path: root/arch/Kconfig
2013-11-15kernel: remove CONFIG_USE_GENERIC_SMP_HELPERSChristoph Hellwig
We've switched over every architecture that supports SMP to it, so remove the new useless config variable. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes from Ingo Molnar: "Main changes in this cycle were: - Updated full dynticks support. - Event stream support for architected (ARM) timers. - ARM clocksource driver updates. - Move arm64 to using the generic sched_clock framework & resulting cleanup in the generic sched_clock code. - Misc fixes and cleanups" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits) x86/time: Honor ACPI FADT flag indicating absence of a CMOS RTC clocksource: sun4i: remove IRQF_DISABLED clocksource: sun4i: Report the minimum tick that we can program clocksource: sun4i: Select CLKSRC_MMIO clocksource: Provide timekeeping for efm32 SoCs clocksource: em_sti: convert to clk_prepare/unprepare time: Fix signedness bug in sysfs_get_uname() and its callers timekeeping: Fix some trivial typos in comments alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist clocksource: arch_timer: Do not register arch_sys_counter twice timer stats: Add a 'Collection: active/inactive' line to timer usage statistics sched_clock: Remove sched_clock_func() hook arch_timer: Move to generic sched_clock framework clocksource: tcb_clksrc: Remove IRQF_DISABLED clocksource: tcb_clksrc: Improve driver robustness clocksource: tcb_clksrc: Replace clk_enable/disable with clk_prepare_enable/disable_unprepare clocksource: arm_arch_timer: Use clocksource for suspend timekeeping clocksource: dw_apb_timer_of: Mark a few more functions as __init clocksource: Put nodes passed to CLOCKSOURCE_OF_DECLARE callbacks centrally arm: zynq: Enable arm_global_timer ...
2013-10-01irq: Optimize softirq stack selection in irq exitFrederic Weisbecker
If irq_exit() is called on the arch's specified irq stack, it should be safe to run softirqs inline under that same irq stack as it is near empty by the time we call irq_exit(). For example if we use the same stack for both hard and soft irqs here, the worst case scenario is: hardirq -> softirq -> hardirq. But then the softirq supersedes the first hardirq as the stack user since irq_exit() is called in a mostly empty stack. So the stack merge in this case looks acceptable. Stack overrun still have a chance to happen if hardirqs have more opportunities to nest, but then it's another problem to solve. So lets adapt the irq exit's softirq stack on top of a new Kconfig symbol that can be defined when irq_exit() runs on the irq stack. That way we can spare some stack switch on irq processing and all the cache issues that come along. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org>
2013-09-30vtime: Add HAVE_VIRT_CPU_ACCOUNTING_GEN KconfigKevin Hilman
With VIRT_CPU_ACCOUNTING_GEN, cputime_t becomes 64-bit. In order to use that feature, arch code should be audited to ensure there are no races in concurrent read/write of cputime_t. For example, reading/writing 64-bit cputime_t on some 32-bit arches may require multiple accesses for low and high value parts, so proper locking is needed to protect against concurrent accesses. Therefore, add CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN which arches can enable after they've been audited for potential races. This option is automatically enabled on 64-bit platforms. Feature requested by Frederic Weisbecker. Signed-off-by: Kevin Hilman <khilman@linaro.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Arm Linux <linux-arm-kernel@lists.infradead.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2013-09-28mutex: replace CONFIG_HAVE_ARCH_MUTEX_CPU_RELAX with simple ifdefHeiko Carstens
Linus suggested to replace #ifndef CONFIG_HAVE_ARCH_MUTEX_CPU_RELAX #define arch_mutex_cpu_relax() cpu_relax() #endif with just a simple #ifndef arch_mutex_cpu_relax # define arch_mutex_cpu_relax() cpu_relax() #endif to get rid of CONFIG_HAVE_CPU_RELAX_SIMPLE. So architectures can simply define arch_mutex_cpu_relax if they want an architecture specific function instead of having to add a select statement in their Kconfig in addition. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2013-08-13microblaze: fix clone syscallMichal Simek
Fix inadvertent breakage in the clone syscall ABI for Microblaze that was introduced in commit f3268edbe6fe ("microblaze: switch to generic fork/vfork/clone"). The Microblaze syscall ABI for clone takes the parent tid address in the 4th argument; the third argument slot is used for the stack size. The incorrectly-used CLONE_BACKWARDS type assigned parent tid to the 3rd slot. This commit restores the original ABI so that existing userspace libc code will work correctly. All kernel versions from v3.8-rc1 were affected. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: soft-dirty bits for user memory changes trackingPavel Emelyanov
