path: root/Makefile
2013-05-26Linux 3.10-rc3v3.10-rc3Linus Torvalds
2013-05-20Linux 3.10-rc2v3.10-rc2Linus Torvalds
2013-05-11Linux 3.10-rc1v3.10-rc1Linus Torvalds
2013-05-07Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "Non-critical kbuild changes: - make coccicheck improvements, but no new semantic patches this time - make rpm improvements - make tar-pkg change to include the architecture in the filename. This is a deliberate incompatibility, but nobody has complained so far and it is useful if you build for different architectures. It also matches what the deb-pkg and rpm-pkg targets produce. - kbuild documentation fix" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: rpm-pkg: Remove pointless set -e statements rpm-pkg: Always regenerate the specfile rpm-pkg: Do not write to the parent directory rpm-pkg: Do not package the whole source directory buildtar: Add ARCH to the archive name Coccinelle: Fix patch output when coccicheck is used with M= and C= Coccinelle: Add support to the SPFLAGS variable Coccinelle: Cleanup the setting of the FLAGS and OPTIONS variables Coccinelle: Restore coccicheck verbosity in ONLINE mode (C=1 or C=2) scripts/package/Makefile: compare objtree with srctree instead of test KBUILD_OUTPUT doc: change example to existing Makefile fragment scripts/tags.sh: Add magic for OFFSET and DEFINE
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-05-02Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC non-critical fixes from Olof Johansson: "Here is a collection of fixes (and some intermixed cleanups) that were considered less important and thus not included in the later parts of the 3.9-rc cycle. It's a bit all over the map, contents wise. A series of ux500 fixes and cleanups, a bunch of various fixes for OMAP and tegra, and some for Freescale i.MX and even Qualcomm MSM. Note that there's also a patch on this branch to globally turn off -Wmaybe-uninitialized when building with -Os. It's been posted several times by Arnd and no dissent was raised, but nobody seemed interested to pick it up. So here it is, as the topmost patch." * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits) Turn off -Wmaybe-uninitialized when building with -Os ARM: orion5x: include linux/cpu.h ARM: tegra: call cpu_do_idle from C code ARM: u300: fix ages old copy/paste bug ARM: OMAP2+: add dependencies on ARCH_MULTI_V6/V7 ARM: tegra: solve adr range issue with THUMB2_KERNEL enabled ARM: tegra: fix relocation truncated error when THUMB2_KERNEL enabled ARM: tegra: fix build error when THUMB2_KERNEL enabled ARM: msm: Fix uncompess.h tx underrun check ARM: vexpress: Remove A9 PMU compatible values for non-A9 platforms ARM: cpuimx27 and mbimx27: prepend CONFIG_ to Kconfig macro ARM: OMAP2+: fix typo "CONFIG_BRIDGE_DVFS" ARM: OMAP1: remove "config MACH_OMAP_HTCWIZARD" ARM: mach-imx: mach-imx6q: Fix sparse warnings ARM: mach-imx: src: Include "common.h ARM: mach-imx: gpc: Include "common.h" ARM: mach-imx: avic: Staticize *avic_base ARM: mach-imx: tzic: Staticize *tzic_base ARM: mach-imx: clk: Include "clk.h" ARM: mach-imx: clk-busy: Staticize clk_busy_mux_ops ...
