path: root/arch/alpha/kernel/module.c
2008-04-28alpha: handle kcalloc failureJim Meyering
arch/alpha/kernel/module.c (module_frob_arch_sections): Handle kcalloc failure. Signed-off-by: Jim Meyering <meyering@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-17alpha: fixes for specific machine typesIvan Kokshaysky
Files: arch/alpha/kernel/core_mcpcia.c arch/alpha/kernel/sys_rawhide.c include/asm-alpha/core_mcpcia.h Determine correct hose configuration; RAWHIDE family can have 2 or 4 hoses, so make sure non-existent hoses are ignored. arch/alpha/kernel/err_titan.c Supply a needed #include <asm/irq_regs.h> arch/alpha/kernel/module.c Add some useful output to the relocation overflow messages. arch/alpha/kernel/sys_noritake.c Supply necessary noritake_end_irq() to correct interrupt handling. This fixes a problem first noted by hangs during boot probing with a DE500-BA TULIP NIC present. arch/alpha/kernel/sys_sio.c Correct saving of original PIRQ register (PCI IRQ routing); change default PIRQ setting to leave PCI IRQs 9 and 14 free to be used for sound (Multia) and IDE (any), respectively. include/asm-alpha/io.h Supply the "isa_virt_to_bus" routine. Signed-off-by: Jay Estabrook <jay.estabrook@hp.com> Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-09-09[PATCH] alpha: process_reloc_for_got confuses r_offset and r_addendChaskiel Grundman
arch/alpha/kernel/module.c:process_reloc_for_got(), which figures out how big the .got section for a module should be, appears to be confusing r_offset (the file offset that the relocation needs to be applied to) with r_addend (the offset of the relocation's actual target address from the address of the relocation's symbol). Because of this, one .got entry is allocated for each relocation instead of one each unique symbol/addend. In the module I am working with, this causes the .got section to be almost 10 times larger than it needs to be (75544 bytes instead of 7608 bytes). As the .got is accessed with global-pointer-relative instructions, it needs to be within the 64k gp "zone", and a 75544 byte .got clearly does not fit. The result of this is that relocation overflows are detected during module load and the load is aborted. Change struct got_entry/process_reloc_for_got to fix this. Acked-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