The soft-dirty is a bit on a PTE which helps to track which pages a task writes to. In order to do this tracking one should 1. Clear soft-dirty bits from PTEs ("echo 4 > /proc/PID/clear_refs) 2. Wait some time. 3. Read soft-dirty bits (55'th in /proc/PID/pagemap2 entries) To do this tracking, the writable bit is cleared from PTEs when the soft-dirty bit is. Thus, after this, when the task tries to modify a page at some virtual address the #PF occurs and the kernel sets the soft-dirty bit on the respective PTE. Note, that although all the task's address space is marked as r/o after the soft-dirty bits clear, the #PF-s that occur after that are processed fast. This is so, since the pages are still mapped to physical memory, and thus all the kernel does is finds this fact out and puts back writable, dirty and soft-dirty bits on the PTE. Another thing to note, is that when mremap moves PTEs they are marked with soft-dirty as well, since from the user perspective mremap modifies the virtual memory at mremap's new address. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-15Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core fixes from Thomas Gleixner: - Two fixlets for the fallout of the generic idle task conversion - Documentation update * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu/idle: Wrap cpu-idle poll mode within rcu_idle_enter/exit idle: Fix hlt/nohlt command-line handling in new generic idle kthread: Document ways of reducing OS jitter due to per-CPU kthreads
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-05-05idle: Fix hlt/nohlt command-line handling in new generic idleKevin Hilman
commit d1669912 (idle: Implement generic idle function) added a new generic idle along with support for hlt/nohlt command line options to override default idle loop behavior. However, the command-line processing is never compiled. The command-line handling is wrapped by CONFIG_GENERIC_IDLE_POLL_SETUP and arches that use this feature select it in their Kconfigs. However, no Kconfig definition was created for this option, so it is never enabled, and therefore command-line override of the idle-loop behavior is broken after migrating to the generic idle loop. To fix, add a Kconfig definition for GENERIC_IDLE_POLL_SETUP. Tested on ARM (OMAP4/Panda) which enables the command-line overrides by default. Signed-off-by: Kevin Hilman <khilman@linaro.org> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linaro-kernel@lists.linaro.org Link: http://lkml.kernel.org/r/1366849153-25564-1-git-send-email-khilman@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-03-15CONFIG_SYMBOL_PREFIX: cleanup.Rusty Russell
We have CONFIG_SYMBOL_PREFIX, which three archs define to the string "_". But Al Viro broke this in "consolidate cond_syscall and SYSCALL_ALIAS declarations" (in linux-next), and he's not the first to do so. Using CONFIG_SYMBOL_PREFIX is awkward, since we usually just want to prefix it so something. So various places define helpers which are defined to nothing if CONFIG_SYMBOL_PREFIX isn't set: 1) include/asm-generic/unistd.h defines __SYMBOL_PREFIX. 2) include/asm-generic/vmlinux.lds.h defines VMLINUX_SYMBOL(sym) 3) include/linux/export.h defines MODULE_SYMBOL_PREFIX. 4) include/linux/kernel.h defines SYMBOL_PREFIX (which differs from #7) 5) kernel/modsign_certificate.S defines ASM_SYMBOL(sym) 6) scripts/modpost.c defines MODULE_SYMBOL_PREFIX 7) scripts/Makefile.lib defines SYMBOL_PREFIX on the commandline if CONFIG_SYMBOL_PREFIX is set, so that we have a non-string version for pasting. (arch/h8300/include/asm/linkage.h defines SYMBOL_NAME(), too). Let's solve this properly: 1) No more generic prefix, just CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX. 2) Make linux/export.h usable from asm. 3) Define VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR(). 4) Make everyone use them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Tested-by: James Hogan <james.hogan@imgtec.com> (metag)
2013-03-12Select VIRT_TO_BUS directly where neededStephen Rothwell
In commit 887cbce0adea ("arch Kconfig: centralise ARCH_NO_VIRT_TO_BUS") I introduced the config sybmol HAVE_VIRT_TO_BUS and selected that where needed. I am not sure what I was thinking. Instead, just directly select VIRT_TO_BUS where it is needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03make HAVE_SYSCALL_WRAPPERS unconditionalAl Viro
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-02Add HAVE_64BIT_ALIGNED_ACCESSJames Hogan