2013-04-30Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Features: - Add "uretprobes" - an optimization to uprobes, like kretprobes are an optimization to kprobes. "perf probe -x file sym%return" now works like kretprobes. By Oleg Nesterov. - Introduce per core aggregation in 'perf stat', from Stephane Eranian. - Add memory profiling via PEBS, from Stephane Eranian. - Event group view for 'annotate' in --stdio, --tui and --gtk, from Namhyung Kim. - Add support for AMD NB and L2I "uncore" counters, by Jacob Shin. - Add Ivy Bridge-EP uncore support, by Zheng Yan - IBM zEnterprise EC12 oprofile support patchlet from Robert Richter. - Add perf test entries for checking breakpoint overflow signal handler issues, from Jiri Olsa. - Add perf test entry for for checking number of EXIT events, from Namhyung Kim. - Add perf test entries for checking --cpu in record and stat, from Jiri Olsa. - Introduce perf stat --repeat forever, from Frederik Deweerdt. - Add --no-demangle to report/top, from Namhyung Kim. - PowerPC fixes plus a couple of cleanups/optimizations in uprobes and trace_uprobes, by Oleg Nesterov. Various fixes and refactorings: - Fix dependency of the python binding wrt libtraceevent, from Naohiro Aota. - Simplify some perf_evlist methods and to allow 'stat' to share code with 'record' and 'trace', by Arnaldo Carvalho de Melo. - Remove dead code in related to libtraceevent integration, from Namhyung Kim. - Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf sched lat' back working, by Arnaldo Carvalho de Melo - We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho de Melo. - Kill a bunch of die() calls, from Namhyung Kim. - Fix build on non-glibc systems due to libio.h absence, from Cody P Schafer. - Remove some perf_session and tracing dead code, from David Ahern. - Honor parallel jobs, fix from Borislav Petkov - Introduce tools/lib/lk library, initially just removing duplication among tools/perf and tools/vm. from Borislav Petkov ... and many more I missed to list, see the shortlog and git log for more details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits) perf/x86/intel/P4: Robistify P4 PMU types perf/x86/amd: Fix AMD NB and L2I "uncore" support perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c perf/x86: Check all MSRs before passing hw check perf/x86/amd: Add support for AMD NB and L2I "uncore" counters perf/x86/intel: Add Ivy Bridge-EP uncore support perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management perf/x86: Avoid kfree() in CPU_{STARTING,DYING} uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit() uprobes/tracing: Change create_trace_uprobe() to support uretprobes uprobes/tracing: Make seq_printf() code uretprobe-friendly uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher() uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers uprobes/tracing: Generalize struct uprobe_trace_entry_head uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls uprobes/tracing: Kill the pointless seq_print_ip_sym() call uprobes/tracing: Kill the pointless task_pt_regs() calls ...
2013-04-29Turn off -Wmaybe-uninitialized when building with -OsArnd Bergmann
gcc-4.7 and higher add a lot of false positive warnings about potential uses of uninitialized warnings, but only when optimizing for size (-Os). This is the default when building allyesconfig, which turns on CONFIG_CC_OPTIMIZE_FOR_SIZE. In order to avoid getting a lot of patches that initialize such variables and accidentally hide real errors along the way, let's just turn off this warning on the respective gcc versions when building with size optimizations. The -Wmaybe-uninitialized option was introduced in the same gcc version (4.7) that is now causing the false positives, so there is no effect on older compilers. A side effect is that when building with CONFIG_CC_OPTIMIZE_FOR_SIZE, we might now see /fewer/ warnings about possibly uninitialized warnings than with -O2, but that is still much better than seeing warnings known to be bogus. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-04-28Linux 3.9v3.9Linus Torvalds
2013-04-21Linux 3.9-rc8v3.9-rc8Linus Torvalds
2013-04-21Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/cpu/perf_event_intel.c Merge in the latest fixes before applying new patches, resolve the conflict. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-18rpm-pkg: Do not package the whole source directoryMichal Marek
The source tree can contain lots of uninteresting data like tag or cscope files, packaging which slows down make rpm needlessly. It can also break the build, if the tree contains an unrelated file named *.spec. The downside of this change is that new subdirectories have to be added to the KBUILD_ALLDIRS variable in the top-level Makefile. The upside is that the behavior is more predictable. Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-16Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fix from Michal Marek: "Fix for a missing dependency when generating scripts/mod/devicetable-offsets.h. This dependency got introduced in v3.9-rc1." * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: generate generic headers before recursing into scripts
2013-04-14Linux 3.9-rc7v3.9-rc7Linus Torvalds
2013-04-10kbuild: generate generic headers before recursing into scriptsAndreas Schwab
