git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild fix from Michal Marek:
"The main kbuild branch ended up with a single commit this time, a fix
to send errors to stderr"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: Print errors to stderr
... at least in the top-level Makefile and scripts/link-vmlinux.sh.
There are some more instances of the 'echo <error>; exit 1' pattern in
some arch Makefiles and kconfig.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
When the READABLE_ASM cc-option tests were added they were done so prior
to the arch Makefile include, resulting in cc-option being run on the
host cc instead of the factoring in the cross prefix set up by the
architecture.
This bumps the include back up so that cc-option actually runs on the
compiler that we're building with.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Pull kbuild updates from Michal Marek.
Fixed up nontrivial merge conflict in Makefile as per Stephen Rothwell
and linux-next (and trivial arch/sparc/Makefile changes due to removed
sparc32 logic).
mips: Fix KBUILD_CPPFLAGS definition
kbuild: fix ia64 link
kbuild: document KBUILD_LDS, KBUILD_VMLINUX_{INIT,MAIN} and LDFLAGS_vmlinux
kbuild: link of vmlinux moved to a script
kbuild: refactor final link of sparc32
kbuild: drop unused KBUILD_VMLINUX_OBJS from top-level Makefile
kbuild: Makefile: remove unnecessary check for m68knommu ARCH
Pull exception table generation updates from Ingo Molnar:
"The biggest change here is to allow the build-time sorting of the
exception table, to speed up booting. This is achieved by the
architecture enabling BUILDTIME_EXTABLE_SORT. This option is enabled
for x86 and MIPS currently.
On x86 a number of fixes and changes were needed to allow build-time
sorting of the exception table, in particular a relocation invariant
exception table format was needed. This required the abstracting out
of exception table protocol and the removal of 20 years of accumulated
assumptions about the x86 exception table format.
While at it, this tree also cleans up various other aspects of
exception handling, such as early(er) exception handling for
rdmsr_safe() et al.
All in one, as the result of these changes the x86 exception code is
now pretty nice and modern. As an added bonus any regressions in this
code will be early and violent crashes, so if you see any of those,
you'll know whom to blame!"
Fix up trivial conflicts in arch/{mips,x86}/Kconfig files due to nearby
modifications of other core architecture options.
* 'x86-extable-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (35 commits)
Revert "x86, extable: Disable presorted exception table for now"
scripts/sortextable: Handle relative entries, and other cleanups
x86, extable: Switch to relative exception table entries
x86, extable: Add _ASM_EXTABLE_EX() macro
x86, extable: Remove open-coded exception table entries in arch/x86/ia32/ia32entry.S
x86, extable: Remove open-coded exception table entries in arch/x86/include/asm/xsave.h
x86, extable: Remove open-coded exception table entries in arch/x86/include/asm/kvm_host.h
x86, extable: Remove the now-unused __ASM_EX_SEC macros
x86, extable: Remove open-coded exception table entries in arch/x86/xen/xen-asm_32.S
x86, extable: Remove open-coded exception table entries in arch/x86/um/checksum_32.S
x86, extable: Remove open-coded exception table entries in arch/x86/lib/usercopy_32.c
x86, extable: Remove open-coded exception table entries in arch/x86/lib/putuser.S
x86, extable: Remove open-coded exception table entries in arch/x86/lib/getuser.S
x86, extable: Remove open-coded exception table entries in arch/x86/lib/csum-copy_64.S
x86, extable: Remove open-coded exception table entries in arch/x86/lib/copy_user_nocache_64.S
x86, extable: Remove open-coded exception table entries in arch/x86/lib/copy_user_64.S
x86, extable: Remove open-coded exception table entries in arch/x86/lib/checksum_32.S
x86, extable: Remove open-coded exception table entries in arch/x86/kernel/test_rodata.c
x86, extable: Remove open-coded exception table entries in arch/x86/kernel/entry_64.S
'x86-cpu-for-linus', 'x86-debug-for-linus' and 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
Pull initial trivial x86 stuff from Ingo Molnar.
