According to Documentation/Changes, make 3.80 is still being supported
for building the kernel, hence make files must not make (unconditional)
use of features introduced only in newer versions. Commit 8779657d29c0
("stackprotector: Introduce CONFIG_CC_STACKPROTECTOR_STRONG") however
introduced an "else ifdef" construct which make 3.80 doesn't understand.
Also correct a warning message still referencing the old config option
name.
Apart from that I question the use of "ifdef" here (but it was used that
way already prior to said commit): ifeq (,y) would seem more to the
point.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Michal Marek <mmarek@suse.cz>
An extra parenthesis typo introduced in 19952a92037e ("stackprotector:
Unify the HAVE_CC_STACKPROTECTOR logic between architectures") is
causing the following error when CONFIG_CC_STACKPROTECTOR_REGULAR is
enabled:
Makefile:608: Cannot use CONFIG_CC_STACKPROTECTOR: -fstack-protector not supported by compiler
Makefile:608: *** missing separator. Stop.
Signed-off-by: Fathi Boudra <fathi.boudra@linaro.org>
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull __TIME__/__DATE__ removal from Michal Marek:
"This series by Josh finishes the removal of __DATE__ and __TIME__ from
the kernel. The last patch adds -Werror=date-time to KBUILD_CFLAGS to
stop these from reappearing.
Part of the series went through Greg's trees during this merge window,
which is why this pull request is not based on v3.13-rc1"
* 'drop-time' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Makefile: Build with -Werror=date-time if the compiler supports it
x86: math-emu: Drop already-disabled print of build date
net: wireless: brcm80211: Drop debug version with build date/time
mtd: denali: Drop print of build date/time
Pull kbuild changes from Michal Marek:
- fix make -s detection with make-4.0
- fix for scripts/setlocalversion when the kernel repository is a
submodule
- do not hardcode ';' in macros that expand to assembler code, as some
architectures' assemblers use a different character for newline
- Fix passing --gdwarf-2 to the assembler
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
frv: Remove redundant debugging info flag
mn10300: Remove redundant debugging info flag
kbuild: Fix debugging info generation for .S files
arch: use ASM_NL instead of ';' for assembler new line character in the macro
kbuild: Fix silent builds with make-4
Fix detectition of kernel git repository in setlocalversion script [take #2]
GCC 4.9 and newer have a new warning -Wdate-time, which warns on any use
of __DATE__, __TIME__, or __TIMESTAMP__, which would make the build
non-deterministic. Now that the kernel does not use any of those
macros, turn on -Werror=date-time if available, to keep it that way.
The kernel already (optionally) records this information at build time
in a single place; other kernel code should not duplicate that.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Change the debuging info generation flag in KBUILD_AFLAGS from '-gdwarf-2' to
'-Wa,--gdwarf-2'. This will properly generate the debugging info for .S files
when CONFIG_DEBUG_INFO=y.
It seems current gcc does not pass a '--gdwarf-2' option on to the assembler
when '-gdwarf-2' is on its command line (note the differece in the gcc and as
flags). This change provides the correct assembler flag to gcc, and so does
not rely on gcc to emit a flag for the assembler.
Signed-off-by: Geoff Levand <geoff@infradead.org> for Huawei, Linaro
Pull strong stackprotector support from Ingo Molnar:
"This tree adds a CONFIG_CC_STACKPROTECTOR_STRONG=y, a new, stronger
stack canary checking method supported by the newest GCC versions (4.9
and later).