The headers are now needed inside scripts/mod since 6543bec ("mod/file2alias: make modalias generation safe for cross compiling"). Reported-and-tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Reported-and-tested-by: "Jon Medhurst (Tixy)" <tixy@linaro.org> Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-08Merge branch 'for-tip' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/core Pull IBM zEnterprise EC12 support patchlet from Robert Richter. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-07Linux 3.9-rc6v3.9-rc6Linus Torvalds
2013-03-31Linux 3.9-rc5v3.9-rc5Linus Torvalds
2013-03-23Linux 3.9-rc4v3.9-rc4Linus Torvalds
2013-03-21Merge tag 'perf-core-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/core Conflicts: tools/Makefile Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo: . Honor parallel jobs, fix from Borislav Petkov . Introduce tools/lib/lk library, initially just removing duplication among tools/perf and tools/vm. from Borislav Petkov . Fix build on non-glibc systems due to libio.h absence, from Cody P Schafer. . Remove some perf_session and tracing dead code, from David Ahern. . Introduce perf stat --repeat forever, from Frederik Deweerdt. . Add perf test entries for checking --cpu in record and stat, from Jiri Olsa. . Add perf test entries for checking breakpoint overflow signal handler issues, from Jiri Olsa. . Add perf test entry for for checking number of EXIT events, from Namhyung Kim. . Simplify some perf_evlist methods and to allow 'stat' to share code with 'record' and 'trace'. . Remove dead code in related to libtraceevent integration, from Namhyung Kim. . Event group view for 'annotate' in --stdio, --tui and --gtk, from Namhyung Kim. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> [ resolved the trivial merge conflict with upstream ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-03-17Linux 3.9-rc3v3.9-rc3Linus Torvalds
2013-03-15perf tools: Honor parallel jobsBorislav Petkov
We need to hand down parallel build options like the internal make --jobserver-fds one so that parallel builds can also happen when building perf from the toplevel directory. Make it so #1! Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1361374353-30385-3-git-send-email-bp@alien8.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-03-15CONFIG_SYMBOL_PREFIX: cleanup.Rusty Russell
We have CONFIG_SYMBOL_PREFIX, which three archs define to the string "_". But Al Viro broke this in "consolidate cond_syscall and SYSCALL_ALIAS declarations" (in linux-next), and he's not the first to do so. Using CONFIG_SYMBOL_PREFIX is awkward, since we usually just want to prefix it so something. So various places define helpers which are defined to nothing if CONFIG_SYMBOL_PREFIX isn't set: 1) include/asm-generic/unistd.h defines __SYMBOL_PREFIX. 2) include/asm-generic/vmlinux.lds.h defines VMLINUX_SYMBOL(sym) 3) include/linux/export.h defines MODULE_SYMBOL_PREFIX. 4) include/linux/kernel.h defines SYMBOL_PREFIX (which differs from #7) 5) kernel/modsign_certificate.S defines ASM_SYMBOL(sym) 6) scripts/modpost.c defines MODULE_SYMBOL_PREFIX 7) scripts/Makefile.lib defines SYMBOL_PREFIX on the commandline if CONFIG_SYMBOL_PREFIX is set, so that we have a non-string version for pasting. (arch/h8300/include/asm/linkage.h defines SYMBOL_NAME(), too). Let's solve this properly: 1) No more generic prefix, just CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX. 2) Make linux/export.h usable from asm. 3) Define VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR(). 4) Make everyone use them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Tested-by: James Hogan <james.hogan@imgtec.com> (metag)
2013-03-10Linux 3.9-rc2v3.9-rc2Linus Torvalds
2013-03-03Linux 3.9-rc1v3.9-rc1Linus Torvalds
2013-02-27Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Alias generation in modpost is cross-compile safe. - kernel/timeconst.h is now generated using a bc script instead of perl. - scripts/link-vmlinux.sh now works with an alternative $KCONFIG_CONFIG. - destination-y for exported headers is supported in Kbuild files again. - depmod is called with -P $CONFIG_SYMBOL_PREFIX on architectures that need it. - CONFIG_DEBUG_INFO_REDUCED disables var-tracking - scripts/setlocalversion works with too much translated locales ;) * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix reading of .config in link-vmlinux.sh kbuild: Unset language specific variables in setlocalversion script Kbuild: Disable var tracking with CONFIG_DEBUG_INFO_REDUCED depmod: pass -P $CONFIG_SYMBOL_PREFIX kbuild: Fix destination-y for installed headers scripts/link-vmlinux.sh: source variables from KCONFIG_CONFIG kernel: Replace timeconst.pl with a bc script mod/file2alias: make modalias generation safe for cross compiling
2013-02-25Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "The sweeping change is to make add_taint() explicitly indicate whether to disable lockdep, but it's a mechanical change." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Add option to not sign modules during modules_install MODSIGN: Add -s <signature> option to sign-file MODSIGN: Specify the hash algorithm on sign-file command line MODSIGN: Simplify Makefile with a Kconfig helper module: clean up load_module a little more. modpost: Ignore ARC specific non-alloc sections module: constify within_module_* taint: add explicit flag to show whether lock dep is still OK. module: printk message when module signature fail taints kernel.