On 64 bit architectures with no efficient unaligned access, padding and explicit alignment must be added in various places to prevent unaligned 64bit accesses (such as taskstats and trace ring buffer). However this also needs to apply to 32 bit architectures with 64 bit accesses requiring alignment such as metag. This is solved by adding a new Kconfig symbol HAVE_64BIT_ALIGNED_ACCESS which defaults to 64BIT && !HAVE_EFFICIENT_UNALIGNED_ACCESS, and can be explicitly selected by METAG and any other relevant architectures. This can be used in various places to determine whether 64bit alignment is required. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Paris <eparis@redhat.com> Cc: Will Drewry <wad@chromium.org>
2013-02-27arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUSStephen Rothwell
Change it to CONFIG_HAVE_VIRT_TO_BUS and set it in all architecures that already provide virt_to_bus(). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "This is the first pile; another one will come a bit later and will contain SYSCALL_DEFINE-related patches. - a bunch of signal-related syscalls (both native and compat) unified. - a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE (fixing several potential problems with missing argument validation, while we are at it) - a lot of now-pointless wrappers killed - a couple of architectures (cris and hexagon) forgot to save altstack settings into sigframe, even though they used the (uninitialized) values in sigreturn; fixed. - microblaze fixes for delivery of multiple signals arriving at once - saner set of helpers for signal delivery introduced, several architectures switched to using those." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits) x86: convert to ksignal sparc: convert to ksignal arm: switch to struct ksignal * passing alpha: pass k_sigaction and siginfo_t using ksignal pointer burying unused conditionals make do_sigaltstack() static arm64: switch to generic old sigaction() (compat-only) arm64: switch to generic compat rt_sigaction() arm64: switch compat to generic old sigsuspend arm64: switch to generic compat rt_sigqueueinfo() arm64: switch to generic compat rt_sigpending() arm64: switch to generic compat rt_sigprocmask() arm64: switch to generic sigaltstack sparc: switch to generic old sigsuspend sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE sparc: kill sign-extending wrappers for native syscalls kill sparc32_open() sparc: switch to use of generic old sigaction sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE mips: switch to generic sys_fork() and sys_clone() ...
2013-02-14burying unused conditionalsAl Viro
__ARCH_WANT_SYS_RT_SIGACTION, __ARCH_WANT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND, __ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} - can be assumed always set.
2013-02-03generic sys_sigaction() and compat_sys_sigaction()Al Viro
conditional on OLD_SIGACTION/COMPAT_OLD_SIGACTION Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03generic sys_compat_rt_sigaction()Al Viro
Again, protected by a temporary config symbol (GENERIC_COMPAT_RT_SIGACTION); will be gone by the end of series. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03old sigsuspend variants in kernel/signal.cAl Viro
conditional on OLD_SIGSUSPEND/OLD_SIGSUSPEND3, depending on which variety of that fossil is needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03generic compat_sys_rt_sigqueueinfo()Al Viro
conditional on GENERIC_COMPAT_RT_SIGQUEUEINFO; by the end of that series it will become the same thing as COMPAT and conditional will die out. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03generic compat_sys_rt_sigpending()Al Viro
conditional on GENERIC_COMPAT_RT_SIGPENDING; by the end of that series it will become the same thing as COMPAT and conditional will die out. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03generic compat_sys_rt_sigprocmask()Al Viro
conditional on GENERIC_COMPAT_RT_SIGPROCMASK; by the end of that series it will become the same thing as COMPAT and conditional will die out. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03sanitize rt_sigaction() situation a bitAl Viro
Switch from __ARCH_WANT_SYS_RT_SIGACTION to opposite (!CONFIG_ODD_RT_SIGACTION); the only two architectures that need it are alpha and sparc. The reason for use of CONFIG_... instead of __ARCH_... is that it's needed only kernel-side and doing it that way avoids a mess with include order on many architectures. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-01-21kprobes/x86: Move ftrace-based kprobe code into kprobes-ftrace.cMasami Hiramatsu