Here's the 'intensity comparison' between the various protection
modes:
- defconfig
11430641 kernel text size
36110 function bodies
- defconfig + CONFIG_CC_STACKPROTECTOR_REGULAR
11468490 kernel text size (+0.33%)
1015 of 36110 functions are stack-protected (2.81%)
- defconfig + CONFIG_CC_STACKPROTECTOR_STRONG via this patch
11692790 kernel text size (+2.24%)
7401 of 36110 functions are stack-protected (20.5%)
the strong model comes with non-trivial costs, which is why we
preserved the 'regular' and 'none' models as well"
* 'core-stackprotector-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
stackprotector: Unify the HAVE_CC_STACKPROTECTOR logic between architectures
make-4 changed the way/order it presents the command line options
into MAKEFLAGS
In make-3.8x, '-s' would always be first into a group of options
with the '-'/hyphen removed
$ make -p -s 2>/dev/null | grep ^MAKEFLAGS
MAKEFLAGS = sp
In make-4, '-s' seems to always be last into a group of options
$ make -s -p 2>/dev/null | grep ^MAKEFLAGS
MAKEFLAGS = ps
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Commit 1bf49dd4be0b ("./Makefile: export initial ramdisk compression
config option") started setting the INITRD_COMPRESS environment variable
depending on which decompression models the kernel had available.
That is completely broken.
For example, we by default have CONFIG_RD_LZ4 enabled, and are able to
decompress such an initrd, but the user tools to *create* such an initrd
may not be availble. So trying to tell dracut to generate an
lz4-compressed image just because we can decode such an image is
completely inappropriate.
Cc: J P <ppandit@redhat.com>
Cc: Jan Beulich <JBeulich@suse.com>
This changes the stack protector config option into a choice of
"None", "Regular", and "Strong":
CONFIG_CC_STACKPROTECTOR_NONE
"Regular" means the old CONFIG_CC_STACKPROTECTOR=y option.
"Strong" is a new mode introduced by this patch. With "Strong" the
kernel is built with -fstack-protector-strong (available in
gcc 4.9 and later). This option increases the coverage of the stack
protector without the heavy performance hit of -fstack-protector-all.
For reference, the stack protector options available in gcc are:
-fstack-protector-all:
Adds the stack-canary saving prefix and stack-canary checking
suffix to _all_ function entry and exit. Results in substantial
use of stack space for saving the canary for deep stack users
(e.g. historically xfs), and measurable (though shockingly still
low) performance hit due to all the saving/checking. Really not
suitable for sane systems, and was entirely removed as an option
from the kernel many years ago.
-fstack-protector:
Adds the canary save/check to functions that define an 8
(--param=ssp-buffer-size=N, N=8 by default) or more byte local
char array. Traditionally, stack overflows happened with
string-based manipulations, so this was a way to find those
functions. Very few total functions actually get the canary; no
measurable performance or size overhead.
Adds the canary for a wider set of functions, since it's not
just those with strings that have ultimately been vulnerable to
stack-busting. With this superset, more functions end up with a
canary, but it still remains small compared to all functions
with only a small change in performance. Based on the original
design document, a function gets the canary when it contains any
of:
- local variable's address used as part of the right hand side
of an assignment or function argument
- local variable is an array (or union containing an array),
regardless of array type or length
- uses register local variables
https://docs.google.com/a/google.com/document/d/1xXBH6rRZue4f296vGt9YQcuLVQHeE516stHwt8M9xyU
Find below a comparison of "size" and "objdump" output when built with
gcc-4.9 in three configurations:
- defconfig
With -strong, ARM's compressed boot code now triggers stack
protection, so a static guard was added. Since this is only used
during decompression and was never used before, the exposure
here is very small. Once it switches to the full kernel, the
stack guard is back to normal.
Chrome OS has been using -fstack-protector-strong for its kernel
builds for the last 8 months with no problems.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/1387481759-14535-3-git-send-email-keescook@chromium.org
[ Improved the changelog and descriptions some more. ]
Instead of duplicating the CC_STACKPROTECTOR Kconfig and
Makefile logic in each architecture, switch to using
HAVE_CC_STACKPROTECTOR and keep everything in one place. This
retains the x86-specific bug verification scripts.
Link: http://lkml.kernel.org/r/1387481759-14535-2-git-send-email-keescook@chromium.org
config option") however introduced "else ifeq" constructs which make
3.80 doesn't understand. Replace the logic there with more conventional
(in the kernel build infrastructure) list constructs (except that the
list here is intentionally limited to exactly one element).
