Disintegrate asm/system.h for Alpha.
cc: linux-alpha@vger.kernel.org
T2 are the only alpha SMP systems that do HAE switching at runtime, which
is fundamentally racy on SMP. This patch limits MMIO space on T2 to HAE0
only, like we did on MCPCIA (rawhide) long ago. This leaves us with only
112 Mb of PCI MMIO (128 Mb HAE aperture minus 16 Mb reserved for EISA),
but since linux PCI allocations are reasonably tight, it should be enough
for sane hardware configurations.
Also, fix a typo in MCPCIA_FROB_MMIO macro which shouldn't call set_hae()
if MCPCIA_ONE_HAE_WINDOW is defined. It's more for correctness, as
set_hae() is a no-op anyway in that case.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
The commit c186caca3dbe7f44da624cb4f9d78e1b1dfb13b8 leads to the
following errors with CONFIG_ALPHA_{TSUNAMI, TITAN, RAWHIDE, MARVEL}:
/home/fujita/git/linux-2.6/include/asm-generic/dma-mapping-common.h: In
function `dma_map_sg_attrs':
/home/fujita/git/linux-2.6/include/asm-generic/dma-mapping-common.h:49:
error: implicit declaration of function `for_each_sg'
/home/fujita/git/linux-2.6/include/asm-generic/dma-mapping-common.h:50:
error: syntax error before "kmemcheck_mark_initialized"
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Reported-by: Michael Cree <mcree@orcon.net.nz>
Signed-off-by: Matt Turner <mattst88@gmail.com>
Sam Ravnborg did the build-test that the direct header file move works,
I'm just committing it.
This is a pure move:
mkdir arch/alpha/include
git mv include/asm-alpha arch/alpha/include/asm
with no other changes.
Requested-and-tested-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