Split ftrace-based kprobes code from kprobes, and introduce CONFIG_(HAVE_)KPROBES_ON_FTRACE Kconfig flags. For the cleanup reason, this also moves kprobe_ftrace check into skip_singlestep. Link: http://lkml.kernel.org/r/20120928081520.3560.25624.stgit@ltc138.sdl.hitachi.co.jp Cc: Ingo Molnar <mingo@elte.hu> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "sigaltstack infrastructure + conversion for x86, alpha and um, COMPAT_SYSCALL_DEFINE infrastructure. Note that there are several conflicts between "unify SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline; resolution is trivial - just remove definitions of SS_ONSTACK and SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and include/uapi/linux/signal.h contains the unified variant." Fixed up conflicts as per Al. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to generic sigaltstack new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those generic compat_sys_sigaltstack() introduce generic sys_sigaltstack(), switch x86 and um to it new helper: compat_user_stack_pointer() new helper: restore_altstack() unify SS_ONSTACK/SS_DISABLE definitions new helper: current_user_stack_pointer() missing user_stack_pointer() instances Bury the conditionals from kernel_thread/kernel_execve series COMPAT_SYSCALL_DEFINE: infrastructure
2012-12-19introduce generic sys_sigaltstack(), switch x86 and um to itAl Viro
Conditional on CONFIG_GENERIC_SIGALTSTACK; architectures that do not select it are completely unaffected Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-19Bury the conditionals from kernel_thread/kernel_execve seriesAl Viro
All architectures have CONFIG_GENERIC_KERNEL_THREAD CONFIG_GENERIC_KERNEL_EXECVE __ARCH_WANT_SYS_EXECVE None of them have __ARCH_WANT_KERNEL_EXECVE and there are only two callers of kernel_execve() (which is a trivial wrapper for do_execve() now) left. Kill the conditionals and make both callers use do_execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-19Merge tag 'byteswap-for-linus-20121219' of ↵Linus Torvalds
git://git.infradead.org/users/dwmw2/byteswap Pull preparatory gcc intrisics bswap patch from David Woodhouse: "This single patch is effectively a no-op for now. It enables architectures to opt in to using GCC's __builtin_bswapXX() intrinsics for byteswapping, and if we merge this now then the architecture maintainers can enable it for their arch during the next cycle without dependency issues. It's worth making it a par-arch opt-in, because although in *theory* the compiler should never do worse than hand-coded assembler (and of course it also ought to do a lot better on platforms like Atom and PowerPC which have load-and-swap or store-and-swap instructions), that isn't always the case. See http://gcc.gnu.org/bugzilla/show_bug.cgi?id=46453 for example." * tag 'byteswap-for-linus-20121219' of git://git.infradead.org/users/dwmw2/byteswap: byteorder: allow arch to opt to use GCC intrinsics for byteswapping
2012-12-17percpu_rw_semaphore: introduce CONFIG_PERCPU_RWSEMOleg Nesterov
Currently only block_dev and uprobes use percpu_rw_semaphore, add the config option selected by BLOCK || UPROBES. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Anton Arapov <anton@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull big execve/kernel_thread/fork unification series from Al Viro: "All architectures are converted to new model. Quite a bit of that stuff is actually shared with architecture trees; in such cases it's literally shared branch pulled by both, not a cherry-pick. A lot of ugliness and black magic is gone (-3KLoC total in this one): - kernel_thread()/kernel_execve()/sys_execve() redesign. We don't do syscalls from kernel anymore for either kernel_thread() or kernel_execve(): kernel_thread() is essentially clone(2) with callback run before we return to userland, the callbacks either never return or do successful do_execve() before returning. kernel_execve() is a wrapper for do_execve() - it doesn't need to do transition to user mode anymore. As a result kernel_thread() and kernel_execve() are arch-independent now - they live in kernel/fork.c and fs/exec.c resp. sys_execve() is also in fs/exec.c and it's completely architecture-independent. - daemonize() is gone, along with its parts in fs/*.c - struct pt_regs * is no longer passed to do_fork/copy_process/ copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump. - sys_fork()/sys_vfork()/sys_clone() unified; some architectures still need wrappers (ones with callee-saved registers not saved in pt_regs on syscall entry), but the main part of those suckers is in kernel/fork.c now." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits) do_coredump(): get rid of pt_regs argument print_fatal_signal(): get rid of pt_regs argument ptrace_signal(): get rid of unused arguments get rid of ptrace_signal_deliver() arguments new helper: signal_pt_regs() unify default ptrace_signal_deliver flagday: kill pt_regs argument of do_fork() death to idle_regs() don't pass regs to copy_process() flagday: don't pass regs to copy_thread() bfin: switch to generic vfork, get rid of pointless wrappers xtensa: switch to generic clone() openrisc: switch to use of generic fork and clone unicore32: switch to generic clone(2) score: switch to generic fork/vfork/clone c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone() take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h mn10300: switch to generic fork/vfork/clone h8300: switch to generic fork/vfork/clone tile: switch to generic clone() ... Conflicts: arch/microblaze/include/asm/Kbuild
