Aside of the usual motivation for constification, this function has a
history of being abused a hook for interrupt and other fixups so I turned
this function const ages ago in the MIPS code but it should be done
treewide.
Due to function pointer passing in varous places a few other functions
had to be constified as well.
To: Anton Vorontsov <avorontsov@mvista.com>
To: Chris Metcalf <cmetcalf@tilera.com>
To: Colin Cross <ccross@android.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
To: Eric Miao <eric.y.miao@gmail.com>
To: Erik Gilling <konkers@android.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
To: "H. Peter Anvin" <hpa@zytor.com>
To: Imre Kaloz <kaloz@openwrt.org>
To: Ingo Molnar <mingo@redhat.com>
To: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To: Jesse Barnes <jbarnes@virtuousgeek.org>
To: Krzysztof Halasa <khc@pm.waw.pl>
To: Lennert Buytenhek <kernel@wantstofly.org>
To: Matt Turner <mattst88@gmail.com>
To: Nicolas Pitre <nico@fluxnic.net>
To: Olof Johansson <olof@lixom.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
To: Richard Henderson <rth@twiddle.net>
To: Russell King <linux@arm.linux.org.uk>
To: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: x86@kernel.org
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
We plan to remove cpu_xx() old APIs. Thus convert them. This patch has
no functional change.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Scripted with coccinelle.
Signed-off-by: Matt Turner <mattst88@gmail.com>
Good riddance... Nuke a pile of redundant handlers that the
generic code takes care of as well.
Tested-by: Michael Cree <mcree@orcon.net.nz>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Stop touching irq_desc[irq] directly, instead use accessor
functions provided. Use irq_has_action instead of directly
testing the irq_desc.
Also kill superfluous IRQ_DISABLED initialization, since that's the
default state of the irq_desc[i].status field.
Signed-off-by: Frans Pop <elendil@planet.nl>
The typename member of struct irq_chip was kept for migration purposes
and is obsolete since more than 2 years. Fix up the leftovers.
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have
been kept around for migration reasons. After more than two years it's
time to remove them finally.
This patch cleans up one of the remaining users. When all such patches
hit mainline we can remove the defines and typedefs finally.
Impact: cleanup
Convert the last remaining users to struct irq_chip and remove the
define.
according to Ingo, change set_affinity() in irq_chip should return int,
because that way we can handle failure cases in a much cleaner way, in
the genirq layer.
v2: fix two typos
[ Impact: extend API ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
LKML-Reference: <49F654E9.4070809@kernel.org>
Use the generic pci_swizzle_interrupt_pin() instead of arch-specific code.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Impact: change existing irq_chip API
Not much point with gentle transition here: the struct irq_chip's
setaffinity method signature needs to change.
Fortunately, not widely used code, but hits a few architectures.
Note: In irq_select_affinity() I save a temporary in by mangling
irq_desc[irq].affinity directly. Ingo, does this break anything?
(Folded in fix from KOSAKI Motohiro)
Signed-off-by: Mike Travis <travis@sgi.com>
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Acked-by: Ingo Molnar <mingo@redhat.com>
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: jeremy@xensource.com
This code replaces earlier and incomplete handling of graphics on non-zero PCI
domains (aka hoses or peer PCI buses).
An option (CONFIG_VGA_HOSE) is set TRUE if configuring a GENERIC kernel, or a
kernel for MARVEL, TITAN, or TSUNAMI machines, as these are the machines whose
SRM consoles are capable of configuring and handling graphics options on
non-zero hoses. All other machines have the option set FALSE.
A routine, "find_console_vga_hose()", is used to find the graphics device
which the machine's firmware believes is the console device, and it sets a
global (pci_vga_hose) for later use in managing access to the device. This is
called in "init_arch" on TITAN and TSUNAMI machines; MARVEL machines use a
custom version of this routine because of extra complexity.
A routine, "locate_and_init_vga()", is used to find the graphics device and
set a global (pci_vga_hose) for later use in managing access to the device, in
the case where "find_console_vga_hose" has failed.
Various adjustments are made to the ioremap and ioportmap routines for
detecting and translating "legacy" VGA register and memory references to the
real PCI domain.
[akpm@linux-foundation.org: don't statically init bss]
[akpm@linux-foundation.org: build fix]
Signed-off-by: Jay Estabrook <jay.estabrook@hp.com>
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
isa_no_iack_sc_device_interrupt() always gets get_irq_regs() as
argument; kill that argument.
All but two callers of handle_irq() pass get_irq_regs() as argument;
convert the remaining two, kill set_irq_regs() inside handle_irq().
callers of ->device_interrupt() do set_irq_regs() now; pt_regs argument
removed, remaining uses of regs in instances of ->device_interrupt()
are switched to get_irq_regs() and will be gone in the next patch.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This patch-queue improves the generic IRQ layer to be truly generic, by adding
various abstractions and features to it, without impacting existing
functionality.
While the queue can be best described as "fix and improve everything in the
generic IRQ layer that we could think of", and thus it consists of many
smaller features and lots of cleanups, the one feature that stands out most is
the new 'irq chip' abstraction.
The irq-chip abstraction is about describing and coding and IRQ controller
driver by mapping its raw hardware capabilities [and quirks, if needed] in a
straightforward way, without having to think about "IRQ flow"
(level/edge/etc.) type of details.
This stands in contrast with the current 'irq-type' model of genirq
architectures, which 'mixes' raw hardware capabilities with 'flow' details.
The patchset supports both types of irq controller designs at once, and
converts i386 and x86_64 to the new irq-chip design.
As a bonus side-effect of the irq-chip approach, chained interrupt controllers
(master/slave PIC constructs, etc.) are now supported by design as well.
The end result of this patchset intends to be simpler architecture-level code
and more consolidation between architectures.
We reused many bits of code and many concepts from Russell King's ARM IRQ
layer, the merging of which was one of the motivations for this patchset.
This patch:
rename desc->handler to desc->chip.
Originally i did not want to do this, because it's a big patch. But having
both "desc->handler", "desc->handle_irq" and "action->handler" caused a
large degree of confusion and made the code appear alot less clean than it
truly is.
I have also attempted a dual approach as well by introducing a
desc->chip alias - but that just wasnt robust enough and broke
frequently.
So lets get over with this quickly. The conversion was done automatically
via scripts and converts all the code in the kernel.
This renaming patch is the first one amongst the patches, so that the
remaining patches can stay flexible and can be merged and split up
without having some big monolithic patch act as a merge barrier.
[akpm@osdl.org: build fix]
[akpm@osdl.org: another build fix]
Basically, this extends original dp264 fixup to all dp264 variations.
Here is one minor change: mask out bits 4-7 of a value assigned by SRM,
because
- newer consoles report ISA IRQs with offset 0xe0;
- even if console IRQ value is bogus, we'll have a value < 16
so it should be harmless as it won't clash with native IRQs.
Particularly this fixes USB interrupt problem on xp1000 and es40.
Acked-by: Richard Henderson <rth@twiddle.net>
infrastructure for it.
Let it rip!
