/amd: Add support for AMD NB and L2I "uncore" counters perf/x86/intel: Add Ivy Bridge-EP uncore support perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management perf/x86: Avoid kfree() in CPU_{STARTING,DYING} uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit() uprobes/tracing: Change create_trace_uprobe() to support uretprobes uprobes/tracing: Make seq_printf() code uretprobe-friendly uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher() uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers uprobes/tracing: Generalize struct uprobe_trace_entry_head uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls uprobes/tracing: Kill the pointless seq_print_ip_sym() call uprobes/tracing: Kill the pointless task_pt_regs() calls ...
2013-04-29Turn off -Wmaybe-uninitialized when building with -OsArnd Bergmann
gcc-4.7 and higher add a lot of false positive warnings about potential uses of uninitialized warnings, but only when optimizing for size (-Os). This is the default when building allyesconfig, which turns on CONFIG_CC_OPTIMIZE_FOR_SIZE. In order to avoid getting a lot of patches that initialize such variables and accidentally hide real errors along the way, let's just turn off this warning on the respective gcc versions when building with size optimizations. The -Wmaybe-uninitialized option was introduced in the same gcc version (4.7) that is now causing the false positives, so there is no effect on older compilers. A side effect is that when building with CONFIG_CC_OPTIMIZE_FOR_SIZE, we might now see /fewer/ warnings about possibly uninitialized warnings than with -O2, but that is still much better than seeing warnings known to be bogus. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-04-28Linux 3.9v3.9Linus Torvalds
2013-04-21Linux 3.9-rc8v3.9-rc8Linus Torvalds
2013-04-21Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/cpu/perf_event_intel.c Merge in the latest fixes before applying new patches, resolve the conflict. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-18rpm-pkg: Do not package the whole source directoryMichal Marek
The source tree can contain lots of uninteresting data like tag or cscope files, packaging which slows down make rpm needlessly. It can also break the build, if the tree contains an unrelated file named *.spec. The downside of this change is that new subdirectories have to be added to the KBUILD_ALLDIRS variable in the top-level Makefile. The upside is that the behavior is more predictable. Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-16Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fix from Michal Marek: "Fix for a missing dependency when generating scripts/mod/devicetable-offsets.h. This dependency got introduced in v3.9-rc1." * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: generate generic headers before recursing into scripts
2013-04-14Linux 3.9-rc7v3.9-rc7Linus Torvalds
