path: root/arch/alpha/kernel/pci.c
2008-06-20alpha: resurrect Cypress IDE quirkIvan Kokshaysky
Which was removed in the hope that generic legacy IDE quirk in drivers/pci/probe.c is sufficient for Cypress IDE. It isn't, as this controller has non-standard BAR layout: secondary channel registers are in the BAR0-1 of the second PCI function - not in the BAR2-3 of the same function, as the generic quirk routine assumes. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28alpha: remove remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ The change in pci-iommu,c should be safe as arena has not been assigned when we get to this point. Some were within #if 0 blocks, have changed them and left the blocks as they appear to be debugging infrastructure. A #define FN __FUNCTION__ was removed and occurances of FN were replaced with __func__ as well. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24alpha: fix legacy mode PCI IDE controllersIvan Kokshaysky
Legacy IDE resources were never properly allocated on most alpha platforms, so IDE expectedly stopped working after commit 10f000a2fd805e8ccfe988e8615545467bb7f7df (generic pci_enable_resources). Always allocate "fixed" PCI resources before doing anything else; remove Cypress IDE quirk, as it's a generic problem which is handled in common PCI probe code. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20PCI: alpha: use generic pci_enable_resources()Bjorn Helgaas
Use the generic pci_enable_resources() instead of the arch-specific code. Unlike this arch-specific code, the generic version: - skips resources unless requested in "mask" - skips ROM resources unless IORESOURCE_ROM_ENABLE is set - checks for resource collisions with "!r->parent" Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-26deal with alpha section warningsAl Viro
2007-02-07PCI: make isa_bridge Alpha-onlyAdrian Bunk
Since isa_bridge is neither assigned any value !NULL nor used on !Alpha, there's no reason for providing it. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-07[PATCH] alpha: switch to pci_get APIAlan Cox
Now that we have pci_get_bus_and_slot we can do the job correctly. Note that some of these calls intentionally leak a device - this is because the device in question is always needed from boot to reboot. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: change pci core and arch code to use resource_size_tGreg Kroah-Hartman
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-04[PATCH] pci and yenta: pcibios_bus_to_resourceDominik Brodowski
In yenta_socket, we default to using the resource setting of the CardBus bridge. However, this is a PCI-bus-centric view of resources and thus needs to be converted to generic resources first. Therefore, add a call to pcibios_bus_to_resource() call in between. This function is a mere wrapper on x86 and friends, however on some others it already exists, is added in this patch (alpha, arm, ppc, ppc64) or still needs to be provided (parisc -- where is its pcibios_resource_to_bus() ?). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
