path: root/arch/alpha/defconfig
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-06alpha/parisc: remove config variable DEBUG_RWLOCKJiri Olsa
Remove config variable DEBUG_RWLOCK, since it is not used. Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-06-23[PATCH] update all defconfigs for ARCH_DISCONTIGMEM_ENABLEDave Hansen
This will at least suppress one prompt that users would have received the first time they compile with the new DISCONTIG arch option. They'll still get the "Memory Model" prompt, but 99% of them will have the default work there. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
