path: root/arch/alpha/kernel/signal.c
2007-05-30alpha: support new syscallsRichard Henderson
Some of the new syscalls require supporting TIF_RESTORE_SIGMASK. Signed-off-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-23[PATCH] fix incorrect SA_ONSTACK behaviour for 64-bit processesLaurent MEYER
- When setting a sighandler using sigaction() call, if the flag SA_ONSTACK is set and no alternate stack is provided via sigaltstack(), the kernel still try to install the alternate stack. This behavior is the opposite of the one which is documented in Single Unix Specifications V3. - Also when setting an alternate stack using sigaltstack() with the flag SS_DISABLE, the kernel try to install the alternate stack on signal delivery. These two use cases makes the process crash at signal delivery. Signed-off-by: Laurent Meyer <meyerlau@fr.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