2012-12-06byteorder: allow arch to opt to use GCC intrinsics for byteswappingDavid Woodhouse
Since GCC 4.4, there have been __builtin_bswap32() and __builtin_bswap16() intrinsics. A __builtin_bswap16() came a little later (4.6 for PowerPC, 48 for other platforms). By using these instead of the inline assembler that most architectures have in their __arch_swabXX() macros, we let the compiler see what's actually happening. The resulting code should be at least as good, and much *better* in the cases where it can be combined with a nearby load or store, using a load-and-byteswap or store-and-byteswap instruction (e.g. lwbrx/stwbrx on PowerPC, movbe on Atom). When GCC is sufficiently recent *and* the architecture opts in to using the intrinsics by setting CONFIG_ARCH_USE_BUILTIN_BSWAP, they will be used in preference to the __arch_swabXX() macros. An architecture which does not set ARCH_USE_BUILTIN_BSWAP will continue to use its own hand-crafted macros. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com>
2012-11-30context_tracking: New context tracking susbsystemFrederic Weisbecker
Create a new subsystem that probes on kernel boundaries to keep track of the transitions between level contexts with two basic initial contexts: user or kernel. This is an abstraction of some RCU code that use such tracking to implement its userspace extended quiescent state. We need to pull this up from RCU into this new level of indirection because this tracking is also going to be used to implement an "on demand" generic virtual cputime accounting. A necessary step to shutdown the tick while still accounting the cputime. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Gilad Ben-Yossef <gilad@benyossef.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> [ paulmck: fix whitespace error and email address. ] Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-11-28generic sys_fork / sys_vfork / sys_cloneAl Viro
... and get rid of idiotic struct pt_regs * in asm-generic/syscalls.h prototypes of the same, while we are at it. Eventually we want those in linux/syscalls.h, of course, but that'll have to wait a bit. Note that there are *three* variants of sys_clone() order of arguments. Braindamage galore... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull third pile of kernel_execve() patches from Al Viro: "The last bits of infrastructure for kernel_thread() et.al., with alpha/arm/x86 use of those. Plus sanitizing the asm glue and do_notify_resume() on alpha, fixing the "disabled irq while running task_work stuff" breakage there. At that point the rest of kernel_thread/kernel_execve/sys_execve work can be done independently for different architectures. The only pending bits that do depend on having all architectures converted are restrictred to fs/* and kernel/* - that'll obviously have to wait for the next cycle. I thought we'd have to wait for all of them done before we start eliminating the longjump-style insanity in kernel_execve(), but it turned out there's a very simple way to do that without flagday-style changes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to saner kernel_execve() semantics arm: switch to saner kernel_execve() semantics x86, um: convert to saner kernel_execve() semantics infrastructure for saner ret_from_kernel_thread semantics make sure that kernel_thread() callbacks call do_exit() themselves make sure that we always have a return path from kernel_execve() ppc: eeh_event should just use kthread_run() don't bother with kernel_thread/kernel_execve for launching linuxrc alpha: get rid of switch_stack argument of do_work_pending() alpha: don't bother passing switch_stack separately from regs alpha: take SIGPENDING/NOTIFY_RESUME loop into signal.c alpha: simplify TIF_NEED_RESCHED handling
2012-10-12infrastructure for saner ret_from_kernel_thread semanticsAl Viro