2013-02-22Kbuild: Disable var tracking with CONFIG_DEBUG_INFO_REDUCEDAndi Kleen
Newer gcc enables the var-tracking pass with -g to keep track which registers contain which variables. This is one of the slower passes in gcc. With reduced debug info (aimed at objdump -S, but not using a full debugger) we don't need this fine grained tracking. But it was still enabled because -g was enabled. Disable it explicitely for DEBUG_INFO_REDUCED. On my 8T workstation this gives me about a 12 second gain in building a reasonable kernel config (2min16 vs 2min28) with DEBUG_INFO_REDUCED. With full DEBUG_INFO it takes 2min46 The actual improvement in user time taken by the compiler is much higher (all CPU combined user time 15min5s vs 16m30 before) but the usual amdahl bottleneck on the linker prevents more speedup. It still saves some more energy and keeps cycles for other things. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22depmod: pass -P $CONFIG_SYMBOL_PREFIXJames Hogan
On architectures which have symbol prefixes, depmod emits lots of warnings like this: WARNING: $module.ko needs unknown symbol $symbol This is because depmod isn't being passed the -P <symbol_prefix> arguments to specify the symbol prefix to ignore. This option is included since the 3.13 release of module-init-tools. Update scripts/depmod.sh to take extra arguments for the symbol prefix (required but may be empty), and update the main Makefile to always pass "$(CONFIG_SYMBOL_PREFIX)" to scripts/depmod.sh. If the provided symbol prefix is non-empty, scripts/depmod.sh checks if depmod --version reports module-init-tools with a version number < 3.13 otherwise it appends -P $SYMBOL_PREFIX to the depmod command line. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: Mike Frysinger <vapier@gentoo.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-dist-devel@blackfin.uclinux.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-19Merge branch 'x86-build-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull two x86 kernel build changes from Ingo Molnar: "The first change modifies how 'make oldconfig' works on cross-bitness situations on x86. It was felt the new behavior of preserving the bitness of the .config is more logical. This is a leftover of the merge. The second change eliminates a Perl warning. (There's another, more complete fix resulting of this warning fix, which second fix in flight to you via the kbuild tree, which will remove the timeconst.pl script altogether.)" * 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timeconst.pl: Eliminate Perl warning x86: Default to ARCH=x86 to avoid overriding CONFIG_64BIT
2013-02-18Linux 3.8v3.8Linus Torvalds
2013-02-09Linux 3.8-rc7v3.8-rc7Linus Torvalds
2013-02-01Linux 3.8-rc6v3.8-rc6Linus Torvalds
2013-01-25Linux 3.8-rc5v3.8-rc5Linus Torvalds
2013-01-25MODSIGN: Add option to not sign modules during modules_installMichal Marek
To allow the builder to sign only a subset of modules, or to sign the modules using a key that is not available on the build machine, add CONFIG_MODULE_SIG_ALL. If this option is unset, no modules will be signed during build. The default is 'y', to preserve the current behavior. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-25MODSIGN: Specify the hash algorithm on sign-file command lineMichal Marek
Make the script usable without a .config file. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-24mod/file2alias: make modalias generation safe for cross compilingAndreas Schwab
Use the target compiler to compute the offsets for the fields of the device_id structures, so that it won't be broken by different alignments between the host and target ABIs. This also fixes missing endian corrections for some modaliases. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-01-22arm64: makefile: fix uname munging when setting ARCH on native machineWill Deacon
By popular demand, arch/aarch64 is now known as arch/arm64. However, uname -m (and indeed the GNU triplet) still use aarch64 as the machine string. This patch fixes native builds of both the kernel and perf tools by updating the relevant Makefiles to munge the output of uname -m and set the ARCH variable appropriately. Cc: <stable@vger.kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-01-17Linux 3.8-rc4v3.8-rc4Linus Torvalds
