path: root/arch/alpha/kernel/core_marvel.c
2009-11-30arch/alpha/kernel: Add kmalloc NULL testsJulia Lawall
Check that the result of kmalloc is not NULL before passing it to other functions. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression *x; identifier f; constant char *C; @@ x = \(kmalloc\|kcalloc\|kzalloc\)(...); ... when != x == NULL when != x != NULL when != (x || ...) ( kfree(x) f(...,C,...,x,...) | *f(...,x,...) | *x->f ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-09-24alpha: AGP update (fixes compile failure)Ivan Kokshaysky
This brings Alpha AGP platforms in sync with the change to struct agp_memory (unsigned long *memory => struct page **pages). Only compile tested (I don't have titan/marvel hardware), but this change looks pretty straightforward, so hopefully it's ok. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Dave Airlie <airlied@linux.ie> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15alpha: fix RTC on marvelIvan Kokshaysky
Unlike other alphas, marvel doesn't have real PC-style CMOS clock hardware - RTC accesses are emulated via PAL calls. Unfortunately, for unknown reason these calls work only on CPU #0. So current implementation for arbitrary CPU makes CMOS_READ/WRITE to be executed on CPU #0 via IPI. However, for obvious reason this doesn't work with standard get/set_rtc_time() functions, where a bunch of CMOS accesses is done with disabled interrupts. Solved by making the IPI calls for entire get/set_rtc_time() functions, not for individual CMOS accesses. Which is also a lot more effective performance-wise. The patch is largely based on the code from Jay Estabrook. My changes: - tweak asm-generic/rtc.h by adding a couple of #defines to avoid a massive code duplication in arch/alpha/include/asm/rtc.h; - sys_marvel.c: fix get/set_rtc_time() return values (Jay's FIXMEs). NOTE: this fixes *only* LIB_RTC drivers. Legacy (CONFIG_RTC) driver wont't work on marvel. Actually I think that we should just disable CONFIG_RTC on alpha (maybe in 2.6.30?), like most other arches - AFAIK, all modern distributions use LIB_RTC anyway. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20alpha: use bcd2bin/bin2bcdAdrian Bunk
Change alpha to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-26smp_call_function: get rid of the unused nonatomic/retry argumentJens Axboe
It's never used and the comments refer to nonatomic and retry interchangably. So get rid of it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-26alpha: convert to generic helpers for IPI function callsJens Axboe
This converts alpha to use the new helpers for smp_call_function() and friends, and adds support for smp_call_function_single(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-28alpha: remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ The change in pci-iommu,c should be safe as arena has not been assigned when we get to this point. Some were within #if 0 blocks, have changed them and left the blocks as they appear to be debugging infrastructure. A #define FN __FUNCTION__ was removed and occurances of FN were replaced with __func__ as well. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01ALPHA: support graphics on non-zero PCI domainsJay Estabrook
This code replaces earlier and incomplete handling of graphics on non-zero PCI domains (aka hoses or peer PCI buses). An option (CONFIG_VGA_HOSE) is set TRUE if configuring a GENERIC kernel, or a kernel for MARVEL, TITAN, or TSUNAMI machines, as these are the machines whose SRM consoles are capable of configuring and handling graphics options on non-zero hoses. All other machines have the option set FALSE. A routine, "find_console_vga_hose()", is used to find the graphics device which the machine's firmware believes is the console device, and it sets a global (pci_vga_hose) for later use in managing access to the device. This is called in "init_arch" on TITAN and TSUNAMI machines; MARVEL machines use a custom version of this routine because of extra complexity. A routine, "locate_and_init_vga()", is used to find the graphics device and set a global (pci_vga_hose) for later use in managing access to the device, in the case where "find_console_vga_hose" has failed. Various adjustments are made to the ioremap and ioportmap routines for detecting and translating "legacy" VGA register and memory references to the real PCI domain. [akpm@linux-foundation.org: don't statically init bss] [akpm@linux-foundation.org: build fix] Signed-off-by: Jay Estabrook <jay.estabrook@hp.com> Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-31[PATCH] Don't pass boot parameters to argv_init[]OGAWA Hirofumi
The boot cmdline is parsed in parse_early_param() and parse_args(,unknown_bootoption). And __setup() is used in obsolete_checksetup(). start_kernel() -> parse_args() -> unknown_bootoption() -> obsolete_checksetup() If __setup()'s callback (->setup_func()) returns 1 in obsolete_checksetup(), obsolete_checksetup() thinks a parameter was handled. If ->setup_func() returns 0, obsolete_checksetup() tries other ->setup_func(). If all ->setup_func() that matched a parameter returns 0, a parameter is seted to argv_init[]. Then, when runing /sbin/init or init=app, argv_init[] is passed to the app. If the app doesn't ignore those arguments, it will warning and exit. This patch fixes a wrong usage of it, however fixes obvious one only. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