* allow kernel_execve() leave the actual return to userland to caller (selected by CONFIG_GENERIC_KERNEL_EXECVE). Callers updated accordingly. * architecture that does select GENERIC_KERNEL_EXECVE in its Kconfig should have its ret_from_kernel_thread() do this: call schedule_tail call the callback left for it by copy_thread(); if it ever returns, that's because it has just done successful kernel_execve() jump to return from syscall IOW, its only difference from ret_from_fork() is that it does call the callback. * such an architecture should also get rid of ret_from_kernel_execve() and __ARCH_WANT_KERNEL_EXECVE This is the last part of infrastructure patches in that area - from that point on work on different architectures can live independently. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09thp, x86: introduce HAVE_ARCH_TRANSPARENT_HUGEPAGEGerald Schaefer
Cleanup patch in preparation for transparent hugepage support on s390. Adding new architectures to the TRANSPARENT_HUGEPAGE config option can make the "depends" line rather ugly, like "depends on (X86 || (S390 && 64BIT)) && MMU". This patch adds a HAVE_ARCH_TRANSPARENT_HUGEPAGE instead. x86 already has MMU "def_bool y", so the MMU check is superfluous there and HAVE_ARCH_TRANSPARENT_HUGEPAGE can be selected in arch/x86/Kconfig. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-01Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "Continued quest to clean up and enhance the cputime code by Frederic Weisbecker, in preparation for future tickless kernel features. Other than that, smallish changes." Fix up trivial conflicts due to additions next to each other in arch/{x86/}Kconfig * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) cputime: Make finegrained irqtime accounting generally available cputime: Gather time/stats accounting config options into a single menu ia64: Reuse system and user vtime accounting functions on task switch ia64: Consolidate user vtime accounting vtime: Consolidate system/idle context detection cputime: Use a proper subsystem naming for vtime related APIs sched: cpu_power: enable ARCH_POWER sched/nohz: Clean up select_nohz_load_balancer() sched: Fix load avg vs. cpu-hotplug sched: Remove __ARCH_WANT_INTERRUPTS_ON_CTXSW sched: Fix nohz_idle_balance() sched: Remove useless code in yield_to() sched: Add time unit suffix to sched sysctl knobs sched/debug: Limit sd->*_idx range on sysctl sched: Remove AFFINE_WAKEUPS feature flag s390: Remove leftover account_tick_vtime() header cputime: Consolidate vtime handling on context switch sched: Move cputime code to its own file cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING tile: Remove SD_PREFER_LOCAL leftover ...
2012-10-01Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf update from Ingo Molnar: "Lots of changes in this cycle as well, with hundreds of commits from over 30 contributors. Most of the activity was on the tooling side. Higher level changes: - New 'perf kvm' analysis tool, from Xiao Guangrong. - New 'perf trace' system-wide tracing tool - uprobes fixes + cleanups from Oleg Nesterov. - Lots of patches to make perf build on Android out of box, from Irina Tirdea - Extend ftrace function tracing utility to be more dynamic for its users. It allows for data passing to the callback functions, as well as reading regs as if a breakpoint were to trigger at function entry. The main goal of this patch series was to allow kprobes to use ftrace as an optimized probe point when a probe is placed on an ftrace nop. With lots of help from Masami Hiramatsu, and going through lots of iterations, we finally came up with a good solution. - Add cpumask for uncore pmu, use it in 'stat', from Yan, Zheng. - Various tracing updates from Steve Rostedt - Clean up and improve 'perf sched' performance by elliminating lots of needless calls to libtraceevent. - Event group parsing support, from Jiri Olsa - UI/gtk refactorings and improvements from Namhyung Kim - Add support for non-tracepoint events in perf script python, from Feng Tang - Add --symbols to 'script', similar to the one in 'report', from Feng Tang. Infrastructure enhancements and fixes: - Convert the trace builtins to use the growing evsel/evlist tracepoint infrastructure, removing several open coded constructs like switch like series of strcmp to dispatch events, etc. Basically what had already been showcased in 'perf sched'. - Add evsel constructor for tracepoints, that uses libtraceevent just to parse the /format events file, use it in a new 'perf test' to make sure the libtraceevent format parsing regressions can be more readily caught. - Some strange errors were happening in some builds, but not on the next, reported by several people, problem was some parser related files, generated during the build, didn't had proper make deps, fix from Eric Sandeen. - Introduce struct and cache information about the environment where a perf.data file was captured, from Namhyung Kim. - Fix handling of unresolved samples when --symbols is used in 