2013-01-09Linux 3.8-rc3v3.8-rc3Linus Torvalds
2013-01-02Linux 3.8-rc2v3.8-rc2Linus Torvalds
2012-12-21Linux 3.8-rc1v3.8-rc1Linus Torvalds
2012-12-20x86: Default to ARCH=x86 to avoid overriding CONFIG_64BITDavid Woodhouse
It is easy to waste a bunch of time when one takes a 32-bit .config from a test machine and try to build it on a faster 64-bit system, and its existing setting of CONFIG_64BIT=n gets *changed* to match the build host. Similarly, if one has an existing build tree it is easy to trash an entire build tree that way. This is because the default setting for $ARCH when discovered from 'uname' is one of the legacy pre-x86-merge values (i386 or x86_64), which effectively force the setting of CONFIG_64BIT to match. We should default to ARCH=x86 instead, finally completing the merge that we started so long ago. This patch preserves the behaviour of the legacy ARCH settings for commands such as: make ARCH=x86_64 randconfig make ARCH=i386 randconfig ... since making the value of CONFIG_64BIT actually random in that situation is not desirable. In time, perhaps we can retire this legacy use of the old ARCH= values. We already have a way to override values for *any* config option, using $KCONFIG_ALLCONFIG, so it could be argued that we don't necessarily need to keep ARCH={i386,x86_64} around as a special case just for overriding CONFIG_64BIT. We'd probably at least want to add a way to override config options from the command line ('make CONFIG_FOO=y oldconfig') before we talk about doing that though. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Link: http://lkml.kernel.org/r/1356040315.3198.51.camel@shinybook.infradead.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-12-20Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The kbuild changes are minimal this time: - scripts/pnmlogo fix for some newer format - minor top-level Makefile cleanup - fix for a v3.5 regression with make clean M=<directory>" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Do not remove vmlinux when cleaning external module scripts/pnmtologo: fix for plain PBM kbuild: Remove reference to uninitialised variable
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-14MODSIGN: Add modules_sign make targetJosh Boyer
If CONFIG_MODULE_SIG is set, and 'make modules_sign' is called then this patch will cause the modules to get a signature appended. The make target is intended to be run after 'make modules_install', and will modify the modules in-place in the installed location. It can be used to produce signed modules after they have been processed by distribution build scripts. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (minor typo fix)
2012-12-10Linux 3.7v3.7Linus Torvalds
2012-12-09kbuild: Do not remove vmlinux when cleaning external modulePawel Moll
Since commit 1f2bfbd00e466ff3489b2ca5cc75b1cccd14c123 "kbuild: link of vmlinux moved to a script" make clean with M=<dir> argument (so cleaning external module) removes vmlinux, System.map and couple of other files from the *main* kernel build directory! This not what was happening before and almost certainly not what one would expect. This patch moves makes the clean target of the script called only when !KBUILD_EXTMOD. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Cc: stable@vger.kernel.org [v3.5+] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-12-03Linux 3.7-rc8v3.7-rc8Linus Torvalds
2012-12-01Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "This is mostly about unbreaking architectures that took the UAPI changes in the v3.7 cycle, plus misc fixes." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf kvm: Fix building perf kvm on non x86 arches perf kvm: Rename perf_kvm to perf_kvm_stat perf: Make perf build for x86 with UAPI disintegration applied perf powerpc: Use uapi/unistd.h to fix build error tools: Pass the target in descend tools: Honour the O= flag when tool build called from a higher Makefile tools: Define a Makefile function to do subdir processing x86: Export asm/{svm.h,vmx.h,perf_regs.h} perf tools: Fix strbuf_addf() when the buffer needs to grow perf header: Fix numa topology printing perf, powerpc: Fix hw breakpoints returning -ENOSPC