Various random cleanups and trivial fixes.
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86-64: Eliminate dead ia32 syscall handlers
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/pci-calgary_64.c: Remove obsoleted simple_strtoul() usage
x86: Don't continue booting if we can't load the specified initrd
x86: kernel/dumpstack.c simple_strtoul cleanup
x86: kernel/check.c simple_strtoul cleanup
debug: Add CONFIG_READABLE_ASM
x86: spinlock.h: Remove REG_PTR_MODE
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/cache_info: Fix setup of l2/l3 ids
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Avoid double stack traces with show_regs()
* 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, microcode: microcode_core.c simple_strtoul cleanup
Pull trivial updates from Jiri Kosina:
"As usual, it's mostly typo fixes, redundant code elimination and some
documentation updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits)
edac, mips: don't change code that has been removed in edac/mips tree
xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer
lib: Change mail address of Oskar Schirmer
net: Change mail address of Oskar Schirmer
arm/m68k: Change mail address of Sebastian Hess
i2c: Change mail address of Oskar Schirmer
net: Fix tcp_build_and_update_options comment in struct tcp_sock
atomic64_32.h: fix parameter naming mismatch
Kconfig: replace "--- help ---" with "---help---"
c2port: fix bogus Kconfig "default no"
edac: Fix spelling errors.
qla1280: Remove redundant NULL check before release_firmware() call
remoteproc: remove redundant NULL check before release_firmware()
qla2xxx: Remove redundant NULL check before release_firmware() call.
aic94xx: Get rid of redundant NULL check before release_firmware() call
tehuti: delete redundant NULL check before release_firmware()
qlogic: get rid of a redundant test for NULL before call to release_firmware()
bna: remove redundant NULL test before release_firmware()
tg3: remove redundant NULL test before release_firmware() call
typhoon: get rid of redundant conditional before all to release_firmware()
Pull perf changes from Ingo Molnar:
"Lots of changes:
- (much) improved assembly annotation support in perf report, with
jump visualization, searching, navigation, visual output
improvements and more.
- kernel support for AMD IBS PMU hardware features. Notably 'perf
record -e cycles:p' and 'perf top -e cycles:p' should work without
skid now, like PEBS does on the Intel side, because it takes
advantage of IBS transparently.
- the libtracevents library: it is the first step towards unifying
tracing tooling and perf, and it also gives a tracing library for
external tools like powertop to rely on.
- infrastructure: various improvements and refactoring of the UI
modules and related code
- infrastructure: cleanup and simplification of the profiling
targets code (--uid, --pid, --tid, --cpu, --all-cpus, etc.)
- tons of robustness fixes all around
- various ftrace updates: speedups, cleanups, robustness
improvements.
- typing 'make' in tools/ will now give you a menu of projects to
build and a short help text to explain what each does.
- ... and lots of other changes I forgot to list.
The perf record make bzImage + perf report regression you reported
should be fixed."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (166 commits)
tracing: Remove kernel_lock annotations
tracing: Fix initial buffer_size_kb state
ring-buffer: Merge separate resize loops
perf evsel: Create events initially disabled -- again
perf tools: Split term type into value type and term type
perf hists: Fix callchain ip printf format
perf target: Add uses_mmap field
ftrace: Remove selecting FRAME_POINTER with FUNCTION_TRACER
ftrace/x86: Have x86 ftrace use the ftrace_modify_all_code()
ftrace: Make ftrace_modify_all_code() global for archs to use
ftrace: Return record ip addr for ftrace_location()
ftrace: Consolidate ftrace_location() and ftrace_text_reserved()
ftrace: Speed up search by skipping pages by address
ftrace: Remove extra helper functions
ftrace: Sort all function addresses, not just per page
tracing: change CPU ring buffer state from tracing_cpumask
tracing: Check return value of tracing_dentry_percpu()
ring-buffer: Reset head page before running self test
ring-buffer: Add integrity check at end of iter read
ring-buffer: Make addition of pages in ring buffer atomic
A new option is added to the relocs tool called '--realmode'.