'report', from Feng Tang. - Add union member access support to 'probe', from Hyeoncheol Lee. - Fixups to die() removal, from Namhyung Kim. - Render fixes for the TUI, from Namhyung Kim. - Don't enable annotation in non symbolic view, from Namhyung Kim. - Fix pipe mode in 'report', from Namhyung Kim. - Move related stats code from stat to util/, will be used by the 'stat' kvm tool, from Xiao Guangrong. - Remove die()/exit() calls from several tools. - Resolve vdso callchains, from Jiri Olsa - Don't pass const char pointers to basename, so that we can unconditionally use libgen.h and thus avoid ifdef BIONIC lines, from David Ahern - Refactor hist formatting so that it can be reused with the GTK browser, From Namhyung Kim - Fix build for another rbtree.c change, from Adrian Hunter. - Make 'perf diff' command work with evsel hists, from Jiri Olsa. - Use the only field_sep var that is set up: symbol_conf.field_sep, fix from Jiri Olsa. - .gitignore compiled python binaries, from Namhyung Kim. - Get rid of die() in more libtraceevent places, from Namhyung Kim. - Rename libtraceevent 'private' struct member to 'priv' so that it works in C++, from Steven Rostedt - Remove lots of exit()/die() calls from tools so that the main perf exit routine can take place, from David Ahern - Fix x86 build on x86-64, from David Ahern. - {int,str,rb}list fixes from Suzuki K Poulose - perf.data header fixes from Namhyung Kim - Allow user to indicate objdump path, needed in cross environments, from Maciek Borzecki - Fix hardware cache event name generation, fix from Jiri Olsa - Add round trip test for sw, hw and cache event names, catching the problem Jiri fixed, after Jiri's patch, the test passes successfully. - Clean target should do clean for lib/traceevent too, fix from David Ahern - Check the right variable for allocation failure, fix from Namhyung Kim - Set up evsel->tp_format regardless of evsel->name being set already, fix from Namhyung Kim - Oprofile fixes from Robert Richter. - Remove perf_event_attr needless version inflation, from Jiri Olsa - Introduce libtraceevent strerror like error reporting facility, from Namhyung Kim - Add pmu mappings to perf.data header and use event names from cmd line, from Robert Richter - Fix include order for bison/flex-generated C files, from Ben Hutchings - Build fixes and documentation corrections from David Ahern - Assorted cleanups from Robert Richter - Let O= makes handle relative paths, from Steven Rostedt - perf script python fixes, from Feng Tang. - Initial bash completion support, from Frederic Weisbecker - Allow building without libelf, from Namhyung Kim. - Support DWARF CFI based unwind to have callchains when %bp based unwinding is not possible, from Jiri Olsa. - Symbol resolution fixes, while fixing support PPC64 files with an .opt ELF section was the end goal, several fixes for code that handles all architectures and cleanups are included, from Cody Schafer. - Assorted fixes for Documentation and build in 32 bit, from Robert Richter - Cache the libtraceevent event_format associated to each evsel early, so that we avoid relookups, i.e. calling pevent_find_event repeatedly when processing tracepoint events. [ This is to reduce the surface contact with libtraceevents and make clear what is that the perf tools needs from that lib: so far parsing the common and per event fields. ] - Don't stop the build if the audit libraries are not installed, fix from Namhyung Kim. - Fix bfd.h/libbfd detection with recent binutils, from Markus Trippelsdorf. - Improve warning message when libunwind devel packages not present, from Jiri Olsa" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits) perf trace: Add aliases for some syscalls perf probe: Print an enum type variable in "enum variable-name" format when showing accessible variables perf tools: Check libaudit availability for perf-trace builtin perf hists: Add missing period_* fields when collapsing a hist entry perf trace: New tool perf evsel: Export the event_format constructor perf evsel: Introduce rawptr() method perf tools: Use perf_evsel__newtp in the event parser perf evsel: The tracepoint constructor should store sys:name perf evlist: Introduce set_filter() method perf evlist: Renane set_filters method to apply_filters perf test: Add test to check we correctly parse and match syscall open parms perf evsel: Handle endianity in intval method perf evsel: Know if byte swap is needed perf tools: Allow handling a NULL cpu_map as meaning "all cpus" perf evsel: Improve tracepoint constructor setup tools lib traceevent: Fix error path on pevent_parse_event perf test: Fix build failure trace: Move trace event enable from fs_initcall to core_initcall tracing: Add an option for disabling markers ...