Cc: P J P <ppandit@redhat.com>
- LTO fixes, but the kallsyms part had to be reverted
- Pass -Werror=implicit-int and -Werror=strict-prototypes to the
compiler by default
- snprintf fix in modpost
- remove GREP_OPTIONS from the environment to be immune against exotic
grep option settings
kallsyms: Revert back to 128 max symbol length
Kbuild: Ignore GREP_OPTIONS env variable
scripts: kallsyms: Use %zu to print 'size_t'
scripts/bloat-o-meter: use .startswith rather than fragile slicing
scripts/bloat-o-meter: ignore changes in the size of linux_banner
kbuild: replace unbounded sprintf call in modpost
kbuild, bloat-o-meter: fix static detection
Kbuild: Handle longer symbols in kallsyms.c
kbuild: Increase kallsyms max symbol length
Makefile: enable -Werror=implicit-int and -Werror=strict-prototypes by default
Make menuconfig allows one to choose compression format of an initial
ramdisk image. But this choice does not result in duly compressed ramdisk
image. Because - $ make install - does not pass on the selected
compression choice to the dracut(8) tool, which creates the initramfs
file. dracut(8) generates the image with the default compression, ie.
gzip(1).
This patch exports the selected compression option to a sub-shell
environment, so that it could be used by dracut(8) tool to generate
appropriately compressed initramfs images.
There isn't a straightforward way to pass on options to dracut(8) via
positional parameters. Because it is indirectly invoked at the end of a $
make install sequence.
# make install
-> arch/$arch/boot/Makefile
-> arch/$arch/boot/install.sh
-> /sbing/installkernel ...
-> /sbin/new-kernel-pkg ...
-> /sbin/dracut ...
Signed-off-by: P J P <ppandit@redhat.com>
When building the kernel in a shell which defines GREP_OPTIONS so that
grep behavior is modified, we can break the generation of the syscalls
table like so:
__SYSCALL_COMMON(^[[01;31m^[[K0^[[m^[[K, sys_read, sys_read)
__SYSCALL_COMMON(^[[01;31m^[[K1^[[m^[[K, sys_write, sys_write)
__SYSCALL_COMMON(^[[01;31m^[[K1^[[m^[[K0, sys_mprotect, sys_mprotect) ...
This is just the initial breakage, later we barf when generating
modules.
In this case, GREP_OPTIONS contains "--color=always" which adds the shell
colors markup and completely fudges the headers under ...generated/asm/.
Fix that by unexporting the GREP_OPTIONS variable for the whole kernel
build as we tend to use grep at a bunch of places.
The common error found in forward-ported/backported patches is missing
headers. One recent example (files and function names are mangled):
void foo(){}
EXPORT_SYMBOL(foo);
gave only warning
foo.c:12345678:5: warning: function declaration isn't a prototype [-Wstrict-prototypes]
void foo(){}
foo.c:12345679:5: warning: data definition has no type or storage class [enabled by default]
EXPORT_SYMBOL(foo);
foo.c:12345679:5: warning: type defaults to 'int' in declaration of 'EXORT_SYMBOL' [-Werror=implicit-int]
Now it's a fatal error. Tested on x86_64 allyesconfig.
[akpm@linux-foundation.org: fix typos in comments]
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
This reverts the Linux for Workgroups thing. And no, before somebody
asks, we're not doing Linux95. Not for a few years, at least.
Sure, the flag added some color to the logo, and could have remained as
a testament to my leet gimp skills. But no. And I'll do this early, to
avoid the chance of forgetting when I'm doing the actual rc1 release on
the road.
Pull kbuild update from Michal Marek:
"Only these two commits are in the kbuild branch this time:
- Using filechk for include/config/kernel.release
- Cleanup in scripts/sortextable.c"
kbuild: Do not overwrite include/config/kernel.release needlessly
scripts: remove unused function in sortextable.c
Use filechk to detect if the content changed or not.