This option causes the generation of 16-bit segment relocations
and 32-bit linear relocations for the real-mode code. When
the real-mode code is moved to the low-memory during kernel
initialization, these relocation entries can be used to
relocate the code properly.
In the assembly code 16-bit segment relocations must be relative
to the 'real_mode_seg' absolute symbol. Linear relocations must be
relative to a symbol prefixed with 'pa_'.
16-bit segment relocation is used to load cs:ip in 16-bit code.
Linear relocations are used in the 32-bit code for relocatable
data references. They are declared in the linker script of the
real-mode code.
The relocs tool is moved to arch/x86/tools/relocs.c, and added new
target archscripts that can be used to build scripts needed building
an architecture. be compiled before building the arch/x86 tree.
[ hpa: accelerating this because it detects invalid absolute
relocations, a serious bug in binutils 2.22.52.0.x which currently
produces bad kernels. ]
Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
Cc: <stable@vger.kernel.org>
Merge reason: We are going to queue up a dependent patch:
"perf tools: Move parse event automated tests to separated object"
That depends on:
commit e7c72d8
perf tools: Add 'G' and 'H' modifiers to event parsing
tools/perf/builtin-stat.c
Conflicted with the recent 'perf_target' patches when checking the
result of perf_evsel open routines to see if a retry is needed to cope
with older kernels where the exclude guest/host perf_event_attr bits
were not used.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
.. and this should hopefully be the last -rc before final 3.4 release.
Move the final link of vmlinux to a script to improve
readability and maintainability of the code.
The Makefile fragments used to link vmlinux has over the
years seen far too many changes and the logic had become
hard to follow.
As the process by nature is serialized there was
nothing gained including this in the Makefile.
"um" has special link requirments - and the
only way to handle this was to hard-code the linking
of "um" in the script.
This was better than trying to modularize it only for the
benefit of "um" anyway.
The shell script has been improved after input from:
Arnaud Lacombe <lacombar@gmail.com>
Nick Bowler <nbowler@elliptictech.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Arnaud Lacombe <lacombar@gmail.com>
Cc: Nick Bowler <nbowler@elliptictech.com>
Cc: Richard Weinberger <richard@nod.at>
sparc32 uses an additional final link to support btfix.
Introduce a new set of exported variables in the top-level Makefile
to make the extra linking step simpler.
sparc32 has hardcoded knowledge of kallsyms support. This fix
include support for EXTRA_KALLSYM_PASS=1.
The ugly part is that it is hardcoded in the arch/sparc/boot
Makefile.
ARCH is never set to m68knomm.
make ARCH=m68knomm is not supported anymore.
Signed-off-by: Edward Shao <laface.tw@gmail.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Greg Ungerer <gerg@uclinux.org>
Merge v3.4-rc4 - we were on -rc2 before.
Define a config variable BUILDTIME_EXTABLE_SORT to control build time
sorting of the kernel's exception table.
Patch Makefile to do the sorting when BUILDTIME_EXTABLE_SORT is
selected.
Signed-off-by: David Daney <david.daney@cavium.com>
Link: http://lkml.kernel.org/r/1334872799-14589-4-git-send-email-ddaney.cavm@gmail.com
Merge Linux 3.4-rc2: we were on v3.3, update the base.
Now you can do
$ make tools/<toolname>
from the toplevel kernel directory and have the respective tool built.
If you want to build and install it, do
$ make tools/<toolname>_install
$ make tools/<toolname>_clean
should clean the respective tool directories.
If you want to clean all in tools, simply do
$ make tools/clean
Also, if you want to get what the possible targets are, simply calling
$ make tools/
should give you the short help.
$ make tools/install
installs all tools, of course. Doh.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Michal Marek <mmarek@suse.cz>
Link: http://lkml.kernel.org/r/1334162178-17152-6-git-send-email-bp@amd64.org