2012-09-30preparation for generic kernel_thread()Al Viro
Let architectures select GENERIC_KERNEL_THREAD and have their copy_thread() treat NULL regs as "it came from kernel_thread(), sp argument contains the function new thread will be calling and stack_size - the argument for that function". Switching the architectures begins shortly... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-28Make most arch asm/module.h files use asm-generic/module.hDavid Howells
Use the mapping of Elf_[SPE]hdr, Elf_Addr, Elf_Sym, Elf_Dyn, Elf_Rel/Rela, ELF_R_TYPE() and ELF_R_SYM() to either the 32-bit version or the 64-bit version into asm-generic/module.h for all arches bar MIPS. Also, use the generic definition mod_arch_specific where possible. To this end, I've defined three new config bools: (*) HAVE_MOD_ARCH_SPECIFIC Arches define this if they don't want to use the empty generic mod_arch_specific struct. (*) MODULES_USE_ELF_RELA Arches define this if their modules can contain RELA records. This causes the Elf_Rela mapping to be emitted and allows apply_relocate_add() to be defined by the arch rather than have the core emit an error message. (*) MODULES_USE_ELF_REL Arches define this if their modules can contain REL records. This causes the Elf_Rel mapping to be emitted and allows apply_relocate() to be defined by the arch rather than have the core emit an error message. Note that it is possible to allow both REL and RELA records: m68k and mips are two arches that do this. With this, some arch asm/module.h files can be deleted entirely and replaced with a generic-y marker in the arch Kbuild file. Additionally, I have removed the bits from m32r and score that handle the unsupported type of relocation record as that's now handled centrally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-26rcu: Settle config for userspace extended quiescent stateFrederic Weisbecker
Create a new config option under the RCU menu that put CPUs under RCU extended quiescent state (as in dynticks idle mode) when they run in userspace. This require some contribution from architectures to hook into kernel and userspace boundaries. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alessio Igor Bogani <abogani@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Avi Kivity <avi@redhat.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christoph Lameter <cl@linux.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Gilad Ben Yossef <gilad@benyossef.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Kevin Hilman <khilman@ti.com> Cc: Max Krasnyansky <maxk@qualcomm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sven-Thorsten Dietrich <thebigcorporation@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-09-25cputime: Make finegrained irqtime accounting generally availableFrederic Weisbecker
There is no known reason for this option to be unavailable on other archs than x86. They just need to call enable_sched_clock_irqtime() if they have a sufficiently finegrained clock to make it working. Move it to the general option and let the user choose between it and pure tick based or virtual cputime accounting. Note that virtual cputime accounting already performs a finegrained irqtime accounting. CONFIG_IRQ_TIME_ACCOUNTING is a kind of middle ground between tick and virtual based accounting. So CONFIG_IRQ_TIME_ACCOUNTING and CONFIG_VIRT_CPU_ACCOUNTING are mutually exclusive choices. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-08-17cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTINGFrederic Weisbecker
S390, ia64 and powerpc all define their own version of CONFIG_VIRT_CPU_ACCOUNTING. Generalize the config and its description to a single place to avoid duplication. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-08-10perf: Add ability to attach user stack dump to sampleJiri Olsa
Introducing PERF_SAMPLE_STACK_USER sample type bit to trigger the dump of the user level stack on sample. The size of the dump is specified by sample_stack_user value. Being able to dump parts of the user stack, starting from the stack pointer, will be useful to make a post mortem dwarf CFI based stack unwinding. Added HAVE_PERF_USER_STACK_DUMP config option to determine if the architecture provides user stack dump on perf event samples. This needs access to the user stack pointer which is not unified across architectures. Enabling this for x86 architecture. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Original-patch-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1344345647-11536-6-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-10perf: Unified API to record selective sets of arch registersJiri Olsa
This brings a new API to help the selective dump of registers on event sampling, and its implementation for x86 arch. Added HAVE_PERF_REGS config option to determine if the architecture provides perf registers ABI. The information about desired registers will be passed in u64 mask. It's up to the architecture to map the registers into the mask bits. For the x86 arch implementation, both 32 and 64 bit registers bits are defined within single enum to ensure 64 bit system can provide register dump for compat task if needed in the future. Original-patch-by: Frederic Weisbecker <fweisbec@gmail.com> [ Added missing linux/errno.h include ] Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1344345647-11536-2-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
